[Mapbender-commits] r4079 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 23 04:37:37 EDT 2009
Author: christoph
Date: 2009-06-23 04:37:37 -0400 (Tue, 23 Jun 2009)
New Revision: 4079
   trunk/mapbender/http/javascripts/map_obj.js
Mapbender API
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2009-06-23 08:27:23 UTC (rev 4078)
+++ trunk/mapbender/http/javascripts/map_obj.js	2009-06-23 08:37:37 UTC (rev 4079)
@@ -1,11 +1,11 @@
 * $Id: map_obj.js 2517 2008-06-19 16:40:00Z christoph $
 * COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
 var mb_mapObj = [];
-function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+function Map (frameName, elementName, width, height, wms_index){
 	 * set the extent of the wms
@@ -14,21 +14,22 @@
 		this.extent = String(minx) + "," + String(miny) + "," + String(maxx) + "," + String(maxy);
 	this.restrictedExtent = function (extent) {
 		this.restrictedExtent = extent;
 	 * get the width of the mapObj
-	 * @member mb_mapObj_const
+	 * @member Map
 	 * @return width of the mapObj
 	 * @type integer
 	this.getWidth = function(){
 		return parseInt(this.width, 10);
 	 * set the width of the mapObj
@@ -44,25 +45,25 @@
 		var domElement = this.getDomElement();
 		domElement.style.width = this.width;
 	 * get the height of the mapObj
+	 * @member Map
 	 * @type integer
 	this.getHeight = function(){
 		return parseInt(this.height, 10);
 	this.getDomElement = function(){
 		if(this.frameName){
 			return window.frames[this.frameName].document.getElementById(this.elementName);
 		return document.getElementById(this.elementName);
 	 * set the height of the mapObj
@@ -77,7 +78,7 @@
 		domElement.style.height = this.height;
 	this.getMousePosition = function (e) {
 		var clickX, clickY;
@@ -100,24 +101,24 @@
 		if (this.type == "DIV") {
 			var mapDomElement = this.getDomElement();
 			currentPos = new Point(
-				clickX - parseInt(mapDomElement.style.left),
+				clickX - parseInt(mapDomElement.style.left),
 				clickY - parseInt(mapDomElement.style.top)
 			// if the mouse position is not on top of the map, return null
-			if (currentPos.x < 0 || currentPos.x > this.width ||
+			if (currentPos.x < 0 || currentPos.x > this.width ||
 				currentPos.y < 0 || currentPos.y > this.height) {
 				return null;
 		else {
-				clickX,
+				clickX,
 				clickY
 		return currentPos;
 	 * converts the extent of the mapobject so that the maximum	extent will be displayed
@@ -133,13 +134,13 @@
 			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
 			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
 		// Check if ext is within restricted extent
 		// If not, calculate a new extent according
 		// to restricted extent.
 		if ( this.restrictedExtent ) {
-			if ( ext.minx  < this.restrictedExtent.minx ) {
+			if ( ext.minx  < this.restrictedExtent.minx ) {
 	            ext.minx = this.restrictedExtent.minx;
 	            ext.maxx = ext.minx + (relation_px_x * ext.extenty);
@@ -188,9 +189,9 @@
 			index++;
-	// set list of visible layers, active querylayers
+	// set list of visible layers, active querylayers
 	// and styles for each WMS in this map
 	var cnt_layers;
@@ -204,7 +205,7 @@
 		styles = "";
 		layers = "";
 		querylayers = "";
 		for (var ii = 0; ii < this.wms[i].objLayer.length; ii++) {
 			// layer is visible and not root layer
 			if (this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii > 0) {
@@ -229,10 +230,10 @@
 		this.styles[i] = styles;
 		this.querylayers[i] = querylayers;
 	this.epsg = wms[0].gui_wms_epsg;
 	var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
 	for (var i = 0; i < wms[0].gui_epsg.length; i++) {
 		if (this.epsg == wms[0].gui_epsg[i]) {
 			bbox_minx = parseFloat(wms[0].gui_minx[i]);
@@ -242,27 +243,27 @@
 	var wmsExtent = new Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
 	this.calculateExtent(wmsExtent);
 	this.mapURL = [];
-	domElement.style.height = this.height;
+	domElement.style.height = this.height;
 	this.afterMapRequest = new MapbenderEvent();
 	 * get the extent of the mapObj
+	 * @member Map
 	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
 	 * @type string
 	this.getExtent = function(){
 		return this.extent;
 	 * get the extent as minx, maxx, miny, maxy
@@ -274,7 +275,7 @@
 		var ext = new Extent(c[0], c[1], c[2], c[3]);
 		return ext;
 	 * Sets the list of layers, styles and querylayers for a specified WMS
@@ -313,9 +314,9 @@
 //		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
 	 * @param {Object} direction
 	this.pan = function (direction) {
@@ -327,83 +328,79 @@
 		var xtentx = maxx - minx;
 		var xtenty =  maxy - miny;
 		var factor = 0.5;
 		switch (direction) {
 			case "NW" :
-				minx -= (xtentx * factor);
-				maxx -= (xtentx * factor);
-				miny += (xtenty * factor);
+				minx -= (xtentx * factor);
+				maxx -= (xtentx * factor);
+				miny += (xtenty * factor);
 				maxy += (xtenty * factor);
 				break;
 			case "N" :
 				break;
 			case "NE" :
-				minx += (xtentx * factor);
-				maxx += (xtentx * factor);
+				minx += (xtentx * factor);
+				maxx += (xtentx * factor);
 				break;
 			case "E" :
 				break;
 			case "SE" :
-				miny -= (xtenty * factor);
-				maxy -= (xtenty * factor);
+				miny -= (xtenty * factor);
+				maxy -= (xtenty * factor);
 				break;
 			case "S" :
 				break;
 			case "SW" :
 				break;
 			case "W" :
 				break;
 		this.extent = minx + "," + miny + "," + maxx + "," + maxy;
 		this.restrictedExtent;
 		this.setMapRequest();
 	this.zoomFull = function () {
-** not in use until now and commented out because of error in zoomFull module (Bolsena 23.6.09)
 		if (this.restrictedExtent) {
 			var newExtent = this.calculateExtent(this.restrictedExtent);
 			this.repaint(new Point(newExtent.minx, newExtent.miny), new Point(newExtent.maxx, newExtent.maxy));
 		else {
 			for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
 				if (this.epsg == this.wms[0].gui_epsg[i]) {
 					var bbox_minx = parseFloat(this.wms[0].gui_minx[i]);
 					var bbox_miny = parseFloat(this.wms[0].gui_miny[i]);
 					var bbox_maxx = parseFloat(this.wms[0].gui_maxx[i]);
 					var bbox_maxy = parseFloat(this.wms[0].gui_maxy[i]);
 					var newExtent = this.calculateExtent(wmsExtent);
 					break;
 	 * zoom the map with a zoomfactor and optional to x,y coords
@@ -417,11 +414,11 @@
 		if (!in_) {
 			factor = 1 / factor;
 		var extent = this.getExtentInfos();
 		var distx = extent.maxx - extent.minx;
 		var disty = extent.maxy - extent.miny;
 		if (x && y) {
 			var centerx = parseFloat(x);
 			var centery = parseFloat(y);
@@ -430,7 +427,7 @@
 			var centerx = extent.minx + distx / 2;
 			var centery = extent.miny + disty / 2;
 		var new_distx = distx / factor;
 		var new_disty = disty / factor;
 		var minx = centerx - new_distx / 2;
@@ -444,7 +441,7 @@
 		var relation_px_x = this.getWidth() / this.getHeight();
 		var relation_px_y = this.getHeight() / this.getWidth();
-			if ( minx  < this.restrictedExtent.minx ) {
+			if ( minx  < this.restrictedExtent.minx ) {
 	            maxx = minx + (relation_px_x * new_disty);
@@ -462,12 +459,12 @@
 		this.setExtent(minx, miny, maxx, maxy);
 	var performUnknownCalculation = function (value) {
 		return Math.pow(10,(
 			Math.round(
@@ -476,7 +473,7 @@
 	this.convertPixelToReal = function (aPoint) {
 		var arrayBBox = this.extent.split(",");
 		var minX = parseFloat(arrayBBox[0]);
@@ -500,14 +497,14 @@
 		else{
 			roundy =  performUnknownCalculation(deltaY);
 		var posX = parseFloat(minX + (aPoint.x / this.width) * xtentx);
 		var posY = parseFloat(maxY - (aPoint.y / this.height) * xtenty);
 		posX = Math.round(posX * roundx) / roundx;
 		posY = Math.round(posY * roundy) / roundy;
 		return new Point(posX, posY);
 	 * Convert real world coordinates to pixel coordinates
@@ -518,11 +515,11 @@
 		var maxX = parseFloat(arrayBBox[2]);
 		var maxY = parseFloat(arrayBBox[3]);
 		return new Point(
-			Math.round((aPoint.x - minX) * this.width /(maxX - minX)),
+			Math.round((aPoint.x - minX) * this.width /(maxX - minX)),
 			Math.round((maxY - aPoint.y) * this.height/(maxY - minY))
 	 * get the srs of the mapObj
@@ -532,7 +529,7 @@
 	this.getSRS = function(){
 		return this.epsg;
 	 * get all mapRequests
@@ -553,7 +550,7 @@
 		return false;
 	 * Return the map URL of the WMS at index i
 	 * @param {Object} currentWmsIndex
@@ -565,17 +562,17 @@
 			return false;
 		var layerNames = validLayers.join(",");
 		url = currentWms.wms_getmap;
 		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
 		if (currentWms.wms_version == "1.0.0") {
 			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
 		else {
 			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
 		url += "LAYERS=" + layerNames + "&";
 		url += "STYLES=";
 		var layer = layerNames.split(",");
@@ -594,14 +591,14 @@
 		url += "HEIGHT=" + this.height + "&";
 		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
 		url += "BGCOLOR=0xffffff&";
 		if (currentWms.gui_wms_mapformat.search(/gif/i) > -1 ||
 		currentWms.gui_wms_mapformat.search(/png/i) > -1) {
 			url += "TRANSPARENT=TRUE&";
 		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
 		// add vendor-specific
 		for (var v = 0; v < mb_vendorSpecific.length; v++) {
 			var functionName = 'setMapRequest';
@@ -609,7 +606,7 @@
 			// if eval doesn't evaluate a function, the result is undefined.
 			// Sometimes it is necessary not to evaluate a function, for
 			// example if you want to change a variable from the current
-			// scope (see mod_addSLD.php)
+			// scope (see mod_addSLD.php)
 			if (typeof(vendorSpecificString) != "undefined") {
 				url += vendorSpecificString + "&";
@@ -624,11 +621,11 @@
 		return url;
 	 * get all featureInfoRequests
+	 * @member Map
 	 * @param float x the x-value of the click position in pixel
 	 * @param float y the y-value of the click position in pixel
 	 * @return array of all featureInfoRequests of this map object
@@ -659,11 +656,11 @@
 		return false;
 	 * calculation of the mapscale
+	 * @member Map
 	 * @return scale
 	 * @type integer
@@ -687,7 +684,7 @@
 		return parseInt(Math.round(scale));
@@ -699,10 +696,10 @@
 		for (var i = 0; i < this.wms[wmsIndex].objLayer.length; i++) {
 			var currentLayer = this.wms[wmsIndex].objLayer[i];
 			var myLayername = currentLayer.layer_name;
 			var myMinscale = currentLayer.gui_layer_minscale;
 			var myMaxscale = currentLayer.gui_layer_maxscale;
 			for (var ii = 0; ii < thisLayer.length; ii++) {
 				if (thisLayer[ii] == myLayername && !currentLayer.has_childs) {
 					if (myMinscale !== 0 && thisScale < myMinscale) {
@@ -722,9 +719,9 @@
 		var str_layerstyles = [];
 		str_layerstyles[0] = str_layer;
 		return str_layerstyles;
 	this.repaintScale = function(x, y, scale){
 		if (x === null && y === null) {
@@ -741,18 +738,18 @@
 		var maxy = parseFloat(y) + (this.height / (mb_resolution * 100 * 2) * scale);
 		this.repaint(new Point(minx, miny), new Point(maxx, maxy));
 	this.repaint = function(min, max){
 		this.extent = min.x + "," + min.y + "," + max.x + "," + max.y;
 	this.setSingleMapRequest = function (wms_id) {
 		eventBeforeMapRequest.trigger({map:this});
-		var ts = mb_timestamp();
-		for (var ii = 0; ii < this.wms.length; ii++){
+		var ts = mb_timestamp();
+		for (var ii = 0; ii < this.wms.length; ii++){
 			var currentWms = this.wms[ii];
 			if (currentWms.wms_id != wms_id) {
 				continue;
@@ -762,16 +759,16 @@
 			if (mb_log) {
 				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
-			var myDivId = this.elementName + "_div_" + ii;
+			var myDivId = this.elementName + "_div_" + ii;
 			writeTag(this.frameName, myDivId, newMapRequest);
 			var myMapId = this.elementName + "_map_" + ii;
 			eventAfterMapRequest.trigger({"map":this, "myMapId":myMapId});
 			return true;
-		return false;
+		return false;
 	this.mb_setFutureObj = function(mod_back_cnt){
 		var cnt = this.mb_MapFutureObj.length;
 		this.mb_MapFutureObj[cnt] = {};
@@ -781,7 +778,7 @@
 		this.mb_MapFutureObj[cnt].epsg = this.epsg;
 		this.mb_MapFutureObj[cnt].extent = this.extent;
 		this.mb_MapFutureObj[cnt].layers = [];
 		for(var i=0; i<this.layers.length;i++){
 			this.mb_MapFutureObj[cnt].layers[i] = this.layers[i];
@@ -798,7 +795,7 @@
 			this.mb_MapFutureObj[cnt].querylayers[i] = this.querylayers[i];
 	this.setMapRequest = function(){
 		var ret = eventBeforeMapRequest.trigger({
 				map: this
@@ -808,19 +805,19 @@
 		var myMapId = [];
 		var newMapRequest = "";
 		for (var ii = 0; ii < this.wms.length; ii++) {
 			if (!(currentWms.gui_wms_visible > 0)) {
 				continue;
 			myMapId.push(this.elementName + "_map_" + ii);
 			newMapRequest += getLayerHtmlCode(ii);
 		writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
@@ -835,21 +832,21 @@
 	var getLayerHtmlCode = function (ii) {
 		var currentWms = that.wms[ii];
-		var myDivId = that.elementName + "_div_" + ii;
+		var myDivId = that.elementName + "_div_" + ii;
 		var myMapId = that.elementName + "_map_" + ii;
 		//disable Layer which are out of scale
 		var validLayers = that.checkScale(ii);
 		var layerNames = validLayers.toString();
 		var newMapURL = false;
 		var opacityString = "";
 		if (that.layers[ii] !== "" && layerNames !== ''){
 			// get map URL
 			newMapURL = that.getMapUrl(ii);
 			var currentOpacity = currentWms.gui_wms_mapopacity;
 			if (currentOpacity != 1) {
 				opacityString += "opacity:" + currentOpacity + "; ";
@@ -858,32 +855,32 @@
 				opacityString += "-khtml-opacity:" + currentOpacity;
 		var imageString = "";
 		if (newMapURL) {
 			imageString = "<img id='"+myMapId+"' name='mapimage' ";
 			imageString += "src='" + newMapURL + "' ";
 			imageString += "width='"+that.width+"' ";
 			imageString += "height='"+that.height+"' ";
-			imageString += "border='0'>";
+			imageString += "border='0'>";
 		var newMapRequest = "<div id='"+myDivId+"' ";
 		newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
 		newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
 		newMapRequest += imageString;
-		newMapRequest += "</div>";
-		that.mapURL[ii]= newMapURL;
+		newMapRequest += "</div>";
+		that.mapURL[ii]= newMapURL;
 		currentWms.mapURL = newMapURL;
 		if (mb_log && currentWms.mapURL) {
 			var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
 		return newMapRequest;
 	this.getWmsIdByTitle = function (title) {
 		for (var i=0; i < this.wms.length; i++) {
 			if (this.wms[i].wms_title == title) {
@@ -910,7 +907,7 @@
 		var new_querylayerarray = [];
 		var new_stylesarray = [];
 		var new_mapURLarray = [];
 		for	(i = 0; i < this.wms.length; i++) {
 			if (i != wmsIndex) {
 				new_wmsarray.push(this.wms[i]);
@@ -923,24 +920,24 @@
 				wms_ID = this.wms[i].wms_id;
-		this.wms = new_wmsarray;
-		this.layers = new_layerarray;
-		this.querylayers = new_querylayerarray;
-		this.styles = new_stylesarray;
+		this.wms = new_wmsarray;
+		this.layers = new_layerarray;
+		this.querylayers = new_querylayerarray;
+		this.styles = new_stylesarray;
 		this.mapURL = new_mapURLarray;
 		var another_new_wmsarray = [];
 		for	(i = 0; i < window.wms.length; i++) {
 			if (window.wms[i].wms_id != wms_ID) {
-				another_new_wmsarray.push(window.wms[i]);
+				another_new_wmsarray.push(window.wms[i]);
-		window.wms = another_new_wmsarray;
+		window.wms = another_new_wmsarray;
-	 * move a wms or layer
+	 * move a wms or layer
 	 * @param int wms_id id of wms to move
 	 * @param int layer_id id of layer to move
@@ -954,18 +951,18 @@
 				break;
 		//check if only one wms is affected?
 		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
 			return this.wms[i].moveLayer(layer_id, moveUp);
 		//else swap wms
 		j = i + (moveUp?-1:1);
 		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
 			return false;
 		upper = this.wms[i];
 		this.wms[i] = this.wms[j];
 		this.wms[j] = upper;
@@ -978,10 +975,10 @@
 		this.layers[j] = upperLayers;
 		this.styles[j] = upperStyles;
 		this.querylayers[j] = upperQuerylayers;
 		return true;
 	this.getMousePos = function(e){
 		if(ie){
 			if(this.frameName){
@@ -997,18 +994,18 @@
 			clickX = e.pageX;
 			clickY = e.pageY;
 		//remove divtag offset
 		clickX -= parseInt(this.getDomElement().style.left);
 		clickY -= parseInt(this.getDomElement().style.top);
 		return new Point(clickX, clickY);
 	eventAfterMapObjectConstruction.trigger();
-mb_mapObj_const.prototype.getWfsConfIds = function (wfs_config) {
+Map.prototype.getWfsConfIds = function (wfs_config) {
 	var db_wfs_conf_id = [];
 	var js_wfs_conf_id = [];
More information about the Mapbender_commits mailing list
