[Mapbender-commits] r4070 -
branches/mifan_dev/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Jun 22 11:55:18 EDT 2009
Author: mifan
Date: 2009-06-22 11:55:17 -0400 (Mon, 22 Jun 2009)
New Revision: 4070
branches/mifan_dev/mapbender/http/classes/class_csw.php
xml parsing in cat class
Modified: branches/mifan_dev/mapbender/http/classes/class_csw.php
--- branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-06-22 13:58:26 UTC (rev 4069)
+++ branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-06-22 15:55:17 UTC (rev 4070)
@@ -39,6 +39,7 @@
var $cat_op_describerecord;
var $cat_getcapabilities_doc;
+ var $cat_upload_url;
var $fees;
var $accessconstraints;
var $contactperson;
@@ -58,6 +59,9 @@
var $catowner;
var $cattimestamp;
+ //store catalog retrieval status
+ var $cat_status;
function csw(){
@@ -80,6 +84,36 @@
//import connector
$x = new connector($url);
$data = $x->file;
+ if(!$data){
+ $this->cat_status = false;
+ return false;
+ else {
+ $this->wms_status = true;
+ //arrays to hold xml struct values and index
+ $value_array = null;
+ $index_array = null;
+ $this->cat_getcapabilities_doc = $data;
+ $this->cat_upload_url = $url;
+ $this->cat_id="";//Auto-assing catalog id
+ $parser = xml_parser_create("");
+ xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+ xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+ xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+ xml_parse_into_struct($parser,$data,$value_array,$index_array);
+ $code = xml_get_error_code($parser);
+ if ($code) {
+ $line = xml_get_current_line_number($parser);
+ $mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
+ xml_parser_free($parser);
@@ -99,7 +133,9 @@
public function setCatObjToDB($gui)
+ global $con;
+ db_begin();
+ $sql = "INSERT INTO cat ()"
More information about the Mapbender_commits
