[Mapbender-commits] r4129 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jun 24 11:36:52 EDT 2009
Author: vera
Date: 2009-06-24 11:36:52 -0400 (Wed, 24 Jun 2009)
New Revision: 4129
   trunk/mapbender/http/php/mod_digitize_messages.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_digitize_messages.php
--- trunk/mapbender/http/php/mod_digitize_messages.php	2009-06-24 15:33:26 UTC (rev 4128)
+++ trunk/mapbender/http/php/mod_digitize_messages.php	2009-06-24 15:36:52 UTC (rev 4129)
@@ -1,85 +1,85 @@
-<?php
-#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$e = new mb_notice("locale: " . $_SESSION["mb_locale"] . "; lang: " . $_SESSION["mb_lang"]);
-$e = new mb_notice(setlocale(LC_ALL, $_SESSION["mb_locale"]));
-// Messages
-$msg_obj = array();
-$msg_obj["messageDescriptionPolygon"] = _mb("polygon");
-$msg_obj["messageDescriptionLine"] = _mb("line");
-$msg_obj["messageDescriptionPoint"] = _mb("point");
-$msg_obj["messageErrorNotAnInteger"] = _mb("Not an integer value.");
-$msg_obj["messageErrorNotAFloat"] = _mb("Not a double value.");
-$msg_obj["messageErrorFieldIsEmpty"] = _mb("This field may not be empty.");
-$msg_obj["messageErrorFormEvaluation"] = _mb("Failure during form evaluation.");
-$msg_obj["messageErrorWfsWrite"] = _mb("An error occured.");
-$msg_obj["messageErrorMergeNotApplicable"] = _mb("At least two geometries must be available. Only polygons are allowed in the geometry list.");
-$msg_obj["messageErrorSplitNotApplicable"] = _mb("Exactly two geometries must be available. The first geometry shall be a polygon, the second geometry shall be a line.");
-$msg_obj["messageErrorDifferenceNotApplicable"] = _mb("Exactly two polygons must be available.");
-$msg_obj["messageSuccessWfsWrite"] = _mb("Success.");
-$msg_obj["messageConfirmDeleteGeomFromDb"] = _mb("Delete geometry from database?");
-$msg_obj["messageConfirmDeleteAllGeomFromList"] = _mb("Clear list of geometries?");
-$msg_obj["messageSelectAnOption"] = _mb("Please select an entry.");
-$msg_obj["buttonLabelSaveGeometry"] = _mb("Save");
-$msg_obj["buttonLabelUpdateGeometry"] = _mb("Update");
-$msg_obj["buttonLabelDeleteGeometry"] = _mb("Delete");
-$msg_obj["buttonLabelAbort"] = _mb("Abort");
-$msg_obj["errorMessageEpsgMismatch"] = _mb("Fatal error: EPSG mismatch. ");
-$msg_obj["errorMessageNoGeometrySelected"] = _mb("No geometry selected!");
-$msg_obj["buttonLabelPointOff"] = _mb("add point");
-$msg_obj["buttonLabelPointOn"] = _mb("cancel editing");
-$msg_obj["buttonLabelLineOff"] = _mb("add line");
-$msg_obj["buttonLabelLineOn"] = _mb("finish line");
-$msg_obj["buttonLabelPolygonOff"] = _mb("add polygon");
-$msg_obj["buttonLabelPolygonOn"] = _mb("close polygon");
-$msg_obj["buttonLabelMoveBasepointOff"] = _mb("move basepoint");
-$msg_obj["buttonLabelMoveBasepointOn"] = _mb("move basepoint");
-$msg_obj["buttonLabelInsertBasepointOff"] = _mb("Insert basepoint");
-$msg_obj["buttonLabelInsertBasepointOn"] = _mb("Insert basepoint");
-$msg_obj["buttonLabelDeleteBasepointOff"] = _mb("Delete basepoint");
-$msg_obj["buttonLabelDeleteBasepointOn"] = _mb("Delete basepoint");
-$msg_obj["buttonLabelClearListOff"] = _mb("clear list of geometries");
-$msg_obj["buttonLabelClearListOn"] = _mb("clear list of geometries");
-$msg_obj["buttonLabelMergeOff"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
-$msg_obj["buttonLabelMergeOn"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
-$msg_obj["buttonLabelSplitOff"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
-$msg_obj["buttonLabelSplitOn"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
-$msg_obj["buttonLabelDifferenceOff"] = _mb("Combine two polygons (to create en- and exclave or to compute the difference)");
-$msg_obj["buttonLabelDifferenceOn"] = _mb("Split geometries");
-$msg_obj["buttonDig_wfs_title"] = _mb("save / update / delete");
-$msg_obj["buttonDig_remove_title"] = _mb("remove from workspace");
-$msg_obj["buttonDig_removeDb_title"] = _mb("remove from database");
-$msg_obj["buttonDig_clone_title"] = _mb("clone this geometry");
-$msg_obj["closePolygon_title"] = _mb("click the first basepoint to close the polygon");
-$msg_obj["measureTagLabelCurrent"] = _mb("Current: ");
-$msg_obj["measureTagLabelTotal"] = _mb("Total: ");
-$msg_obj["digitizeDefaultGeometryName"] = _mb("new");
-$json = new Mapbender_JSON();
-$output = $json->encode($msg_obj);
-header("Content-type:application/x-json; charset=utf-8");
-echo $output;
+<?php
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$e = new mb_notice("locale: " . Mapbender::session()->get("mb_locale") . "; lang: " . Mapbender::session()->get("mb_lang"));
+$e = new mb_notice(setlocale(LC_ALL, Mapbender::session()->get("mb_locale")));
+// Messages
+$msg_obj = array();
+$msg_obj["messageDescriptionPolygon"] = _mb("polygon");
+$msg_obj["messageDescriptionLine"] = _mb("line");
+$msg_obj["messageDescriptionPoint"] = _mb("point");
+$msg_obj["messageErrorNotAnInteger"] = _mb("Not an integer value.");
+$msg_obj["messageErrorNotAFloat"] = _mb("Not a double value.");
+$msg_obj["messageErrorFieldIsEmpty"] = _mb("This field may not be empty.");
+$msg_obj["messageErrorFormEvaluation"] = _mb("Failure during form evaluation.");
+$msg_obj["messageErrorWfsWrite"] = _mb("An error occured.");
+$msg_obj["messageErrorMergeNotApplicable"] = _mb("At least two geometries must be available. Only polygons are allowed in the geometry list.");
+$msg_obj["messageErrorSplitNotApplicable"] = _mb("Exactly two geometries must be available. The first geometry shall be a polygon, the second geometry shall be a line.");
+$msg_obj["messageErrorDifferenceNotApplicable"] = _mb("Exactly two polygons must be available.");
+$msg_obj["messageSuccessWfsWrite"] = _mb("Success.");
+$msg_obj["messageConfirmDeleteGeomFromDb"] = _mb("Delete geometry from database?");
+$msg_obj["messageConfirmDeleteAllGeomFromList"] = _mb("Clear list of geometries?");
+$msg_obj["messageSelectAnOption"] = _mb("Please select an entry.");
+$msg_obj["buttonLabelSaveGeometry"] = _mb("Save");
+$msg_obj["buttonLabelUpdateGeometry"] = _mb("Update");
+$msg_obj["buttonLabelDeleteGeometry"] = _mb("Delete");
+$msg_obj["buttonLabelAbort"] = _mb("Abort");
+$msg_obj["errorMessageEpsgMismatch"] = _mb("Fatal error: EPSG mismatch. ");
+$msg_obj["errorMessageNoGeometrySelected"] = _mb("No geometry selected!");
+$msg_obj["buttonLabelPointOff"] = _mb("add point");
+$msg_obj["buttonLabelPointOn"] = _mb("cancel editing");
+$msg_obj["buttonLabelLineOff"] = _mb("add line");
+$msg_obj["buttonLabelLineOn"] = _mb("finish line");
+$msg_obj["buttonLabelPolygonOff"] = _mb("add polygon");
+$msg_obj["buttonLabelPolygonOn"] = _mb("close polygon");
+$msg_obj["buttonLabelMoveBasepointOff"] = _mb("move basepoint");
+$msg_obj["buttonLabelMoveBasepointOn"] = _mb("move basepoint");
+$msg_obj["buttonLabelInsertBasepointOff"] = _mb("Insert basepoint");
+$msg_obj["buttonLabelInsertBasepointOn"] = _mb("Insert basepoint");
+$msg_obj["buttonLabelDeleteBasepointOff"] = _mb("Delete basepoint");
+$msg_obj["buttonLabelDeleteBasepointOn"] = _mb("Delete basepoint");
+$msg_obj["buttonLabelClearListOff"] = _mb("clear list of geometries");
+$msg_obj["buttonLabelClearListOn"] = _mb("clear list of geometries");
+$msg_obj["buttonLabelMergeOff"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
+$msg_obj["buttonLabelMergeOn"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
+$msg_obj["buttonLabelSplitOff"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
+$msg_obj["buttonLabelSplitOn"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
+$msg_obj["buttonLabelDifferenceOff"] = _mb("Combine two polygons (to create en- and exclave or to compute the difference)");
+$msg_obj["buttonLabelDifferenceOn"] = _mb("Split geometries");
+$msg_obj["buttonDig_wfs_title"] = _mb("save / update / delete");
+$msg_obj["buttonDig_remove_title"] = _mb("remove from workspace");
+$msg_obj["buttonDig_removeDb_title"] = _mb("remove from database");
+$msg_obj["buttonDig_clone_title"] = _mb("clone this geometry");
+$msg_obj["closePolygon_title"] = _mb("click the first basepoint to close the polygon");
+$msg_obj["measureTagLabelCurrent"] = _mb("Current: ");
+$msg_obj["measureTagLabelTotal"] = _mb("Total: ");
+$msg_obj["digitizeDefaultGeometryName"] = _mb("new");
+$json = new Mapbender_JSON();
+$output = $json->encode($msg_obj);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
\ No newline at end of file
More information about the Mapbender_commits mailing list
