[Mapbender-commits] r4042 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Jun 18 05:49:42 EDT 2009
Author: verenadiewald
Date: 2009-06-18 05:49:42 -0400 (Thu, 18 Jun 2009)
New Revision: 4042
Removed:
trunk/mapbender/http/javascripts/mod_digitize_tab_category.php
removed mod_digitize_tab_category.php (all category functionality is included into mod_digitize_tab.php)
Deleted: trunk/mapbender/http/javascripts/mod_digitize_tab_category.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab_category.php 2009-06-18 09:43:14 UTC (rev 4041)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab_category.php 2009-06-18 09:49:42 UTC (rev 4042)
@@ -1,2206 +0,0 @@
-<?php
-# $Id: mod_digitize_tab.php 3939 2009-05-12 19:43:45Z marc $
-# http://www.mapbender.org/index.php/mod_digitize_tab.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-$e_target = $_GET["e_target"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Digitize</title>
-<?php
-$digitize_conf_filename = "digitize_default.conf";
-include '../include/dyn_css.php';
-<script language='JavaScript'>
-// Returns a form with the elements of a selected WFS grouped in tabs
-// (if the original WFS is the selected WFS, the values are set too)
-var initialTab = false;
-function buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex) {
- var featureTypeMismatch = false;
- if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
- var str = "";
- var hasGeometryColumn = false;
- var featureTypeArray = wfsConf[wfsConfIndex];
- var memberElements;
- var fid = false;
- if (!featureTypeMismatch) {
- memberElements = d.get(memberIndex).e;
- fid = memberElements.getElementValueByName('fid');
- if (typeof(featureTypeArray["element"]) !== "undefined") {
- featureTypeElementArray = featureTypeArray["element"];
- elementCategories.sort();
- str += "<form id='"+featureTypeElementFormId+"'>\n\t\n";
- initialTab = elementCategories[0];
- for(var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
- str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
- // 2. add rows to form
- for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
- var featureTypeElement = featureTypeElementArray[i];
- var elementName = featureTypeElement['element_name'];
- var elementType = featureTypeElement['element_type'];
- var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
- var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
- var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
- if(featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
- continue;
- str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
- str += '<table>';
- var elementLabelExists = (featureTypeElement['f_label'] != "");
- var elementLabel = "";
- if (elementLabelExists) {
- elementLabel = featureTypeElement['f_label'];
- var elementLabelStyle = featureTypeElement['f_label_id'];
- if (!isGeomColumn) {
- if (isEditable) {
- str += "\t\t<tr>\n";
- if(elementLabelExists) {
- str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
- str += "\t\t\t<td>\n";
- else {
- str += '<td colspan="2">';
- var elementValue = "";
- for (var j = 0 ; j < memberElements.count() ; j ++) {
- if (memberElements.getName(j) == featureTypeElement['element_name']) {
- elementValue = memberElements.getValue(j);
- var formElementHtml = featureTypeElement['f_form_element_html'];
- if (!formElementHtml) {
- mandatoryHint = '';
- var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
- str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
- str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
- str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
- else {
- while (formElementHtml.match(/\\/)) {
- formElementHtml = formElementHtml.replace(/\\/, "");
- var patternString = "<select";
- pattern = new RegExp(patternString);
- if (pattern.test(formElementHtml)) {
- formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
- var patternString = "hasdatepicker";
- formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
- var patternString = "<textarea";
- formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
- str += formElementHtml;
- if(featureTypeElement.f_helptext.length > 0) {
- str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../x_geoportal/img/help.png" width="16" height="16" alt="?" /></a> ';
- str += '<div id="helptext' +i+ '" class="helptext">';
- str += '<p>';
- str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
- str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
- str += '</p>';
- str += '</div>';
- str += "\t\t\t</td>\n\t\t</tr>\n";
- else {
- hasGeometryColumn = true;
- str += '</table>';
- str += '</div>';
- // 3. add buttons "save", "update", "delete"
- str += "<table>";
- var isTransactional = (featureTypeArray['wfs_transaction']);
- if (isTransactional) {
- var options = ["save", "update", "delete", "abort"];
- for (var i = 0 ; i < options.length ; i++) {
- var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
- onClickText += "if (result.isCorrect) {";
- onClickText += "window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
-// onClickText += "window.close();";
- onClickText += "}";
- onClickText += "else {";
- onClickText += "alert(result.errorMessage);this.disabled=false;"
- if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
- str += "\t\t\t<td><input type='button' name='saveButton' value='"+buttonLabelSaveGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\" /></td>\n";
- if (!featureTypeMismatch && fid) {
- if (options[i] == "update" && hasGeometryColumn) {
- str += "\t\t\t<td><input type='button' name='updateButton' value='"+buttonLabelUpdateGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\"/></td>\n";
- if (options[i] == "delete"){
- var deleteOnClickText = "var deltrans = confirm('"+messageConfirmDeleteGeomFromDb[selectedLanguage]+"');";
- deleteOnClickText += "if (deltrans){";
- deleteOnClickText += onClickText + "}";
- str += "\t\t\t<td><input type='button' name='deleteButton' value='"+buttonLabelDeleteGeometry[selectedLanguage]+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
- if (options[i] == "abort") {
- str += "\t\t\t<td><input type='button' name='abortButton' value='"+buttonLabelAbort[selectedLanguage]+"' onclick=\"window.close();\" /></td>\n";
- str += "\t\t</tr>\n";
- str += "\t</table>\n";
- str += "<input type='hidden' id='fid' value='"+fid+"'>";
-// str += "<input type='text' name='mb_wfs_conf'>";
- str += "</form>\n";
- return str;
-// Buttons
-function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
- buttonDig_id.push(id);
- buttonDig_on.push(isOn);
- buttonDig_src.push(src);
- buttonDig_title_off.push(titleOff);
- buttonDig_title_on.push(titleOn);
- buttonDig_x.push(x);
- buttonDig_y.push(y);
-function htmlspecialchars(p_string) {
- p_string = p_string.replace(/&/g, '&');
- p_string = p_string.replace(/</g, '<');
- p_string = p_string.replace(/>/g, '>');
- p_string = p_string.replace(/"/g, '"');
- // p_string = p_string.replace(/'/g, ''');
- return p_string;
-//default definition of image directory for digitize buttons, might
-//be overwritten with digitize conf data
-var buttonDig_imgdir = "../img/button_digitize/";
-var buttonDig_id = [];
-var buttonDig_on = [];
-var buttonDig_src = [];
-var buttonDig_title_off = [];
-var buttonDig_title_on = [];
-var buttonDig_x = [];
-var buttonDig_y = [];
-var mapWindow;
-var mapDomElement;
-var mapType = "";
-parent.eventInit.register(function () {
- var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
- mapDomElement = parent.mb_mapObj[mapIndex].getDomElement();
- mapType = mapDomElement.tagName.toUpperCase();
- if (mapType == "DIV") {
- mapWindow = parent.window;
- else if (mapType == "IFRAME") {
- mapWindow = mapDomElement.window;
- else {
- new parent.Mb_warning("Could not set CSS for map in digitizing module.");
-<?php
-echo "var mod_digitize_target = '".$e_target."';";
-$digitizeConfFilenameAndPath = dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename;
-if ($digitize_conf_filename && file_exists($digitizeConfFilenameAndPath)) {
- include($digitizeConfFilenameAndPath);
-var wfsWindow;
-var wfsConf = [];
-var d;
-var mod_digitize_width;
-var mod_digitize_height;
-var mod_digitizeEvent = false;
-var nonTransactionalHighlight;
-var button_point = "Point";
-var button_line = "Line";
-var button_polygon = "Polygon";
-var button_move = "dragBasePoint";
-var button_insert = "setBasePoint";
-var button_delete = "delBasePoint";
-var button_clear = "clear";
-var button_split = "digitizeSplit";
-var button_merge = "digitizeMerge";
-var button_difference = "digitizeDifference";
-var digitizeDivTag;
-var GeometryArray;
-var MultiGeometry = parent.MultiGeometry;
-var Geometry;
-var Point;
-var geomType;
-var msgObj;
-var featureTypeElementFormId = "featureTypeElementForm";
-try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
-try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
-try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
-function toggleTabs(tabId) {
- if(!initialTab) {
- return;
- var tabHeaders = wfsWindow.document.getElementsByTagName('a');
- var tabs = wfsWindow.document.getElementsByTagName('div');
- for(var i = 0; i < tabHeaders.length; i++) {
- if(tabHeaders[i].id.indexOf('tabheader') != -1) {
- tabHeaders[i].className = 'tabheader';
- for(var i = 0; i < tabs.length; i++) {
- if(tabs[i].className === 'tabcontent') {
- tabs[i].style.visibility = 'hidden';
- tabs[i].style.display = 'none';
- wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
- wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
- wfsWindow.document.getElementById('tab_' + tabId).style.display = 'block';
- return false;
-function showHelptext(helptextId) {
- hideHelptext();
- wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
- wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'block';
- return false;
-function hideHelptext(helptextId) {
- if(helptextId) {
- wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
- wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'none';
- var helptext = wfsWindow.document.getElementsByTagName('div');
- for(var i = 0; i < helptext.length; i++) {
- if(helptext[i].className === 'helptext') {
- helptext[i].style.visibility = 'hidden';
- helptext[i].style.display = 'none';
- return false;
-function getMousePosition(e) {
- parent.mb_getMousePos(e, mod_digitize_target);
- var currentPos = null;
- currentPos = new parent.Point(
- parent.clickX - parseInt(mapDomElement.style.left),
- parent.clickY - parseInt(mapDomElement.style.top)
- else {
- parent.clickX,
- parent.clickY
- return currentPos;
-function initializeDigitize () {
- d = new parent.GeometryArray();
- GeometryArray = parent.GeometryArray;
- Geometry = parent.Geometry;
- Point = parent.Point;
- geomType = parent.geomType;
- * Append geometries from KML when KML has been loaded
-function appendGeometryArrayFromKML () {
- try {
- parent.kmlHasLoaded.register(function(properties){
- d.importGeoJSON(properties);
-// d = parent.geoJsonToGeometryArray(properties);
- executeDigitizeSubFunctions();
- catch (e) {
- var exc = new parent.Mb_warning(e);
-// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
-function appendGeometryArray(obj) {
- executeDigitizePreFunctions();
- for (i=0; i<obj.count(); i++) {
- d.addCopy(obj.get(i));
-function mod_digitize_go(e){
- // ie workaround
- if (e == undefined) {
- e = mapWindow.event;
- if (e) {
- // track mouse position
- var currentPos = getMousePosition(e);
- s.check(currentPos);
- else {
-// s.clean();
- var el = mapDomElement;
- el.onmousedown = mod_digitize_start;
-function mod_digitize_timeout(){
- el.onmousedown = null;
- el.onmouseup = null;
- el.onmousemove = null;
-function mod_digitize_start(e){
- // check if a proper geometry is selected
- if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
- if (mod_digitizeEvent != false) {
- alert(msgObj.errorMessageNoGeometrySelected);
- return false;
- var realWorldPos;
- if (s.isSnapped()) {
- realWorldPos = s.getSnappedPoint();
- s.clean();
- else {
- realWorldPos = parent.mapToReal(mod_digitize_target,currentPos);
- if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
- // close the polygon
- d.close();
- parent.mb_disableThisButton(button_polygon);
- return true;
- else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
- // close the line
- d.close();
- parent.mb_disableThisButton(button_line);
- return true;
- else {
- // set the calculated real world position as point of the geometry
- d.getGeometry(-1,-1).addPoint(realWorldPos);
- d.getGeometry(-1,-1).setEpsg(parent.mb_mapObj[mapIndex].epsg);
- if(d.get(-1).geomType == parent.geomType.point){
- d.close();
- parent.mb_disableThisButton(button_point);
- return true;
- // add first point of polygon to snapping list (if three points have been inserted).
- else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
- s.add(d.getPoint(-1, -1, 0));
- // add last point of line to snapping list (if at least two points have been inserted).
- else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
- if (mod_digitizeEvent != button_move) {
- s.store(d);
- s.add(d.getPoint(-1, -1, -1));
- return true;
-// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
-var basepointObject = false;
-var basepointMemberIndex = null;
-var basepointGeometryIndex = null;
-var basepointRingIndex = null;
-var basepointPointIndex = null;
-var basepointDragActive = false;
-function handleBasepoint(obj,memberIndex, geometryIndex, ringIndex, pointIndex){
- if (!(
- mod_digitizeEvent == button_move ||
- mod_digitizeEvent == button_insert ||
- mod_digitizeEvent == button_delete)
- return false;
- basepointObject = obj;
- basepointMemberIndex = memberIndex;
- basepointGeometryIndex = geometryIndex;
- if (pointIndex == undefined) {
- pointIndex = ringIndex;
- basepointRingIndex = undefined;
- else {
- basepointRingIndex = ringIndex;
- basepointPointIndex = pointIndex;
- if(mod_digitizeEvent == button_move){
- mod_digitize_timeout();
- basepointObject.style.cursor = 'move';
- basepointObject.onmousedown = parent.frames[mod_digitize_elName].selectBasepoint;
- if(mod_digitizeEvent == button_delete){
- basepointObject.style.cursor = 'crosshair';
- basepointObject.onmousedown = parent.frames[mod_digitize_elName].deleteBasepoint;
-function convertLinepointToBasepoint(obj, memberIndex, geomIndex, ringIndex, pointIndex){
- if(!(mod_digitizeEvent == button_insert)){ return false; }
- if(mod_digitizeEvent == button_insert){
- obj.style.cursor = 'crosshair';
- obj.onclick = insertBasepoint;
- basepointGeometryIndex = geomIndex;
-function insertBasepoint(e){
- var i = basepointMemberIndex;
- var j = basepointGeometryIndex;
- var k = basepointRingIndex;
- var l = basepointPointIndex;
- var ind = parent.getMapObjIndexByName(mod_digitize_target);
- var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(currentPos.x, currentPos.y));
- if (k == undefined) {
- d.getGeometry(i,j).addPointAtIndex(p, l);
- else {
- d.getGeometry(i,j).innerRings.get(k).addPointAtIndex(p, l);
-function deleteBasepoint(){
- if (k != undefined) {
- d.delAllPointsLike(d.getPoint(i, j, k, l));
- else {
- d.delAllPointsLike(d.getPoint(i, j, l));
-function selectBasepoint(e){
- if(!basepointDragActive && mod_digitizeEvent == button_move){
- basepointDragActive = true;
- s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
- // replace basepoint by transparent blob
- basepointObject.style.width = mod_digitize_width;
- basepointObject.style.height = mod_digitize_height;
- basepointObject.style.left = 0;
- basepointObject.style.top = 0;
- if (parent.ie) {
- // ie cannot handle backgroundColor = 'transparent'
- basepointObject.style.background = "url(../img/transparent.gif)";
- else{
- basepointObject.style.backgroundColor = 'transparent';
- basepointObject.onmouseup = releaseBasepoint;
- basepointObject.onmousemove = dragBasepoint;
-function dragBasepoint(e){
- if(basepointDragActive){
- var res = s.check(currentPos);
-function updateAllPointsOfNonTransactionalLike(oldP, newP){
- for (var i = 0; i < d.count(); i++) {
- if (isTransactional(d.get(i))) {
- d.get(i).updateAllPointsLike(oldP, newP);
-function releaseBasepoint(e){
- basepointDragActive = false;
- var basepointDragEnd = currentPos;
- basepointObject.onmousedown = null;
- var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(basepointDragEnd.x, basepointDragEnd.y));
- var oldPoint;
- oldPoint = parent.cloneObject(d.getPoint(i,j,l));
- else {
- oldPoint = parent.cloneObject(d.getPoint(i,j,k,l));
- var snappedPoint = parent.cloneObject(s.getSnappedPoint());
- if (!nonTransactionalEditable) {
- updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
- else {
- d.updateAllPointsLike(oldPoint, snappedPoint);
- s.clean();
- else {
- updateAllPointsOfNonTransactionalLike(oldPoint, p);
- else {
- d.updateAllPointsLike(oldPoint, p);
- basepointMemberIndex = null;
- basepointGeometryIndex = null;
- basepointPointIndex = null;
-// --- basepoint handling (end) -----------------------------------------------------------------------------------------
-// --- registered functions (begin) ---------------------------------------------------------------------------------------
-function registerDigitizePreFunctions(stringFunction){
- mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
-function registerDigitizeSubFunctions(stringFunction){
- mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
-function executeDigitizeSubFunctions(){
- for(var i=0; i<mod_digitizeSubFunctions.length; i++){
- eval(mod_digitizeSubFunctions[i]);
-function executeDigitizePreFunctions(){
- for(var i=0; i<mod_digitizePreFunctions.length; i++){
- eval(mod_digitizePreFunctions[i]);
-function registerFunctions(){
- mod_digitizePreFunctions = [];
- mod_digitizeSubFunctions = [];
- registerDigitizePreFunctions("updateExtent()");
- registerDigitizePreFunctions("drawDashedLine()");
- registerDigitizeSubFunctions("updateListOfGeometries()");
- registerDigitizeSubFunctions("drawDashedLine()");
- parent.eventInit.register(function () {
- initializeDigitize();
- setStyleForTargetFrame();
- checkDigitizeTag();
- initialiseSnapping();
-// appendGeometryArrayFromKML();
- initialiseHighlight();
- initialiseMeasure();
- getMessages();
- parent.eventLocalize.register(function() {
- getMessages();
- parent.eventAfterMapRequest.register(function () {
- updateExtent();
- parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
-function checkDigitizeTag(){
- var digitizeTagName = "digitizeDiv";
- var digitizeTagStyle;
- digitizeTagStyle = {"z-index":digitizeTransactionalZIndex, "font-size":"10px"};
- digitizeDivTag = new parent.DivTag(digitizeTagName, "", digitizeTagStyle, mapDomElement);
- else {
- digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
- digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
- parent.mb_registerPanSubElement(digitizeTagName);
- parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
-function setStyleForTargetFrame(){
- var cssLink = mapWindow.document.createElement("link");
- var cssHead = mapWindow.document.getElementsByTagName("head")[0];
- cssLink.setAttribute("href", cssUrl);
- cssLink.setAttribute("type", "text/css");
- cssLink.setAttribute("rel", "stylesheet");
- cssHead.appendChild(cssLink);
-function initialiseSnapping(){
- s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
-function initialiseHighlight(){
- nonTransactionalHighlight = new parent.Highlight([mod_digitize_target], "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
-function initialiseMeasure(){
- measureDivTag = new parent.DivTag(measureTagName, "", measureTagStyle);
- else {
- measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
- parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
-// --- registered functions (end) -----------------------------------------------------------------------------------------
-function updateMeasureTag () {
- if (d.count() > 0 ) {
- if (d.get(-1).count() > 0) {
- if (d.getGeometry(-1, -1).count() > 0) {
- if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
- var measureString = "";
- measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
- measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
- measureDivTag.write(measureString);
- return true;
- measureDivTag.clean();
-// --- button handling (begin) --------------------------------------------------------------------------------------------
-function displayButtons(){
- for (var i = 0 ; i < buttonDig_id.length ; i ++) {
- if (parseInt(buttonDig_on[i])==1) {
- var divTag = document.createElement("div");
- divTag.setAttribute("id", "div_" + buttonDig_id[i]);
-// FIREFOX
- document.getElementById("digButtons").appendChild(divTag);
-//IE WORKAROUND, WORKS ALSO FOR FIREFOX
- var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
- parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
-function updateButtons() {
- var currentButton = document.getElementById(buttonDig_id[i]);
- var currentStatus = buttonDig_id[i].status;
- var currentTitle = "";
- switch (buttonDig_id[i]) {
- case "Point":
- if (currentStatus == 1) {
- currentTitle = msgObj.buttonLabelPointOn;
- else {
- currentTitle = msgObj.buttonLabelPointOff;
- break;
- case "Line":
- currentTitle = msgObj.buttonLabelLineOn;
- else {
- currentTitle = msgObj.buttonLabelLineOff;
- break;
- case "Polygon":
- currentTitle = msgObj.buttonLabelPolygonOn;
- else {
- currentTitle = msgObj.buttonLabelPolygonOff;
- break;
- case "dragBasePoint":
- currentTitle = msgObj.buttonLabelMoveBasepointOn;
- else {
- currentTitle = msgObj.buttonLabelMoveBasepointOff;
- break;
- case "setBasePoint":
- currentTitle = msgObj.buttonLabelInsertBasepointOn;
- else {
- currentTitle = msgObj.buttonLabelInsertBasepointOff;
- break;
- case "delBasePoint":
- currentTitle = msgObj.buttonLabelDeleteBasepointOn;
- else {
- currentTitle = msgObj.buttonLabelDeleteBasepointOff;
- break;
- case "clear":
- currentTitle = msgObj.buttonLabelClearListOn;
- else {
- currentTitle = msgObj.buttonLabelClearListOff;
- break;
- case "digitizeSplit":
- currentTitle = msgObj.buttonLabelSplitOn;
- else {
- currentTitle = msgObj.buttonLabelSplitOff;
- break;
- case "digitizeMerge":
- currentTitle = msgObj.buttonLabelMergeOn;
- else {
- currentTitle = msgObj.buttonLabelMergeOff;
- break;
- case "digitizeDifference":
- currentTitle = msgObj.buttonLabelDifferenceOn;
- else {
- currentTitle = msgObj.buttonLabelDifferenceOff;
- break;
- currentButton.title = currentTitle;
-function initDigButton(ind, pos){
- parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
- parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
- parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
- parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
- parent.mb_button[ind].title_on = buttonDig_title_on[pos];
- parent.mb_button[ind].title_off = buttonDig_title_off[pos];
- parent.mb_button[ind].status = 0;
- parent.mb_button[ind].elName = buttonDig_id[pos];
- parent.mb_button[ind].fName = "";
- parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
- parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
-function digitizeEnable(obj) {
- if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
- mod_digitizeEvent = obj.id;
- else if (obj.id == button_point || obj.id == button_line ||
- obj.id == button_polygon || obj.id == button_clear ||
- obj.id == button_split || obj.id == button_merge ||
- obj.id == button_difference){
- el.onmousemove = mod_digitize_go;
- if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
- s.store(d);
- obj.title = obj.title_on;
- if (obj.id == button_point) {
- if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
- if (d.get(-1).geomType != parent.geomType.point) {
- d.close();
- else {
- if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
- d.addMember(parent.geomType.point);
- d.get(-1).addGeometry();
- else {
-// delete existing line or polygon
- d.del(-1);
- else if (obj.id == button_polygon) {
- if (d.get(-1).geomType != parent.geomType.polygon) {
- d.close();
- else {
- // new geometry
- d.addMember(parent.geomType.polygon);
- else {
-// continue a line as a polygon
- var geometryTemplate = parent.cloneObject(d.get(-1));
- d.del(-1);
- for (var i = 0; i < geometryTemplate.count(); i++) {
- for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
- d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
- else if (obj.id == button_line) {
- if (d.get(-1).geomType != parent.geomType.line) {
- d.close();
- else {
- d.addMember(parent.geomType.line);
- else {
-// continue a polygon as a line
- d.del(-1);
- else if (obj.id == button_clear) {
- var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
- if (clear) {
- parent.mb_disableThisButton(button_clear);
- else if (obj.id == button_merge) {
- var applicable = (d.count() > 1);
- var polygonTextArray = [];
- if (d.get(i).geomType != parent.geomType.polygon) {
- applicable = false;
- polygonTextArray = [];
- break;
- polygonTextArray.push(d.get(i).toText());
- if (!applicable) {
- alert(msgObj.messageErrorMergeNotApplicable);
- parent.mb_disableThisButton(button_merge);
- return false;
- parent.mb_ajax_post("../php/mod_digitize_mergePolygon.php", {polygons: polygonTextArray.join(";")}, function(json, status) {
- var response = eval('(' + json + ')');
- var polygon = response.polygon;
- d.importGeometryFromText(polygon, parent.mb_mapObj[mapIndex].epsg);
- // remove the original polygons
- var len = d.count();
- for (var i = 0; i < len-1; i++) {
- d.del(0);
- else if (obj.id == button_split) {
- var applicable = (d.count() == 2) &&
- (d.get(0).geomType == parent.geomType.polygon) &&
- (d.get(1).geomType == parent.geomType.line);
- alert(msgObj.messageErrorSplitNotApplicable);
- parent.mb_disableThisButton(button_split);
- return false;
- var polygonText = d.get(0).toText();
- var lineText = d.get(1).toText();
- parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
- var polygonArray = response.polygons;
- var wfsConfId = d.get(0).wfs_conf;
- for (var i in polygonArray) {
- d.importGeometryFromText(polygonArray[i], parent.mb_mapObj[mapIndex].epsg);
- d.get(-1).wfs_conf = wfsConfId;
- // remove the original polygon and the temporary line
- d.del(0);
- d.del(0);
- else if (obj.id == button_difference) {
- (d.get(1).geomType == parent.geomType.polygon);
- alert(msgObj.messageErrorDifferenceNotApplicable);
- parent.mb_disableThisButton(button_difference);
- return false;
- var polygon1Text = d.get(0).toText();
- var polygon2Text = d.get(1).toText();
- parent.mb_ajax_post("../php/mod_digitize_differencePolygon.php", {polygon1: polygon1Text, polygon2: polygon2Text}, function(json, status) {
- var wfsProperties = d.get(0).e;
- d.get(-1).e = wfsProperties;
- // remove the original and the temporary polygon
- d.del(0);
- d.del(0);
-function digitizeDisable(obj) {
- if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
- obj.title = obj.title_off;
- if (d.get(-1).get(-1).count() == 0) {
- d.delGeometry(-1,-1);
- mod_digitizeEvent = false;
-// --- button handling (end) ----------------------------------------------------------------------------------------------
-// --- display (begin) -----------------------------------------------------------------------------------------
-function updateExtent() {
- var anInd = parent.getMapObjIndexByName(mod_digitize_target);
- var change = false;
- if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
- mod_digitize_width = parent.mb_mapObj[anInd].width;
- change = true;
- if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
- mod_digitize_height = parent.mb_mapObj[anInd].height;
- change = true;
- if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
- mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
- change = true;
-// if (change) {
-// drawDashedLine();
-function drawDashedLine(){
- nonTransactionalHighlight.clean();
- var smP = "";
- smP += "<div class='t_img'>";
- smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
- smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
- var smPArray = [];
- smPArray[smPArray.length] = "<div class='t_img'>"
- + "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
- + "<div class='t_img'>"
- + "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
- var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
- var width = mapObj.width;
- var height = mapObj.height;
- var arrayBBox = mapObj.extent.split(",")
- var minX = parseFloat(arrayBBox[0]);
- var minY = parseFloat(arrayBBox[1]);
- var maxX = parseFloat(arrayBBox[2]);
- var maxY = parseFloat(arrayBBox[3]);
- var cx = width/(maxX - minX);
- var cy = height/(maxY - minY);
- var isMoveOrInsertOrDelete = mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete;
- var minDist = 6;
- for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
- var currentGeomArray = d.get(i);
- if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
- nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
- else {
- for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
- var currentGeometry = d.getGeometry(i,j);
- var isPolygon = currentGeomArray.geomType == parent.geomType.polygon;
- var isLine = currentGeomArray.geomType == parent.geomType.line;
- var isComplete = currentGeometry.isComplete();
- var lastPaintedPoint = false;
- for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
- var currentPoint = currentGeometry.get(k);
- var currentPointMap = new Point(Math.round((currentPoint.x - minX)*cx), Math.round((maxY - currentPoint.y)*cy));
-// var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
-// if (!isTooCloseToPrevious) {
- var currentPointIsVisible = currentPointMap.x > 0 && currentPointMap.x < width && currentPointMap.y > 0 && currentPointMap.y < height;
- if (currentPointIsVisible) {
- if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint-1 && isLine))) {
- smPArray[smPArray.length] = "<div class='bp' style='top:"+
- (currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+
- digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
- else {
- smPArray[smPArray.length] = "<div class='bp' style='top:"+(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
- if(k==0 && isPolygon && !isComplete){
- smPArray[smPArray.length] = " title='"+msgObj.closePolygon_title+"' ";
- if(isMoveOrInsertOrDelete) {
- smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
- smPArray[smPArray.length] = "></div>";
- lastPaintedPoint = currentPointMap;
- if (k > 0) {
- points = parent.calculateVisibleDash(currentPointMap, previousPointMap, width, height);
- if (points != false) {
- smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
- var previousPointMap = currentPointMap;
- if (isPolygon && currentGeometry.innerRings.count() > 0) {
- // draw inner rings
- for (var l = 0, lenRings = currentGeometry.innerRings.count(); l < lenRings; l++) {
- var currentRing = currentGeometry.innerRings.get(l);
- for (var m = 0, lenPoint = currentRing.count(); m < lenPoint; m++) {
- var currentPoint = currentRing.get(m);
- var currentPointMap = new Point(Math.round((currentPoint.x - minX) * cx), Math.round((maxY - currentPoint.y) * cy));
- // var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
- // if (!isTooCloseToPrevious) {
- if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint - 1 && isLine))) {
- smPArray[smPArray.length] = "<div class='bp' style='top:" +
- (currentPointMap.y - 2) +
- "px;left:" +
- (currentPointMap.x - 2) +
- "px;z-index:" +
- digitizeTransactionalZIndex +
- ";background-color:" +
- linepointColor +
- else {
- smPArray[smPArray.length] = "<div class='bp' style='top:" + (currentPointMap.y - 2) + "px;left:" + (currentPointMap.x - 2) + "px;z-index:" + digitizeTransactionalZIndex + ";'";
- if (m == 0 && isPolygon && !isComplete) {
- smPArray[smPArray.length] = " title='" + msgObj.closePolygon_title + "' ";
- if (isMoveOrInsertOrDelete) {
- smPArray[smPArray.length] = " onmouseover='parent.window.frames[\"" + mod_digitize_elName + "\"].handleBasepoint(this," + i + "," + j + "," + l + "," + m + ")' ;";
- if (m > 0) {
- smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, l, m);
- digitizeDivTag.write(smPArray.join(""));
-function evaluateDashes(start, end, memberIndex, geomIndex, ringIndex, pointIndex){
- ringIndex = undefined;
- var strArray = [];
- var delta = new parent.Point(end.x - start.x, end.y - start.y);
- var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
- var vecLength = start.dist(end);
- var n = Math.round(vecLength/dotDistance);
- if (n > 0) {
- var step = delta.dividedBy(n);
- for(var i=1; i < n; i++){
- var x = Math.round(start.x + i * step.x) - 2;
- var y = Math.round(start.y + i * step.y) - 2;
- if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
- if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
- strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
- else {
- strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
- if(mod_digitizeEvent == button_insert) {
- strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+ringIndex+","+pointIndex+")'";
- strArray[strArray.length] = "></div>";
- return strArray.join("");
-function isTransactional(geom) {
-// alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
- if (typeof(geom.wfs_conf) == 'number') {
- if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
- var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
- if (isTransactionalGeom) {
- return true;
- else{
- return false;
- else if (typeof(geom.wfs_conf) == 'undefined') {
- return true;
-function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
- return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
-function getName (geom) {
- wfsConfId = geom.wfs_conf;
- wfsConf = parent.get_complete_wfs_conf();
- if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
- var resultName = "";
- for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
- if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
- resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
- if (resultName == "") {
- resultName = wfsConf[wfsConfId]['g_label'];
- return resultName;
- else if (geom.e.getElementValueByName("name")) {
- return geom.e.getElementValueByName("name");
- else {
- return msgObj.digitizeDefaultGeometryName;
-function updateListOfGeometries(){
- var listOfGeom = "<ul>";
- if (d.count() > 0) {
- for (var i = 0 ; i < d.count(); i ++) {
- if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
- // for the geometries from a kml, there is another save dialogue
- if (d.get(i).isFromKml()) {
- // if the kml is in the db (id = id in database)
- if (d.get(i).e.getElementValueByName("Mapbender:id")) {
- // button: geometry information, update kml
- listOfGeom += "<li>";
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>";
- else {
- // button: geometry information, save, update, delete
- if (wfsExistsForGeom(d.get(i), wfsConf)) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>";
- // button: remove this geometry
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>";
- // button clone this geometry
- if (addCloneGeometryButton === true) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_clone_src+"' title='"+msgObj.buttonDig_clone_title+"' onclick='d.addCopy(d.get("+i+"));d.get(-1).e.delElement(\"fid\");executeDigitizeSubFunctions();'>";
- // button: remove geometry from database
- if (d.get(i).e.getElementValueByName('fid')) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">";
- listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
- listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"),\""+geomHighlightColour+"\")' ";
- listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
- var geomName = getName(d.get(i));
- var currentGeomType;
- if (d.get(i).geomType == parent.geomType.polygon) {
- currentGeomType = msgObj.messageDescriptionPolygon;
- else if (d.get(i).geomType == parent.geomType.line) {
- currentGeomType = msgObj.messageDescriptionLine;
- else if (d.get(i).geomType == parent.geomType.point) {
- currentGeomType = msgObj.messageDescriptionPoint;
- var multi = "";
- if (d.get(i).count() > 1) {
- multi = "multi";
- listOfGeom += ">" + htmlspecialchars(geomName) +" (" + multi + currentGeomType + ")</div>";
- // multigeometries
- listOfGeom += "<ul>";
- for (var j = 0; j < d.get(i).count(); j++) {
- var currentGeom = d.get(i).get(j);
- if (d.get(i).count() > 1 || (d.get(i).geomType == geomType.polygon &&
- d.get(i).get(j).innerRings &&
- d.get(i).get(j).innerRings.count() > 0)) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").del(" + j + ");executeDigitizeSubFunctions();'>";
- listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
- listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\")' ";
- listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
- listOfGeom += ">" + currentGeomType + "#" + (j+1) +"</div></li>";
- if (d.get(i).geomType == geomType.polygon &&
- d.get(i).get(j).innerRings.count() > 0) {
- for (var k = 0; k < d.get(i).get(j).innerRings.count(); k++) {
- var currentRing = d.get(i).get(j).innerRings.get(k);
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").get(" + j + ").innerRings.del(" + k + ");executeDigitizeSubFunctions();'>";
- listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
- listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\")' ";
- listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
- listOfGeom += ">inner ring #" + (k+1) +"</div></li>";
- listOfGeom += "</ul>";
- listOfGeom += "</li>";
- parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
-// --- display (end) -----------------------------------------------------------------------------------------
-// --- wfs window (begin) -----------------------------------------------------------------------------------------
-// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
-function formCorrect(doc, formId) {
- var isCorrect = true;
- var errorMessage = "";
- var result;
- var form = doc.getElementById(formId);
- result = mandatoryFieldsNotEmpty(doc, form);
- isCorrect = isCorrect && result.isCorrect;
- errorMessage += result.errorMessage;
- //select box is now checked within function mandatoryFieldsNotEmpty
- //result = validBoxEntrySelected(form);
- //isCorrect = isCorrect && result.isCorrect;
- //errorMessage += result.errorMessage;
- result = dataTypeIsCorrect(doc, form);
- return {"isCorrect":isCorrect, "errorMessage":errorMessage};
-function validBoxEntrySelected(form){
- for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
- if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
- if (parseInt(form.childNodes[i].selectedIndex) == 0) {
- return {"isCorrect":false, "errorMessage":errorMessage};
- else if (form.childNodes[i].hasChildNodes()) {
- isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
- if (!isCorrect) {
- errorMessage = msgObj.messageSelectAnOption + "\n";
-function mandatoryFieldsNotEmpty(doc, node){
- nodeArray = doc.getElementsByName("mandatory");
- for (var i = 0; i < nodeArray.length && isCorrect; i++) {
- if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
- var nodeId = nodeArray[i].id.substr(10);
- if (nodeArray[i].value == "true") {
- if (doc.getElementById(nodeId).value == "") {
- isCorrect = false;
- errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
- if (nodeArray[i].nodeName.toUpperCase() == "SELECT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
-function isInteger(str) {
- if (str.match(/^\d*$/)) {
- return true;
- return false;
-function isFloat(str) {
- if (isInteger(str)) {
- return true;
- if (str.match(/^\d+\.\d+$/)) {
- return true;
- return false;
-function replaceCommaByDecimalPoint(str) {
- var patternString = ",";
- var pattern = new RegExp(patternString);
- while (str.match(pattern)) {
- str = str.replace(pattern, ".");
- return str;
-function dataTypeIsCorrect(doc, node){
- nodeArray = doc.getElementsByName("datatype");
- for (var i = 0; i < nodeArray.length ; i++) {
- if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
- var nodeId = nodeArray[i].id.substr(9);
- var nodeValue = doc.getElementById(nodeId).value;
- if (nodeArray[i].value == "int") {
- if (!isInteger(nodeValue)) {
- errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
- else if (nodeArray[i].value == "double") {
- nodeValue = replaceCommaByDecimalPoint(nodeValue);
- if (!isFloat(nodeValue)) {
- errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
- else {
- doc.getElementById(nodeId).value = nodeValue;
-// --- wfs window form check (end) -----------------------------------------------------------------------------------------
-function getAvailableWfsForGeom(geom, wfsConf) {
- var wfsConfIndices = [];
- for (var attr in wfsConf) {
- var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
- if (!isTrans) {
- continue;
- if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
- if (parseInt(geom.wfs_conf) == parseInt(attr)) {
- wfsConfIndices.push(attr);
- else {
- for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
- var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
- if (isGeomColumn) {
- var isMultiPolygon = (
- geom.geomType == parent.geomType.polygon &&
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiSurfacePropertyType'
- var isPolygon = (
- geom.count() == 1 &&
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'SurfacePropertyType'
- var isMultiLine = (
- geom.geomType == parent.geomType.line &&
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiCurvePropertyType'
- var isLine = (
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'CurvePropertyType'
- var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
-// alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
- if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
- return wfsConfIndices;
-function wfsExistsForGeom(geom, wfsConf) {
- wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
-// alert(wfsConfIndices.join(","));
- if (wfsConfIndices.length > 0) {
- return true;
- return false;
-function showWfsKml (geometryIndex) {
- wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
- wfsKmlWindow.document.open("text/html");
- wfsKmlWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
- wfsKmlWindow.document.close();
- str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
- var properties = d.get(geometryIndex).e;
- var propertyCount = properties.count();
- for (var i = 0; i < propertyCount; i++) {
- var key = properties.getName(i);
- var value = properties.getValue(i);
- var expr = /Mapbender:/;
- if (!key.match(expr)) {
- str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
- str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
- var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
- var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
- deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
- str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
-// delete button not yet implemented
-// str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
- str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
- wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
-// this method opens a new window and displays the attributes in wfs_conf
-function showWfs(geometryIndex) {
- wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
- wfsWindow.document.open("text/html");
- var str = "";
- var strStyle = "";
- var defaultIndex = -1;
- str += "<form id='wfs'>\n";
- // 1. add select box
- var onChangeText = "document.getElementById('elementForm').innerHTML = ";
- onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
- onChangeText += "window.opener.setWfsWindowStyle(this.value);";
- str += "\t<select name='wfs' size='" + wfsConf.length + "'";
- str += " onChange=\""+ onChangeText +"\"";
- str += ">\n\t\t";
- var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
- var selected = false;
- for (var i = 0; i < wfsConfIndices.length ; i++) {
- str += "<option value='" + wfsConfIndices[i] + "'";
- if (!selected) {
- str += " selected";
- selected = true;
- defaultIndex = parseInt(wfsConfIndices[i]);
- str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
- str += "</option>\n\t\t";
- str += "</select>\n\t\t</form>\n\t";
- str += "<div id='elementForm'>\n</div>";
- if (defaultIndex != -1) {
- var htmlStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
- htmlStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
- htmlStr += '<style type="text/css">'
- htmlStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
- htmlStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
- htmlStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
- htmlStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
- htmlStr += 'div.helptext p { margin: 0 ; }';
- htmlStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
- htmlStr += 'a img { vertical-align: middle;border: 0; }';
- htmlStr += '</style>';
- htmlStr += '</head><body></body></html>';
-// wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
- wfsWindow.document.write(htmlStr);
- wfsWindow.document.write(str);
- wfsWindow.document.close();
- wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
- else {
- wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
-function setWfsWindowStyle(wfsConfIndex) {
- wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
-// returns a form with the elements of a selected wfs
-// (if the original wfs is the selected wfs, the values are set too)
-function buildElementForm(wfsConfIndex, memberIndex){
- var str = "";
- var fid = false;
- str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
- // Check if there are categories given and
- // build the form in tabs if necessary
- var elementCategories = ['abc','def','123'];
- for(var i = 0; i < featureTypeElementArray.length; i++){
- var categoryName = featureTypeElementArray[i].f_category_name;
- var categoryNameIsUnique = true;
- if(categoryName.length === 0) { continue; }
- for(var j = 0; j < elementCategories.length; j++) {
- if(elementCategories[j] == categoryName) {
- categoryNameIsUnique = false;
- if(categoryNameIsUnique) {
- elementCategories.push(categoryName);
- if(elementCategories.length > 0) {
- return buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex);
- for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
- if (isEditable) {
- if (!formElementHtml || !formElementHtml.match(/<select/)) {
- str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
- str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
- str += "\t\t\t\t<input id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
- else {
- // preselect the correct entry of the box
- var patternString = "option value( )*=( )*'"+elementValue+"'";
- var patternStringForReplace = "option value = '"+elementValue+"'";
- formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
- formElementHtml = formElementHtml.replace(/</g,'<');
- formElementHtml = formElementHtml.replace(/>/g,'>');
- formElementHtml = formElementHtml.replace(/'/g,'\'');
- str += '<p>';
- str += '</p>';
- str += '</div>';
- else {
- str += "</table><table>";
- var options = ["insert", "update", "delete", "abort"];
- if (options[i] == "insert" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
- str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
- str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
- var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
- str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
- str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
- return str;
-function dbGeom(type,m) {
- if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
- d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
- d.get(m).e = new parent.Wfs_element();
- else {
- var myconf = wfsConf[d.get(m).wfs_conf];
- var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
- var proceed = true;
- if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
- proceed = confirm(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs'] + ". Proceed?");
- if (proceed) {
- var fid = false;
- myform = wfsWindow.document.getElementById(featureTypeElementFormId);
- for (var i=0; i<myform.length; i++){
- if (myform.elements[i].id == "fid") {
- fid = myform.elements[i].value;
- if (fid == "false") {
- fid = false;
- else {
- d.get(m).e.setElement('fid', fid);
- else if (myform.elements[i].type == 'text' ){
- if (myform.elements[i].id) {
- var elementId = String(myform.elements[i].id).replace(/mb_digitize_form_/, "");
- d.get(m).e.setElement(elementId, myform.elements[i].value);
- else {
- errorMessage = msgObj.messageErrorFormEvaluation;
- // selectbox
- else if (typeof(myform.elements[i].selectedIndex) == 'number') {
- d.get(m).e.setElement(elementId, myform.elements[i].options[myform.elements[i].selectedIndex].value);
- else {
- else {
- fid = d.get(m).e.getElementValueByName('fid');
-// str = parent.get_wfs_str(myconf, d, m, type, fid);
- var geoJson = d.featureToString(m);
- "../extensions/geom2wfst.php",
- 'geoJson' : geoJson,
- 'method' : type,
- 'wfs_conf_id' : wfsConf[d.get(m).wfs_conf]['wfs_conf_id']
- function(json,status){
- var result = eval('('+json+')');
- var success = result.success;
- var fid = result.fid;
- wfsSubWrite(m, type, status, success, fid);
-function wfsSubWrite(m, type, status, success, fid) {
- if (status == "success" && success) {
- if (type == 'insert' && fid) {
- d.get(m).e.setElement("fid", fid);
- if (type == 'delete') {
- parent.mb_disableThisButton(mod_digitizeEvent);
- d.del(m);
- var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
- else {
- var wfsWriteMessage = msgObj.messageErrorWfsWrite;
- parent.mb_execWfsWriteSubFunctions();
- wfsWindow.alert(wfsWriteMessage);
- window.setTimeout("wfsWindow.close()",0);
- else {
- alert(wfsWriteMessage);
-function getMultiGeometryIdsByPlacemarkId (placemarkId) {
- var multiGeometryIdArray = [];
- var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
- if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
- multiGeometryIdArray.push(i);
- return multiGeometryIdArray;
-function updateKmlInDb (geometryIndex, command) {
- var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
- var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
- if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
- // update properties from form
- myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
- for (var i=0; i < myform.length; i++){
- if (myform.elements[i].type == 'text' ){
- var key = myform.elements[i].name;
- var value = myform.elements[i].value;
- // update all geometries with the same placemark id
- for (var j = 0; j < multiGeometryIdArray.length; j++) {
- var currentProperties = d.get(j).e;
- currentProperties.setElement(key, value);
- var kmlId = properties.getElementValueByName("Mapbender:id");
- parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
- if (obj === "1") {
- wfsKmlWindow.alert("KML updated.");
- var link = wfsKmlWindow.document.createElement("a");
- link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
- link.target = "_blank";
- link.innerHTML = "KML";
- wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
- wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
- else {
- wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
-function getMessages() {
- parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
- msgObj = obj;
- applyMessages();
-function applyMessages() {
- updateMeasureTag();
- updateListOfGeometries();
- updateButtons();
- </script>
- </head>
- <body onload="registerFunctions();displayButtons();">
- <div id='digButtons'></div>
- <div id='listOfGeometries' class='digitizeGeometryList'></div>
- </body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits
