[Mapbender-commits] r4175 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Jun 25 05:05:24 EDT 2009
Author: vera
Date: 2009-06-25 05:05:24 -0400 (Thu, 25 Jun 2009)
New Revision: 4175
trunk/mapbender/http/php/mod_gazetteerMetadata_search.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_gazetteerMetadata_search.php
--- trunk/mapbender/http/php/mod_gazetteerMetadata_search.php 2009-06-25 09:04:08 UTC (rev 4174)
+++ trunk/mapbender/http/php/mod_gazetteerMetadata_search.php 2009-06-25 09:05:24 UTC (rev 4175)
@@ -1,125 +1,125 @@
-<?php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$json = new Mapbender_JSON();
-$user_id = $_SESSION["mb_user_id"];
-$query = stripslashes($_REQUEST["search"]);
-$srs = stripslashes($_REQUEST["srs"]);
-if (!preg_match("/^[a-zA-Z_\- ]+$/", $query)) {
- echo "[]"; die;
-if (!preg_match("/^[a-zA-Z_\-:0-9 ]+$/", $srs)) {
- echo "[]"; die;
-$n = new administration();
-$myguis = $n->getGuisByPermission($user_id, true);
-$mywms = $n->getWmsByOwnGuis($myguis);
-if($mywms == false){
- $mywms = array();
-$mylayer = array();
-for($i = 0; $i < count($mywms); $i++){
- $mylayer = array_merge($mylayer,$n->getLayerByWms($mywms[$i]));
-$res_container_wms = array();
-$res_container_layer = array();
-$obj = array();
-if(preg_match("/\*/",$_REQUEST["search"])){
- $search = trim(preg_replace("/\*/i","", $_REQUEST["search"]));
-if (count($mywms) > 0) {
- $v = array();
- $t = array();
- $sql_wms = "SELECT DISTINCT layer.layer_id, wms.wms_title, " .
- "wms.wms_getcapabilities, wms.wms_version, " .
- "e.minx, e.miny, e.maxx, e.maxy " .
- "FROM wms LEFT JOIN layer ON wms.wms_id = layer.fkey_wms_id " .
- "LEFT JOIN layer_epsg e ON layer.layer_id = e.fkey_layer_id " .
- "AND e.epsg = '$srs' " .
- "WHERE layer.layer_pos = 0 AND wms.wms_id IN (";
- for($i=0; $i<count($mywms); $i++){
- if ($i > 0) {$sql_wms .= ",";}
- $sql_wms .= "$".($i+1);
- array_push($v, $mywms[$i]);
- array_push($t, 'i');
- $sql_wms .= ") AND (wms_title ILIKE '%".$query."%' OR wms_abstract ILIKE '%".$query."%') ORDER BY wms_title";
- $res_wms = db_prep_query($sql_wms,$v,$t);
- while ($row = db_fetch_array($res_wms)) {
- array_push($obj, array(
- 'wms_getcapabilities' => $row['wms_getcapabilities'],
- 'wms_version' => $row['wms_version'],
- 'layer_id' => $row['layer_id'],
- 'title' => $row['wms_title'],
- 'extent' => array(
- $row['minx'],
- $row['miny'],
- $row['maxx'],
- $row['maxy']
-if (count($mylayer) > 0) {
- $v = array();
- $t = array();
- $sql_layer = "SELECT DISTINCT l.layer_id, l.fkey_wms_id, l.layer_title, " .
- "l.layer_name, w.wms_getcapabilities, w.wms_version, " .
- "FROM layer l LEFT JOIN layer_keyword lkw " .
- "LEFT JOIN keyword kw ON kw.keyword_id = lkw.fkey_keyword_id " .
- "ON l.layer_id = lkw.fkey_layer_id " .
- "LEFT JOIN wms w ON l.fkey_wms_id = w.wms_id " .
- "LEFT JOIN layer_epsg e ON l.layer_id = e.fkey_layer_id " .
- "WHERE l.layer_id IN (";
- for($i = 0; $i < count($mylayer); $i++){
- if ($i > 0) {$sql_layer .= ",";}
- $sql_layer .= "$".($i+1);
- array_push($v, $mylayer[$i]);
- $sql_layer .= ") AND (" .
- "layer_title ILIKE '%".$query."%' OR " .
- "layer_name ILIKE '%".$query."%' OR " .
- "layer_abstract ILIKE '%".$query."%' OR " .
- "kw.keyword ILIKE '%".$query."%') ";
- $sql_layer .= "ORDER BY l.layer_title;";
- $res_layer = db_prep_query($sql_layer,$v,$t);
- while ($row = db_fetch_array($res_layer)) {
- 'layer_name' => $row['layer_name'],
- 'title' => $row['layer_title'],
- $row['minx'],
- $row['miny'],
- $row['maxx'],
- $row['maxy']
-$output = $json->encode($obj);
-echo $output;
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$json = new Mapbender_JSON();
+$user_id = Mapbender::session()->get("mb_user_id");
+$query = stripslashes($_REQUEST["search"]);
+$srs = stripslashes($_REQUEST["srs"]);
+if (!preg_match("/^[a-zA-Z_\- ]+$/", $query)) {
+ echo "[]"; die;
+if (!preg_match("/^[a-zA-Z_\-:0-9 ]+$/", $srs)) {
+ echo "[]"; die;
+$n = new administration();
+$myguis = $n->getGuisByPermission($user_id, true);
+$mywms = $n->getWmsByOwnGuis($myguis);
+if($mywms == false){
+ $mywms = array();
+$mylayer = array();
+for($i = 0; $i < count($mywms); $i++){
+ $mylayer = array_merge($mylayer,$n->getLayerByWms($mywms[$i]));
+$res_container_wms = array();
+$res_container_layer = array();
+$obj = array();
+if(preg_match("/\*/",$_REQUEST["search"])){
+ $search = trim(preg_replace("/\*/i","", $_REQUEST["search"]));
+if (count($mywms) > 0) {
+ $v = array();
+ $t = array();
+ $sql_wms = "SELECT DISTINCT layer.layer_id, wms.wms_title, " .
+ "wms.wms_getcapabilities, wms.wms_version, " .
+ "e.minx, e.miny, e.maxx, e.maxy " .
+ "FROM wms LEFT JOIN layer ON wms.wms_id = layer.fkey_wms_id " .
+ "LEFT JOIN layer_epsg e ON layer.layer_id = e.fkey_layer_id " .
+ "AND e.epsg = '$srs' " .
+ "WHERE layer.layer_pos = 0 AND wms.wms_id IN (";
+ for($i=0; $i<count($mywms); $i++){
+ if ($i > 0) {$sql_wms .= ",";}
+ $sql_wms .= "$".($i+1);
+ array_push($v, $mywms[$i]);
+ array_push($t, 'i');
+ $sql_wms .= ") AND (wms_title ILIKE '%".$query."%' OR wms_abstract ILIKE '%".$query."%') ORDER BY wms_title";
+ $res_wms = db_prep_query($sql_wms,$v,$t);
+ while ($row = db_fetch_array($res_wms)) {
+ array_push($obj, array(
+ 'wms_getcapabilities' => $row['wms_getcapabilities'],
+ 'wms_version' => $row['wms_version'],
+ 'layer_id' => $row['layer_id'],
+ 'title' => $row['wms_title'],
+ 'extent' => array(
+ $row['minx'],
+ $row['miny'],
+ $row['maxx'],
+ $row['maxy']
+if (count($mylayer) > 0) {
+ $v = array();
+ $t = array();
+ $sql_layer = "SELECT DISTINCT l.layer_id, l.fkey_wms_id, l.layer_title, " .
+ "l.layer_name, w.wms_getcapabilities, w.wms_version, " .
+ "FROM layer l LEFT JOIN layer_keyword lkw " .
+ "LEFT JOIN keyword kw ON kw.keyword_id = lkw.fkey_keyword_id " .
+ "ON l.layer_id = lkw.fkey_layer_id " .
+ "LEFT JOIN wms w ON l.fkey_wms_id = w.wms_id " .
+ "LEFT JOIN layer_epsg e ON l.layer_id = e.fkey_layer_id " .
+ "WHERE l.layer_id IN (";
+ for($i = 0; $i < count($mylayer); $i++){
+ if ($i > 0) {$sql_layer .= ",";}
+ $sql_layer .= "$".($i+1);
+ array_push($v, $mylayer[$i]);
+ $sql_layer .= ") AND (" .
+ "layer_title ILIKE '%".$query."%' OR " .
+ "layer_name ILIKE '%".$query."%' OR " .
+ "layer_abstract ILIKE '%".$query."%' OR " .
+ "kw.keyword ILIKE '%".$query."%') ";
+ $sql_layer .= "ORDER BY l.layer_title;";
+ $res_layer = db_prep_query($sql_layer,$v,$t);
+ while ($row = db_fetch_array($res_layer)) {
+ 'layer_name' => $row['layer_name'],
+ 'title' => $row['layer_title'],
+ $row['minx'],
+ $row['miny'],
+ $row['maxx'],
+ $row['maxy']
+$output = $json->encode($obj);
+echo $output;
More information about the Mapbender_commits
