[Mapbender-commits] r4087 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Jun 23 06:55:35 EDT 2009
Author: christoph
Date: 2009-06-23 06:55:34 -0400 (Tue, 23 Jun 2009)
New Revision: 4087
trunk/mapbender/http/javascripts/mod_sandclock.php
Modified: trunk/mapbender/http/javascripts/mod_sandclock.php
--- trunk/mapbender/http/javascripts/mod_sandclock.php 2009-06-23 10:37:44 UTC (rev 4086)
+++ trunk/mapbender/http/javascripts/mod_sandclock.php 2009-06-23 10:55:34 UTC (rev 4087)
@@ -88,9 +88,9 @@
* Displays the sandclock
this.show = function (mapId) {
+ var temp = "<img src='"+mod_sandclock_img.src+"'>";
if (!isInitialised) {
map = Mapbender.Modules[options.target];
- var temp = "<img src='"+mod_sandclock_img.src+"'>";
var map_el = map.getDomElement();
if(!map_el.ownerDocument.getElementById(map.elementName+"_sandclock")){
//create Box Elements
@@ -99,16 +99,16 @@
el_top.style.top = "0px";
el_top.style.left = "0px";
el_top.style.overflow = "hidden";
- el_top.style.zIndex = "10";
+ el_top.style.zIndex = "1000";
el_top.style.visibility = "visible";
el_top.style.cursor = "crosshair";
el_top.id = map.elementName+"_sandclock";
map_el.appendChild(el_top);
- writeTag(map.frameName, map.elementName+"_sandclock", temp);
- mb_arrangeElement("", options.target+"_sandclock", (map.width/2 - 16), (map.height/2 - 16));
isInitialised = true;
+ writeTag(map.frameName, map.elementName+"_sandclock", temp);
+ mb_arrangeElement("", options.target+"_sandclock", (map.width/2 - 16), (map.height/2 - 16));
// if mapId is not given, the sandclock has to be turned off manually
More information about the Mapbender_commits
