[Mapbender-commits] r3973 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Jun 2 06:59:35 EDT 2009
Author: beck
Date: 2009-06-02 06:59:34 -0400 (Tue, 02 Jun 2009)
New Revision: 3973
Added:
trunk/mapbender/http/javascripts/x_mod_digitize_tab.php
Added: trunk/mapbender/http/javascripts/x_mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/x_mod_digitize_tab.php (rev 0)
+++ trunk/mapbender/http/javascripts/x_mod_digitize_tab.php 2009-06-02 10:59:34 UTC (rev 3973)
@@ -0,0 +1,1671 @@
+<?php
+# $Id: mod_digitize_tab.php 2320 2009-02-27 14:46:23Z baudson $
+# http://www.mapbender.org/index.php/mod_digitize_tab.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+import_request_variables("PG");
+require_once("../php/mb_validateSession.php");
+require_once("../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$gui_id = $_SESSION["mb_user_gui"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Digitize</title>
+<?php
+$digitize_conf_filename = "digitize_default.conf";
+include '../include/dyn_css.php';
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'digitize' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+$cnt = 0;
+while($row = db_fetch_array($res)){
+ $e_src = $row["e_src"];
+ $e_target = explode(",",$row["e_target"]);
+ $cnt++;
+if($cnt > 1) echo "alert('digitize_button: ID not unique!');";
+echo "<script language='JavaScript'>";
+echo "var mod_digitize_target = '".$e_target[0]."';";
+echo "var mod_digitize_frame = '".$e_target[1]."';";
+include("../../conf/" . $digitize_conf_filename);
+function htmlspecialchars(p_string) {
+ p_string = p_string.replace(/&/g, '&');
+ p_string = p_string.replace(/</g, '<');
+ p_string = p_string.replace(/>/g, '>');
+ p_string = p_string.replace(/"/g, '"');
+ // p_string = p_string.replace(/'/g, ''');
+ return p_string;
+var wfsWindow;
+var dwin = null;
+var wfsConf = [];
+var d = new parent.GeometryArray();
+var mod_digitize_width;
+var mod_digitize_height;
+var mod_digitizeEvent = false;
+var nonTransactionalHighlight;
+var button_point = "Point";
+var button_line = "Line";
+var button_polygon = "Polygon";
+var button_move = "dragBasePoint";
+var button_insert = "setBasePoint";
+var button_delete = "delBasePoint";
+var button_clear = "clear";
+var button_combine = "combine";
+var digitizeDivTag;
+registerFunctions();
+var featureTypeElementFormId = "featureTypeElementForm";
+try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+function toggleTabs(tabId) {
+ if(!initialTab) {
+ return;
+ var tabHeaders = wfsWindow.document.getElementsByTagName('a');
+ var tabs = wfsWindow.document.getElementsByTagName('div');
+ for(var i = 0; i < tabHeaders.length; i++) {
+ if(tabHeaders[i].id.indexOf('tabheader') != -1) {
+ tabHeaders[i].className = 'tabheader';
+ for(var i = 0; i < tabs.length; i++) {
+ if(tabs[i].className === 'tabcontent') {
+ tabs[i].style.visibility = 'hidden';
+ tabs[i].style.display = 'none';
+ wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
+ wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
+ wfsWindow.document.getElementById('tab_' + tabId).style.display = 'block';
+ return false;
+function showHelptext(helptextId) {
+ hideHelptext();
+ wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+ wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'block';
+ return false;
+function hideHelptext(helptextId) {
+ if(helptextId) {
+ wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+ wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'none';
+ var helptext = wfsWindow.document.getElementsByTagName('div');
+ for(var i = 0; i < helptext.length; i++) {
+ if(helptext[i].className === 'helptext') {
+ helptext[i].style.visibility = 'hidden';
+ helptext[i].style.display = 'none';
+ return false;
+// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
+function appendGeometryArray(obj) {
+ executeDigitizePreFunctions();
+ for (i=0; i<obj.count(); i++) {
+ d.addCopy(obj.get(i));
+ executeDigitizeSubFunctions();
+function mod_digitize_go(e){
+ parent.mb_registerGML(mod_digitize_target,d);
+ // ie workaround
+ if (e == undefined) {
+ e = parent.frames[mod_digitize_target].event;
+ if (e) {
+ // track mouse position
+ parent.mb_getMousePos(e, mod_digitize_target);
+ var currentPos = new parent.Point(parent.clickX, parent.clickY);
+ s.check(currentPos);
+ else {
+// s.clean();
+ var el = parent.frames[mod_digitize_target].document;
+ el.onmousedown = mod_digitize_start;
+function mod_digitize_timeout(){
+ el.onmousedown = null;
+ el.onmouseup = null;
+ el.onmousemove = null;
+function mod_digitize_start(e){
+ // check if a proper geometry is selected
+ if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
+ if (mod_digitizeEvent != false) {
+ alert(errorMessageNoGeometrySelected[selectedLanguage]);
+ return false;
+ var realWorldPos;
+ if (s.isSnapped()) {
+ realWorldPos = s.getSnappedPoint();
+ s.clean();
+ else {
+ parent.mb_getMousePos(e,mod_digitize_target);
+ realWorldPos = parent.mapToReal(mod_digitize_target,new parent.Point(parent.clickX,parent.clickY));
+ if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
+ // close the polygon
+ d.close();
+ parent.mb_disableThisButton(button_polygon);
+ return true;
+ else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
+ // close the line
+ d.close();
+ parent.mb_disableThisButton(button_line);
+ return true;
+ else {
+ // set the calculated real world position as point of the geometry
+ d.getGeometry(-1,-1).addPoint(realWorldPos);
+ if(d.get(-1).geomType == parent.geomType.point){
+ d.close();
+ parent.mb_disableThisButton(button_point);
+ return true;
+ // add first point of polygon to snapping list (if three points have been inserted).
+ else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
+ s.add(d.getPoint(-1, -1, 0));
+ // add last point of line to snapping list (if at least two points have been inserted).
+ else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
+ if (mod_digitizeEvent != button_move) {
+ s.store(d);
+ s.add(d.getPoint(-1, -1, -1));
+ return true;
+// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
+var basepointObject = false;
+var basepointMemberIndex = null;
+var basepointGeometryIndex = null;
+var basepointPointIndex = null;
+var basepointDragActive = false;
+function handleBasepoint(obj,memberIndex,geometryIndex,pointIndex){
+ if(!(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete)){ return false; }
+ basepointObject = obj;
+ basepointMemberIndex = memberIndex;
+ basepointGeometryIndex = geometryIndex;
+ basepointPointIndex = pointIndex;
+ if(mod_digitizeEvent == button_move){
+ mod_digitize_timeout();
+ basepointObject.style.cursor = 'move';
+ basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].selectBasepoint;
+ if(mod_digitizeEvent == button_delete){
+ basepointObject.style.cursor = 'crosshair';
+ basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].deleteBasepoint;
+function convertLinepointToBasepoint(obj, memberIndex, geomIndex, pointIndex){
+ if(!(mod_digitizeEvent == button_insert)){ return false; }
+ if(mod_digitizeEvent == button_insert){
+ obj.style.cursor = 'crosshair';
+ obj.onclick = insertBasepoint;
+ basepointGeometryIndex = geomIndex;
+function insertBasepoint(e){
+ var i = basepointMemberIndex;
+ var j = basepointGeometryIndex;
+ var k = basepointPointIndex;
+ var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX, parent.clickY);
+ var p = new parent.Point(pos[0], pos[1]);
+ d.getGeometry(i,j).addPointAtIndex(p, k);
+function deleteBasepoint(){
+ d.delAllPointsLike(d.getPoint(i,j,k));
+function selectBasepoint(e){
+ if(!basepointDragActive && mod_digitizeEvent == button_move){
+ basepointDragActive = true;
+ s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
+ // replace basepoint by transparent blob
+ basepointObject.style.width = mod_digitize_width;
+ basepointObject.style.height = mod_digitize_height;
+ basepointObject.style.left = 0;
+ basepointObject.style.top = 0;
+ if (parent.ie) {
+ // ie cannot handle backgroundColor = 'transparent'
+ basepointObject.style.background = "url(../img/transparent.gif)";
+ else{
+ basepointObject.style.backgroundColor = 'transparent';
+ basepointObject.onmouseup = releaseBasepoint;
+ basepointObject.onmousemove = dragBasepoint;
+function dragBasepoint(e){
+ if(basepointDragActive){
+ var res = s.check(currentPos);
+function updateAllPointsOfNonTransactionalLike(oldP, newP){
+ for (var i = 0; i < d.count(); i++) {
+ if (isTransactional(d.get(i))) {
+ d.get(i).updateAllPointsLike(oldP, newP);
+function releaseBasepoint(e){
+ basepointDragActive = false;
+ var basepointDragEnd = new parent.Point(parent.clickX, parent.clickY);
+ basepointObject.onmousedown = null;
+ var p = parent.makeClickPos2RealWorldPos(mod_digitize_target, basepointDragEnd.x, basepointDragEnd.y);
+ var oldPoint = parent.cloneObject(d.getPoint(i,j,k));
+ var snappedPoint = parent.cloneObject(s.getSnappedPoint());
+ if (!nonTransactionalEditable) {
+ updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
+ else {
+ d.updateAllPointsLike(oldPoint, snappedPoint);
+ s.clean();
+ else {
+ var newPoint = new parent.Point(p[0],p[1]);
+ updateAllPointsOfNonTransactionalLike(oldPoint, newPoint);
+ else {
+ d.updateAllPointsLike(oldPoint, newPoint);
+ basepointMemberIndex = null;
+ basepointGeometryIndex = null;
+ basepointPointIndex = null;
+// --- basepoint handling (end) -----------------------------------------------------------------------------------------
+// --- registered functions (begin) ---------------------------------------------------------------------------------------
+function registerDigitizePreFunctions(stringFunction){
+ mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
+function registerDigitizeSubFunctions(stringFunction){
+ mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
+function executeDigitizeSubFunctions(){
+ for(var i=0; i<mod_digitizeSubFunctions.length; i++){
+ eval(mod_digitizeSubFunctions[i]);
+function executeDigitizePreFunctions(){
+ for(var i=0; i<mod_digitizePreFunctions.length; i++){
+ eval(mod_digitizePreFunctions[i]);
+function registerFunctions(){
+ mod_digitizePreFunctions = [];
+ mod_digitizeSubFunctions = [];
+ registerDigitizePreFunctions("updateExtent()");
+ registerDigitizePreFunctions("drawDashedLine()");
+ registerDigitizeSubFunctions("updateListOfGeometries()");
+ registerDigitizeSubFunctions("drawDashedLine()");
+ registerDigitizeSubFunctions("updateMeasureTag()");
+ parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].setStyleForTargetFrame()");
+ parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkDigitizeTag()");
+ parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseSnapping()");
+ parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseHighlight()");
+ parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseMeasure()");
+ parent.mb_registerSubFunctions("window.frames['" + mod_digitize_elName + "'].updateExtent()");
+ parent.mb_registerWfsReadSubFunctions(function(geom){parent.tab_open(mod_digitize_elName);parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);});
+ parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
+function checkDigitizeTag(){
+ var digitizeTagName = "digitize";
+ var digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
+ digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
+ parent.mb_registerPanSubElement(digitizeTagName);
+ parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
+function setStyleForTargetFrame(){
+ var cssLink = parent.window.frames[mod_digitize_target].document.createElement("link");
+ cssLink.setAttribute("href", cssUrl);
+ cssLink.setAttribute("type", "text/css");
+ cssLink.setAttribute("rel", "stylesheet");
+ var cssTmp = parent.window.frames[mod_digitize_target].document.getElementsByTagName("head")[0];
+ cssTmp.appendChild(cssLink);
+function initialiseSnapping(){
+ s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
+function initialiseHighlight(){
+ nonTransactionalHighlight = new parent.Highlight(new Array(mod_digitize_target), "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
+function initialiseMeasure(){
+ measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
+ parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
+// --- registered functions (end) -----------------------------------------------------------------------------------------
+function updateMeasureTag () {
+ if (d.count() > 0 ) {
+ if (d.get(-1).count() > 0) {
+ if (d.getGeometry(-1, -1).count() > 0) {
+ if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
+ var measureString = "";
+ measureString += measureTagLabelCurrent[selectedLanguage] + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
+ measureString += measureTagLabelTotal[selectedLanguage] + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
+ measureDivTag.write(measureString);
+ return true;
+ measureDivTag.clean();
+// --- button handling (begin) --------------------------------------------------------------------------------------------
+function displayButtons(){
+ for (var i = 0 ; i < buttonDig_id.length ; i ++) {
+ if (parseInt(buttonDig_on[i])==1) {
+ var divTag = document.createElement("div");
+ divTag.setAttribute("id", "div_" + buttonDig_id[i]);
+// FIREFOX
+ document.getElementById("digButtons").appendChild(divTag);
+//IE WORKAROUND, WORKS ALSO FOR FIREFOX
+ var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
+ parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
+function initDigButton(ind, pos){
+ parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
+ parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
+ parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
+ parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
+ parent.mb_button[ind].title_on = buttonDig_title_on[pos];
+ parent.mb_button[ind].title_off = buttonDig_title_off[pos];
+ parent.mb_button[ind].status = 0;
+ parent.mb_button[ind].elName = buttonDig_id[pos];
+ parent.mb_button[ind].fName = "";
+ parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
+ parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+function digitizeEnable(obj) {
+ if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
+ mod_digitizeEvent = obj.id;
+ else if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon || obj.id == button_clear || obj.id == button_combine){
+ el.onmousemove = mod_digitize_go;
+ if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
+ s.store(d);
+ obj.title = obj.title_on;
+ if (obj.id == button_point) {
+ if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
+ if (d.get(-1).geomType != parent.geomType.point) {
+ d.close();
+ else {
+ if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
+ d.addMember(parent.geomType.point);
+ d.get(-1).addGeometry();
+ else {
+// delete existing line or polygon
+ d.del(-1);
+ else if (obj.id == button_polygon) {
+ if (d.get(-1).geomType != parent.geomType.polygon) {
+ d.close();
+ else {
+ // new geometry
+ d.addMember(parent.geomType.polygon);
+ else {
+// continue a line as a polygon
+ var geometryTemplate = parent.cloneObject(d.get(-1));
+ d.del(-1);
+ for (var i = 0; i < geometryTemplate.count(); i++) {
+ for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
+ d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
+ else if (obj.id == button_line) {
+ if (d.get(-1).geomType != parent.geomType.line) {
+ d.close();
+ else {
+ d.addMember(parent.geomType.line);
+ else {
+// continue a polygon as a line
+ d.del(-1);
+ else if (obj.id == button_clear) {
+ var clear = confirm(messageConfirmDeleteAllGeomFromList[selectedLanguage]);
+ if (clear) {
+ d = new parent.GeometryArray();
+ parent.mb_disableThisButton(button_clear);
+ else if (obj.id == button_combine) {
+// d.combineToMultiGeometry();
+// prompt('', d.toJSONString());
+// parent.mb_ajax_post("../php/jsonTest.php", {json:d.toJSONString()}, function(test, status) {
+// alert(test);
+ parent.mb_disableThisButton(button_combine);
+function digitizeDisable(obj) {
+ if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
+ obj.title = obj.title_off;
+ if (d.get(-1).get(-1).count() == 0) {
+ d.delGeometry(-1,-1);
+ mod_digitizeEvent = false;
+// --- button handling (end) ----------------------------------------------------------------------------------------------
+// --- display (begin) -----------------------------------------------------------------------------------------
+function updateExtent() {
+ var anInd = parent.getMapObjIndexByName(mod_digitize_target);
+ var change = false;
+ if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
+ mod_digitize_width = parent.mb_mapObj[anInd].width;
+ change = true;
+ if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
+ mod_digitize_height = parent.mb_mapObj[anInd].height;
+ change = true;
+ if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
+ mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
+ change = true;
+// if (change) {
+// drawDashedLine();
+function drawDashedLine(){
+ nonTransactionalHighlight.clean();
+ var smP = "";
+ smP += "<div class='t_img'>";
+ smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
+ smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+ for(var i=0; i<d.count(); i++){
+ if (!nonTransactionalEditable && !isTransactional(d.get(i))) {
+ nonTransactionalHighlight.add(d.get(i), nonTransactionalColor);
+ else {
+ for(var j=0; j<d.get(i).count(); j++){
+ for(var k = 0; k < d.getGeometry(i,j).count(); k++){
+ var pos = parent.makeRealWorld2mapPos(mod_digitize_target,d.getPoint(i,j,k).x,d.getPoint(i,j,k).y);
+ if (!d.getGeometry(i,j).isComplete() &&
+ ( (k == 0 && d.get(i).geomType == parent.geomType.polygon) || (k == d.getGeometry(i,j).count()-1 && d.get(i).geomType == parent.geomType.line))) {
+ smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
+ else {
+ smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
+ if(j==0 && d.get(i).geomType == parent.geomType.polygon && !d.getGeometry(i,j).isComplete()){
+ smP += " title='"+closePolygon_title+"' ";
+ if(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete) {
+ smP += " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
+ smP += "></div>";
+ var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
+ for(var k = 1; k < d.getGeometry(i,j).count(); k++){
+ var p0 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k));
+ var p1 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k-1));
+ points = parent.calculateVisibleDash(p0, p1, parent.mb_mapObj[mapObjInd].width, parent.mb_mapObj[mapObjInd].height);
+ if (points != false) {
+ smP += evaluateDashes(points[0], points[1], i, j, k);
+ digitizeDivTag.write(smP);
+function evaluateDashes(start, end, memberIndex, geomIndex, pointIndex){
+ var str_dashedLine = "";
+ var delta = new parent.Point(end.x - start.x, end.y - start.y);
+ var vecLength = start.dist(end);
+ var n = Math.round(vecLength/dotDistance);
+ var step = new parent.Point(delta.x/n, delta.y/n);
+ for(var i=1; i<n; i++){
+ var x = Math.round(start.x + i * step.x) - 2;
+ var y = Math.round(start.y + i * step.y) - 2;
+ if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
+ if (memberIndex == d.count()-1 && !d.getGeometry(-1,-1).isComplete()) {
+ str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
+ else {
+ str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
+ if(mod_digitizeEvent == button_insert) {
+ str_dashedLine += "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+pointIndex+")'";
+ str_dashedLine += "></div>";
+ return str_dashedLine;
+function isTransactional(geom) {
+// alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
+ if (typeof(geom.wfs_conf) == 'number') {
+ if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
+ var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
+ if (isTransactionalGeom) {
+ return true;
+ else{
+ return false;
+ else if (typeof(geom.wfs_conf) == 'undefined') {
+ return true;
+function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
+ return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
+function getName (geom) {
+ wfsConfId = geom.wfs_conf;
+ wfsConf = parent.get_complete_wfs_conf();
+ if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
+ var resultName = "";
+ for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+ if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
+ resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
+ if (resultName == "") {
+ resultName = wfsConf[wfsConfId]['g_label'];
+ return resultName;
+ else {
+ return digitizeDefaultGeometryName[selectedLanguage];
+function updateListOfGeometries(){
+ var listOfGeom = "<table style='position:absolute; top:"+geomList_y+"px; left:"+geomList_x+"px;'>\n";
+ if (d.count() > 0) {
+ for (var i = 0 ; i < d.count(); i ++) {
+ if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
+ listOfGeom += "\t<tr>\n\t\t<td>\n";
+ if (wfsExistsForGeom(d.get(i), wfsConf)) {
+ listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+buttonDig_wfs_title[selectedLanguage]+"' onclick='showWfs("+i+")'>\n";
+ listOfGeom += "\t\t</td>\n\t\t<td>\n";
+ listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+buttonDig_remove_title[selectedLanguage]+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
+ if (isValidWfsConfIndex(wfsConf, d.get(i).wfs_conf)) {
+ listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+buttonDig_removeDb_title[selectedLanguage]+"' onclick=\"var deltrans = confirm('"+messageConfirmDeleteGeomFromDb[selectedLanguage]+"');if (deltrans) dbGeom('delete', "+i+")\">\n";
+ listOfGeom += "\t\t</td>\n\t\t<td style = 'color:blue;font-size:12px'>\n";
+ listOfGeom += "\t\t\t<div onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"));' ";
+ listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"))' ";
+ listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"));' ";
+ var geomName = getName(d.get(i));
+ if (d.get(i).geomType == parent.geomType.polygon) {geomName += " ("+messageDescriptionPolygon[selectedLanguage]+")";}
+ else if (d.get(i).geomType == parent.geomType.line) {geomName += " ("+messageDescriptionLine[selectedLanguage]+")";}
+ else if (d.get(i).geomType == parent.geomType.point) {geomName += " ("+messageDescriptionPoint[selectedLanguage]+")";}
+ listOfGeom += ">" + htmlspecialchars(geomName) +"</div>\t\t</td>\n\t</tr>\n";
+ listOfGeom += "</table>\n";
+ parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
+// --- display (end) -----------------------------------------------------------------------------------------
+// --- wfs window (begin) -----------------------------------------------------------------------------------------
+// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
+function formCorrect(doc, formId) {
+ var isCorrect = true;
+ var errorMessage = "";
+ var result;
+ var form = doc.getElementById(formId);
+ result = mandatoryFieldsNotEmpty(doc, form);
+ isCorrect = isCorrect && result.isCorrect;
+ errorMessage += result.errorMessage;
+ result = validBoxEntrySelected(form);
+ result = dataTypeIsCorrect(doc, form);
+ return {"isCorrect":isCorrect, "errorMessage":errorMessage};
+function validBoxEntrySelected(form){
+ var name = "";
+ for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
+ if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
+ name += form.childNodes[i].name;
+ if (parseInt(form.childNodes[i].selectedIndex) == 0 && form.childNodes[i].getAttribute("mandatory") == "true") {
+ var msg = name + ": " + messageSelectAnOption[selectedLanguage] + "\n"
+ var categ = form.childNodes[i].getAttribute("category");
+ if (typeof(categ) != "undefined") {
+ msg = categ + " => " + msg;
+ return {"isCorrect":false, "errorMessage":msg};
+ else if (form.childNodes[i].hasChildNodes()) {
+ var res = validBoxEntrySelected(form.childNodes[i]);
+ errorMessage = res.errorMessage + errorMessage;
+ isCorrect = res.isCorrect;
+function mandatoryFieldsNotEmpty(doc, node){
+ nodeArray = doc.getElementsByName("mandatory");
+ for (var i = 0; i < nodeArray.length; i++) {
+ if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
+ var nodeId = nodeArray[i].id.substr(10);
+ if (nodeArray[i].value == "true") {
+ if (doc.getElementById(nodeId).value == "") {
+ isCorrect = false;
+ errorMessage += doc.getElementById(nodeId).getAttribute("category") + " => " + doc.getElementById(nodeId).name +": "+ messageErrorFieldIsEmpty[selectedLanguage] +"\n";
+function isInteger(str) {
+ if (str.match(/^\d*$/)) {
+ return true;
+ return false;
+function isFloat(str) {
+ if (isInteger(str)) {
+ return true;
+ if (str.match(/^\d+\.\d+$/)) {
+ return true;
+ return false;
+function replaceCommaByDecimalPoint(str) {
+ var patternString = ",";
+ var pattern = new RegExp(patternString);
+ while (str.match(pattern)) {
+ str = str.replace(pattern, ".");
+ return str;
+function dataTypeIsCorrect(doc, node){
+ nodeArray = doc.getElementsByName("datatype");
+ for (var i = 0; i < nodeArray.length ; i++) {
+ if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
+ var nodeId = nodeArray[i].id.substr(9);
+ var nodeValue = doc.getElementById(nodeId).value;
+ if (nodeArray[i].value == "int") {
+ if (!isInteger(nodeValue)) {
+ errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ messageErrorNotAnInteger[selectedLanguage] + "\n";
+ else if (nodeArray[i].value == "double") {
+ nodeValue = replaceCommaByDecimalPoint(nodeValue);
+ if (!isFloat(nodeValue)) {
+ errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ messageErrorNotAFloat[selectedLanguage] + "\n";
+ else {
+ doc.getElementById(nodeId).value = nodeValue;
+// --- wfs window form check (end) -----------------------------------------------------------------------------------------
+function getAvailableWfsForGeom(geom, wfsConf) {
+ var wfsConfIndices = [];
+ for (var attr in wfsConf) {
+ var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
+ if (!isTrans) {
+ continue;
+ if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
+ if (parseInt(geom.wfs_conf) == parseInt(attr)) {
+ wfsConfIndices.push(attr);
+ else {
+ for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
+ var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
+ if (isGeomColumn) {
+ var isMultiPolygon = (geom.geomType == parent.geomType.polygon && wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType');
+ var isPolygon = (geom.geomType == parent.geomType.polygon && geom.count() == 1 && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType');
+ var isMultiLine = (geom.geomType == parent.geomType.line && wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType');
+ var isLine = (geom.geomType == parent.geomType.line && geom.count() == 1 && wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType');
+ var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
+// alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
+ if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
+ return wfsConfIndices;
+function wfsExistsForGeom(geom, wfsConf) {
+ wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
+// alert(wfsConfIndices.join(","));
+ if (wfsConfIndices.length > 0) {
+ return true;
+ return false;
+// this method opens a new window and displays the attributes in wfs_conf
+function showWfs(geometryIndex) {
+ wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+ wfsWindow.document.open("text/html");
+ var str = "";
+ var strStyle = "";
+ var defaultIndex = -1;
+ str += "<form id='wfs'>\n";
+ // 1. add select box
+ var onChangeText = "document.getElementById('elementForm').innerHTML = ";
+ onChangeText += "window.opener.buildElementForm(this.value, " + geometryIndex + ");";
+ onChangeText += "window.opener.setWfsWindowStyle(this.value);";
+ onChangeText += "$('.hasDatepicker').datepicker();";
+ str += "\t<select name='wfs' size='" + wfsConf.length + "'";
+ str += " onChange=\""+ onChangeText +"\"";
+ str += ">\n\t\t";
+ var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
+ var selected = false;
+ for (var i = 0; i < wfsConfIndices.length ; i++) {
+ str += "<option value='" + wfsConfIndices[i] + "'";
+ if (!selected) {
+ str += " selected";
+ selected = true;
+ defaultIndex = parseInt(wfsConfIndices[i]);
+ str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
+ str += "</option>\n\t\t";
+ str += "</select>\n\t\t</form>\n\t";
+ var elForm = "";
+ if (defaultIndex != -1) {
+ var headStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
+ headStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
+ headStr += '<style type="text/css">'
+ headStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
+ headStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
+ headStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
+ headStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
+ headStr += 'div.helptext p { margin: 0 ; }';
+ headStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
+ headStr += 'a img { vertical-align: middle;border: 0; }';
+ headStr += '</style>';
+ headStr += '</head><body onload="var $dp = $(\'.hasdatepicker\');$dp.datepicker();">';
+ wfsWindow.document.write(headStr);
+ elForm = buildElementForm(defaultIndex, geometryIndex);
+ else {
+ var headStr = "<html><head><style type='text/css'></style></head><body>";
+ str += "<div id='elementForm'>\n" + elForm + "</div>";
+ str += "<script type='text/javascript' src='../extensions/jquery-1.2.6.min.js'><\/script>";
+ str += "<script type='text/javascript' src='../extensions/jquery-ui-personalized-1.5.3.min.js'><\/script>";
+ str += "</body></html>";
+ wfsWindow.document.write(str);
+ wfsWindow.document.close();
+ toggleTabs(initialTab);
+function setWfsWindowStyle(wfsConfIndex) {
+ wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
+function prepareSelectBox (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+ // set category
+ if (categoryName) {
+ var patternString = "<select";
+ formElementHtml = formElementHtml.replace(pattern, patternString + " category='" + categoryName + "' ");
+ if (isMandatory) {
+ // set border if mandatory
+ patternString = "<select";
+ pattern = new RegExp(patternString);
+ formElementHtml = formElementHtml.replace(pattern, patternString + " mandatory='true' style='border:1px solid red' ");
+ // set name of select box to elementlabel
+ patternString = "name\s*=\s*\\*'\w+\\*'";
+ if (pattern.test(formElementHtml)) {
+ formElementHtml = formElementHtml.replace(pattern, "name='" + elementLabel + "'");
+ else {
+ formElementHtml = formElementHtml.replace(pattern, "<select name='" + elementLabel + "'");
+ // preselect the correct entry of the box
+ patternString = "option value='"+elementValue+"'";
+ formElementHtml = formElementHtml.replace(pattern, patternString+" selected");
+ return formElementHtml;
+function prepareDatepicker (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+ // set category
+ var patternString = "<input";
+ patternString = "<input";
+ else {
+ formElementHtml = formElementHtml.replace(pattern, "<input name='" + elementLabel + "'");
+ formElementHtml = formElementHtml.replace(pattern, patternString + " value='"+elementValue+"'");
+function prepareTextArea (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+ // set category
+ var patternString = "<textarea";
+ patternString = "<textarea";
+ else {
+ formElementHtml = formElementHtml.replace(pattern, "<textarea name='" + elementLabel + "'");
+ patternString = "<\/textarea>";
+ formElementHtml = formElementHtml.replace(pattern, elementValue + patternString);
+// Returns a form with the elements of a selected WFS grouped in tabs
+// (if the original WFS is the selected WFS, the values are set too)
+var initialTab = false;
+function buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex) {
+ var featureTypeMismatch = false;
+ if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
+ var str = "";
+ var hasGeometryColumn = false;
+ var featureTypeArray = wfsConf[wfsConfIndex];
+ var memberElements;
+ var fid = false;
+ if (!featureTypeMismatch) {
+ memberElements = d.get(memberIndex).e;
+ fid = memberElements.getElementValueByName('fid');
+ if (typeof(featureTypeArray["element"]) !== "undefined") {
+ featureTypeElementArray = featureTypeArray["element"];
+ elementCategories.sort();
+ str += "<form id='"+featureTypeElementFormId+"'>\n\t\n";
+ initialTab = elementCategories[0];
+ for(var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
+ str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
+ // 2. add rows to form
+ for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
+ var featureTypeElement = featureTypeElementArray[i];
+ var elementName = featureTypeElement['element_name'];
+ var elementType = featureTypeElement['element_type'];
+ var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
+ var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
+ var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
+ if(featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
+ continue;
+ str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
+ str += '<table>';
+ var elementLabelExists = (featureTypeElement['f_label'] != "");
+ var elementLabel = "";
+ if (elementLabelExists) {
+ elementLabel = featureTypeElement['f_label'];
+ var elementLabelStyle = featureTypeElement['f_label_id'];
+ if (!isGeomColumn) {
+ if (isEditable) {
+ str += "\t\t<tr>\n";
+ if(elementLabelExists) {
+ str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
+ str += "\t\t\t<td>\n";
+ else {
+ str += '<td colspan="2">';
+ var elementValue = "";
+ for (var j = 0 ; j < memberElements.count() ; j ++) {
+ if (memberElements.getName(j) == featureTypeElement['element_name']) {
+ elementValue = memberElements.getValue(j);
+ var formElementHtml = featureTypeElement['f_form_element_html'];
+ if (!formElementHtml) {
+ mandatoryHint = '';
+ var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
+ str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+ str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+ str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+ else {
+ while (formElementHtml.match(/\\/)) {
+ formElementHtml = formElementHtml.replace(/\\/, "");
+ formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
+ var patternString = "hasdatepicker";
+ formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
+ formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
+ str += formElementHtml;
+ if(featureTypeElement.f_helptext.length > 0) {
+ str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../x_geoportal/img/help.png" width="16" height="16" alt="?" /></a> ';
+ str += '<div id="helptext' +i+ '" class="helptext">';
+ str += '<p>';
+ str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+ str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
+ str += '</p>';
+ str += '</div>';
+ str += "\t\t\t</td>\n\t\t</tr>\n";
+ else {
+ hasGeometryColumn = true;
+ str += '</table>';
+ str += '</div>';
+ // 3. add buttons "save", "update", "delete"
+ str += "<table>";
+ var isTransactional = (featureTypeArray['wfs_transaction']);
+ if (isTransactional) {
+ var options = ["save", "update", "delete", "abort"];
+ for (var i = 0 ; i < options.length ; i++) {
+ var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
+ onClickText += "if (result.isCorrect) {";
+ onClickText += "window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
+// onClickText += "window.close();";
+ onClickText += "}";
+ onClickText += "else {";
+ onClickText += "alert(result.errorMessage);this.disabled=false;"
+ if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
+ str += "\t\t\t<td><input type='button' name='saveButton' value='"+buttonLabelSaveGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\" /></td>\n";
+ if (!featureTypeMismatch && fid) {
+ if (options[i] == "update" && hasGeometryColumn) {
+ str += "\t\t\t<td><input type='button' name='updateButton' value='"+buttonLabelUpdateGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\"/></td>\n";
+ if (options[i] == "delete"){
+ var deleteOnClickText = "var deltrans = confirm('"+messageConfirmDeleteGeomFromDb[selectedLanguage]+"');";
+ deleteOnClickText += "if (deltrans){";
+ deleteOnClickText += onClickText + "}";
+ str += "\t\t\t<td><input type='button' name='deleteButton' value='"+buttonLabelDeleteGeometry[selectedLanguage]+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
+ if (options[i] == "abort") {
+ str += "\t\t\t<td><input type='button' name='abortButton' value='"+buttonLabelAbort[selectedLanguage]+"' onclick=\"window.close();\" /></td>\n";
+ str += "\t\t</tr>\n";
+ str += "\t</table>\n";
+ str += "<input type='hidden' id='fid' value='"+fid+"'>";
+// str += "<input type='text' name='mb_wfs_conf'>";
+ str += "</form>\n";
+ return str;
+// returns a form with the elements of a selected wfs
+// (if the original wfs is the selected wfs, the values are set too)
+function buildElementForm(wfsConfIndex, memberIndex){
+ var str = "";
+ var fid = false;
+ // Check if there are categories given and
+ // build the form in tabs if necessary
+ var elementCategories = [];
+ for(var i = 0; i < featureTypeElementArray.length; i++){
+ var categoryName = featureTypeElementArray[i].f_category_name;
+ var categoryNameIsUnique = true;
+ if(categoryName.length === 0) { continue; }
+ for(var j = 0; j < elementCategories.length; j++) {
+ if(elementCategories[j] == categoryName) {
+ categoryNameIsUnique = false;
+ if(categoryNameIsUnique) {
+ elementCategories.push(categoryName);
+ if(elementCategories.length > 0) {
+ return buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex);
+ str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
+ for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
+ if (isEditable) {
+ str += "\t\t\t\t<input id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+ else {
+ str += '<p>';
+ str += '</p>';
+ str += '</div>';
+ else {
+ str += "</table><table>";
+ return str;
+function dbGeom(type,m) {
+ if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
+ d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
+ d.get(m).e = new parent.Wfs_element();
+ else {
+ var myconf = wfsConf[d.get(m).wfs_conf];
+ if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
+ alert(errorMessageEpsgMismatch[selectedLanguage] + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs']);
+ else {
+ var fid = false;
+ myform = wfsWindow.document.getElementById(featureTypeElementFormId);
+ for (var i=0; i<myform.length; i++){
+ if (myform.elements[i].id == "fid") {
+ fid = myform.elements[i].value;
+ d.get(m).e.setElement('fid', fid);
+ else if (myform.elements[i].type == 'text' || myform.elements[i].tagName.toUpperCase() == "TEXTAREA"){
+ if (myform.elements[i].id) {
+ d.get(m).e.setElement(myform.elements[i].id, myform.elements[i].value);
+ else {
+ errorMessage = messageErrorFormEvaluation[selectedLanguage];
+ // selectbox
+ else if (typeof(myform.elements[i].selectedIndex) == 'number') {
+ if (myform.elements[i].id && myform.elements[i].selectedIndex !== 0) {
+ d.get(m).e.setElement(myform.elements[i].id, myform.elements[i].options[myform.elements[i].selectedIndex].value);
+ else {
+ else {
+ fid = d.get(m).e.getElementValueByName('fid');
+ str = parent.get_wfs_str(myconf, d, m, type, fid);
+ parent.mb_ajax_post("../extensions/geom2wfst.php", {'filter':str,'url':myconf['wfs_transaction'],'featuretype_name':myconf['featuretype_name'],'wfs_conf_id':wfsConf[d.get(m).wfs_conf]['wfs_conf_id']}, function(json,status){
+ var result = eval('('+json+')');
+ var response = result.response;
+ var fid = result.fid;
+ wfsSubWrite(m, type, status, response, fid);
+function wfsSubWrite(m, type, status, response, fid) {
+ if (type == 'save' && fid) {
+ d.get(m).e.setElement("fid", fid);
+ if (type == 'delete') {
+ parent.mb_disableThisButton(mod_digitizeEvent);
+ d.del(m);
+ parent.mb_execWfsWriteSubFunctions();
+ if (status == "success" && response == "success") {
+ var wfsWriteMessage = messageSuccessWfsWrite[selectedLanguage];
+ else {
+ var wfsWriteMessage = messageErrorWfsWrite[selectedLanguage];
+ wfsWindow.alert(wfsWriteMessage);
+ window.setTimeout("wfsWindow.close()",0);
+ else {
+ alert(wfsWriteMessage);
+ </script>
+ </head>
+ <body onload="displayButtons();">
+ <table cellpadding='0' cellspacing='0' align = center><tr><td><div id='digButtons'></div></td></tr></table>
+ <div id = 'listOfGeometries'></div>
+ </body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
