[Mapbender-commits] r4443 - branches/2.6/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 29 09:03:57 EDT 2009
Author: christoph
Date: 2009-07-29 09:03:57 -0400 (Wed, 29 Jul 2009)
New Revision: 4443
   branches/2.6/http/html/mod_treefolderPlain.php
Modified: branches/2.6/http/html/mod_treefolderPlain.php
--- branches/2.6/http/html/mod_treefolderPlain.php	2009-07-29 13:03:25 UTC (rev 4442)
+++ branches/2.6/http/html/mod_treefolderPlain.php	2009-07-29 13:03:57 UTC (rev 4443)
@@ -417,12 +417,12 @@
 		l=selectedLayer;
 	if(j==-1||k==-1||l==-1){
-		alert("You have to select the WMS you want to move up!")
+		alert("<?php echo _mb('You have to select the WMS you want to move up!');?> ")
 		return;
 	var lid= mb_mapObj[j].wms[k].objLayer[l].layer_id;
 	if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
-		alert("Illegal move operation");
+		alert("<?php echo _mb('Illegal move operation');?>");
 		return;
 	treeState = getState();
@@ -449,12 +449,12 @@
 		l=selectedLayer;
-		alert("You have to select the WMS you want to move down!")
+		alert("<?php echo _mb('You have to select the WMS you want to move down!');?>")
 		return;
 	if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
 		return;
@@ -481,11 +481,11 @@
 		l=selectedLayer;
-		alert("You have to select the WMS you want to delete!")
+		alert("<?php echo _mb('You have to select the WMS you want to delete!');?>")
 		return;
 	if(l!=0){
-		alert("It is not possible to delete a single layer, please select a WMS!")
+		alert("<?php echo _mb('It is not possible to delete a single layer, please select a WMS!');?>")
 		return;
 	var visibleWMS=0;
@@ -493,10 +493,10 @@
 		if( mb_mapObj[j].wms[i].gui_wms_visible=='1'|| mb_mapObj[j].wms[i].gui_wms_visible==1)
 			visibleWMS++;
 	if(visibleWMS<=1){
-		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+		alert ("<?php echo _mb('Last WMS can not be removed.');?>");
 		return;
-	if(confirm('Are you sure you want to remove "'+ mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
+	if(confirm('<?php echo _mb("Are you sure you want to remove");?>' + ' "'+ mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
   		 mb_mapObjremoveWMS(j,k);
 		 mb_mapObj[j].zoom(true, 1.0);
 		 mb_execloadWmsSubFunctions();
More information about the Mapbender_commits mailing list
