[Mapbender-commits] r4430 - branches/2.5/resources/db
svn_mapbender at osgeo.org
Wed Jul 29 05:21:39 EDT 2009
Author: christoph
Date: 2009-07-29 05:21:39 -0400 (Wed, 29 Jul 2009)
New Revision: 4430
branches/2.5/resources/db/install_2.5.2.sh
Modified: branches/2.5/resources/db/install_2.5.2.sh
--- branches/2.5/resources/db/install_2.5.2.sh 2009-07-29 09:18:10 UTC (rev 4429)
+++ branches/2.5/resources/db/install_2.5.2.sh 2009-07-29 09:21:39 UTC (rev 4430)
@@ -73,8 +73,10 @@
if [ "$DBENCODING" = "i" ]
then
DBENCODING="ISO-8859-1"
+ DBFOLDER="iso"
else
DBENCODING="UTF-8"
+ DBFOLDER="utf8"
fi
echo ""
@@ -137,9 +139,9 @@
mysql -e "create database $DBNAME CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$DBPASSWORD
fi
mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/mysql_schema_2.5.sql > log_schema.txt 2> err_schema.txt
- mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/$DBENCODING/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
- mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5_to_2.5.1rc1_mysql_$DBENCODING.sql > log_update.txt 2> err_update.txt
- mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
+ mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/$DBFOLDER/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
+ mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/$DBFOLDER/update/update_2.5_to_2.5.1rc1_mysql_$DBENCODING.sql > log_update.txt 2> err_update.txt
+ mysql $DBNAME -p$DBPASSWORD -h $DBHOST -P $DBPORT < mysql/$DBFOLDER/update/update_2.5.1rc1_to_2.5.1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
@@ -157,15 +159,15 @@
echo "creating database"
createdb -U $DBUSER -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
echo "creating schema"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f postgresql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
echo "loading data"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f postgresql/$DBFOLDER/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
echo "setting sequences"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f postgresql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
echo "update to 2.5.1rc1"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql $DBNAME > log_update.txt 2> err_update.txt
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f postgresql/$DBFOLDER/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql $DBNAME > log_update.txt 2> err_update.txt
echo "update to 2.5.1"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f postgresql/$DBFOLDER/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
More information about the Mapbender_commits
