[Mapbender-commits] r4053 - branches/google_dev/http/print
svn_mapbender at osgeo.org
Fri Jun 19 10:52:11 EDT 2009
Author: christoph
Date: 2009-06-19 10:52:11 -0400 (Fri, 19 Jun 2009)
New Revision: 4053
branches/google_dev/http/print/mod_printPDF.php
branches/google_dev/http/print/mod_printPDF_pdf.php
Modified: branches/google_dev/http/print/mod_printPDF.php
--- branches/google_dev/http/print/mod_printPDF.php 2009-06-19 14:50:45 UTC (rev 4052)
+++ branches/google_dev/http/print/mod_printPDF.php 2009-06-19 14:52:11 UTC (rev 4053)
@@ -185,7 +185,7 @@
var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
var prevscale= pt.mb_getScale(target);
- pt.mb_mapObj[ind].extent = new Extent(
+ pt.mb_mapObj[ind].extent = new pt.Extent(
parseFloat(coord[0]),
parseFloat(pos[1]),
parseFloat(pos[0]),
@@ -311,6 +311,21 @@
document.forms['form1'].elements['measured_y_values'].value = tmp_y;
+ // google maps
+ try {
+ var map = pt.getMapObjByName(target);
+ if (typeof map.google !== "undefined") {
+ document.forms['form1'].elements['google_zoom'].value = map.google.map.get_zoom();
+ document.forms['form1'].elements['google_type'].value = map.google.map.get_mapTypeId();
+ document.forms['form1'].elements['google_key'].value = map.google.key;
+ document.forms['form1'].elements['google_center_lat'].value = map.google.map.get_center().lat();
+ document.forms['form1'].elements['google_center_lng'].value = map.google.map.get_center().lng();
+ catch (e) {
document.form1.submit();
else{
@@ -400,6 +415,11 @@
<input type="hidden" name="mylegend" value="true" >
<input type="hidden" name="measured_x_values" />
<input type="hidden" name="measured_y_values" />
+<input type="hidden" name="google_center_lat" />
+<input type="hidden" name="google_center_lng" />
+<input type="hidden" name="google_zoom" />
+<input type="hidden" name="google_key" />
+<input type="hidden" name="google_type" />
<p>
<input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
Modified: branches/google_dev/http/print/mod_printPDF_pdf.php
--- branches/google_dev/http/print/mod_printPDF_pdf.php 2009-06-19 14:50:45 UTC (rev 4052)
+++ branches/google_dev/http/print/mod_printPDF_pdf.php 2009-06-19 14:52:11 UTC (rev 4053)
@@ -319,6 +319,25 @@
$header_width = $a4l_header_width;
session_write_close();
+if ($_REQUEST["google_key"] && $_REQUEST["google_center_lat"] && $_REQUEST["google_center_lng"] &&
+ $_REQUEST["google_zoom"] && $_REQUEST["google_type"]) {
+ $google_map_width = $map_width;
+ $google_map_height = $map_height;
+ if ($factor > 1) {
+ $google_map_width *= 4;
+ $google_map_height *= 4;
+ $googleUrl = "http://maps.google.com/staticmap?center=" .
+ $_REQUEST["google_center_lat"] . "," .
+ $_REQUEST["google_center_lng"] . "&" .
+ "zoom=" . $_REQUEST["google_zoom"] . "&" .
+ "size=" . $google_map_width . "x" . $google_map_height . "&" .
+ "maptype=" . $_REQUEST["google_type"] . "&" .
+ "key=" . $_REQUEST["google_key"];
+// array_splice($array_urls, 0, 0, $googleUrl);
+ $array_urls[]= $googleUrl;
$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
More information about the Mapbender_commits
