[Mapbender-commits] r4018 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jun 12 09:15:37 EDT 2009
Author: astrid_emde
Date: 2009-06-12 09:15:37 -0400 (Fri, 12 Jun 2009)
New Revision: 4018
Removed:
   trunk/mapbender/conf/mapbender.conf
beck checked in mapbender.conf: I deleted it again
Deleted: trunk/mapbender/conf/mapbender.conf
--- trunk/mapbender/conf/mapbender.conf	2009-06-12 12:03:19 UTC (rev 4017)
+++ trunk/mapbender/conf/mapbender.conf	2009-06-12 13:15:37 UTC (rev 4018)
@@ -1,166 +0,0 @@
-<?php
-# $Id: mapbender.conf-dist 3843 2009-03-30 07:24:14Z astrid_emde $
-# http://www.mapbender.org/index.php/Mapbender.conf
-# Copyright (C) 2002 CCGIS
-# type of mapbender database
-#define("SYS_DBTYPE", "mysql");
-define("SYS_DBTYPE", "pgsql");
-# database information
-if(SYS_DBTYPE=="mysql")
-	define("DBSERVER", "<HOST>");
-	define("PORT", "3306");
-	define("DB", "<database>");
-	define("OWNER", "<owner>");
-	define("PW", "<password>");
-	# database with geos functions
-	define("GEOS_DBSERVER", "<HOST>");
-	define("GEOS_PORT", "5432");
-	define("GEOS_DB", "<database with geos functions>");
-	define("GEOS_OWNER", "<owner>");
-	define("GEOS_PW", "<password>");
-else {
-	define("DBSERVER", "localhost");
-	define("PORT", "5432");
-	define("DB", "mapbender_trunk");
-	define("OWNER", "postgres");
-	define("PW", "postgres");
-# prepared statements (PHP > 5.1.x, PostgreSQL > 7.4)
-define("PREPAREDSTATEMENTS",true);
-# encoding - default characterset UTF-8 / ISO-8859-1
-define("CHARSET","UTF-8");
-# error_reporting
-//ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
-# directory for temporary files
-define("TMPDIR", "../tmp");
-# URL to login
-define("LOGIN", "http://localhost/aptana/mapbender_trunk/http/frames/login.php");
-define("MAXLOGIN", 100);
-$login = LOGIN;
-# URL to owsproxy
-# (no terminating slash)
-define("OWSPROXY", "http://<ip or name>/owsproxy");
-# type of server-connection
-# curl, socket, http
-#define("CONNECTION", "curl");
-define("CONNECTION", "http");
-#define("CONNECTION", "socket");
-define("CONNECTION_PROXY", "<ip>");
-define("CONNECTION_PORT", "<port>");
-define("CONNECTION_USER", "<user>");
-define("CONNECTION_PASSWORD", "<password>");
-# HOSTs not for Proxy (curl)
-define("NOT_PROXY_HOSTS", "<ip>,<ip>,<ip>");
-# security: path to modules
-define("CHECK", false);
-# enable/disable portal
-define("PORTAL", false);
-# mail settings for internal mapbender mails
-# smtp mailing
-# for further settings check 'class_administration.php'
-# please check phpmailer for more information
-define("USE_PHP_MAILING", "false");
-define("MAILHOST", "<host>");
-define("MAILUSERNAME", "<user>");
-define("MAILPASSWORD", "<password>");
-define("MAILADMIN", "<mailaddress of the mailadmin>");
-define("MAILADMINNAME", "<mailadminname>");
-$mailHost = MAILHOST;
-$mailUsername =  MAILUSERNAME;
-$mailPassword =  MAILPASSWORD;
-# wms monitoring
-define("AUTO_UPDATE", "0");
-define("TIME_LIMIT", "300");
-define("PHP_PATH", "/usr/local/bin/");
-# Mapbender error logging
-define("LOG_LEVEL", "error"); //"off","error","warning","notice" or "all"
-define("LOG_JS", "on"); // "on", "alert", "console" or "off"
-# Internationalization
-define("USE_I18N", false);  // requires gettext for PHP.
-							// If "false", LANGUAGE is set to english
-define("LANGUAGE", "en");   // only available if USE_I18N is "true".
-							// "en", "de", "bg", "gr", "nl", "hu", "it", "es","fr","pt"
-###HACK for GLOBALS
-$DBSERVER=DBSERVER;
-  $DB=DB;
-  $OWNER=OWNER;
-  $PW=PW;
-  $GEOS_DBSERVER=GEOS_DBSERVER;
-  $GEOS_DB=GEOS_DB;
-  $GEOS_PORT =GEOS_PORT;
-  $GEOS_OWNER=GEOS_OWNER;
-  $GEOS_PW=GEOS_PW;
More information about the Mapbender_commits mailing list
