[Mapbender-commits] r4449 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Wed Jul 29 09:36:42 EDT 2009
Author: christoph
Date: 2009-07-29 09:36:42 -0400 (Wed, 29 Jul 2009)
New Revision: 4449
trunk/mapbender/http/javascripts/map_obj.js
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2009-07-29 13:36:03 UTC (rev 4448)
+++ trunk/mapbender/http/javascripts/map_obj.js 2009-07-29 13:36:42 UTC (rev 4449)
@@ -3,7 +3,7 @@
* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
* Package: Map
@@ -196,7 +196,77 @@
this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
return ext;
+ var ignoredWms = [];
+ var undoIgnoreWms = function () {
+ ignoredWms = [];
+ var ignoreWms = function (wms) {
+ ignoredWms.push(wms.wms_id);
+ var isIgnoredWms = function (wms) {
+ for (var j = 0; j < ignoredWms.length; j++) {
+ if (ignoredWms[j] === wms.wms_id) {
+ return true;
+ return false;
+ var getIgnoredWms = function () {
+ return ignoredWms;
+ this.setSrs = function (options) {
+ if (typeof options.srs !== "string") {
+ new Mb_exception("Mapbender.Map.setSrs: SRS is not a string: " + options.srs);
+ return null;
+ if (!options.extent || options.extent.constructor !== Mapbender.Extent) {
+ new Mb_exception("Mapbender.Map.setSrs: Extent is not a Mapbender.Extent: " + options.extent);
+ return null;
+ // check which WMS support the new SRS
+ undoIgnoreWms();
+ for (var i = 0; i < this.wms.length; i++) {
+ var found = false;
+ for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
+ if (options.srs === this.wms[i].gui_epsg[j]) {
+ found = true;
+ break;
+ if (!found) {
+ ignoreWms(this.wms[i]);
+ var ignoredWms = getIgnoredWms();
+ // ...and optionally display a message
+ if (options.displayWarning && ignoredWms.length > 0) {
+ var msg = "The following WMS do not support the current SRS: " +
+ ignoredWms.join(",");
+ try {
+ Mapbender.modules.dialogManager.openDialog({
+ content: msg,
+ modal: false,
+ effectShow: 'puff'
+ catch (e) {
+ new Mb_warning(e.message + " " + msg);
+ // actually set the new values and return extent
+ this.epsg = options.srs;
+ return this.calculateExtent(options.extent);
// private
this.width = width;
// private
@@ -267,20 +337,28 @@
this.querylayers[i] = querylayers;
- this.epsg = wms[0].gui_wms_epsg;
var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
for (var i = 0; i < wms[0].gui_epsg.length; i++) {
- if (this.epsg == wms[0].gui_epsg[i]) {
+ if (wms[0].gui_wms_epsg == wms[0].gui_epsg[i]) {
bbox_minx = parseFloat(wms[0].gui_minx[i]);
bbox_miny = parseFloat(wms[0].gui_miny[i]);
bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+ break;
- var wmsExtent = new Mapbender.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
- this.calculateExtent(wmsExtent);
+ this.setSrs({
+ srs: wms[0].gui_wms_epsg,
+ extent: new Mapbender.Extent(
+ bbox_minx,
+ bbox_miny,
+ bbox_maxx,
+ bbox_maxy
this.mapURL = [];
var domElement = this.getDomElement();
domElement.style.width = this.width;
@@ -415,8 +493,8 @@
this.zoomFull = function () {
if (this.restrictedExtent) {
- var newExtent = this.calculateExtent(this.restrictedExtent);
- this.repaint(new Point(newExtent.minx, newExtent.miny), new Point(newExtent.maxx, newExtent.maxy));
+ this.calculateExtent(this.restrictedExtent);
+ this.setMapRequest();
else {
for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
@@ -427,8 +505,8 @@
var bbox_maxy = parseFloat(this.wms[0].gui_maxy[i]);
- var newExtent = this.calculateExtent(wmsExtent);
- this.repaint(newExtent.min, newExtent.max);
+ this.calculateExtent(wmsExtent);
break;
@@ -631,7 +709,7 @@
url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
// add vendor-specific
for (var v = 0; v < mb_vendorSpecific.length; v++) {
var functionName = 'setMapRequest';
@@ -777,7 +855,7 @@
this.repaint = function(min, max){
if (typeof min !== "undefined" && typeof max !== "undefined") {
- this.extent = new Mapbender.Extent(min, max);
+ this.extent = this.calculateExtent(new Extent(min, max));
@@ -789,6 +867,15 @@
for (var ii = 0; ii < this.wms.length; ii++){
var currentWms = this.wms[ii];
+ try {
+ if (!this.requestMapIfSrsNotSupported && isIgnoredWms(currentWms)) {
+ continue;
+ catch (e) {
if (currentWms.wms_id != wms_id) {
continue;
@@ -855,6 +942,13 @@
for (var ii = 0; ii < this.wms.length; ii++) {
+ try {
+ if (this.skipWmsIfSrsNotSupported && isIgnoredWms(currentWms)) {
+ continue;
+ catch (e) {
if (!(currentWms.gui_wms_visible > 0)) {
continue;
More information about the Mapbender_commits
