[Mapbender-commits] r4127 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Jun 24 11:29:30 EDT 2009
Author: vera
Date: 2009-06-24 11:29:30 -0400 (Wed, 24 Jun 2009)
New Revision: 4127
trunk/mapbender/http/php/mod_deleteWFS.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_deleteWFS.php
--- trunk/mapbender/http/php/mod_deleteWFS.php 2009-06-24 15:27:38 UTC (rev 4126)
+++ trunk/mapbender/http/php/mod_deleteWFS.php 2009-06-24 15:29:30 UTC (rev 4127)
@@ -1,96 +1,96 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/DeleteWFS
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-import_request_variables("PG");
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Delete WFS - All Users</title>
-<?php
-include '../include/dyn_css.php';
-<script type="text/javascript">
-function validate(){
- var ind = document.form1.wfsList.selectedIndex;
- if(ind > -1){
- var permission = confirm("delete: " + document.form1.wfsList.options[ind].text + " ?");
- if(permission === true){
- document.form1.del.value = 1;
- document.form1.submit();
-</script>
-<style type="text/css">
- body{
- background-color: #ffffff;
- font-family: Arial, Helvetica, sans-serif;
- font-size : 12px;
- color: #808080
-</style>
-</head>
-<body>
-<?php
-$logged_user_name=$_SESSION["mb_user_name"];
-$logged_user_id=$_SESSION["mb_user_id"];
-###delete
-if($wfsList){
- $sql = "DELETE FROM wfs WHERE wfs_id = $1";
- $v = array($wfsList);
- $t = array("i");
- $res = db_prep_query($sql, $v, $t);
-$sql_wfs = "SELECT * FROM wfs ORDER BY wfs_id";
-$res_wfs = db_query($sql_wfs);
-$cnt_wfs = 0;
-echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<br><b>WFS List: <b><br><br>";
-echo "<select class='wfsList' size='20' name='wfsList' >";
-while($row = db_fetch_array($res_wfs)){
- echo "<option value='".$row["wfs_id"]."'>".$row["wfs_id"]." ".$row["wfs_name"]." - ".$row["wfs_title"]."</option>";
- $cnt_wfs++;
-echo "</select><br><br>";
-echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
-<input type='hidden' name='del'>
-</form>
-</body>
-</html>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/DeleteWFS
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Delete WFS - All Users</title>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+function validate(){
+ var ind = document.form1.wfsList.selectedIndex;
+ if(ind > -1){
+ var permission = confirm("delete: " + document.form1.wfsList.options[ind].text + " ?");
+ if(permission === true){
+ document.form1.del.value = 1;
+ document.form1.submit();
+</script>
+<style type="text/css">
+ body{
+ background-color: #ffffff;
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #808080
+</style>
+</head>
+<body>
+<?php
+$logged_user_name=Mapbender::session()->get("mb_user_name");
+$logged_user_id=Mapbender::session()->get("mb_user_id");
+###delete
+if($wfsList){
+ $sql = "DELETE FROM wfs WHERE wfs_id = $1";
+ $v = array($wfsList);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
+$sql_wfs = "SELECT * FROM wfs ORDER BY wfs_id";
+$res_wfs = db_query($sql_wfs);
+$cnt_wfs = 0;
+echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<br><b>WFS List: <b><br><br>";
+echo "<select class='wfsList' size='20' name='wfsList' >";
+while($row = db_fetch_array($res_wfs)){
+ echo "<option value='".$row["wfs_id"]."'>".$row["wfs_id"]." ".$row["wfs_name"]." - ".$row["wfs_title"]."</option>";
+ $cnt_wfs++;
+echo "</select><br><br>";
+echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
+<input type='hidden' name='del'>
+</form>
+</body>
+</html>
More information about the Mapbender_commits
