[Mapbender-commits] r4458 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Thu Jul 30 11:04:27 EDT 2009
Author: christoph
Date: 2009-07-30 11:04:27 -0400 (Thu, 30 Jul 2009)
New Revision: 4458
trunk/mapbender/resources/db/update/update_2.7.sql
http://trac.osgeo.org/mapbender/ticket/506
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql 2009-07-29 15:54:51 UTC (rev 4457)
+++ trunk/mapbender/resources/db/update/update_2.7.sql 2009-07-30 15:04:27 UTC (rev 4458)
@@ -123,3 +123,97 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+---------------------------------------------MONITORING BEGIN
+-- Index: idx_mb_monitor_status
+-- DROP INDEX idx_mb_monitor_status;
+CREATE INDEX idx_mb_monitor_status
+ ON mb_monitor
+ USING btree
+ (status);
+-- Index: idx_mb_monitor_upload_id
+-- DROP INDEX idx_mb_monitor_upload_id;
+CREATE INDEX idx_mb_monitor_upload_id
+ ON mb_monitor
+ USING btree
+ (upload_id);
+-- Table: mb_wms_availability
+-- DROP TABLE mb_wms_availability;
+CREATE TABLE mb_wms_availability
+ fkey_wms_id integer,
+ fkey_upload_id character varying,
+ last_status integer,
+ availability real,
+ image integer,
+ status_comment character varying,
+ average_resp_time real,
+ upload_url character varying,
+ map_url character varying,
+ CONSTRAINT mb_wms_availability_fkey_wms_id_wms_id FOREIGN KEY (fkey_wms_id)
+ REFERENCES wms (wms_id) MATCH SIMPLE
+ ON UPDATE CASCADE ON DELETE CASCADE
+WITH OIDS;
+-- Function: mb_monitor_after()
+-- DROP FUNCTION mb_monitor_after();
+CREATE OR REPLACE FUNCTION mb_monitor_after()
+ RETURNS "trigger" AS
+$BODY$DECLARE
+ availability_new REAL;
+ average_res_cap REAL;
+ count_monitors REAL;
+ BEGIN
+ IF TG_OP = 'UPDATE' THEN
+ count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
+ --the following should be adopted if the duration of storing is changed!!!
+ average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
+ IF NEW.status > -1 THEN --service gives caps
+ availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors + 100)/(count_monitors+1) as numeric),2);
+ ELSE --service has problems with caps
+ availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors)/(count_monitors+1) as numeric),2);
+ END IF;
+ UPDATE mb_wms_availability SET average_resp_time=average_res_cap,last_status=NEW.status, availability=availability_new, image=NEW.image, status_comment=NEW.status_comment,upload_url=NEW.upload_url,map_url=NEW.map_url WHERE mb_wms_availability.fkey_wms_id=NEW.fkey_wms_id;
+ RETURN NEW;
+ END IF;
+ IF TG_OP = 'INSERT' THEN
+ IF (select count(fkey_wms_id) from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id) > 0 then -- service is not new
+ UPDATE mb_wms_availability set fkey_upload_id=NEW.upload_id,last_status=NEW.status,status_comment=NEW.status_comment,upload_url=NEW.upload_url where fkey_wms_id=NEW.fkey_wms_id;
+ else --service has not yet been monitored
+ INSERT INTO mb_wms_availability (fkey_upload_id,fkey_wms_id,last_status,status_comment,upload_url,map_url,average_resp_time,availability) VALUES (NEW.upload_id,NEW.fkey_wms_id,NEW.status,NEW.status_comment,NEW.upload_url::text,NEW.map_url,0,100);
+ end if;
+ RETURN NEW;
+ END IF;
+ END;
+$BODY$
+ LANGUAGE 'plpgsql' VOLATILE;
+-- Trigger: mb_monitor_after on mb_monitor
+-- DROP TRIGGER mb_monitor_after ON mb_monitor;
+CREATE TRIGGER mb_monitor_after
+ AFTER INSERT OR UPDATE
+ ON mb_monitor
+ FOR EACH ROW
+ EXECUTE PROCEDURE mb_monitor_after();
+---------------------------------------------MONITORING END
More information about the Mapbender_commits
