[Mapbender-commits] r4112 - branches/kmq_dev/http/classes
    svn_mapbender at osgeo.org
    Wed Jun 24 05:17:15 EDT 2009
Author: kmq
Date: 2009-06-24 05:17:15 -0400 (Wed, 24 Jun 2009)
New Revision: 4112
   branches/kmq_dev/http/classes/class_user.php
class User expandend for persistence
Modified: branches/kmq_dev/http/classes/class_user.php
--- branches/kmq_dev/http/classes/class_user.php	2009-06-23 18:07:13 UTC (rev 4111)
+++ branches/kmq_dev/http/classes/class_user.php	2009-06-24 09:17:15 UTC (rev 4112)
@@ -28,23 +28,23 @@
 	var $id;
 	var $name;
-	var $password = ""; // passwords should be set, not read
-	var $owner; // make this reference to a USER object
-	var $descr;
+	// var $password = ""; // password is readonly,
+	var $owner = 0;
+	var $descr ="";
 	var $loginCount;
-	var $email;
-	var $phone;
-	var $department;
-	var $resolution;
-	var $organization;
-	var $position;
-	var $phone1;
-	var $fax;
-	var $deliveryPoint;
-	var $city;
+	var $email = "";
+	var $phone ="";
+	var $department ="";
+	var $resolution = 72;
+	var $organization ="";
+	var $position = "";
+	var $phone1 = "";
+	var $fax = "";
+	var $deliveryPoint ="";
+	var $city ="";
 	var $postalCode;
-	var $country;
-	var $url;
+	var $country ="";
+	var $url ="";
@@ -54,8 +54,14 @@
 	public function __construct ($userId) {
 		$this->id = $userId;
-		if($userId ) {$this->load();}
+		try{
+			if($userId) {$this->load();}
+		catch(Exception $E)
+			new mb_exception($E->getMessage());
@@ -73,7 +79,7 @@
 		$result = '{"name":"'. 				$this->name .'",'
-							.'"password":"'. 		$this->password .'",'
+							.'"password":				"*************",'
 							.'"owner":"'. 			$this->owner .'",'
 							.'"descr":"'. 			$this->descr .'",'
 							.'"loginCount":"'.	$this->loginCount .'",'
@@ -97,22 +103,28 @@
 	public function  create()
 		//FIXME: can users exist that have the same name? I think not, but the db does not enforce it
-		if($this->name == ""){ $e = new mb_exception("Can' t create user without name");}
+		if($this->name == ""){ $e = new Exception("Can' t create user without name");}
-		$sql_user_create = "INSERT INTO mb_user (mb_user_name) VALUES ($1) ; ";
+		//$sql_user_create = "INSERT INTO mb_user (mb_user_name) VALUES ($1) ; ";
+		$sql_user_create = "INSERT INTO mb_user (mb_user_name) VALUES ('". $this->name ."');";
 		$v = array($this->name);
 		$t = array("s");
 		db_begin();
-	//	$sql_user_prepared = db_prepare_query($sql_user_create,$v,$t);
-		$sql_user_prepared = "INSERT INTO mb_user (mb_user_name) VALUES ('". $this->name ."') ; ";
-		$result = db_query($sql_user_prepared);
-		if($result == false)
+		//$insert_result =  db_prep_query($sql_user_create,$v,$t);
+		$insert_result = db_query($sql_user_create);
+		if($insert_result == false)
 			db_rollback();
-			$e = new mb_exception("Could not insert new user");
+			$e = new Exception("Could not insert new user");
+		$id = db_insertid($insert_result,'mb_user','mb_user_id');
+		if($id != 0)
+			$this->id = $id;
 		$commit_result = $this->commit();
 		if($commit_result == false)
@@ -122,11 +134,13 @@
 			catch(Exception $E)
-				print "cautght it";
-				$newE = new mb_exception("Could not set inital values of new user");
+				print "caught it";
+				$newE = new Exception("Could not set inital values of new user");
 				throw $newE;
 		db_commit();
@@ -134,21 +148,69 @@
 	public function commit()
-		//db_begin();
-		//db_commit();
+		$sql_update = "UPDATE mb_user SET ".
+			"mb_user_name = $1, ".
+			"mb_user_owner = $2, ".
+			"mb_user_description = $3, ".
+			"mb_user_email = $4, ".
+			"mb_user_phone = $5, ".
+			"mb_user_department = $6, ".
+			"mb_user_resolution = $7, ".
+			"mb_user_organisation_name = $8, ".
+			"mb_user_position_name = $9, ".
+			"mb_user_phone1 = $10, ".
+			"mb_user_facsimile = $11, ".
+			"mb_user_delivery_point = $12, ".
+			"mb_user_city = $13, ".
+			"mb_user_postal_code = $14, ".
+			"mb_user_country = $15, ".
+			"mb_user_online_resource = $16 ".
+			"WHERE mb_user_id = $17;";
+			$v = array($this->name,
+									$this->owner,
+									$this->description,
+									$this->email,
+									$this->phone,
+									$this->department,
+									$this->resolution,
+									$this->organization,
+									$this->position,
+									$this->phone1,
+									$this->facsimile,
+									$this->deliveryPoint,
+									$this->city,
+									$this->postalCode,
+									$this->country,
+									$this->url,
+									$this->id);
+			$t = array("s", "i", "s", "s", "s", "s", "i",  "s", "s",  "s", "s", "s",  "s", "i",  "s", "s", "i");
+			$update_result = db_prep_query($sql_update,$v,$t);
+			if(!$update_result)
+				throw new Exception("Database error updating user");
+		return true;
 	public function remove()
 		$sql_user_remove = "DELETE FROM mb_user WHERE mb_user_id = $1";
 		$v = array($this->id);
 		$t = array("i");
-		$sql_prepared = db_prepare_query($sql_user_remove,$v,$t);
-		$result = db_query($sql_prepared);
+		$result = db_prep_query($sql_user_remove,$v,$t);
-			$e = new mb_exception("Could not delete user");
+			$e = new mb_exception("Database error deleting userr");
 		return true;
@@ -162,7 +224,6 @@
 		if($row = db_fetch_array($res_user)){
 			$this->name = $row['mb_user_name'];
-			$this->password = ""; // passwords should be set, not read
 			$this->owner = $row['mb_user_owner'];
 			$this->descr	= $row['mb_user_description'];
 			$this->loginCount = $row['mb_user_login_count'];
@@ -182,10 +243,16 @@
 		}else{
 			//no such user
-			echo "no such user";
+			 throw new Exception("no such user");
 		return true;
+	public function setPassword($newPassword)
+		return false;
 	 * Returns an array of application IDs that the user is allowed to access.
More information about the Mapbender_commits
