[Mapbender-commits] r4047 -
branches/mifan_dev/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jun 18 23:56:26 EDT 2009
Author: mifan
Date: 2009-06-18 23:56:26 -0400 (Thu, 18 Jun 2009)
New Revision: 4047
Added:
branches/mifan_dev/mapbender/http/classes/class_csw.php
class to hold main Catalog element from DB and to DB
Added: branches/mifan_dev/mapbender/http/classes/class_csw.php
--- branches/mifan_dev/mapbender/http/classes/class_csw.php (rev 0)
+++ branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-06-19 03:56:26 UTC (rev 4047)
@@ -0,0 +1,55 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_wms
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_user.php");
+require_once(dirname(__FILE__)."/class_administration.php");
+ * CSW main class
+ * @author nazgul
+class csw{
+ var $title;
+ var $abstract;
+ var $fees;
+ var $accessconstraints;
+ var $contactperson;
+ var $contactposition;
+ var $contactorganization;
+ var $address;
+ var $city;
+ var $stateorprovince;
+ var $postcode;
+ var $country;
+ var $contactvoicetelephone;
+ var $contactfacsimiletelephone;
+ var $contactelectronicmailaddress;
+ var $catowner;
+ var $cattimestamp;
+ function csw(){
\ No newline at end of file
More information about the Mapbender_commits
