[Mapbender-commits] r4061 - branches/kmq_dev/http/classes
svn_mapbender at osgeo.org
Fri Jun 19 16:47:58 EDT 2009
Author: kmq
Date: 2009-06-19 16:47:57 -0400 (Fri, 19 Jun 2009)
New Revision: 4061
branches/kmq_dev/http/classes/class_user.php
Started adding Methods to class Use
Modified: branches/kmq_dev/http/classes/class_user.php
--- branches/kmq_dev/http/classes/class_user.php 2009-06-19 15:41:40 UTC (rev 4060)
+++ branches/kmq_dev/http/classes/class_user.php 2009-06-19 20:47:57 UTC (rev 4061)
@@ -27,6 +27,25 @@
* @var Integer The user ID
var $id;
+ var $name;
+ var $password = ""; // passwords should be set, not read
+ var $owner; // make this reference to a USER object
+ var $descr;
+ var $loginCount;
+ var $email;
+ var $phone;
+ var $department;
+ var $resolution;
+ var $organization;
+ var $position;
+ var $phone1;
+ var $fax;
+ var $deliveryPoint;
+ var $city;
+ var $postalCode;
+ var $country;
+ var $url;
* Constructor
@@ -35,6 +54,8 @@
public function __construct ($userId) {
$this->id = $userId;
+ if($userId ) {$this->load();}
@@ -43,7 +64,129 @@
public function __toString () {
return (string) $this->id;
+ * @return JSON serialization of this user
+ public function toJSON()
+ $result = '{"name":"'. $this->name .'",'
+ .'"password":"'. $this->password .'",'
+ .'"owner":"'. $this->owner .'",'
+ .'"descr":"'. $this->descr .'",'
+ .'"loginCount":"'. $this->loginCount .'",'
+ .'"email":"'. $this->email .'",'
+ .'"phone":"'. $this->phone .'",'
+ .'"department":"'. $this->department .'",'
+ .'"resolution":"'. $this->resolution .'",'
+ .'"organization":"'.$this->organizatin .'",'
+ .'"position":"'. $this->position .'",'
+ .'"phone1":"'. $this->phone1 .'",'
+ .'"fax":"'. $this->fax .'",'
+ .'"deliveryPoint":"'. $this->deliveryPoint .'",'
+ .'"city":"'. $this->city .'",'
+ .'"postalCode":"'. $this->postalCode .'",'
+ .'"country":"'. $this->country .'",'
+ .'"url":"'. $this->url .'"}';
+ return $result;
+ public function create()
+ //FIXME: can users exist that have the same name? I think not, but the db does not enforce it
+ if($this->name == ""){ $e = new mb_exception("Can' t create user without name");}
+ $sql_user_create = "INSERT INTO mb_user (mb_user_name) VALUES ($1) ; ";
+ $v = array($this->name);
+ $t = array("s");
+ db_begin();
+ // $sql_user_prepared = db_prepare_query($sql_user_create,$v,$t);
+ $sql_user_prepared = "INSERT INTO mb_user (mb_user_name) VALUES ('". $this->name ."') ; ";
+ $result = db_query($sql_user_prepared);
+ if($result == false)
+ db_rollback();
+ $e = new mb_exception("Could not insert new user");
+ $commit_result = $this->commit();
+ if($commit_result == false)
+ try {
+ db_rollback();
+ catch(Exception $E)
+ print "cautght it";
+ $newE = new mb_exception("Could not set inital values of new user");
+ throw $newE;
+ db_commit();
+ public function commit()
+ //db_begin();
+ //db_commit();
+ public function remove()
+ $sql_user_remove = "DELETE FROM mb_user WHERE mb_user_id = $1";
+ $v = array($this->id);
+ $t = array("i");
+ $sql_prepared = db_prepare_query($sql_user_remove,$v,$t);
+ $result = db_query($sql_prepared);
+ $e = new mb_exception("Could not delete user");
+ return true;
+ public function load()
+ $sql_user = "SELECT * from mb_user WHERE mb_user_id = $1; ";
+ $t = array("i");
+ $res_user = db_prep_query($sql_user,$v,$t);
+ if($row = db_fetch_array($res_user)){
+ $this->name = $row['mb_user_name'];
+ $this->password = ""; // passwords should be set, not read
+ $this->owner = $row['mb_user_owner'];
+ $this->descr = $row['mb_user_description'];
+ $this->loginCount = $row['mb_user_login_count'];
+ $this->email = $row['mb_user_email'];
+ $this->phone = $row['mb_user_phone'];
+ $this->department = $row['mb_user_department'];
+ $this->resolution = $row['mb_user_resolution'];
+ $this->organization = $row['mb_user_organizationName'];
+ $this->position = $row['mb_user_position_name'];
+ $this->phone1 = $row['mb_user_phone1'];
+ $this->fax = $row['mb_user_facsimile'];
+ $this->deliveryPoint = $row['mb_user_delivery_point'];
+ $this->city = $row['mb_user_user_city'];
+ $this->postalCode = $row['mb_user_postal_code'];
+ $this->country = $row['mb_user_country'];
+ $this->url = $row['mb_user_online_resource'];
+ }else{
+ //no such user
+ echo "no such user";
+ return true;
* Returns an array of application IDs that the user is allowed to access.
More information about the Mapbender_commits
