[Mapbender-commits] r4007 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Fri Jun 5 12:12:50 EDT 2009
Author: christoph
Date: 2009-06-05 12:12:49 -0400 (Fri, 05 Jun 2009)
New Revision: 4007
trunk/mapbender/resources/db/update/update_2.7.sql
http://trac.osgeo.org/mapbender/ticket/481
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql 2009-06-05 15:54:03 UTC (rev 4006)
+++ trunk/mapbender/resources/db/update/update_2.7.sql 2009-06-05 16:12:49 UTC (rev 4007)
@@ -60,4 +60,23 @@
INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
\ No newline at end of file
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
+-- update wfs conf module
+UPDATE gui_element SET
+e_attributes = 'href = "../php/mod_wfs_conf_client.php" target="AdminFrame"'
+WHERE e_id = 'wfs_conf' AND fkey_gui_id IN ('admin1', 'admin_de_services', 'admin_en_services');
+ALTER TABLE wfs_conf ADD COLUMN
+wfs_conf_type int4 NOT NULL DEFAULT 0;
+-- new wfs conf columns
+ALTER TABLE wfs_conf_element ADD COLUMN
+f_helptext text;
+f_category_name varchar(255) NOT NULL DEFAULT '';
More information about the Mapbender_commits
