[Mapbender-commits] r4156 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 04:30:37 EDT 2009
Author: vera
Date: 2009-06-25 04:30:37 -0400 (Thu, 25 Jun 2009)
New Revision: 4156
   trunk/mapbender/http/php/mod_editWMS_Metadata.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_editWMS_Metadata.php
--- trunk/mapbender/http/php/mod_editWMS_Metadata.php	2009-06-25 08:27:52 UTC (rev 4155)
+++ trunk/mapbender/http/php/mod_editWMS_Metadata.php	2009-06-25 08:30:37 UTC (rev 4156)
@@ -1,497 +1,497 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php?title=Edit_WMS_Metadata
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/mb_validatePermission.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-include_once '../include/dyn_css.php';
-$adm = new administration();
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>Edit WMS Metadata</title>
-<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET; ?>">
-<script language="JavaScript">
-var dTarget;
-function save() {
-   document.forms[0].update_content.value=1;
-   document.forms[0].submit();
-function deletepreview(layer_id) {
-	var url = String(document.location);
-	url = url.substr(0, url.indexOf('?'));
-	window.open(url+"?<?php echo $urlParameters; ?>&delete_preview=1&layer_id="+layer_id,'delete preview', 'height=50, width=150, dependent=yes');
-	document.getElementById(layer_id+"_dp").style.display="none";
-function pick_the_date(obj) {
-    dTarget = obj;
-	var datePickerParameters = "m=Jan_Feb_Mrz_Apr_Mai_Jun_Jul_Aug_Sep_Okt_Nov_Dez&d=Mo_Di_Mi_Do_Fr_Sa_So&t=heute";
-	var datePickerStyle = "left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0"
-    var dp = window.open('../extensions/datepicker/datepicker.php?' + datePickerParameters,'dp',datePickerStyle);
-    dp.focus();
-    return false;
-</script>
-</head>
-<body>
-<?php
-function guessTimestamp($timestr) {
-     if (mb_strpos($timestr, '.')) {
-        list($day, $month, $year) = explode(".", $timestr);
-     elseif (mb_strpos($timestr, '/')) {
-        list($month, $day, $year) = explode("/", $timestr);
-     elseif (mb_strpos($timestr, '-')) {
-        list($year, $month, $day) = explode("-", $timestr);
-     else {
-     	$year = 0;
-        $month = 0;
-        $day = 0;
-     return mktime(0, 0, 0, $month, $day, intval($year));
-#Update handling
-if (isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true) {
-	$update_wms_sql = "UPDATE wms SET ";
-	$update_wms_sql .= "wms_title = $1, wms_abstract = $2, fees = $3, ";
-	$update_wms_sql .= "accessconstraints = $4, contactperson = $5, ";
-	$update_wms_sql .= "contactposition = $6, contactorganization = $7, ";
-	$update_wms_sql .= "address = $8, city = $9, stateorprovince = $10, ";
-	$update_wms_sql .= "postcode = $11, country = $12, ";
-	$update_wms_sql .= "contactvoicetelephone = $13, ";
-	$update_wms_sql .= "contactfacsimiletelephone = $14, ";
-	$update_wms_sql .= "contactelectronicmailaddress = $15 ";
-	$v = array();
-	array_push($v, $_REQUEST['wms_title_box']);
-	array_push($v, $_REQUEST['wms_abstract_box']);
-	array_push($v, $_REQUEST['fees_box']);
-	array_push($v, $_REQUEST['accessconstraints_box']);
-	array_push($v, $_REQUEST['contactperson_box']);
-	array_push($v, $_REQUEST['contactposition_box']);
-	array_push($v, $_REQUEST['contactorganization_box']);
-	array_push($v, $_REQUEST['address_box']);
-	array_push($v, $_REQUEST['city_box']);
-	array_push($v, $_REQUEST['stateorprovince_box']);
-	array_push($v, $_REQUEST['postcode_box']);
-	array_push($v, $_REQUEST['country_box']);
-	array_push($v, $_REQUEST['contactvoicetelephone_box']);
-	array_push($v, $_REQUEST['contactfacsimiletelephone_box']);
-	array_push($v, $_REQUEST['contactelectronicmailaddress_box']);
-	$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
-	if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "") {
-        $update_wms_sql .= ", wms_timestamp = $16 ";
-		array_push($v, guessTimestamp($_REQUEST['wms_timestamp_box']));
-		array_push($t, "s");
-		$update_wms_sql .= "WHERE wms_id = $17";
-	else {
-		$update_wms_sql .= "WHERE wms_id = $16";
-	array_push($v, 	$_REQUEST['wms_id']);
-    $res_update_wms_sql = db_prep_query($update_wms_sql, $v, $t);
-    while(list($key,$val) = each($_REQUEST)) {
-        if(preg_match("/___/", $key)) {
-            $myKey = explode("___", $key);
-            $layer_id = preg_replace("/L_/","",$myKey[0]);
-            if($myKey[1]=="layer_abstract") {
-				$layer_sql = "UPDATE layer SET layer_abstract = $1 ";
-				$layer_sql .= "WHERE layer_id = $2 AND fkey_wms_id = $3";
-                $v = array($val, $layer_id, $_REQUEST['wms_id']);
-                $t = array("s", "i", "s");
-                $res_keyword_sql = db_prep_query($layer_sql, $v, $t);
-            if($myKey[1]=="layer_keywords") {
-                #Get all keywords depending on the given layer after user modification
-                $keywords  = explode(",",$val);
-                #delete all blanks from the keywords list
-                for ($j = 0; $j < count($keywords); $j++) {
-                    $word = $keywords[$j];
-                    $word = trim($word);
-                    $keywords[$j] = $word;
-                #echo "1: Keywords eines Layers: id des Layers: ", $layer_id, ", �bergebener String: ", $val, ";<br>";
-                #Get all keywords depending on this layer from database
-                $keyword_sql = "SELECT keyword_id, keyword FROM keyword, layer_keyword, layer " .
-                               "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
-                               "AND layer_keyword.fkey_layer_id = layer.layer_id " .
-                               "AND layer.fkey_wms_id = $1 " .
-                               "AND layer.layer_id = $2";
-                $v = array($_REQUEST['wms_id'], $layer_id);
-                $t = array("s", "i");
-                $res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
-                while($keyword_row = db_fetch_array($res_keyword_sql))
-                    $keyword = $keyword_row['keyword'];
-                    $keyword_id = $keyword_row['keyword_id'];
-                    #keyword has been deleted or has been modified
-                    #keyword exists in database but not in user data
-                    $index = -1;
-                    #echo "1a: Abfrage ob DB Keywords in User Liste: Keyword: ", $keyword, ";<br>";
-                    if(in_array($keyword, $keywords) == false)
-                        #echo "1c: Keyword nicht in User Liste: Keyword: ", $keyword, ";<br>";
-                        #Deleting reference to the keyword from the layer_keyword table.
-                        $keyword_sql = "DELETE FROM layer_keyword " .
-                                       "WHERE fkey_layer_id = $1 " .
-                                       "AND fkey_keyword_id = $2";
-                        $v = array($layer_id, $keyword_id);
-                        $t = array("i", "i");
-                        db_prep_query($keyword_sql, $v, $t);
-                        #Checking, if the keyword is in use by any layer
-                        $layer_sql = "SELECT * FROM layer_keyword " .
-                                       "WHERE fkey_keyword_id = $1";
-                        $v = array($keyword_id);
-                        $t = array("i");
-                        $res_layer_sql = db_prep_query($layer_sql, $v, $t);
-                        if(!($row = db_fetch_array($res_layer_sql)))
-                            #If keyword will not longer be in use, delete it from keyword table
-                            $keyword_sql = "DELETE FROM keyword " .
-                                           "WHERE keyword_id = $1";
-                            $t = array("i");
-                    #Keyword exists in the database and in the user data
-                    else
-                        #echo "1d: Keyword ist in User Liste: Keyword: ", $keyword, ";<br>";
-                        for($i = 0; $i < count($keywords); $i++)
-                            #Delete keyword from the user data list, because the data
-                            #have not to be updated within the database
-                            if($keywords[$i] == $keyword)
-                                $keywords[$i] = null;
-                #Inserting keyword, that are not existing in the database
-                    #echo "2: Alle Eintr�ge des Keyword arrays: Keyword: ", $keywords[$i], "; Index: ", $i, ";<br>";
-                    if($keywords[$i] != null)
-                        #echo "3: Eintr�ge ungleich null: Keyword: ", $keywords[$i], "; Index: ", $i, ";<nr>";
-                        $keyword = trim($keywords[$i]);
-                        #Check, if the keyword is exsiting in the database
-                        $keyword_sql = "SELECT keyword_id FROM keyword " .
-                                       "WHERE UPPER(keyword) = UPPER($1)";
-                        $v = array($keyword);
-                        $t = array("s");
-                        $keyword_row = db_fetch_array($res_keyword_sql);
-                        if($keyword_row != null)
-                            $keyword_id = $keyword_row[0];
-                            #echo "4: Keyword in Datenbank vorhanden: id des Keywords: ", $keyword_id, ";<br>";
-                        #Keyword does not exist in the database
-                        else
-                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ($1)";
-                            $t = array("s");
-                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
-                            $t = array("s");
-                                #echo "4: Keyword in der Datenbank nicht vorhanden: id des Keywords: ", $keyword_id, ";<br>";
-                        #Inserting the reference between layer and keyword in the layer_keyword table
-                        $keyword_sql = "INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) " .
-                                       "VALUES ($1, $2)";
-                        $t = array("s", "s");
-                #Delete all elements from array
-                unset($keywords);
-unset($update_content);
-#delete preview
-if(isset($_REQUEST['delete_preview']) && $_REQUEST['delete_preview']=='1'
-	&& isset($_REQUEST['layer_id']))
-    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = $1";
-    $v = array($_REQUEST['layer_id']);
-    $t = array("s");
-    $res_preview_sql = db_prep_query($preview_sql, $v, $t);
-    die("Preview has been deleted!</body></html>");
-<form name='form1' action='<?php echo $self . "&show_wms_list=true"; ?>' method='post'>
-<table border='0'>
-<tr>
-<td WIDTH="300" align="left">
-<B>WMS Metadaten<B/>
-<td/>
-<td WIDTH="160">
-<td/>
-</tr>
-<?php
-#Use select box to select a wms
-if (isset($_REQUEST['show_wms_list']) && $_REQUEST['show_wms_list'] == true)
-    #Querying information from wms data table
-    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = $1 ORDER BY wms_title";
-    $v = array($_SESSION["mb_user_id"]);
-    $t = array("i");
-    $res_wms_sql = db_prep_query($wms_sql, $v, $t);
-    #wms-selection
-    $selectBox = "";
-    while($row = db_fetch_array($res_wms_sql)) {
-        if ($adm->getWmsPermission($row["wms_id"], $_SESSION['mb_user_id'])) {
-	        $selectBox .= "<option value='".$row["wms_id"]."' ";
-	        if(isset($_REQUEST['wmsList']) && $_REQUEST['wmsList'] == $row["wms_id"]) {
-	            $selectBox .= "selected";
-	        $selectBox .= "> ".$row["wms_title"]."</option>";
-    if ($selectBox != "") {
-	    echo "<tr><td>";
-	    echo "<select size=6 name='wmsList' onchange='submit()'>".$selectBox."</select>";
-	    echo "</td><td width='160px' align='right'>";
-	    echo "<input type='button' class='sbutton' value='save' onclick='save()'>";
-		echo "</td></tr>";
-    else {
-    	echo "<div>no wms owner.</div>";
-    	die;
-    if(isset($_REQUEST['wmsList']) == true && $_REQUEST['wmsList'] <>0)
-    editWMSByWMSID ($_REQUEST['wmsList']);
-echo "</table>";
-//$wms_id;
-function editWMSByWMSID($param_wms_id)
-    global $wms_id;
-    $wms_id = $param_wms_id;
-if(isset($wms_id) == true && $wms_id <>0)
-	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = $1";
-	$v = array($wms_id);
-	$t = array("s");
-    $res_selected_wms_sql = db_prep_query($selected_wms_sql, $v, $t);
-    $selected_row = db_fetch_array($res_selected_wms_sql);
-    <table border='0' class='table_top' >
-    <tr>
-    <td>WMS-Titel:<td><td/>
-    <input type='text' name='wms_title_box' value='<?php echo $selected_row["wms_title"];?>' /><td/>
-    <td>WMS- Abstract:<td><td/>
-    <input type='text' name='wms_abstract_box' value='<?php echo $selected_row["wms_abstract"];?>' /><td/>
-    <td >Fees:<td><td/>
-    <input type='text' name='fees_box' value='<?php echo $selected_row["fees"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>Access Constraints:<td><td/>
-    <input type='text' name='accessconstraints_box' value='<?php echo $selected_row["accessconstraints"]?>'/><td/>
-    <td>Contact Person:<td><td/>
-    <input type='text' name='contactperson_box' value='<?php echo $selected_row["contactperson"]?>'/><td/>
-    <td>Contact Position:<td><td/>
-    <input type='text' name='contactposition_box' value='<?php echo $selected_row["contactposition"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>Contact Organization:<td><td/>
-    <input type='text' name='contactorganization_box' value='<?php echo $selected_row["contactorganization"]?>'/><td/>
-    <td>Address:<td><td/>
-    <input type='text' name='address_box' value='<?php echo $selected_row["address"]?>'/><td/>
-    <td style="width:">City:<td><td/>
-    <input type='text' name='city_box' value='<?php echo $selected_row["city"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>State or Province:<td><td/>
-    <input type='text' name='stateorprovince_box' value='<?php echo $selected_row["stateorprovince"]?>'/><td/>
-    <td>Postcode:<td><td/>
-    <input type='text' name='postcode_box' value='<?php echo $selected_row["postcode"]?>'/><td/>
-    <td>Country:<td><td/>
-    <input type='text' name='country_box' value='<?php echo $selected_row["country"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>Telephone:<td><td/>
-    <input type='text' name='contactvoicetelephone_box'
-        value='<?php echo $selected_row["contactvoicetelephone"]?>'/><td/>
-    <td>Fax:<td><td/>
-    <input type='text' name='contactfacsimiletelephone_box' value='<?php echo $selected_row["contactfacsimiletelephone"]?>'/><td/>
-    <td>E-Mail:<td><td/>
-    <input type='text' name='contactelectronicmailaddress_box' value='<?php echo $selected_row["contactelectronicmailaddress"]?>'/><td/>
-    <tr/>
-    <tr>
-    <?php
-  if (isset($selected_row["wms_timestamp"]) && $selected_row["wms_timestamp"] <> "") {
-    $datum = date("d.m.Y",$selected_row["wms_timestamp"]);
-  else $datum = ""
-    <td>Date:<td><td/>
-    <input type='text' name='wms_timestamp_box' value='<?php echo $datum?>' onClick='pick_the_date(document.form1.wms_timestamp_box)'/><td/>
-    <tr/>
-    <table class="table_layer">
-    <tr><td>Nr.</td><td>Title</td><td>Abstract</td><td>Keywords</td><td></td></tr>
-<?php
-    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1" .
-                 " ORDER BY layer_pos";
-    $t = array("s");
-    while($layer_row = db_fetch_array($res_layer_sql))
-        <tr align='center'>
-        <td><input type='text' size='1' name='L_<?php echo $layer_row['layer_id']?>___layer_nr'
-            value='<?php echo $layer_row['layer_pos']?>' readonly></td>
-        <td><input type='text' size='15' name='L_<?php echo $layer_row['layer_id']?>___layer_title'
-            value='<?php echo $layer_row['layer_title']?>' readonly></td>
-        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_abstract'
-            value='<?php echo $layer_row['layer_abstract']?>'>
-    <?php
-        $keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
-        $v = array($wms_id, $layer_row['layer_id']);
-        $keywordList = "";
-        $seperator = "";
-            if($keywordList != "")
-                $seperator = ",";
-            $keywordList .= $seperator.$keyword_row["keyword"];
-        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_keywords'
-             value='<?php echo $keywordList?>'>
-        </td>
-        <td>
-        <input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');">
-        </td>
-        <td>
-<?php
-    $preview_sql = "SELECT * FROM layer_preview " .
-                   "WHERE fkey_layer_id = ".$layer_row['layer_id']."";
-    $res_preview_sql = db_query($preview_sql);
-	if(db_numrows($res_preview_sql)>0){?>
-        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
-<?php }else{?>
-        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' style="display:none;" onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
-<?php }*/?>
-        </td>
-        </tr>
-    <?php
-    #editWMSByWMSID(961);
-    </table>
-    <input type='hidden' name='update_content' value=''/>
-    <input type='hidden' name='wms_id' value='<?php echo $wms_id ?>'/>
-    <input type="hidden" value='' name='delete_preview'>
-    <input type="hidden" value='' name='layer_id'>
-    </form>
-    </body>
-    </html>
-<?php
+<?php
+# $Id$
+# http://www.mapbender.org/index.php?title=Edit_WMS_Metadata
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+include_once '../include/dyn_css.php';
+$adm = new administration();
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>Edit WMS Metadata</title>
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET; ?>">
+<script language="JavaScript">
+var dTarget;
+function save() {
+   document.forms[0].update_content.value=1;
+   document.forms[0].submit();
+function deletepreview(layer_id) {
+	var url = String(document.location);
+	url = url.substr(0, url.indexOf('?'));
+	window.open(url+"?<?php echo $urlParameters; ?>&delete_preview=1&layer_id="+layer_id,'delete preview', 'height=50, width=150, dependent=yes');
+	document.getElementById(layer_id+"_dp").style.display="none";
+function pick_the_date(obj) {
+    dTarget = obj;
+	var datePickerParameters = "m=Jan_Feb_Mrz_Apr_Mai_Jun_Jul_Aug_Sep_Okt_Nov_Dez&d=Mo_Di_Mi_Do_Fr_Sa_So&t=heute";
+	var datePickerStyle = "left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0"
+    var dp = window.open('../extensions/datepicker/datepicker.php?' + datePickerParameters,'dp',datePickerStyle);
+    dp.focus();
+    return false;
+</script>
+</head>
+<body>
+<?php
+function guessTimestamp($timestr) {
+     if (mb_strpos($timestr, '.')) {
+        list($day, $month, $year) = explode(".", $timestr);
+     elseif (mb_strpos($timestr, '/')) {
+        list($month, $day, $year) = explode("/", $timestr);
+     elseif (mb_strpos($timestr, '-')) {
+        list($year, $month, $day) = explode("-", $timestr);
+     else {
+     	$year = 0;
+        $month = 0;
+        $day = 0;
+     return mktime(0, 0, 0, $month, $day, intval($year));
+#Update handling
+if (isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true) {
+	$update_wms_sql = "UPDATE wms SET ";
+	$update_wms_sql .= "wms_title = $1, wms_abstract = $2, fees = $3, ";
+	$update_wms_sql .= "accessconstraints = $4, contactperson = $5, ";
+	$update_wms_sql .= "contactposition = $6, contactorganization = $7, ";
+	$update_wms_sql .= "address = $8, city = $9, stateorprovince = $10, ";
+	$update_wms_sql .= "postcode = $11, country = $12, ";
+	$update_wms_sql .= "contactvoicetelephone = $13, ";
+	$update_wms_sql .= "contactfacsimiletelephone = $14, ";
+	$update_wms_sql .= "contactelectronicmailaddress = $15 ";
+	$v = array();
+	array_push($v, $_REQUEST['wms_title_box']);
+	array_push($v, $_REQUEST['wms_abstract_box']);
+	array_push($v, $_REQUEST['fees_box']);
+	array_push($v, $_REQUEST['accessconstraints_box']);
+	array_push($v, $_REQUEST['contactperson_box']);
+	array_push($v, $_REQUEST['contactposition_box']);
+	array_push($v, $_REQUEST['contactorganization_box']);
+	array_push($v, $_REQUEST['address_box']);
+	array_push($v, $_REQUEST['city_box']);
+	array_push($v, $_REQUEST['stateorprovince_box']);
+	array_push($v, $_REQUEST['postcode_box']);
+	array_push($v, $_REQUEST['country_box']);
+	array_push($v, $_REQUEST['contactvoicetelephone_box']);
+	array_push($v, $_REQUEST['contactfacsimiletelephone_box']);
+	array_push($v, $_REQUEST['contactelectronicmailaddress_box']);
+	$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
+	if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "") {
+        $update_wms_sql .= ", wms_timestamp = $16 ";
+		array_push($v, guessTimestamp($_REQUEST['wms_timestamp_box']));
+		array_push($t, "s");
+		$update_wms_sql .= "WHERE wms_id = $17";
+	else {
+		$update_wms_sql .= "WHERE wms_id = $16";
+	array_push($v, 	$_REQUEST['wms_id']);
+    $res_update_wms_sql = db_prep_query($update_wms_sql, $v, $t);
+    while(list($key,$val) = each($_REQUEST)) {
+        if(preg_match("/___/", $key)) {
+            $myKey = explode("___", $key);
+            $layer_id = preg_replace("/L_/","",$myKey[0]);
+            if($myKey[1]=="layer_abstract") {
+				$layer_sql = "UPDATE layer SET layer_abstract = $1 ";
+				$layer_sql .= "WHERE layer_id = $2 AND fkey_wms_id = $3";
+                $v = array($val, $layer_id, $_REQUEST['wms_id']);
+                $t = array("s", "i", "s");
+                $res_keyword_sql = db_prep_query($layer_sql, $v, $t);
+            if($myKey[1]=="layer_keywords") {
+                #Get all keywords depending on the given layer after user modification
+                $keywords  = explode(",",$val);
+                #delete all blanks from the keywords list
+                for ($j = 0; $j < count($keywords); $j++) {
+                    $word = $keywords[$j];
+                    $word = trim($word);
+                    $keywords[$j] = $word;
+                #echo "1: Keywords eines Layers: id des Layers: ", $layer_id, ", �bergebener String: ", $val, ";<br>";
+                #Get all keywords depending on this layer from database
+                $keyword_sql = "SELECT keyword_id, keyword FROM keyword, layer_keyword, layer " .
+                               "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+                               "AND layer_keyword.fkey_layer_id = layer.layer_id " .
+                               "AND layer.fkey_wms_id = $1 " .
+                               "AND layer.layer_id = $2";
+                $v = array($_REQUEST['wms_id'], $layer_id);
+                $t = array("s", "i");
+                $res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
+                while($keyword_row = db_fetch_array($res_keyword_sql))
+                    $keyword = $keyword_row['keyword'];
+                    $keyword_id = $keyword_row['keyword_id'];
+                    #keyword has been deleted or has been modified
+                    #keyword exists in database but not in user data
+                    $index = -1;
+                    #echo "1a: Abfrage ob DB Keywords in User Liste: Keyword: ", $keyword, ";<br>";
+                    if(in_array($keyword, $keywords) == false)
+                        #echo "1c: Keyword nicht in User Liste: Keyword: ", $keyword, ";<br>";
+                        #Deleting reference to the keyword from the layer_keyword table.
+                        $keyword_sql = "DELETE FROM layer_keyword " .
+                                       "WHERE fkey_layer_id = $1 " .
+                                       "AND fkey_keyword_id = $2";
+                        $v = array($layer_id, $keyword_id);
+                        $t = array("i", "i");
+                        db_prep_query($keyword_sql, $v, $t);
+                        #Checking, if the keyword is in use by any layer
+                        $layer_sql = "SELECT * FROM layer_keyword " .
+                                       "WHERE fkey_keyword_id = $1";
+                        $v = array($keyword_id);
+                        $t = array("i");
+                        $res_layer_sql = db_prep_query($layer_sql, $v, $t);
+                        if(!($row = db_fetch_array($res_layer_sql)))
+                            #If keyword will not longer be in use, delete it from keyword table
+                            $keyword_sql = "DELETE FROM keyword " .
+                                           "WHERE keyword_id = $1";
+                            $t = array("i");
+                    #Keyword exists in the database and in the user data
+                    else
+                        #echo "1d: Keyword ist in User Liste: Keyword: ", $keyword, ";<br>";
+                        for($i = 0; $i < count($keywords); $i++)
+                            #Delete keyword from the user data list, because the data
+                            #have not to be updated within the database
+                            if($keywords[$i] == $keyword)
+                                $keywords[$i] = null;
+                #Inserting keyword, that are not existing in the database
+                    #echo "2: Alle Eintr�ge des Keyword arrays: Keyword: ", $keywords[$i], "; Index: ", $i, ";<br>";
+                    if($keywords[$i] != null)
+                        #echo "3: Eintr�ge ungleich null: Keyword: ", $keywords[$i], "; Index: ", $i, ";<nr>";
+                        $keyword = trim($keywords[$i]);
+                        #Check, if the keyword is exsiting in the database
+                        $keyword_sql = "SELECT keyword_id FROM keyword " .
+                                       "WHERE UPPER(keyword) = UPPER($1)";
+                        $v = array($keyword);
+                        $t = array("s");
+                        $keyword_row = db_fetch_array($res_keyword_sql);
+                        if($keyword_row != null)
+                            $keyword_id = $keyword_row[0];
+                            #echo "4: Keyword in Datenbank vorhanden: id des Keywords: ", $keyword_id, ";<br>";
+                        #Keyword does not exist in the database
+                        else
+                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ($1)";
+                            $t = array("s");
+                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+                            $t = array("s");
+                                #echo "4: Keyword in der Datenbank nicht vorhanden: id des Keywords: ", $keyword_id, ";<br>";
+                        #Inserting the reference between layer and keyword in the layer_keyword table
+                        $keyword_sql = "INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) " .
+                                       "VALUES ($1, $2)";
+                        $t = array("s", "s");
+                #Delete all elements from array
+                unset($keywords);
+unset($update_content);
+#delete preview
+if(isset($_REQUEST['delete_preview']) && $_REQUEST['delete_preview']=='1'
+	&& isset($_REQUEST['layer_id']))
+    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = $1";
+    $v = array($_REQUEST['layer_id']);
+    $t = array("s");
+    $res_preview_sql = db_prep_query($preview_sql, $v, $t);
+    die("Preview has been deleted!</body></html>");
+<form name='form1' action='<?php echo $self . "&show_wms_list=true"; ?>' method='post'>
+<table border='0'>
+<tr>
+<td WIDTH="300" align="left">
+<B>WMS Metadaten<B/>
+<td/>
+<td WIDTH="160">
+<td/>
+</tr>
+<?php
+#Use select box to select a wms
+if (isset($_REQUEST['show_wms_list']) && $_REQUEST['show_wms_list'] == true)
+    #Querying information from wms data table
+    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = $1 ORDER BY wms_title";
+    $v = array(Mapbender::session()->get("mb_user_id"));
+    $t = array("i");
+    $res_wms_sql = db_prep_query($wms_sql, $v, $t);
+    #wms-selection
+    $selectBox = "";
+    while($row = db_fetch_array($res_wms_sql)) {
+        if ($adm->getWmsPermission($row["wms_id"], Mapbender::session()->get("mb_user_id"))) {
+	        $selectBox .= "<option value='".$row["wms_id"]."' ";
+	        if(isset($_REQUEST['wmsList']) && $_REQUEST['wmsList'] == $row["wms_id"]) {
+	            $selectBox .= "selected";
+	        $selectBox .= "> ".$row["wms_title"]."</option>";
+    if ($selectBox != "") {
+	    echo "<tr><td>";
+	    echo "<select size=6 name='wmsList' onchange='submit()'>".$selectBox."</select>";
+	    echo "</td><td width='160px' align='right'>";
+	    echo "<input type='button' class='sbutton' value='save' onclick='save()'>";
+		echo "</td></tr>";
+    else {
+    	echo "<div>no wms owner.</div>";
+    	die;
+    if(isset($_REQUEST['wmsList']) == true && $_REQUEST['wmsList'] <>0)
+    editWMSByWMSID ($_REQUEST['wmsList']);
+echo "</table>";
+//$wms_id;
+function editWMSByWMSID($param_wms_id)
+    global $wms_id;
+    $wms_id = $param_wms_id;
+if(isset($wms_id) == true && $wms_id <>0)
+	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = $1";
+	$v = array($wms_id);
+	$t = array("s");
+    $res_selected_wms_sql = db_prep_query($selected_wms_sql, $v, $t);
+    $selected_row = db_fetch_array($res_selected_wms_sql);
+    <table border='0' class='table_top' >
+    <tr>
+    <td>WMS-Titel:<td><td/>
+    <input type='text' name='wms_title_box' value='<?php echo $selected_row["wms_title"];?>' /><td/>
+    <td>WMS- Abstract:<td><td/>
+    <input type='text' name='wms_abstract_box' value='<?php echo $selected_row["wms_abstract"];?>' /><td/>
+    <td >Fees:<td><td/>
+    <input type='text' name='fees_box' value='<?php echo $selected_row["fees"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Access Constraints:<td><td/>
+    <input type='text' name='accessconstraints_box' value='<?php echo $selected_row["accessconstraints"]?>'/><td/>
+    <td>Contact Person:<td><td/>
+    <input type='text' name='contactperson_box' value='<?php echo $selected_row["contactperson"]?>'/><td/>
+    <td>Contact Position:<td><td/>
+    <input type='text' name='contactposition_box' value='<?php echo $selected_row["contactposition"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Contact Organization:<td><td/>
+    <input type='text' name='contactorganization_box' value='<?php echo $selected_row["contactorganization"]?>'/><td/>
+    <td>Address:<td><td/>
+    <input type='text' name='address_box' value='<?php echo $selected_row["address"]?>'/><td/>
+    <td style="width:">City:<td><td/>
+    <input type='text' name='city_box' value='<?php echo $selected_row["city"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>State or Province:<td><td/>
+    <input type='text' name='stateorprovince_box' value='<?php echo $selected_row["stateorprovince"]?>'/><td/>
+    <td>Postcode:<td><td/>
+    <input type='text' name='postcode_box' value='<?php echo $selected_row["postcode"]?>'/><td/>
+    <td>Country:<td><td/>
+    <input type='text' name='country_box' value='<?php echo $selected_row["country"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Telephone:<td><td/>
+    <input type='text' name='contactvoicetelephone_box'
+        value='<?php echo $selected_row["contactvoicetelephone"]?>'/><td/>
+    <td>Fax:<td><td/>
+    <input type='text' name='contactfacsimiletelephone_box' value='<?php echo $selected_row["contactfacsimiletelephone"]?>'/><td/>
+    <td>E-Mail:<td><td/>
+    <input type='text' name='contactelectronicmailaddress_box' value='<?php echo $selected_row["contactelectronicmailaddress"]?>'/><td/>
+    <tr/>
+    <tr>
+    <?php
+  if (isset($selected_row["wms_timestamp"]) && $selected_row["wms_timestamp"] <> "") {
+    $datum = date("d.m.Y",$selected_row["wms_timestamp"]);
+  else $datum = ""
+    <td>Date:<td><td/>
+    <input type='text' name='wms_timestamp_box' value='<?php echo $datum?>' onClick='pick_the_date(document.form1.wms_timestamp_box)'/><td/>
+    <tr/>
+    <table class="table_layer">
+    <tr><td>Nr.</td><td>Title</td><td>Abstract</td><td>Keywords</td><td></td></tr>
+<?php
+    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1" .
+                 " ORDER BY layer_pos";
+    $t = array("s");
+    while($layer_row = db_fetch_array($res_layer_sql))
+        <tr align='center'>
+        <td><input type='text' size='1' name='L_<?php echo $layer_row['layer_id']?>___layer_nr'
+            value='<?php echo $layer_row['layer_pos']?>' readonly></td>
+        <td><input type='text' size='15' name='L_<?php echo $layer_row['layer_id']?>___layer_title'
+            value='<?php echo $layer_row['layer_title']?>' readonly></td>
+        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_abstract'
+            value='<?php echo $layer_row['layer_abstract']?>'>
+    <?php
+        $keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
+        $v = array($wms_id, $layer_row['layer_id']);
+        $keywordList = "";
+        $seperator = "";
+            if($keywordList != "")
+                $seperator = ",";
+            $keywordList .= $seperator.$keyword_row["keyword"];
+        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_keywords'
+             value='<?php echo $keywordList?>'>
+        </td>
+        <td>
+        <input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');">
+        </td>
+        <td>
+<?php
+    $preview_sql = "SELECT * FROM layer_preview " .
+                   "WHERE fkey_layer_id = ".$layer_row['layer_id']."";
+    $res_preview_sql = db_query($preview_sql);
+	if(db_numrows($res_preview_sql)>0){?>
+        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
+<?php }else{?>
+        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' style="display:none;" onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
+<?php }*/?>
+        </td>
+        </tr>
+    <?php
+    #editWMSByWMSID(961);
+    </table>
+    <input type='hidden' name='update_content' value=''/>
+    <input type='hidden' name='wms_id' value='<?php echo $wms_id ?>'/>
+    <input type="hidden" value='' name='delete_preview'>
+    <input type="hidden" value='' name='layer_id'>
+    </form>
+    </body>
+    </html>
+<?php
\ No newline at end of file
More information about the Mapbender_commits mailing list
