[Mapbender-commits] r4239 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Fri Jun 26 05:57:33 EDT 2009
Author: astrid_emde
Date: 2009-06-26 05:57:33 -0400 (Fri, 26 Jun 2009)
New Revision: 4239
branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php
checkSrs() only checks that the ESPG Code is matching checks f.e. EPSG:4326
Modified: branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php 2009-06-26 08:28:23 UTC (rev 4238)
+++ branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php 2009-06-26 09:57:33 UTC (rev 4239)
@@ -611,11 +611,14 @@
//check SRS
var ind = parent.getMapObjIndexByName("mapframe1");
var submit = document.getElementById("submitButton");
- if(global_wfsConfObj[global_selectedWfsConfId].featuretype_srs.toUpperCase()!=parent.mb_mapObj[ind].getSRS().toUpperCase()){
- var msg = "Different EPSG of map and wfs featuretype, no spatial request possible!\n";
- msg += parent.mb_mapObj[ind].getSRS()+" und "+global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
+ var patternString = parent.mb_mapObj[ind].getSRS().toUpperCase();
+ var pattern = new RegExp(patternString);
+if(global_wfsConfObj[global_selectedWfsConfId].featuretype_srs.match(pattern) == -1){
+ var msg = '<?php echo _mb("Different EPSG of map and wfs featuretype, no spatial request possible!");?>';
+ msg += parent.mb_mapObj[ind].getSRS()+" - "+global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
alert(msg);
//disable Submit Button
if(submit)submit.disabled = true;
More information about the Mapbender_commits
