[Mapbender-commits] r4074 - branches/2.6/resources/db
svn_mapbender at osgeo.org
Mon Jun 22 13:15:22 EDT 2009
Author: astrid_emde
Date: 2009-06-22 13:15:22 -0400 (Mon, 22 Jun 2009)
New Revision: 4074
Added:
branches/2.6/resources/db/install_2.6.sh
Removed:
branches/2.6/resources/db/install_2.6rc1.sh
Installation of Mapbender via shell-Script
Copied: branches/2.6/resources/db/install_2.6.sh (from rev 4072, branches/2.6/resources/db/install_2.6rc1.sh)
--- branches/2.6/resources/db/install_2.6.sh (rev 0)
+++ branches/2.6/resources/db/install_2.6.sh 2009-06-22 17:15:22 UTC (rev 4074)
@@ -0,0 +1,188 @@
+#!/bin/bash
+rm log_*.txt
+# Disclaimer
+echo ""
+echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
+echo "The script will create a database for you and will import the Mapbender datat to the new database"
+echo "It will also compile the Mapbender.mo files"
+echo ""
+echo "To run this script you have to set the following options"
+echo " * set the right to execute on this install script"
+echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
+echo " * write access to mapbender/log"
+echo " * write access to mapbender/http/tmp"
+echo " * write access to mapbender/resources/locale/ and subdirectories"
+echo " * provide a database user that can create a database"
+echo ""
+echo ""
+echo "If everything is prepared you can continue."
+echo ""
+echo "Continue? (y)es or (n)o"
+read disclaimer
+if test $disclaimer != "y"
+then
+ exit 1
+fi
+# ask for db version
+echo ""
+echo "Database version? (p)ostgresql or (m)ysql?"
+read dbversion
+if test $dbversion != "p" -a $dbversion != "m"
+then
+ echo ""
+ echo "Incorrect database type. Terminating the script..."
+ exit 1
+fi
+# ask for db character encoding-U $dbuser
+echo ""
+echo "Database character encoding? (i)so-8859-1 or (u)tf-8?"
+read dbenc
+if test $dbenc != "i" -a $dbenc != "u"
+then
+ echo ""
+ echo "Incorrect database character encoding. Terminating the script..."
+ exit 1
+fi
+# ask for database name
+echo ""
+echo "Name of database?"
+read dbname
+if test $dbversion = "m"
+then
+ echo "Not available!!!"
+ exit 1
+ echo ""
+ echo "Enter your MySQL password:"
+ stty -echo
+ read password
+ stty echo
+ echo ""
+ if test $dbenc = "i"
+ then
+ echo ""
+ echo "Installing Mapbender with MySQL (ISO-8859-1) in database $dbname";
+ echo ""
+ mysql -e "create database $dbname CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$password
+ mysql $dbname -p$password < mysql/mysql_schema_2.5.sql > log_schema.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/mysql_data_2.5.sql > log_data.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql > log_update.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql > log_update.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql > log_update.txt
+ elif test $dbenc = "u"
+ then
+ echo ""
+ echo "Installing Mapbender with MySQL (UTF-8) in database $dbname";
+ echo ""
+ mysql -e "create database $dbname CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$password
+ mysql $dbname -p$password < mysql/UTF-8/mysql_data_2.5.sql > log_data.txt
+ mysql $dbname -p$password < mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql > log_update.txt
+ mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql > log_update.txt
+ mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql > log_update.txt
+ fi
+elif test $dbversion = "p" -a $dbenc = "i"
+then
+ echo ""
+ echo "Installing Mapbender with PostgreSQL (ISO-8859-1) in database $dbname";
+ echo ""
+ # ask for database user
+ echo ""
+ echo "Name of database user?"
+ read dbuser
+ #ask for database template
+ echo ""
+ echo "Do you want to use a database template? (y)es or (n)o "
+ read dbtemplateuse
+ if test $dbtemplateuse = "y"
+ then
+ #ask for template name
+ echo ""
+ echo "Name of the template?"
+ read dbtemplate
+ fi
+ if test dbtemplate != ""
+ then
+ createdb -U $dbuser -E ISO-8859-1 $dbname -T $dbtemplate
+ else
+ fi
+ psql -U $dbuser -f pgsql/pgsql_schema_2.5.sql $dbname > log_schema.txt
+ psql -U $dbuser -f pgsql/ISO-8859-1/pgsql_data_2.5.sql $dbname > log_data.txt
+ psql -U $dbuser -f pgsql/pgsql_serial_set_sequences_2.5.sql $dbname > log_sequences.txt
+ psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+ psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+ psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+elif test $dbversion = "p" -a $dbenc = "u"
+then
+ echo ""
+ echo "Installing Mapbender with PostgreSQL (UTF-8) in database $dbname";
+ echo ""
+ echo ""
+ read dbuser
+ echo ""
+ then
+ echo ""
+ read dbtemplate
+ fi
+ echo "The script will ask you several times for your database password. Don't be confused about this."
+ then
+ createdb -U $dbuser -E UTF-8 $dbname -T $dbtemplate
+ else
+ fi
+ psql -U $dbuser -f pgsql/UTF-8/pgsql_data_2.5.sql $dbname > log_data.txt
+ psql -U $dbuser -f pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+ psql -U $dbuser -f pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql $dbname > log_update.txt
+ psql -U $dbuser -f pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+ psql -U $dbuser -f pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql $dbname > log_update.txt
+fi
+echo ""
+echo "Compiling .po files..."
+cd ../../tools/
+./i18n_update_mo.sh
+echo ""
+echo ""
+echo "Finished...check the log files to see if an error occured.";
Deleted: branches/2.6/resources/db/install_2.6rc1.sh
--- branches/2.6/resources/db/install_2.6rc1.sh 2009-06-22 17:14:02 UTC (rev 4073)
+++ branches/2.6/resources/db/install_2.6rc1.sh 2009-06-22 17:15:22 UTC (rev 4074)
@@ -1,122 +0,0 @@
-#!/bin/bash
-rm log_*.txt
-# Disclaimer
-echo ""
-echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
-echo ""
-echo "Continue? (y)es or (n)o"
-read disclaimer
-if test $disclaimer != "y"
-then
- exit 1
-fi
-# ask for db version
-echo ""
-echo "Database version? (p)ostgresql or (m)ysql?"
-read dbversion
-if test $dbversion != "p" -a $dbversion != "m"
-then
- echo ""
- echo "Incorrect database type. Terminating the script..."
- exit 1
-fi
-# ask for db character encoding
-echo ""
-echo "Database character encoding? (i)so-8859-1 or (u)tf-8?"
-read dbenc
-if test $dbenc != "i" -a $dbenc != "u"
-then
- echo ""
- echo "Incorrect database character encoding. Terminating the script..."
- exit 1
-fi
-# ask for database name
-echo ""
-echo "Name of database?"
-read dbname
-if test $dbversion = "m"
-then
- echo "Not available!!!"
- exit 1
- echo ""
- echo "Enter your MySQL password:"
- stty -echo
- read password
- stty echo
- echo ""
- if test $dbenc = "i"
- then
- echo ""
- echo "Installing Mapbender with MySQL (ISO-8859-1) in database $dbname";
- echo ""
- mysql -e "create database $dbname CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$password
- mysql $dbname -p$password < mysql/mysql_schema_2.5.sql > log_schema.txt
- mysql $dbname -p$password < mysql/ISO-8859-1/mysql_data_2.5.sql > log_data.txt
- mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql > log_update.txt
- mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql > log_update.txt
- mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql > log_update.txt
- elif test $dbenc = "u"
- then
- echo ""
- echo "Installing Mapbender with MySQL (UTF-8) in database $dbname";
- echo ""
- mysql -e "create database $dbname CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$password
- mysql $dbname -p$password < mysql/UTF-8/mysql_data_2.5.sql > log_data.txt
- mysql $dbname -p$password < mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql > log_update.txt
- mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql > log_update.txt
- mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql > log_update.txt
- fi
-elif test $dbversion = "p" -a $dbenc = "i"
-then
- exit 1
- echo ""
- echo "Installing Mapbender with PostgreSQL (ISO-8859-1) in database $dbname";
- echo ""
- createdb -E ISO-8859-1 $dbname
- psql -f pgsql/pgsql_schema_2.5.sql $dbname > log_schema.txt
- psql -f pgsql/ISO-8859-1/pgsql_data_2.5.sql $dbname > log_data.txt
- psql -f pgsql/pgsql_serial_set_sequences_2.5.sql $dbname > log_sequences.txt
- psql -f pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
- psql -f pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
- psql -f pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
-elif test $dbversion = "p" -a $dbenc = "u"
-then
- echo ""
- echo "Installing Mapbender with PostgreSQL (UTF-8) in database $dbname";
- echo ""
- createdb -E UTF-8 $dbname
- psql -f pgsql/UTF-8/pgsql_data_2.5.sql $dbname > log_data.txt
- psql -f pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql $dbname > log_update.txt
- psql -f pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql $dbname > log_update.txt
- psql -f pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql $dbname > log_update.txt
-fi
-echo ""
-echo "Compiling .po files..."
-cd ../../tools/
-./i18n_update_mo.sh
-echo ""
-echo ""
-echo "Finished...check the log files to see if an error occured.";
\ No newline at end of file
More information about the Mapbender_commits
