[Mapbender-commits] r4185 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Thu Jun 25 05:34:13 EDT 2009
Author: vera
Date: 2009-06-25 05:34:13 -0400 (Thu, 25 Jun 2009)
New Revision: 4185
   trunk/mapbender/http/php/mod_loadwmc_server.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_loadwmc_server.php
--- trunk/mapbender/http/php/mod_loadwmc_server.php	2009-06-25 09:33:00 UTC (rev 4184)
+++ trunk/mapbender/http/php/mod_loadwmc_server.php	2009-06-25 09:34:13 UTC (rev 4185)
@@ -1,180 +1,180 @@
-<?php
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../classes/class_user.php");
-require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
-require_once(dirname(__FILE__) . "/../classes/class_json.php");
-require_once(dirname(__FILE__) . "/../classes/class_administration.php");
- * encodes and delivers the data
- * @param object the un-encoded object
-function sendOutput($out){
-	global $json;
-	$output = $json->encode($out);
-	if (CHARSET == "ISO-8859-1") {
-		$output = utf8_decode($output);
-	header("Content-Type: text/x-json");
-	echo $output;
- * Get all available WMC documents from the database
- * @return mixed[] an array of wmcs
- * 					(wmc = assoc. array of "id", "title", "timestamp")
-function getWmc(){
-	global $con;
-	global $userId;
-	$wmcArray = array();
-	// get WMC ids
-	$currentUser = new User($userId);
-	$wmcIdArray = $currentUser->getWmcByOwner();
-	// get WMC data
-	$v = array();
-	$t = array();
-	$wmcIdList = "";
-	for ($i = 0; $i < count($wmcIdArray); $i++) {
-		if ($i > 0) {
-			$wmcIdList .= ",";
-		$wmcIdList .= "$".($i+1);
-		array_push($v, $wmcIdArray[$i]);
-		array_push($t, 's');
-	if ($wmcIdList !== "") {
-		$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
-		$sql .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
-		$sql .=	"ORDER BY wmc_timestamp DESC";
-		$res = db_prep_query($sql, $v, $t);
-		while($row = db_fetch_array($res)){
-			$currentResult = array();
-			$currentResult["id"] = $row["wmc_id"];
-			$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
-			$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
-			array_push($wmcArray, $currentResult);
-	return $wmcArray;
-$json = new Mapbender_JSON();
-$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
-$resultObj = array();
-$e = new mb_exception("command: " . $queryObj->command);
-$wmc = new wmc();
-$userId = $_SESSION[mb_user_id];
-switch($queryObj->command){
-	// gets available WMCs
-	case 'getWmc':
-		$resultObj["wmc"] = getWmc();
-	break;
-	// gets XML document of a WMC
-	case 'getWmcDocument':
-		$wmcId = $queryObj->parameters->id;
-		$doc = $wmc->getDocument($wmcId);
-		if (!$doc) {
-			$resultObj["error"] = "The WMC document could not be found.";
-		else {
-			$resultObj["wmc"] = array("document" => $doc);
-	break;
-	// deletes a WMC
-	case 'deleteWmc':
-		if ($wmc->delete($wmcId)) {
-			$resultObj["success"] = "WMC has been deleted from the database.";
-		else {
-			$resultObj["error"] = "WMC could not be deleted.";
-	break;
-	// loads a WMC (returns array of JS code)
-	case 'loadWmc':
-		$wmc->createFromDb($wmcId);
-		$jsArray = $wmc->toJavaScript();
-		if ($jsArray) {
-			$resultObj["javascript"] = $jsArray;
-		else {
-			$resultObj["error"] = "WMC could not be loaded.";
-	break;
-	// merges data with WMC and loads it (returns array of JS code)
-	case 'mergeWmc':
-		$params = $queryObj->parameters;
-		// generate a WMC for the current client state
-		$currentWmc = new wmc();
-		$currentWmc->createFromJs($params->mapObject, $params->generalTitle, $params->extensionData);
-		// get the desired WMC from the database
-		$wmcXml = wmc::getDocument($wmcId);
-		// merge the two WMCs
-		$currentWmc->merge($wmcXml);
-		// load the merged WMC
-		$jsArray = $currentWmc->toJavaScript();
-		if (is_array($jsArray) && count($jsArray) > 0) {
-		else {
-	break;
-	// appends a WMC (returns JS code)
-	case 'appendWmc':
-		$currentWmc->append($wmcXml);
-		else {
-			$resultObj["error"] = "WMC could not be appended.";
-	break;
-	// Invalid command
-	default:
-		$resultObj["error"] = "no action specified...";
-sendOutput($resultObj);
+<?php
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+ * encodes and delivers the data
+ * @param object the un-encoded object
+function sendOutput($out){
+	global $json;
+	$output = $json->encode($out);
+	if (CHARSET == "ISO-8859-1") {
+		$output = utf8_decode($output);
+	header("Content-Type: text/x-json");
+	echo $output;
+ * Get all available WMC documents from the database
+ * @return mixed[] an array of wmcs
+ * 					(wmc = assoc. array of "id", "title", "timestamp")
+function getWmc(){
+	global $con;
+	global $userId;
+	$wmcArray = array();
+	// get WMC ids
+	$currentUser = new User($userId);
+	$wmcIdArray = $currentUser->getWmcByOwner();
+	// get WMC data
+	$v = array();
+	$t = array();
+	$wmcIdList = "";
+	for ($i = 0; $i < count($wmcIdArray); $i++) {
+		if ($i > 0) {
+			$wmcIdList .= ",";
+		$wmcIdList .= "$".($i+1);
+		array_push($v, $wmcIdArray[$i]);
+		array_push($t, 's');
+	if ($wmcIdList !== "") {
+		$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
+		$sql .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
+		$sql .=	"ORDER BY wmc_timestamp DESC";
+		$res = db_prep_query($sql, $v, $t);
+		while($row = db_fetch_array($res)){
+			$currentResult = array();
+			$currentResult["id"] = $row["wmc_id"];
+			$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
+			$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
+			array_push($wmcArray, $currentResult);
+	return $wmcArray;
+$json = new Mapbender_JSON();
+$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
+$resultObj = array();
+$e = new mb_exception("command: " . $queryObj->command);
+$wmc = new wmc();
+$userId = Mapbender::session()->get("mb_user_id");
+switch($queryObj->command){
+	// gets available WMCs
+	case 'getWmc':
+		$resultObj["wmc"] = getWmc();
+	break;
+	// gets XML document of a WMC
+	case 'getWmcDocument':
+		$wmcId = $queryObj->parameters->id;
+		$doc = $wmc->getDocument($wmcId);
+		if (!$doc) {
+			$resultObj["error"] = "The WMC document could not be found.";
+		else {
+			$resultObj["wmc"] = array("document" => $doc);
+	break;
+	// deletes a WMC
+	case 'deleteWmc':
+		if ($wmc->delete($wmcId)) {
+			$resultObj["success"] = "WMC has been deleted from the database.";
+		else {
+			$resultObj["error"] = "WMC could not be deleted.";
+	break;
+	// loads a WMC (returns array of JS code)
+	case 'loadWmc':
+		$wmc->createFromDb($wmcId);
+		$jsArray = $wmc->toJavaScript();
+		if ($jsArray) {
+			$resultObj["javascript"] = $jsArray;
+		else {
+			$resultObj["error"] = "WMC could not be loaded.";
+	break;
+	// merges data with WMC and loads it (returns array of JS code)
+	case 'mergeWmc':
+		$params = $queryObj->parameters;
+		// generate a WMC for the current client state
+		$currentWmc = new wmc();
+		$currentWmc->createFromJs($params->mapObject, $params->generalTitle, $params->extensionData);
+		// get the desired WMC from the database
+		$wmcXml = wmc::getDocument($wmcId);
+		// merge the two WMCs
+		$currentWmc->merge($wmcXml);
+		// load the merged WMC
+		$jsArray = $currentWmc->toJavaScript();
+		if (is_array($jsArray) && count($jsArray) > 0) {
+		else {
+	break;
+	// appends a WMC (returns JS code)
+	case 'appendWmc':
+		$currentWmc->append($wmcXml);
+		else {
+			$resultObj["error"] = "WMC could not be appended.";
+	break;
+	// Invalid command
+	default:
+		$resultObj["error"] = "no action specified...";
+sendOutput($resultObj);
More information about the Mapbender_commits
