[Mapbender-commits] r3975 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 2 07:53:50 EDT 2009
Author: beck
Date: 2009-06-02 07:53:50 -0400 (Tue, 02 Jun 2009)
New Revision: 3975
Added:
   trunk/mapbender/http/javascripts/mod_digitize_tab_category.php
Added: trunk/mapbender/http/javascripts/mod_digitize_tab_category.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab_category.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab_category.php	2009-06-02 11:53:50 UTC (rev 3975)
@@ -0,0 +1,2018 @@
+<?php
+# $Id: mod_digitize_tab.php 3939 2009-05-12 19:43:45Z marc $
+# http://www.mapbender.org/index.php/mod_digitize_tab.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+$e_target = $_GET["e_target"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Digitize</title>
+<?php
+$digitize_conf_filename = "digitize_default.conf";
+include '../include/dyn_css.php';
+<script language='JavaScript'>
+// Buttons
+function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
+	buttonDig_id.push(id);
+	buttonDig_on.push(isOn);
+	buttonDig_src.push(src);
+	buttonDig_title_off.push(titleOff);
+	buttonDig_title_on.push(titleOn);
+	buttonDig_x.push(x);
+	buttonDig_y.push(y);
+function htmlspecialchars(p_string) {
+	p_string = p_string.replace(/&/g, '&amp;');
+	p_string = p_string.replace(/</g, '&lt;');
+	p_string = p_string.replace(/>/g, '&gt;');
+	p_string = p_string.replace(/"/g, '&quot;');
+	//	p_string = p_string.replace(/'/g, '&#039;');
+	return p_string;
+//default definition of image directory for digitize buttons, might
+//be overwritten with digitize conf data
+var buttonDig_imgdir = "../img/button_digitize/";
+var buttonDig_id = [];
+var buttonDig_on = [];
+var buttonDig_src = [];
+var buttonDig_title_off = [];
+var buttonDig_title_on = [];
+var buttonDig_x = [];
+var buttonDig_y = [];
+var mapWindow;
+var mapDomElement;
+var mapType = "";
+parent.eventInit.register(function () {
+	var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
+	mapDomElement = parent.mb_mapObj[mapIndex].getDomElement();
+	mapType = mapDomElement.tagName.toUpperCase();
+	if (mapType == "DIV") {
+		mapWindow = parent.window;
+	else if (mapType == "IFRAME") {
+		mapWindow = mapDomElement.window;
+	else {
+		new parent.Mb_warning("Could not set CSS for map in digitizing module.");
+<?php
+echo "var mod_digitize_target = '".$e_target."';";
+$digitizeConfFilenameAndPath = dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename;
+if ($digitize_conf_filename && file_exists($digitizeConfFilenameAndPath)) {
+	include($digitizeConfFilenameAndPath);
+var wfsWindow;
+var wfsConf = [];
+var d;
+var mod_digitize_width;
+var mod_digitize_height;
+var mod_digitizeEvent = false;
+var nonTransactionalHighlight;
+var button_point = "Point";
+var button_line = "Line";
+var button_polygon = "Polygon";
+var button_move = "dragBasePoint";
+var button_insert = "setBasePoint";
+var button_delete = "delBasePoint";
+var button_clear = "clear";
+var button_split = "digitizeSplit";
+var button_merge = "digitizeMerge";
+var button_difference = "digitizeDifference";
+var digitizeDivTag;
+var GeometryArray;
+var MultiGeometry = parent.MultiGeometry;
+var Geometry;
+var Point;
+var geomType;
+var msgObj;
+var featureTypeElementFormId = "featureTypeElementForm";
+try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
+try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
+function toggleTabs(tabId) {
+	if(!initialTab) {
+		return;
+	var tabHeaders = wfsWindow.document.getElementsByTagName('a');
+	var tabs       = wfsWindow.document.getElementsByTagName('div');
+	for(var i = 0; i < tabHeaders.length; i++) {
+		if(tabHeaders[i].id.indexOf('tabheader') != -1) {
+			tabHeaders[i].className = 'tabheader';
+	for(var i = 0; i < tabs.length; i++) {
+		if(tabs[i].className === 'tabcontent') {
+			tabs[i].style.visibility = 'hidden';
+			tabs[i].style.display    = 'none';
+	wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
+	wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
+	wfsWindow.document.getElementById('tab_' + tabId).style.display    = 'block';
+	return false;
+function showHelptext(helptextId) {
+	hideHelptext();
+	wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+	wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'block';
+	return false;
+function hideHelptext(helptextId) {
+	if(helptextId) {
+		wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+		wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'none';
+	var helptext = wfsWindow.document.getElementsByTagName('div');
+	for(var i = 0; i < helptext.length; i++) {
+		if(helptext[i].className === 'helptext') {
+			helptext[i].style.visibility = 'hidden';
+			helptext[i].style.display    = 'none';
+	return false;
+function getMousePosition(e) {
+	parent.mb_getMousePos(e, mod_digitize_target);
+	var currentPos = null;
+		currentPos = new parent.Point(
+			parent.clickX - parseInt(mapDomElement.style.left),
+			parent.clickY - parseInt(mapDomElement.style.top)
+	else {
+			parent.clickX,
+			parent.clickY
+	return currentPos;
+function initializeDigitize () {
+	d = new parent.GeometryArray();
+	GeometryArray = parent.GeometryArray;
+	Geometry = parent.Geometry;
+	Point = parent.Point;
+	geomType = parent.geomType;
+ * Append geometries from KML when KML has been loaded
+function appendGeometryArrayFromKML () {
+	try {
+		parent.kmlHasLoaded.register(function(properties){
+			d.importGeoJSON(properties);
+//			d = parent.geoJsonToGeometryArray(properties);
+			executeDigitizeSubFunctions();
+	catch (e) {
+		var exc = new parent.Mb_warning(e);
+// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
+function appendGeometryArray(obj) {
+	executeDigitizePreFunctions();
+	for (i=0; i<obj.count(); i++) {
+		d.addCopy(obj.get(i));
+function mod_digitize_go(e){
+	// ie workaround
+	if (e == undefined) {
+		e = mapWindow.event;
+	if (e) {
+		// track mouse position
+		var currentPos = getMousePosition(e);
+		s.check(currentPos);
+	else {
+//		s.clean();
+	var el = mapDomElement;
+	el.onmousedown = mod_digitize_start;
+function mod_digitize_timeout(){
+	el.onmousedown = null;
+	el.onmouseup = null;
+	el.onmousemove = null;
+function mod_digitize_start(e){
+	// check if a proper geometry is selected
+	if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
+		if (mod_digitizeEvent != false) {
+			alert(msgObj.errorMessageNoGeometrySelected);
+		return false;
+	var realWorldPos;
+	if (s.isSnapped()) {
+		realWorldPos = s.getSnappedPoint();
+		s.clean();
+	else {
+		realWorldPos = parent.mapToReal(mod_digitize_target,currentPos);
+	if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
+		// close the polygon
+		d.close();
+		parent.mb_disableThisButton(button_polygon);
+		return true;
+	else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
+		// close the line
+		d.close();
+		parent.mb_disableThisButton(button_line);
+		return true;
+	else {
+		// set the calculated real world position as point of the geometry
+		d.getGeometry(-1,-1).addPoint(realWorldPos);
+		d.getGeometry(-1,-1).setEpsg(parent.mb_mapObj[mapIndex].epsg);
+		if(d.get(-1).geomType == parent.geomType.point){
+			d.close();
+			parent.mb_disableThisButton(button_point);
+			return true;
+		// add first point of polygon to snapping list (if three points have been inserted).
+		else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
+			s.add(d.getPoint(-1, -1, 0));
+		// add last point of line to snapping list (if at least two points have been inserted).
+		else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
+			if (mod_digitizeEvent != button_move) {
+				s.store(d);
+			s.add(d.getPoint(-1, -1, -1));
+	return true;
+// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
+var basepointObject = false;
+var basepointMemberIndex = null;
+var basepointGeometryIndex = null;
+var basepointRingIndex = null;
+var basepointPointIndex = null;
+var basepointDragActive = false;
+function handleBasepoint(obj,memberIndex, geometryIndex, ringIndex, pointIndex){
+	if (!(
+		mod_digitizeEvent == button_move ||
+		mod_digitizeEvent == button_insert ||
+		mod_digitizeEvent == button_delete)
+		return false;
+	basepointObject = obj;
+	basepointMemberIndex = memberIndex;
+	basepointGeometryIndex = geometryIndex;
+	if (pointIndex == undefined) {
+		pointIndex = ringIndex;
+		basepointRingIndex = undefined;
+	else {
+		basepointRingIndex = ringIndex;
+	basepointPointIndex = pointIndex;
+	if(mod_digitizeEvent == button_move){
+		mod_digitize_timeout();
+		basepointObject.style.cursor = 'move';
+		basepointObject.onmousedown = parent.frames[mod_digitize_elName].selectBasepoint;
+	if(mod_digitizeEvent == button_delete){
+		basepointObject.style.cursor = 'crosshair';
+		basepointObject.onmousedown = parent.frames[mod_digitize_elName].deleteBasepoint;
+function convertLinepointToBasepoint(obj, memberIndex, geomIndex, ringIndex, pointIndex){
+	if(!(mod_digitizeEvent == button_insert)){ return false; }
+	if(mod_digitizeEvent == button_insert){
+		obj.style.cursor = 'crosshair';
+		obj.onclick = insertBasepoint;
+		basepointGeometryIndex = geomIndex;
+function insertBasepoint(e){
+	var i = basepointMemberIndex;
+	var j = basepointGeometryIndex;
+	var k = basepointRingIndex;
+	var l = basepointPointIndex;
+	var ind = parent.getMapObjIndexByName(mod_digitize_target);
+	var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(currentPos.x, currentPos.y));
+	if (k == undefined) {
+		d.getGeometry(i,j).addPointAtIndex(p, l);
+	else {
+		d.getGeometry(i,j).innerRings.get(k).addPointAtIndex(p, l);
+function deleteBasepoint(){
+	if (k != undefined) {
+		d.delAllPointsLike(d.getPoint(i, j, k, l));
+	else {
+		d.delAllPointsLike(d.getPoint(i, j, l));
+function selectBasepoint(e){
+	if(!basepointDragActive && mod_digitizeEvent == button_move){
+		basepointDragActive = true;
+		s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
+		// replace basepoint by transparent blob
+		basepointObject.style.width = mod_digitize_width;
+		basepointObject.style.height = mod_digitize_height;
+		basepointObject.style.left = 0;
+		basepointObject.style.top = 0;
+		if (parent.ie) {
+			// ie cannot handle backgroundColor = 'transparent'
+			basepointObject.style.background = "url(../img/transparent.gif)";
+		else{
+			basepointObject.style.backgroundColor = 'transparent';
+		basepointObject.onmouseup = releaseBasepoint;
+		basepointObject.onmousemove = dragBasepoint;
+function dragBasepoint(e){
+	if(basepointDragActive){
+		var res = s.check(currentPos);
+function updateAllPointsOfNonTransactionalLike(oldP, newP){
+	for (var i = 0; i < d.count(); i++) {
+		if (isTransactional(d.get(i))) {
+			d.get(i).updateAllPointsLike(oldP, newP);
+function releaseBasepoint(e){
+	basepointDragActive = false;
+	var basepointDragEnd = currentPos;
+	basepointObject.onmousedown = null;
+	var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(basepointDragEnd.x, basepointDragEnd.y));
+	var oldPoint;
+		oldPoint = parent.cloneObject(d.getPoint(i,j,l));
+	else {
+		oldPoint = parent.cloneObject(d.getPoint(i,j,k,l));
+		var snappedPoint = parent.cloneObject(s.getSnappedPoint());
+		if (!nonTransactionalEditable) {
+			updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
+		else {
+			d.updateAllPointsLike(oldPoint, snappedPoint);
+		s.clean();
+	else {
+			updateAllPointsOfNonTransactionalLike(oldPoint, p);
+		else {
+			d.updateAllPointsLike(oldPoint, p);
+	basepointMemberIndex = null;
+	basepointGeometryIndex = null;
+	basepointPointIndex = null;
+// --- basepoint handling (end) -----------------------------------------------------------------------------------------
+// --- registered functions (begin) ---------------------------------------------------------------------------------------
+function registerDigitizePreFunctions(stringFunction){
+	mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
+function registerDigitizeSubFunctions(stringFunction){
+	mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
+function executeDigitizeSubFunctions(){
+	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
+		eval(mod_digitizeSubFunctions[i]);
+function executeDigitizePreFunctions(){
+	for(var i=0; i<mod_digitizePreFunctions.length; i++){
+		eval(mod_digitizePreFunctions[i]);
+function registerFunctions(){
+	mod_digitizePreFunctions = [];
+	mod_digitizeSubFunctions = [];
+	registerDigitizePreFunctions("updateExtent()");
+	registerDigitizePreFunctions("drawDashedLine()");
+	registerDigitizeSubFunctions("updateListOfGeometries()");
+	registerDigitizeSubFunctions("drawDashedLine()");
+	parent.eventInit.register(function () {
+		initializeDigitize();
+		setStyleForTargetFrame();
+		checkDigitizeTag();
+		initialiseSnapping();
+//		appendGeometryArrayFromKML();
+			initialiseHighlight();
+		initialiseMeasure();
+		getMessages();
+	parent.eventLocalize.register(function() {
+		getMessages();
+	parent.eventAfterMapRequest.register(function () {
+		updateExtent();
+	parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
+function checkDigitizeTag(){
+	var digitizeTagName = "digitizeDiv";
+	var digitizeTagStyle;
+		digitizeTagStyle = {"z-index":digitizeTransactionalZIndex, "font-size":"10px"};
+		digitizeDivTag = new parent.DivTag(digitizeTagName, "", digitizeTagStyle, mapDomElement);
+	else {
+		digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
+		digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
+	parent.mb_registerPanSubElement(digitizeTagName);
+	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
+function setStyleForTargetFrame(){
+	var cssLink = mapWindow.document.createElement("link");
+	var cssHead = mapWindow.document.getElementsByTagName("head")[0];
+	cssLink.setAttribute("href", cssUrl);
+	cssLink.setAttribute("type", "text/css");
+	cssLink.setAttribute("rel", "stylesheet");
+	cssHead.appendChild(cssLink);
+function initialiseSnapping(){
+	s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
+function initialiseHighlight(){
+	nonTransactionalHighlight = new parent.Highlight([mod_digitize_target], "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
+function initialiseMeasure(){
+		measureDivTag = new parent.DivTag(measureTagName, "", measureTagStyle);
+	else {
+		measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
+	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
+// --- registered functions (end) -----------------------------------------------------------------------------------------
+function updateMeasureTag () {
+	if (d.count() > 0 ) {
+		if (d.get(-1).count() > 0) {
+			if (d.getGeometry(-1, -1).count() > 0) {
+				if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
+					var measureString = "";
+					measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
+					measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
+					measureDivTag.write(measureString);
+					return true;
+	measureDivTag.clean();
+// --- button handling (begin) --------------------------------------------------------------------------------------------
+function displayButtons(){
+	for (var i = 0 ; i < buttonDig_id.length ; i ++) {
+		if (parseInt(buttonDig_on[i])==1) {
+			var divTag = document.createElement("div");
+			divTag.setAttribute("id", "div_" + buttonDig_id[i]);
+// FIREFOX
+			document.getElementById("digButtons").appendChild(divTag);
+//IE WORKAROUND, WORKS ALSO FOR FIREFOX
+			var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
+			parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
+function updateButtons() {
+			var currentButton = document.getElementById(buttonDig_id[i]);
+			var currentStatus = buttonDig_id[i].status;
+			var currentTitle = "";
+			switch (buttonDig_id[i]) {
+				case "Point":
+					if (currentStatus == 1) {
+						currentTitle = msgObj.buttonLabelPointOn;
+					else {
+						currentTitle = msgObj.buttonLabelPointOff;
+					break;
+				case "Line":
+						currentTitle = msgObj.buttonLabelLineOn;
+					else {
+						currentTitle = msgObj.buttonLabelLineOff;
+					break;
+				case "Polygon":
+						currentTitle = msgObj.buttonLabelPolygonOn;
+					else {
+						currentTitle = msgObj.buttonLabelPolygonOff;
+					break;
+				case "dragBasePoint":
+						currentTitle = msgObj.buttonLabelMoveBasepointOn;
+					else {
+						currentTitle = msgObj.buttonLabelMoveBasepointOff;
+					break;
+				case "setBasePoint":
+						currentTitle = msgObj.buttonLabelInsertBasepointOn;
+					else {
+						currentTitle = msgObj.buttonLabelInsertBasepointOff;
+					break;
+				case "delBasePoint":
+						currentTitle = msgObj.buttonLabelDeleteBasepointOn;
+					else {
+						currentTitle = msgObj.buttonLabelDeleteBasepointOff;
+					break;
+				case "clear":
+						currentTitle = msgObj.buttonLabelClearListOn;
+					else {
+						currentTitle = msgObj.buttonLabelClearListOff;
+					break;
+				case "digitizeSplit":
+						currentTitle = msgObj.buttonLabelSplitOn;
+					else {
+						currentTitle = msgObj.buttonLabelSplitOff;
+					break;
+				case "digitizeMerge":
+						currentTitle = msgObj.buttonLabelMergeOn;
+					else {
+						currentTitle = msgObj.buttonLabelMergeOff;
+					break;
+				case "digitizeDifference":
+						currentTitle = msgObj.buttonLabelDifferenceOn;
+					else {
+						currentTitle = msgObj.buttonLabelDifferenceOff;
+					break;
+			currentButton.title = currentTitle;
+function initDigButton(ind, pos){
+	parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
+	parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
+	parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
+	parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
+	parent.mb_button[ind].title_on = buttonDig_title_on[pos];
+	parent.mb_button[ind].title_off = buttonDig_title_off[pos];
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = buttonDig_id[pos];
+	parent.mb_button[ind].fName = "";
+	parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
+	parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+function digitizeEnable(obj) {
+	if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
+		mod_digitizeEvent = obj.id;
+	else if (obj.id == button_point || obj.id == button_line ||
+				obj.id == button_polygon || obj.id == button_clear ||
+				obj.id == button_split || obj.id == button_merge ||
+				obj.id == button_difference){
+		el.onmousemove = mod_digitize_go;
+		if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
+			s.store(d);
+		obj.title = obj.title_on;
+		if (obj.id == button_point) {
+			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
+				if (d.get(-1).geomType != parent.geomType.point) {
+					d.close();
+				else {
+			if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
+				d.addMember(parent.geomType.point);
+				d.get(-1).addGeometry();
+			else {
+// delete existing line or polygon
+				d.del(-1);
+		else if (obj.id == button_polygon) {
+				if (d.get(-1).geomType != parent.geomType.polygon) {
+					d.close();
+				else {
+				// new geometry
+				d.addMember(parent.geomType.polygon);
+			else {
+// continue a line as a polygon
+					var geometryTemplate = parent.cloneObject(d.get(-1));
+					d.del(-1);
+					for (var i = 0; i < geometryTemplate.count(); i++) {
+						for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
+							d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
+		else if (obj.id == button_line) {
+				if (d.get(-1).geomType != parent.geomType.line) {
+					d.close();
+				else {
+				d.addMember(parent.geomType.line);
+			else {
+// continue a polygon as a line
+					d.del(-1);
+		else if (obj.id == button_clear) {
+			var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
+			if (clear) {
+				parent.mb_disableThisButton(button_clear);
+		else if (obj.id == button_merge) {
+			var applicable = (d.count() > 1);
+			var polygonTextArray = [];
+				if (d.get(i).geomType != parent.geomType.polygon) {
+					applicable = false;
+					polygonTextArray = [];
+					break;
+				polygonTextArray.push(d.get(i).toText());
+			if (!applicable) {
+				alert(msgObj.messageErrorMergeNotApplicable);
+				parent.mb_disableThisButton(button_merge);
+				return false;
+			parent.mb_ajax_post("../php/mod_digitize_mergePolygon.php", {polygons: polygonTextArray.join(";")}, function(json, status) {
+				var response = eval('(' + json + ')');
+				var polygon = response.polygon;
+				d.importGeometryFromText(polygon, parent.mb_mapObj[mapIndex].epsg);
+				// remove the original polygons
+				var len = d.count();
+				for (var i = 0; i < len-1; i++) {
+					d.del(0);
+		else if (obj.id == button_split) {
+			var applicable = (d.count() == 2) &&
+							(d.get(0).geomType == parent.geomType.polygon) &&
+							(d.get(1).geomType == parent.geomType.line);
+				alert(msgObj.messageErrorSplitNotApplicable);
+				parent.mb_disableThisButton(button_split);
+				return false;
+			var polygonText = d.get(0).toText();
+			var lineText = d.get(1).toText();
+			parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
+				var polygonArray = response.polygons;
+				var wfsConfId = d.get(0).wfs_conf;
+				for (var i in polygonArray) {
+					d.importGeometryFromText(polygonArray[i], parent.mb_mapObj[mapIndex].epsg);
+					d.get(-1).wfs_conf = wfsConfId;
+				// remove the original polygon and the temporary line
+				d.del(0);
+				d.del(0);
+		else if (obj.id == button_difference) {
+							(d.get(1).geomType == parent.geomType.polygon);
+				alert(msgObj.messageErrorDifferenceNotApplicable);
+				parent.mb_disableThisButton(button_difference);
+				return false;
+			var polygon1Text = d.get(0).toText();
+			var polygon2Text = d.get(1).toText();
+			parent.mb_ajax_post("../php/mod_digitize_differencePolygon.php", {polygon1: polygon1Text, polygon2: polygon2Text}, function(json, status) {
+				var wfsProperties = d.get(0).e;
+					d.get(-1).e = wfsProperties;
+				// remove the original and the temporary polygon
+				d.del(0);
+				d.del(0);
+function digitizeDisable(obj) {
+	if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
+		obj.title = obj.title_off;
+		if (d.get(-1).get(-1).count() == 0) {
+			d.delGeometry(-1,-1);
+	mod_digitizeEvent = false;
+// --- button handling (end) ----------------------------------------------------------------------------------------------
+// --- display (begin) -----------------------------------------------------------------------------------------
+function updateExtent() {
+	var anInd = parent.getMapObjIndexByName(mod_digitize_target);
+	var change = false;
+	if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
+		mod_digitize_width = parent.mb_mapObj[anInd].width;
+		change = true;
+	if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
+		mod_digitize_height = parent.mb_mapObj[anInd].height;
+		change = true;
+	if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
+		mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
+		change = true;
+//	if (change) {
+//		drawDashedLine();
+function drawDashedLine(){
+		nonTransactionalHighlight.clean();
+	var smP = "";
+	smP += "<div class='t_img'>";
+	smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
+	smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+	var smPArray = [];
+	smPArray[smPArray.length] = "<div class='t_img'>"
+			+ "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
+			+ "<div class='t_img'>"
+			+ "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+	var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
+	var width = mapObj.width;
+	var height = mapObj.height;
+	var arrayBBox = mapObj.extent.split(",")
+	var minX = parseFloat(arrayBBox[0]);
+	var minY = parseFloat(arrayBBox[1]);
+	var maxX = parseFloat(arrayBBox[2]);
+	var maxY = parseFloat(arrayBBox[3]);
+	var cx = width/(maxX - minX);
+	var cy = height/(maxY - minY);
+	var isMoveOrInsertOrDelete = mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete;
+	var minDist = 6;
+	for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
+		var currentGeomArray = d.get(i);
+		if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
+			nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
+		else {
+			for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
+				var currentGeometry = d.getGeometry(i,j);
+				var isPolygon = currentGeomArray.geomType == parent.geomType.polygon;
+				var isLine = currentGeomArray.geomType == parent.geomType.line;
+				var isComplete = currentGeometry.isComplete();
+				var lastPaintedPoint = false;
+				for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
+					var currentPoint = currentGeometry.get(k);
+					var currentPointMap = new Point(Math.round((currentPoint.x - minX)*cx), Math.round((maxY - currentPoint.y)*cy));
+//					var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
+//					if (!isTooCloseToPrevious) {
+						var currentPointIsVisible = currentPointMap.x > 0 && currentPointMap.x < width && currentPointMap.y > 0 && currentPointMap.y < height;
+						if (currentPointIsVisible) {
+							if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint-1 && isLine))) {
+								smPArray[smPArray.length] = "<div class='bp' style='top:"+
+									(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+
+									digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
+							else {
+								smPArray[smPArray.length] = "<div class='bp' style='top:"+(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
+							if(k==0 && isPolygon && !isComplete){
+								smPArray[smPArray.length] = " title='"+msgObj.closePolygon_title+"' ";
+							if(isMoveOrInsertOrDelete) {
+								smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
+							smPArray[smPArray.length] = "></div>";
+							lastPaintedPoint = currentPointMap;
+						if (k > 0) {
+							points = parent.calculateVisibleDash(currentPointMap, previousPointMap, width, height);
+							if (points != false) {
+								smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
+					var previousPointMap = currentPointMap;
+				if (isPolygon && currentGeometry.innerRings.count() > 0) {
+					// draw inner rings
+					for (var l = 0, lenRings = currentGeometry.innerRings.count(); l < lenRings; l++) {
+						var currentRing = currentGeometry.innerRings.get(l);
+						for (var m = 0, lenPoint = currentRing.count(); m < lenPoint; m++) {
+							var currentPoint = currentRing.get(m);
+							var currentPointMap = new Point(Math.round((currentPoint.x - minX) * cx), Math.round((maxY - currentPoint.y) * cy));
+							//					var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
+							//					if (!isTooCloseToPrevious) {
+								if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint - 1 && isLine))) {
+									smPArray[smPArray.length] = "<div class='bp' style='top:" +
+									(currentPointMap.y - 2) +
+									"px;left:" +
+									(currentPointMap.x - 2) +
+									"px;z-index:" +
+									digitizeTransactionalZIndex +
+									";background-color:" +
+									linepointColor +
+								else {
+									smPArray[smPArray.length] = "<div class='bp' style='top:" + (currentPointMap.y - 2) + "px;left:" + (currentPointMap.x - 2) + "px;z-index:" + digitizeTransactionalZIndex + ";'";
+								if (m == 0 && isPolygon && !isComplete) {
+									smPArray[smPArray.length] = " title='" + msgObj.closePolygon_title + "' ";
+								if (isMoveOrInsertOrDelete) {
+									smPArray[smPArray.length] = " onmouseover='parent.window.frames[\"" + mod_digitize_elName + "\"].handleBasepoint(this," + i + "," + j + "," + l + "," + m + ")' ;";
+							if (m > 0) {
+									smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, l, m);
+	digitizeDivTag.write(smPArray.join(""));
+function evaluateDashes(start, end, memberIndex, geomIndex, ringIndex, pointIndex){
+		ringIndex = undefined;
+	var strArray = [];
+	var delta = new parent.Point(end.x - start.x, end.y - start.y);
+	var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
+	var vecLength = start.dist(end);
+	var n = Math.round(vecLength/dotDistance);
+	if (n > 0) {
+		var step = delta.dividedBy(n);
+	for(var i=1; i < n; i++){
+		var x = Math.round(start.x + i * step.x) - 2;
+		var y = Math.round(start.y + i * step.y) - 2;
+		if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
+			if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
+				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
+			else {
+				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
+			if(mod_digitizeEvent == button_insert) {
+				strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+ringIndex+","+pointIndex+")'";
+			strArray[strArray.length] = "></div>";
+	return strArray.join("");
+function isTransactional(geom) {
+//	alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
+	if (typeof(geom.wfs_conf) == 'number') {
+		if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
+			var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
+			if (isTransactionalGeom) {
+				return true;
+			else{
+				return false;
+	else if (typeof(geom.wfs_conf) == 'undefined') {
+		return true;
+function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
+	return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
+function getName (geom) {
+	wfsConfId = geom.wfs_conf;
+	wfsConf = parent.get_complete_wfs_conf();
+	if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
+		var resultName = "";
+		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
+				resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
+		if (resultName == "") {
+			resultName = wfsConf[wfsConfId]['g_label'];
+		return resultName;
+	else if (geom.e.getElementValueByName("name")) {
+		return geom.e.getElementValueByName("name");
+	else {
+		return msgObj.digitizeDefaultGeometryName;
+function updateListOfGeometries(){
+	var listOfGeom = "<ul>";
+	if (d.count() > 0) {
+		for (var i = 0 ; i < d.count(); i ++) {
+			if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
+				// for the geometries from a kml, there is another save dialogue
+				if (d.get(i).isFromKml()) {
+					// if the kml is in the db (id = id in database)
+					if (d.get(i).e.getElementValueByName("Mapbender:id")) {
+						// button: geometry information, update kml
+						listOfGeom += "<li>";
+						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>";
+				else {
+					// button: geometry information, save, update, delete
+					if (wfsExistsForGeom(d.get(i), wfsConf)) {
+						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>";
+					// button: remove this geometry
+					listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>";
+					// button clone this geometry
+					if (addCloneGeometryButton === true) {
+						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_clone_src+"' title='"+msgObj.buttonDig_clone_title+"' onclick='d.addCopy(d.get("+i+"));d.get(-1).e.delElement(\"fid\");executeDigitizeSubFunctions();'>";
+				// button: remove geometry from database
+				if (d.get(i).e.getElementValueByName('fid')) {
+					listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">";
+				listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
+				listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"),\""+geomHighlightColour+"\")' ";
+				listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
+				var geomName = getName(d.get(i));
+				var currentGeomType;
+				if (d.get(i).geomType == parent.geomType.polygon) {
+					currentGeomType = msgObj.messageDescriptionPolygon;
+				else if (d.get(i).geomType == parent.geomType.line) {
+					currentGeomType = msgObj.messageDescriptionLine;
+				else if (d.get(i).geomType == parent.geomType.point) {
+					currentGeomType = msgObj.messageDescriptionPoint;
+				var multi = "";
+				if (d.get(i).count() > 1) {
+					multi = "multi";
+				listOfGeom += ">" + htmlspecialchars(geomName) +" (" + multi + currentGeomType + ")</div>";
+				// multigeometries
+				listOfGeom += "<ul>";
+				for (var j = 0; j < d.get(i).count(); j++) {
+					var currentGeom = d.get(i).get(j);
+					if (d.get(i).count() > 1 || (d.get(i).geomType == geomType.polygon &&
+						d.get(i).get(j).innerRings &&
+						d.get(i).get(j).innerRings.count() > 0)) {
+						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").del(" + j + ");executeDigitizeSubFunctions();'>";
+						listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
+						listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\")' ";
+						listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
+						listOfGeom += ">" + currentGeomType + "#" + (j+1) +"</div></li>";
+					if (d.get(i).geomType == geomType.polygon &&
+						d.get(i).get(j).innerRings.count() > 0) {
+						for (var k = 0; k < d.get(i).get(j).innerRings.count(); k++) {
+							var currentRing = d.get(i).get(j).innerRings.get(k);
+							listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").get(" + j + ").innerRings.del(" + k + ");executeDigitizeSubFunctions();'>";
+							listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
+							listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\")' ";
+							listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
+							listOfGeom += ">inner ring #" + (k+1) +"</div></li>";
+						listOfGeom += "</ul>";
+				listOfGeom += "</li>";
+	parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
+// --- display (end) -----------------------------------------------------------------------------------------
+// --- wfs window (begin) -----------------------------------------------------------------------------------------
+// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
+function formCorrect(doc, formId) {
+	var isCorrect = true;
+	var errorMessage = "";
+	var result;
+	var form = doc.getElementById(formId);
+	result = mandatoryFieldsNotEmpty(doc, form);
+	isCorrect = isCorrect && result.isCorrect;
+	errorMessage += result.errorMessage;
+	//select box is now checked within function mandatoryFieldsNotEmpty
+	//result = validBoxEntrySelected(form);
+	//isCorrect = isCorrect && result.isCorrect;
+	//errorMessage += result.errorMessage;
+	result = dataTypeIsCorrect(doc, form);
+	return {"isCorrect":isCorrect, "errorMessage":errorMessage};
+function validBoxEntrySelected(form){
+	for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
+		if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
+			if (parseInt(form.childNodes[i].selectedIndex) == 0) {
+				return {"isCorrect":false, "errorMessage":errorMessage};
+		else if (form.childNodes[i].hasChildNodes()) {
+			isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
+	if (!isCorrect) {
+		errorMessage = msgObj.messageSelectAnOption + "\n";
+function mandatoryFieldsNotEmpty(doc, node){
+	nodeArray = doc.getElementsByName("mandatory");
+	for (var i = 0; i < nodeArray.length && isCorrect; i++) {
+		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
+			var nodeId = nodeArray[i].id.substr(10);
+			if (nodeArray[i].value == "true") {
+				if (doc.getElementById(nodeId).value == "") {
+					isCorrect = false;
+					errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
+		if (nodeArray[i].nodeName.toUpperCase() == "SELECT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
+function isInteger(str) {
+	if (str.match(/^\d*$/)) {
+		return true;
+	return false;
+function isFloat(str) {
+	if (isInteger(str)) {
+		return true;
+	if (str.match(/^\d+\.\d+$/)) {
+		return true;
+	return false;
+function replaceCommaByDecimalPoint(str) {
+	var patternString = ",";
+	var pattern = new RegExp(patternString);
+	while (str.match(pattern)) {
+		str = str.replace(pattern, ".");
+	return str;
+function dataTypeIsCorrect(doc, node){
+	nodeArray = doc.getElementsByName("datatype");
+	for (var i = 0; i < nodeArray.length ; i++) {
+		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
+			var nodeId = nodeArray[i].id.substr(9);
+			var nodeValue = doc.getElementById(nodeId).value;
+			if (nodeArray[i].value == "int") {
+				if (!isInteger(nodeValue)) {
+					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
+			else if (nodeArray[i].value == "double") {
+				nodeValue = replaceCommaByDecimalPoint(nodeValue);
+				if (!isFloat(nodeValue)) {
+					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
+				else {
+					doc.getElementById(nodeId).value = nodeValue;
+// --- wfs window form check (end) -----------------------------------------------------------------------------------------
+function getAvailableWfsForGeom(geom, wfsConf) {
+	var wfsConfIndices = [];
+	for (var attr in wfsConf) {
+		var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
+		if (!isTrans) {
+			continue;
+		if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
+			if (parseInt(geom.wfs_conf) == parseInt(attr)) {
+				wfsConfIndices.push(attr);
+		else {
+			for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
+				var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
+				if (isGeomColumn) {
+					var isMultiPolygon = (
+						geom.geomType == parent.geomType.polygon &&
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType' ||
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiSurfacePropertyType'
+					var isPolygon = (
+						geom.count() == 1 &&
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType' ||
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'SurfacePropertyType'
+					var isMultiLine = (
+						geom.geomType == parent.geomType.line &&
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType' ||
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiCurvePropertyType'
+					var isLine = (
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType' ||
+						wfsConf[attr]['element'][elementIndex]['element_type'] == 'CurvePropertyType'
+					var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
+//					alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
+					if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
+	return wfsConfIndices;
+function wfsExistsForGeom(geom, wfsConf) {
+	wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
+//	alert(wfsConfIndices.join(","));
+	if (wfsConfIndices.length > 0) {
+		return true;
+	return false;
+function showWfsKml (geometryIndex) {
+	wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+	wfsKmlWindow.document.open("text/html");
+	wfsKmlWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
+	wfsKmlWindow.document.close();
+	str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
+	var properties = d.get(geometryIndex).e;
+	var propertyCount = properties.count();
+	for (var i = 0; i < propertyCount; i++) {
+		var key = properties.getName(i);
+		var value = properties.getValue(i);
+		var expr = /Mapbender:/;
+		if (!key.match(expr)) {
+			str += "\t\t<tr>\n";
+			str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
+			str += "\t\t\t<td>\n";
+			str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
+			str += "\t\t\t</td>\n\t\t</tr>\n";
+	var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
+	var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
+	deleteOnClickText += "if (deltrans){";
+	deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
+	str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
+// delete button not yet implemented
+//	str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
+	str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
+	str += "\t\t</tr>\n";
+	str += "\t</table>\n";
+	str += "</form>\n";
+	wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
+// this method opens a new window and displays the attributes in wfs_conf
+function showWfs(geometryIndex) {
+	wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+	wfsWindow.document.open("text/html");
+	var str = "";
+	var strStyle = "";
+	var defaultIndex = -1;
+	str += "<form id='wfs'>\n";
+	// 1. add select box
+	var onChangeText = "document.getElementById('elementForm').innerHTML = ";
+	onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
+	onChangeText += "window.opener.setWfsWindowStyle(this.value);";
+	str += "\t<select name='wfs' size='" + wfsConf.length + "'";
+	str += " onChange=\""+ onChangeText +"\"";
+	str += ">\n\t\t";
+	var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
+	var selected = false;
+	for (var i = 0; i < wfsConfIndices.length ; i++) {
+		str += "<option value='" + wfsConfIndices[i] + "'";
+		if (!selected) {
+			str += " selected";
+			selected = true;
+			defaultIndex = parseInt(wfsConfIndices[i]);
+		str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
+		str += "</option>\n\t\t";
+	str += "</select>\n\t\t</form>\n\t";
+	str += "<div id='elementForm'>\n</div>";
+	if (defaultIndex != -1) {
+		var htmlStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
+		htmlStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
+		htmlStr += '<style type="text/css">'
+		htmlStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
+		htmlStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
+		htmlStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
+		htmlStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
+		htmlStr += 'div.helptext p { margin: 0 ; }';
+		htmlStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
+		htmlStr += 'a img { vertical-align: middle;border: 0; }';
+		htmlStr += '</style>';
+		htmlStr += '</head><body></body></html>';
+//		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
+		wfsWindow.document.write(htmlStr);
+		wfsWindow.document.write(str);
+		wfsWindow.document.close();
+		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
+	else {
+		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
+function setWfsWindowStyle(wfsConfIndex) {
+	wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
+// returns a form with the elements of a selected wfs
+// (if the original wfs is the selected wfs, the values are set too)
+function buildElementForm(wfsConfIndex, memberIndex){
+	var featureTypeMismatch = false;
+	if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
+	var str = "";
+	var hasGeometryColumn = false;
+	var featureTypeArray = wfsConf[wfsConfIndex];
+	var memberElements;
+	var fid = false;
+	if (!featureTypeMismatch) {
+		memberElements = d.get(memberIndex).e;
+		fid = memberElements.getElementValueByName('fid');
+	if (typeof(featureTypeArray["element"]) !== "undefined") {
+		str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
+		featureTypeElementArray = featureTypeArray["element"];
+		// Check if there are categories given and
+		// build the form in tabs if necessary
+		var elementCategories = [];
+		for(var i = 0; i < featureTypeElementArray.length; i++){
+			var categoryName         = featureTypeElementArray[i].f_category_name;
+			var categoryNameIsUnique = true;
+			if(categoryName.length === 0) { continue; }
+			for(var j = 0; j < elementCategories.length; j++) {
+				if(elementCategories[j] == categoryName) {
+					categoryNameIsUnique = false;
+			if(categoryNameIsUnique) {
+				elementCategories.push(categoryName);
+		if(elementCategories.length > 0) {
+			return buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex);
+		// 2. add rows to form
+		for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
+			var featureTypeElement = featureTypeElementArray[i];
+			var elementName = featureTypeElement['element_name'];
+			var elementType = featureTypeElement['element_type'];
+			var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
+			var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
+			var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
+			var elementLabelExists = (featureTypeElement['f_label'] != "");
+			var elementLabel = "";
+			if (elementLabelExists) {
+				elementLabel = featureTypeElement['f_label'];
+			var elementLabelStyle = featureTypeElement['f_label_id'];
+			if (!isGeomColumn) {
+				if (isEditable) {
+					str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
+					var elementValue = "";
+						for (var j = 0 ; j < memberElements.count() ; j ++) {
+							if (memberElements.getName(j) == featureTypeElement['element_name']) {
+								elementValue = memberElements.getValue(j);
+					var formElementHtml = featureTypeElement['f_form_element_html'];
+					if (!formElementHtml || !formElementHtml.match(/&lt;select/)) {
+						str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+						str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+						str += "\t\t\t\t<input id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+					else {
+							while (formElementHtml.match(/\\/)) {
+								formElementHtml = formElementHtml.replace(/\\/, "");
+							str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+							str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+							// preselect the correct entry of the box
+							var patternString = "option value( )*=( )*'"+elementValue+"'";
+							var patternStringForReplace = "option value = '"+elementValue+"'";
+							formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
+							formElementHtml = formElementHtml.replace(/&lt;/g,'<');
+							formElementHtml = formElementHtml.replace(/&gt;/g,'>');
+							formElementHtml = formElementHtml.replace(/&#039;/g,'\'');
+							str += formElementHtml;
+					if(featureTypeElement.f_helptext.length > 0) {
+						str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../x_geoportal/img/help.png" width="16" height="16" alt="?" /></a> ';
+						str += '<div id="helptext' +i+ '" class="helptext">';
+						str += '<p>';
+						str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+						str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
+						str += '</p>';
+						str += '</div>';
+			else {
+				hasGeometryColumn = true;
+		// 3. add buttons "save", "update", "delete"
+		str += "</table><table>";
+		var isTransactional = (featureTypeArray['wfs_transaction']);
+		if (isTransactional) {
+			var options = ["insert", "update", "delete", "abort"];
+			for (var i = 0 ; i < options.length ; i++) {
+				var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
+				onClickText += 	"if (result.isCorrect) {";
+				onClickText += 		"window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
+//				onClickText +=      "window.close();";
+				onClickText += 	"}";
+				onClickText += 	"else {";
+				onClickText += 		"alert(result.errorMessage);this.disabled=false;"
+				if (options[i] == "insert" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
+					str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
+				if (!featureTypeMismatch && fid) {
+					if (options[i] == "update" && hasGeometryColumn) {
+						str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
+					if (options[i] == "delete"){
+						var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
+						deleteOnClickText += onClickText + "}";
+						str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
+				if (options[i] == "abort") {
+					str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
+		str += "<input type='hidden' id='fid' value='"+fid+"'>";
+//			str += "<input type='text' name='mb_wfs_conf'>";
+	return str;
+function dbGeom(type,m) {
+	if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
+		d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
+		d.get(m).e = new parent.Wfs_element();
+	else {
+	var myconf = wfsConf[d.get(m).wfs_conf];
+	var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
+	var proceed = true;
+	if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
+		proceed = confirm(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs'] + ". Proceed?");
+	if (proceed) {
+		var fid = false;
+			myform = wfsWindow.document.getElementById(featureTypeElementFormId);
+			for (var i=0; i<myform.length; i++){
+				if (myform.elements[i].id == "fid") {
+					fid = myform.elements[i].value;
+					if (fid == "false") {
+						fid = false;
+					else {
+						d.get(m).e.setElement('fid', fid);
+				else if (myform.elements[i].type == 'text' ){
+					if (myform.elements[i].id) {
+						var elementId = String(myform.elements[i].id).replace(/mb_digitize_form_/, "");
+						d.get(m).e.setElement(elementId, myform.elements[i].value);
+					else {
+						errorMessage = msgObj.messageErrorFormEvaluation;
+				// selectbox
+				else if (typeof(myform.elements[i].selectedIndex) == 'number') {
+						d.get(m).e.setElement(elementId, myform.elements[i].options[myform.elements[i].selectedIndex].value);
+					else {
+		else {
+			fid = d.get(m).e.getElementValueByName('fid');
+//		str = parent.get_wfs_str(myconf, d, m, type, fid);
+		var geoJson = d.featureToString(m);
+			"../extensions/geom2wfst.php",
+				'geoJson' : geoJson,
+				'method' : type,
+				'wfs_conf_id' : wfsConf[d.get(m).wfs_conf]['wfs_conf_id']
+			function(json,status){
+				var result = eval('('+json+')');
+				var success = result.success;
+				var fid = result.fid;
+				wfsSubWrite(m, type, status, success, fid);
+function wfsSubWrite(m, type, status, success, fid) {
+	if (status == "success" && success) {
+		if (type == 'insert' && fid) {
+			d.get(m).e.setElement("fid", fid);
+		if (type == 'delete') {
+			parent.mb_disableThisButton(mod_digitizeEvent);
+			d.del(m);
+		var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
+	else {
+		var wfsWriteMessage = msgObj.messageErrorWfsWrite;
+	parent.mb_execWfsWriteSubFunctions();
+		wfsWindow.alert(wfsWriteMessage);
+		window.setTimeout("wfsWindow.close()",0);
+	else {
+		alert(wfsWriteMessage);
+function getMultiGeometryIdsByPlacemarkId (placemarkId) {
+	var multiGeometryIdArray = [];
+		var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
+		if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
+			multiGeometryIdArray.push(i);
+	return multiGeometryIdArray;
+function updateKmlInDb (geometryIndex, command) {
+	var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
+	var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
+	if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
+		// update properties from form
+		myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
+		for (var i=0; i < myform.length; i++){
+			if (myform.elements[i].type == 'text' ){
+					var key = myform.elements[i].name;
+					var value = myform.elements[i].value;
+					// update all geometries with the same placemark id
+					for (var j = 0; j < multiGeometryIdArray.length; j++) {
+						var currentProperties = d.get(j).e;
+						currentProperties.setElement(key, value);
+		var kmlId = properties.getElementValueByName("Mapbender:id");
+		parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
+			if (obj === "1") {
+				wfsKmlWindow.alert("KML updated.");
+				var link = wfsKmlWindow.document.createElement("a");
+				link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
+				link.target = "_blank";
+				link.innerHTML = "KML";
+				wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
+				wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
+			else {
+				wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
+function getMessages() {
+	parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
+		msgObj = obj;
+		applyMessages();
+function applyMessages() {
+	updateMeasureTag();
+	updateListOfGeometries();
+	updateButtons();
+	</script>
+	</head>
+	<body onload="registerFunctions();displayButtons();">
+		<div id='digButtons'></div>
+		<div id='listOfGeometries' class='digitizeGeometryList'></div>
+	</body>
+</html>
More information about the Mapbender_commits mailing list
