[Mapbender-commits] r4104 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 23 13:54:20 EDT 2009
Author: christoph
Date: 2009-06-23 13:54:20 -0400 (Tue, 23 Jun 2009)
New Revision: 4104
   trunk/mapbender/http/javascripts/map.php
   trunk/mapbender/http/javascripts/mod_copyright.php
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2009-06-23 17:47:28 UTC (rev 4103)
+++ trunk/mapbender/http/javascripts/map.php	2009-06-23 17:54:20 UTC (rev 4104)
@@ -23,7 +23,7 @@
 $json = new Mapbender_JSON();
 // see http://trac.osgeo.org/mapbender/ticket/79
-ini_set('session.bug_compat_42',0);
+ini_set('session.bug_compat_42',0);
 ini_set('session.bug_compat_warn',0);
@@ -76,8 +76,8 @@
 // Load external JavaScript libraries
 $extPath = dirname(__FILE__) . "/../extensions/";
-$extFileArray = array(  "jquery-1.2.6.min.js",
-						"jqjson.js",
+$extFileArray = array(  "jquery-1.2.6.min.js",
+						"jqjson.js",
 						"jquery.mousewheel.min.js",
 						"jquery.form.js");
@@ -96,7 +96,7 @@
 $(function () {
 	initModules();
 	// creates the map objects (mapframe1, overview...)
 	eventInitMap.trigger();
@@ -104,17 +104,17 @@
 	// initialisation
 	eventInit.trigger();
 	eventAfterInit.trigger();
 <?php
 // Load internal JavaScript libraries
 $libPath = dirname(__FILE__) . "/../../lib/";
-$libFileArray = array(  "exception.js",
-						"ajax.js",
+$libFileArray = array(  "exception.js",
+						"ajax.js",
 						"basic.js",
 						"div.js",
 						"list.js",
@@ -166,10 +166,10 @@
 $modulesNotRelyingOnGlobalsArray = explode(",", MODULES_NOT_RELYING_ON_GLOBALS);
-Mapbender.Modules = {};
+Mapbender.modules = {};
 Mapbender.addModule = function (name, obj) {
-	if (name && !Mapbender.Modules[name]) {
-		Mapbender.Modules[name] = obj;
+	if (name && !Mapbender.modules[name]) {
+		Mapbender.modules[name] = obj;
 		return true;
 	return false;
@@ -203,20 +203,19 @@
 			if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
 				ob_start();
-				echo "var options = {" .
-					"id:'$e_id'," .
+				echo "var options = {" .
+					"id:'$e_id'," .
 					"target:" . ($e_target[0] != "" ? $json->encode($e_target) : "[]") . "," .
-					"top:$e_top," .
-					"left:$e_left," .
-					"width:$e_width," .
-					"height:$e_height," .
-					"requires:'$e_require'," .
-					"src:'$e_src'" .
+					"top:$e_top," .
+					"left:$e_left," .
+					"width:$e_width," .
+					"height:$e_height," .
+					"src:'$e_src'" .
 				include "../include/dyn_js_object.php";
 				echo <<<JS
 $.fn.$e_id = function (options) {
 	return this.each(function () {
@@ -231,11 +230,12 @@
 				echo "$('#$e_id').$e_id(options);";
 				$executeJsPluginsArray[] = ob_get_contents();
 				ob_end_clean();
+				echo "Mapbender.modules.$e_id = {};\n";
 				echo "Mapbender.Modules.$e_id = {};\n";
 			else {
-				echo "Mapbender.Modules." . $e_id . " = {\n";
+				echo "Mapbender.modules." . $e_id . " = {\n";
 				echo "id:'".$row_js["e_id"]."',";
 				echo "url:'".$row_js["e_url"]."',";
 				echo "top:'".$row_js["e_top"]."',";
Modified: trunk/mapbender/http/javascripts/mod_copyright.php
--- trunk/mapbender/http/javascripts/mod_copyright.php	2009-06-23 17:47:28 UTC (rev 4103)
+++ trunk/mapbender/http/javascripts/mod_copyright.php	2009-06-23 17:54:20 UTC (rev 4104)
@@ -38,7 +38,7 @@
 	mod_copyright();
 function mod_copyright(){
-	var myMapObj = Mapbender.Modules[mod_copyright_target];
+	var myMapObj = Mapbender.modules[mod_copyright_target];
 	var str_c = "<div>";
 	str_c += "<img src='../img/transparent.gif' width ='"+myMapObj.width+"' height='"+myMapObj.height+"'>";
More information about the Mapbender_commits mailing list
