[Mapbender-commits] r4454 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Wed Jul 29 09:52:27 EDT 2009
Author: christoph
Date: 2009-07-29 09:52:27 -0400 (Wed, 29 Jul 2009)
New Revision: 4454
trunk/mapbender/resources/db/update/update_2.7.sql
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql 2009-07-29 13:46:56 UTC (rev 4453)
+++ trunk/mapbender/resources/db/update/update_2.7.sql 2009-07-29 13:52:27 UTC (rev 4454)
@@ -112,3 +112,14 @@
-- file extension is now .js
UPDATE gui_element SET e_js_file = 'mod_scalebar.js' WHERE e_id = 'scalebar';
+-- parameter: skip WMS request if current SRS is not supported
+-- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
More information about the Mapbender_commits
