[Mapbender-commits] r4124 - in trunk/mapbender: http/javascripts lib
svn_mapbender at osgeo.org
Wed Jun 24 11:17:05 EDT 2009
Author: christoph
Date: 2009-06-24 11:17:05 -0400 (Wed, 24 Jun 2009)
New Revision: 4124
trunk/mapbender/http/javascripts/core.php
trunk/mapbender/http/javascripts/map_obj.js
trunk/mapbender/http/javascripts/mod_reload.php
trunk/mapbender/lib/event.js
API
Modified: trunk/mapbender/http/javascripts/core.php
--- trunk/mapbender/http/javascripts/core.php 2009-06-24 15:16:04 UTC (rev 4123)
+++ trunk/mapbender/http/javascripts/core.php 2009-06-24 15:17:05 UTC (rev 4124)
@@ -27,7 +27,9 @@
var Mapbender = {
- events: {},
+ events: {
modules: {}
<?php
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2009-06-24 15:16:04 UTC (rev 4123)
+++ trunk/mapbender/http/javascripts/map_obj.js 2009-06-24 15:17:05 UTC (rev 4124)
@@ -15,11 +15,11 @@
- * Constructor
+ * Constructor: Map
* Parameters:
* frameName - *[deprecated]* the name of the iframe, for backwards
- * compatibility only
+ * compatibility only, use "" for maps in DIVs
* elementName - the ID of the DOM node
* width - width of the map in pixel
* height - height of the map in pixel
@@ -29,7 +29,16 @@
Mapbender.Map = function (frameName, elementName, width, height, wms_index) {
+ * Method: setExtent
+ * Description:
* set the extent of the wms
+ * Parameters:
+ * minx - x of south west
+ * miny - y of south west
+ * maxx - x of north east
+ * maxy - y of north east
this.setExtent = function(minx, miny, maxx, maxy){
this.extent = String(minx) + "," + String(miny) + "," + String(maxx) + "," + String(maxy);
@@ -183,8 +192,9 @@
return ext;
+ // private
this.width = width;
+ // private
this.height = height;
this.frameName = frameName;
this.type = (frameName !== "") ? "IFRAME" : "DIV";
Modified: trunk/mapbender/http/javascripts/mod_reload.php
--- trunk/mapbender/http/javascripts/mod_reload.php 2009-06-24 15:16:04 UTC (rev 4123)
+++ trunk/mapbender/http/javascripts/mod_reload.php 2009-06-24 15:17:05 UTC (rev 4124)
@@ -32,6 +32,9 @@
* > 60,24,24,1,'','','','mod_reload.php','','mapframe1','',
* > 'http://www.mapbender.org/index.php/Reload');
+ * Help:
+ * http://www.mapbender.org/index.php/Reload
* Maintainer:
* http://www.mapbender.org/User:Vera_Schulze
Modified: trunk/mapbender/lib/event.js
--- trunk/mapbender/lib/event.js 2009-06-24 15:16:04 UTC (rev 4123)
+++ trunk/mapbender/lib/event.js 2009-06-24 15:17:05 UTC (rev 4124)
@@ -1,20 +1,23 @@
- * An event. What happens, when the event occurs, depends on which functions have been
+ * Package: Event
+ * Description:
+ * An event. What happens, when the event occurs, depends on which functions have been
* registered with the event.
* usage:
- * // create a new Event
- * var eventAfterMapRequest = new MapbenderEvent();
+ * > // create a new Event
+ * > var eventAfterMapRequest = new MapbenderEvent();
+ * > // register a function with that event
+ * > eventAfterMapRequest.register(function () {
+ * > // trigger the event
+ * > eventAfterMapRequest.trigger();
- * // register a function with that event
- * eventAfterMapRequest.register(function () {
- * // trigger the event
- * eventAfterMapRequest.trigger();
var MapbenderEvent = Mapbender.Event = function () {
More information about the Mapbender_commits
