[Mapbender-commits] r4134 - in trunk/mapbender/documents/api_js: .
Data files files/docs files/docs/javascript files/http
files/http/javascripts files/lib index javascript search styles
svn_mapbender at osgeo.org
Wed Jun 24 11:47:55 EDT 2009
Author: christoph
Date: 2009-06-24 11:47:55 -0400 (Wed, 24 Jun 2009)
New Revision: 4134
Added:
trunk/mapbender/documents/api_js/Data/
trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
trunk/mapbender/documents/api_js/Data/FileInfo.nd
trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd
trunk/mapbender/documents/api_js/Data/IndexInfo.nd
trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
trunk/mapbender/documents/api_js/Data/SymbolTable.nd
trunk/mapbender/documents/api_js/files/
trunk/mapbender/documents/api_js/files/docs/
trunk/mapbender/documents/api_js/files/docs/javascript/
trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html
trunk/mapbender/documents/api_js/files/http/
trunk/mapbender/documents/api_js/files/http/javascripts/
trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html
trunk/mapbender/documents/api_js/files/lib/
trunk/mapbender/documents/api_js/files/lib/event-js.html
trunk/mapbender/documents/api_js/index/
trunk/mapbender/documents/api_js/index/Classes.html
trunk/mapbender/documents/api_js/index/Files.html
trunk/mapbender/documents/api_js/index/Functions.html
trunk/mapbender/documents/api_js/index/General.html
trunk/mapbender/documents/api_js/index/Variables.html
trunk/mapbender/documents/api_js/javascript/
trunk/mapbender/documents/api_js/javascript/main.js
trunk/mapbender/documents/api_js/javascript/searchdata.js
trunk/mapbender/documents/api_js/search/
trunk/mapbender/documents/api_js/search/ClassesE.html
trunk/mapbender/documents/api_js/search/ClassesM.html
trunk/mapbender/documents/api_js/search/ClassesR.html
trunk/mapbender/documents/api_js/search/ClassesS.html
trunk/mapbender/documents/api_js/search/ClassesZ.html
trunk/mapbender/documents/api_js/search/FilesM.html
trunk/mapbender/documents/api_js/search/FunctionsA.html
trunk/mapbender/documents/api_js/search/FunctionsC.html
trunk/mapbender/documents/api_js/search/FunctionsD.html
trunk/mapbender/documents/api_js/search/FunctionsH.html
trunk/mapbender/documents/api_js/search/FunctionsI.html
trunk/mapbender/documents/api_js/search/FunctionsM.html
trunk/mapbender/documents/api_js/search/FunctionsO.html
trunk/mapbender/documents/api_js/search/FunctionsR.html
trunk/mapbender/documents/api_js/search/FunctionsS.html
trunk/mapbender/documents/api_js/search/FunctionsT.html
trunk/mapbender/documents/api_js/search/GeneralA.html
trunk/mapbender/documents/api_js/search/GeneralC.html
trunk/mapbender/documents/api_js/search/GeneralD.html
trunk/mapbender/documents/api_js/search/GeneralE.html
trunk/mapbender/documents/api_js/search/GeneralF.html
trunk/mapbender/documents/api_js/search/GeneralH.html
trunk/mapbender/documents/api_js/search/GeneralI.html
trunk/mapbender/documents/api_js/search/GeneralK.html
trunk/mapbender/documents/api_js/search/GeneralL.html
trunk/mapbender/documents/api_js/search/GeneralM.html
trunk/mapbender/documents/api_js/search/GeneralN.html
trunk/mapbender/documents/api_js/search/GeneralO.html
trunk/mapbender/documents/api_js/search/GeneralR.html
trunk/mapbender/documents/api_js/search/GeneralS.html
trunk/mapbender/documents/api_js/search/GeneralT.html
trunk/mapbender/documents/api_js/search/GeneralV.html
trunk/mapbender/documents/api_js/search/GeneralZ.html
trunk/mapbender/documents/api_js/search/NoResults.html
trunk/mapbender/documents/api_js/search/VariablesD.html
trunk/mapbender/documents/api_js/search/VariablesK.html
trunk/mapbender/documents/api_js/search/VariablesL.html
trunk/mapbender/documents/api_js/search/VariablesM.html
trunk/mapbender/documents/api_js/search/VariablesN.html
trunk/mapbender/documents/api_js/search/VariablesR.html
trunk/mapbender/documents/api_js/styles/
trunk/mapbender/documents/api_js/styles/main.css
Added: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,2 @@
+( Event */home/install/workspace/trunk/lib/event.js Mapbender 7/home/install/workspace/trunk/http/javascripts/core.php SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js Sandclock @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php Reload =/home/install/workspace/trunk/http/javascripts/mod_reload.php ZoomIn1 >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php
+SearchResults 5/home/install/workspace/trunk/docs/javascript/main.js Map 9/home/install/workspace/trunk/http/javascripts/map_obj.js
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
--- trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1 @@
+( JBEöJBEöJBEöJBEöJBEö
Property changes on: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
+ text/html
Added: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,558 @@
+1.4
+PHP
+/home/install/workspace/trunk/http/sld/classes/Fill.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Fill.php
+/home/install/workspace/trunk/lib/database-pgsql.php 1215532334 0 /home/install/workspace/trunk/lib/database-pgsql.php
+/home/install/workspace/trunk/http/classes/class_administration.php 1236782767 0 /home/install/workspace/trunk/http/classes/class_administration.php
+/home/install/workspace/trunk/http/classes/class_gml_multiline.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_multiline.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php 1245857248 0 /home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php
+/home/install/workspace/trunk/http/javascripts/mod_embedded_legend.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_embedded_legend.php
+/home/install/workspace/trunk/lib/style.js 1220515945 0 /home/install/workspace/trunk/lib/style.js
+/home/install/workspace/trunk/lib/draggableButton.js 1214236663 0 /home/install/workspace/trunk/lib/draggableButton.js
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_gazetteerMetadata_search.php 1235475918 0 /home/install/workspace/trunk/http/php/mod_gazetteerMetadata_search.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php
+/home/install/workspace/trunk/http/sld/sld_main.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_main.php
+/home/install/workspace/trunk/http/javascripts/mod_export_image.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_export_image.php
+/home/install/workspace/trunk/http/php/mod_saveWKT.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_saveWKT.php
+/home/install/workspace/trunk/http/sld/classes/GraphicStroke.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/GraphicStroke.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_wfs_conf_html.php 1244215918 0 /home/install/workspace/trunk/http/php/mod_wfs_conf_html.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php
+/home/install/workspace/trunk/docs/javascript/searchdata.js 1245847652 0 /home/install/workspace/trunk/docs/javascript/searchdata.js
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_main.php 1235406337 0 /home/install/workspace/trunk/tools/mod_monitorCapabilities_main.php
+/home/install/workspace/trunk/http/sld/classes/Font.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Font.php
+/home/install/workspace/trunk/http/javascripts/mod_saveLayerPreview.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_saveLayerPreview.php
+/home/install/workspace/trunk/http/classes/class_wfs_conf.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_wfs_conf.php
+/home/install/workspace/trunk/http/php/mod_deleteWFS.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_deleteWFS.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/classes/class_weldMaps2Image.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_weldMaps2Image.php
+/home/install/workspace/trunk/http/frames/login.php 1245838522 0 /home/install/workspace/trunk/http/frames/login.php
+/home/install/workspace/trunk/http/php/mod_user_filteredGroup.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_user_filteredGroup.php
+/home/install/workspace/trunk/http/extensions/datepicker/datepicker.php 1208966985 0 /home/install/workspace/trunk/http/extensions/datepicker/datepicker.php
+/home/install/workspace/trunk/license/licence_reference.txt 1144962192 0 /home/install/workspace/trunk/license/licence_reference.txt
+/home/install/workspace/trunk/http/php/mod_gazetteer_conf.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gazetteer_conf.php
+/home/install/workspace/trunk/http/javascripts/mod_state.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_state.php
+/home/install/workspace/trunk/lib/exception.js 1236874801 0 /home/install/workspace/trunk/lib/exception.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-CN.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-CN.js
+/home/install/workspace/trunk/lib/alignButton.js 1214236663 0 /home/install/workspace/trunk/lib/alignButton.js
+/home/install/workspace/trunk/http/include/dyn_css.php 1238749332 0 /home/install/workspace/trunk/http/include/dyn_css.php
+/home/install/workspace/trunk/http/javascripts/popup.js 1240915413 0 /home/install/workspace/trunk/http/javascripts/popup.js
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php
+/home/install/workspace/trunk/http/classes/class_wfs_featuretype.php 1233827180 0 /home/install/workspace/trunk/http/classes/class_wfs_featuretype.php
+/home/install/workspace/trunk/http/sld/sld_edit_filter.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_edit_filter.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-tr.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-tr.js
+/home/install/workspace/trunk/http/html/mod_treefolder2.php 1245838522 0 /home/install/workspace/trunk/http/html/mod_treefolder2.php
+/home/install/workspace/trunk/lib/class_Mapbender.php 1245838522 0 /home/install/workspace/trunk/lib/class_Mapbender.php
+/home/install/workspace/trunk/http/php/mod_tab_messages.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_tab_messages.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-no.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-no.js
+/home/install/workspace/trunk/http/sld/classes/LabelPlacement.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/LabelPlacement.php
+/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredUser_filteredGui.php
+/home/install/workspace/trunk/http/classes/class_kml_point.php 1222869057 0 /home/install/workspace/trunk/http/classes/class_kml_point.php
+/home/install/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php 1208966985 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php
+/home/install/workspace/trunk/http/sld/classes/GraphicFill.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/GraphicFill.php
+/home/install/workspace/trunk/http/javascripts/mod_toggleModule.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_toggleModule.php
+/home/install/workspace/trunk/http/extensions/ext_featureInfoTunnel.php 1219923953 0 /home/install/workspace/trunk/http/extensions/ext_featureInfoTunnel.php
+/home/install/workspace/trunk/http/classes/class_mb_notice.php 1199464420 0 /home/install/workspace/trunk/http/classes/class_mb_notice.php
+/home/install/workspace/trunk/http/php/mod_loadCapabilitiesList.php 1217937298 0 /home/install/workspace/trunk/http/php/mod_loadCapabilitiesList.php
+/home/install/workspace/trunk/http/classes/class_weldLegend2PNG.php 1186386922 0 /home/install/workspace/trunk/http/classes/class_weldLegend2PNG.php
+/home/install/workspace/trunk/http/print/mod_printPDF_pdf.php 1237217323 0 /home/install/workspace/trunk/http/print/mod_printPDF_pdf.php
+/home/install/workspace/trunk/http/javascripts/mod_scaleText.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_scaleText.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-cs.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-cs.js
+/home/install/workspace/trunk/http/php/mod_loadCapabilities_temp.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_loadCapabilities_temp.php
+/home/install/workspace/trunk/http/javascripts/mod_coords.php 1230893633 0 /home/install/workspace/trunk/http/javascripts/mod_coords.php
+/home/install/workspace/trunk/http/php/mod_wfs_result.php 1235985010 0 /home/install/workspace/trunk/http/php/mod_wfs_result.php
+/home/install/workspace/trunk/http/classes/class_gml_feature_collection.php 1233657361 0 /home/install/workspace/trunk/http/classes/class_gml_feature_collection.php
+/home/install/workspace/trunk/http/php/mod_zoomCoords.php 1243284290 0 /home/install/workspace/trunk/http/php/mod_zoomCoords.php
+/home/install/workspace/trunk/http/classes/class_point.php 1231151408 0 /home/install/workspace/trunk/http/classes/class_point.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
+/home/install/workspace/trunk/lib/core.js 1245778754 0 /home/install/workspace/trunk/lib/core.js
+/home/install/workspace/trunk/http/php/mb_validateInput.php 1150787814 0 /home/install/workspace/trunk/http/php/mb_validateInput.php
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-id.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-id.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php
+/home/install/workspace/trunk/http/php/mb_validatePermission.php 1208967664 0 /home/install/workspace/trunk/http/php/mb_validatePermission.php
+/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.min.js 1214236582 0 /home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.min.js
+/home/install/workspace/trunk/http/php/mod_wfs_conf_client.php 1244215918 0 /home/install/workspace/trunk/http/php/mod_wfs_conf_client.php
+/home/install/workspace/trunk/http/php/mod_filteredGroup_Gui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGroup_Gui.php
+/home/install/workspace/trunk/lib/event.js 1245780994 1 Event
+/home/install/workspace/trunk/http/php/mod_export_image.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_export_image.php
+/home/install/workspace/trunk/http/javascripts/mod_selArea1.php 1238739052 0 /home/install/workspace/trunk/http/javascripts/mod_selArea1.php
+/home/install/workspace/trunk/http/javascripts/mod_cardindex.js 1200384689 0 /home/install/workspace/trunk/http/javascripts/mod_cardindex.js
+/home/install/workspace/trunk/http/javascripts/mod_add_vendorspecific.php 1245838522 0 /home/install/workspace/trunk/http/javascripts/mod_add_vendorspecific.php
+/home/install/workspace/trunk/http/php/mb_validateSession.php 1245838522 0 /home/install/workspace/trunk/http/php/mb_validateSession.php
+/home/install/workspace/trunk/http/php/mod_gui_owner.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gui_owner.php
+/home/install/workspace/trunk/http/extensions/OpenLayers.js 1214236582 0 /home/install/workspace/trunk/http/extensions/OpenLayers.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql 1218723822 0 /home/install/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql
+/home/install/workspace/trunk/http/include/template_splash.php 1234437340 0 /home/install/workspace/trunk/http/include/template_splash.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql 1243796060 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_read.php 1235406337 0 /home/install/workspace/trunk/tools/mod_monitorCapabilities_read.php
+/home/install/workspace/trunk/http/javascripts/mod_owsproxy.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_owsproxy.php
+/home/install/workspace/trunk/http/javascripts/mod_dependentIframe.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_dependentIframe.php
+/home/install/workspace/trunk/http/php/mod_editFilteredGroup.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editFilteredGroup.php
+/home/install/workspace/trunk/http/javascripts/mod_zoomCoords.php 1245771428 0 /home/install/workspace/trunk/http/javascripts/mod_zoomCoords.php
+/home/install/workspace/trunk/http/php/mod_newGui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_newGui.php
+/home/install/workspace/trunk/http/javascripts/mod_scaleSel.php 1245779179 0 /home/install/workspace/trunk/http/javascripts/mod_scaleSel.php
+/home/install/workspace/trunk/http/javascripts/mod_copyright.php 1245779661 0 /home/install/workspace/trunk/http/javascripts/mod_copyright.php
+/home/install/workspace/trunk/http/classes/class_wfs_factory.php 1236703245 0 /home/install/workspace/trunk/http/classes/class_wfs_factory.php
+/home/install/workspace/trunk/http/php/mod_filteredWms_topic.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredWms_topic.php
+/home/install/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php 1245779179 0 /home/install/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php
+/home/install/workspace/trunk/http/php/mod_button_tooltips.php 1245855574 0 /home/install/workspace/trunk/http/php/mod_button_tooltips.php
+/home/install/workspace/trunk/tools/char_code.php 1152008002 0 /home/install/workspace/trunk/tools/char_code.php
+/home/install/workspace/trunk/http/javascripts/mod_sandclock2.php 1213021102 0 /home/install/workspace/trunk/http/javascripts/mod_sandclock2.php
+/home/install/workspace/trunk/http/extensions/ext_weldMaps.php 1245838522 0 /home/install/workspace/trunk/http/extensions/ext_weldMaps.php
+/home/install/workspace/trunk/http/php/mod_digitize_messages.php 1237899999 0 /home/install/workspace/trunk/http/php/mod_digitize_messages.php
+/home/install/workspace/trunk/http/javascripts/mod_savewmc.php 1231425706 0 /home/install/workspace/trunk/http/javascripts/mod_savewmc.php
+/home/install/workspace/trunk/lib/i18n.php 1208967270 0 /home/install/workspace/trunk/lib/i18n.php
+/home/install/workspace/trunk/http/javascripts/mod_loadwmc.js 1236875384 0 /home/install/workspace/trunk/http/javascripts/mod_loadwmc.js
+/home/install/workspace/trunk/http/classes/class_layer_monitor.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_layer_monitor.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/javascripts/mod_legend.php 1237199301 0 /home/install/workspace/trunk/http/javascripts/mod_legend.php
+/home/install/workspace/trunk/docs/javascript/main.js 1245847652 1 SearchPanel
+/home/install/workspace/trunk/http/javascripts/map_obj.js 1245853941 1 Map
+/home/install/workspace/trunk/http/javascripts/initOpenLayersWms.php 1245838522 0 /home/install/workspace/trunk/http/javascripts/initOpenLayersWms.php
+/home/install/workspace/trunk/lib/point.js 1235985010 0 /home/install/workspace/trunk/lib/point.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hu.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hu.js
+/home/install/workspace/trunk/http/php/mod_treefolderClient.php 1229692761 0 /home/install/workspace/trunk/http/php/mod_treefolderClient.php
+/home/install/workspace/trunk/http/php/mod_loadCapabilities.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_loadCapabilities.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pt-BR.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pt-BR.js
+/home/install/workspace/trunk/http/php/mod_renameGUI.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_renameGUI.php
+/home/install/workspace/trunk/http/javascripts/mod_print1.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_print1.php
+/home/install/workspace/trunk/http/javascripts/mod_center1.php 1230893633 0 /home/install/workspace/trunk/http/javascripts/mod_center1.php
+/home/install/workspace/trunk/http/extensions/jquery.js 1208966985 0 /home/install/workspace/trunk/http/extensions/jquery.js
+/home/install/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php 1197632053 0 /home/install/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php
+/home/install/workspace/trunk/http/sld/classes/PolygonSymbolizer.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/PolygonSymbolizer.php
+/home/install/workspace/trunk/http/javascripts/mod_horizTabs.js 1204803057 0 /home/install/workspace/trunk/http/javascripts/mod_horizTabs.js
+/home/install/workspace/trunk/http/extensions/fisheye.js 1208966985 0 /home/install/workspace/trunk/http/extensions/fisheye.js
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/javascripts/mod_loadwmc.php 1236782767 0 /home/install/workspace/trunk/http/javascripts/mod_loadwmc.php
+/home/install/workspace/trunk/http/extensions/datepicker/datepicker.js 1208966985 0 /home/install/workspace/trunk/http/extensions/datepicker/datepicker.js
+/home/install/workspace/trunk/http/index.php 1237546299 0 /home/install/workspace/trunk/http/index.php
+/home/install/workspace/trunk/http/php/mod_zoomCoords_en.php 1210165862 0 /home/install/workspace/trunk/http/php/mod_zoomCoords_en.php
+/home/install/workspace/trunk/http/classes/class.ezpdf.php 1200385469 0 /home/install/workspace/trunk/http/classes/class.ezpdf.php
+/home/install/workspace/trunk/http/classes/class_keyword.php 1218442761 0 /home/install/workspace/trunk/http/classes/class_keyword.php
+/home/install/workspace/trunk/lib/resizableButton.js 1214236663 0 /home/install/workspace/trunk/lib/resizableButton.js
+/home/install/workspace/trunk/http/classes/class_locale.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_locale.php
+/home/install/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php
+/home/install/workspace/trunk/docs/Menu_Backup.txt 1245781036 0 /home/install/workspace/trunk/docs/Menu_Backup.txt
+/home/install/workspace/trunk/http/php/mod_mapOV.php 1226479717 0 /home/install/workspace/trunk/http/php/mod_mapOV.php
+/home/install/workspace/trunk/http/classes/class_wfs_1_1_factory.php 1236703245 0 /home/install/workspace/trunk/http/classes/class_wfs_1_1_factory.php
+/home/install/workspace/trunk/http/classes/class_user.php 1244215918 0 /home/install/workspace/trunk/http/classes/class_user.php
+/home/install/workspace/trunk/http/javascripts/mod_dragMapSize.php 1232623861 0 /home/install/workspace/trunk/http/javascripts/mod_dragMapSize.php
+/home/install/workspace/trunk/http/sld/classes/UserStyle.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/UserStyle.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-uk.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-uk.js
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
+/home/install/workspace/trunk/http/php/mod_editApplication_server.php 1214236840 0 /home/install/workspace/trunk/http/php/mod_editApplication_server.php
+/home/install/workspace/trunk/http/php/mod_exportGUI.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_exportGUI.php
+/home/install/workspace/trunk/http/javascripts/mod_navFrame.php 1239028534 0 /home/install/workspace/trunk/http/javascripts/mod_navFrame.php
+/home/install/workspace/trunk/http/javascripts/mod_selectMapsize.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_selectMapsize.php
+/home/install/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php 1225983996 0 /home/install/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php
+/home/install/workspace/trunk/http/javascripts/geometry.js 1245779178 0 /home/install/workspace/trunk/http/javascripts/geometry.js
+/home/install/workspace/trunk/http/javascripts/map.js 1245744950 0 /home/install/workspace/trunk/http/javascripts/map.js
+/home/install/workspace/trunk/log/ReadMe.txt 1144962718 0 /home/install/workspace/trunk/log/ReadMe.txt
+/home/install/workspace/trunk/http/classes/class_ows_factory.php 1233742970 0 /home/install/workspace/trunk/http/classes/class_ows_factory.php
+/home/install/workspace/trunk/http/javascripts/map.php 1245838522 0 /home/install/workspace/trunk/http/javascripts/map.php
+/home/install/workspace/trunk/http/classes/class_gml.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_gml.php
+/home/install/workspace/trunk/http/classes/class_weldMaps2PNG.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_weldMaps2PNG.php
+/home/install/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php
+/home/install/workspace/trunk/http/javascripts/mod_setTimeout.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_setTimeout.php
+/home/install/workspace/trunk/http/extensions/jquery.contextmenu.r2.js 1236961566 0 /home/install/workspace/trunk/http/extensions/jquery.contextmenu.r2.js
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single.php 1235406337 0 /home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single.php
+/home/install/workspace/trunk/Readme.txt 1240853897 0 /home/install/workspace/trunk/Readme.txt
+/home/install/workspace/trunk/lib/ajax.js 1239182831 0 /home/install/workspace/trunk/lib/ajax.js
+/home/install/workspace/trunk/lib/list.js 1213361788 0 /home/install/workspace/trunk/lib/list.js
+/home/install/workspace/trunk/http/php/mod_createJSObjFromXML.php 1236782767 0 /home/install/workspace/trunk/http/php/mod_createJSObjFromXML.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php
+/home/install/workspace/trunk/http/javascripts/mod_poi.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_poi.php
+/home/install/workspace/trunk/http/html/mod_treefolder2_multiple.php 1245838522 0 /home/install/workspace/trunk/http/html/mod_treefolder2_multiple.php
+/home/install/workspace/trunk/tools/send_post_curl.php 1243515049 0 /home/install/workspace/trunk/tools/send_post_curl.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php 1237043600 0 /home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php
+/home/install/workspace/trunk/license/license_js.txt 1150726978 0 /home/install/workspace/trunk/license/license_js.txt
+/home/install/workspace/trunk/lib/class_mapbender_session.php 1245838522 0 /home/install/workspace/trunk/lib/class_mapbender_session.php
+/home/install/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php
+/home/install/workspace/trunk/http/php/mod_digitize_mergePolygon.php 1223458316 0 /home/install/workspace/trunk/http/php/mod_digitize_mergePolygon.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/img/button_blue/README.TXT 1150456812 0 /home/install/workspace/trunk/http/img/button_blue/README.TXT
+/home/install/workspace/trunk/http/classes/class_metadata.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_metadata.php
+/home/install/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php 1239705380 0 /home/install/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php
+/home/install/workspace/trunk/http/tmp/ReadMe.txt 1145003810 0 /home/install/workspace/trunk/http/tmp/ReadMe.txt
+/home/install/workspace/trunk/http/classes/class_ows.php 1236703245 0 /home/install/workspace/trunk/http/classes/class_ows.php
+/home/install/workspace/trunk/http/extensions/jquery-1.2.6.min.js 1214236582 0 /home/install/workspace/trunk/http/extensions/jquery-1.2.6.min.js
+/home/install/workspace/trunk/http/sld/sld_function_getusersld.php 1231319765 0 /home/install/workspace/trunk/http/sld/sld_function_getusersld.php
+/home/install/workspace/trunk/http/php/mod_gui_user.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gui_user.php
+/home/install/workspace/trunk/http/extensions/wz_jsgraphics.js 1221663284 0 /home/install/workspace/trunk/http/extensions/wz_jsgraphics.js
+/home/install/workspace/trunk/http/javascripts/initWms.php 1236782767 0 /home/install/workspace/trunk/http/javascripts/initWms.php
+/home/install/workspace/trunk/http/javascripts/mod_back.php 1237199301 0 /home/install/workspace/trunk/http/javascripts/mod_back.php
+/home/install/workspace/trunk/http/php/mod_createCategory.php 1236068706 0 /home/install/workspace/trunk/http/php/mod_createCategory.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
+/home/install/workspace/trunk/http/php/mod_updateWMS.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_updateWMS.php
+/home/install/workspace/trunk/http/sld/classes/ParameterValue.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/ParameterValue.php
+/home/install/workspace/trunk/http/php/mod_gazetteer_edit.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gazetteer_edit.php
+/home/install/workspace/trunk/http/classes/class_stripRequest.php 1227687853 0 /home/install/workspace/trunk/http/classes/class_stripRequest.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ca.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ca.js
+/home/install/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js 1214236840 0 /home/install/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js
+/home/install/workspace/trunk/docs/Topics.txt 1245847652 0 /home/install/workspace/trunk/docs/Topics.txt
+/home/install/workspace/trunk/http/php/mod_usemap.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_usemap.php
+/home/install/workspace/trunk/http/sld/sld_parse.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_parse.php
+/home/install/workspace/trunk/http/include/dyn_js.php 1238749332 0 /home/install/workspace/trunk/http/include/dyn_js.php
+/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php
+/home/install/workspace/trunk/http/extensions/jquery.form.js 1236536525 0 /home/install/workspace/trunk/http/extensions/jquery.form.js
+/home/install/workspace/trunk/http/include/dyn_js_object.php 1245648655 0 /home/install/workspace/trunk/http/include/dyn_js_object.php
+/home/install/workspace/trunk/http/classes/class_checkInput.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_checkInput.php
+/home/install/workspace/trunk/http/sld/classes/UnaryLogicOp.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/UnaryLogicOp.php
+/home/install/workspace/trunk/http/classes/class_gml_multipolygon.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_multipolygon.php
+/home/install/workspace/trunk/http/javascripts/mod_box1.js 1245779179 0 /home/install/workspace/trunk/http/javascripts/mod_box1.js
+/home/install/workspace/trunk/http/javascripts/mod_home.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_home.php
+/home/install/workspace/trunk/http/sld/classes/Displacement.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Displacement.php
+/home/install/workspace/trunk/http/javascripts/mod_scalebar.php 1239704908 0 /home/install/workspace/trunk/http/javascripts/mod_scalebar.php
+/home/install/workspace/trunk/http/classes/class_kml_parser_ows.php 1222869057 0 /home/install/workspace/trunk/http/classes/class_kml_parser_ows.php
+/home/install/workspace/trunk/http/javascripts/mod_displayObj.js 1164286253 0 /home/install/workspace/trunk/http/javascripts/mod_displayObj.js
+/home/install/workspace/trunk/http/sld/classes/ElseFilter.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/ElseFilter.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-he.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-he.js
+/home/install/workspace/trunk/http/javascripts/mod_tab.js 1236949870 0 /home/install/workspace/trunk/http/javascripts/mod_tab.js
+/home/install/workspace/trunk/http/php/mod_gui_group.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gui_group.php
+/home/install/workspace/trunk/lib/selectableButton.js 1214236663 0 /home/install/workspace/trunk/lib/selectableButton.js
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql 1238355978 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/javascripts/mod_body.js 1245680608 0 /home/install/workspace/trunk/http/javascripts/mod_body.js
+/home/install/workspace/trunk/http/php/mb_getGUIs.php 1150727701 0 /home/install/workspace/trunk/http/php/mb_getGUIs.php
+/home/install/workspace/trunk/http/javascripts/mod_sandclock.php 1245779179 1 Sandclock
+/home/install/workspace/trunk/http/classes/class_mb_exception.php 1233657361 0 /home/install/workspace/trunk/http/classes/class_mb_exception.php
+/home/install/workspace/trunk/http/sld/classes/DisplayOperationModule.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/DisplayOperationModule.php
+/home/install/workspace/trunk/http/php/createImageFromText.php 1186565603 0 /home/install/workspace/trunk/http/php/createImageFromText.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ja.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ja.js
+/home/install/workspace/trunk/http/php/mod_filteredGui_User.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGui_User.php
+/home/install/workspace/trunk/http/html/mod_treefolder.php 1208967270 0 /home/install/workspace/trunk/http/html/mod_treefolder.php
+/home/install/workspace/trunk/http/php/mod_gui_filteredGroup.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gui_filteredGroup.php
+/home/install/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql
+/home/install/workspace/trunk/http/sld/sld_pick_color.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_pick_color.php
+/home/install/workspace/trunk/http/classes/class_wfs_configuration.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_wfs_configuration.php
+/home/install/workspace/trunk/core/globalSettings.php 1245838748 0 /home/install/workspace/trunk/core/globalSettings.php
+/home/install/workspace/trunk/http/php/mod_changeEPSG_server.php 1230909423 0 /home/install/workspace/trunk/http/php/mod_changeEPSG_server.php
+/home/install/workspace/trunk/lib/database-mysqli.php 1215768576 0 /home/install/workspace/trunk/lib/database-mysqli.php
+/home/install/workspace/trunk/http/sld/sld_function_handler.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_function_handler.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ro.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ro.js
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single_diff.php 1235406337 0 /home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single_diff.php
+/home/install/workspace/trunk/http/classes/class_kml.php 1217937298 0 /home/install/workspace/trunk/http/classes/class_kml.php
+/home/install/workspace/trunk/http/sld/classes/Mark.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Mark.php
+/home/install/workspace/trunk/http/php/mod_exportMapImage_server.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_exportMapImage_server.php
+/home/install/workspace/trunk/http/classes/class_SaveLegend.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_SaveLegend.php
+/home/install/workspace/trunk/owsproxy/http/index.php 1222346431 0 /home/install/workspace/trunk/owsproxy/http/index.php
+/home/install/workspace/trunk/http/sld/classes/LegendGraphic.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/LegendGraphic.php
+/home/install/workspace/trunk/http/frames/cleanurl.php 1208967270 0 /home/install/workspace/trunk/http/frames/cleanurl.php
+/home/install/workspace/trunk/http/javascripts/mod_treeConf.js 1150280597 0 /home/install/workspace/trunk/http/javascripts/mod_treeConf.js
+/home/install/workspace/trunk/http/classes/class_kml_multigeometry.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_kml_multigeometry.php
+/home/install/workspace/trunk/license/gpl.txt 1144962192 0 /home/install/workspace/trunk/license/gpl.txt
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php
+/home/install/workspace/trunk/http/php/mod_group_filteredGui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_group_filteredGui.php
+/home/install/workspace/trunk/http/sld/classes/Graphic.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Graphic.php
+/home/install/workspace/trunk/http/php/mod_wfs.php 1245245453 0 /home/install/workspace/trunk/http/php/mod_wfs.php
+/home/install/workspace/trunk/http/classes/class_gml_3_factory.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_3_factory.php
+/home/install/workspace/trunk/http/sld/classes/PropertyIsNull.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/PropertyIsNull.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-da.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-da.js
+/home/install/workspace/trunk/http/php/mod_wfsLayerObj_conf.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_wfsLayerObj_conf.php
+/home/install/workspace/trunk/lib/customTreeController.js 1236961566 0 /home/install/workspace/trunk/lib/customTreeController.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php
+/home/install/workspace/trunk/http/javascripts/mod_displayWmc.php 1213362274 0 /home/install/workspace/trunk/http/javascripts/mod_displayWmc.php
+/home/install/workspace/trunk/http/classes/class_universal_wfs_factory.php 1233657361 0 /home/install/workspace/trunk/http/classes/class_universal_wfs_factory.php
+/home/install/workspace/trunk/http/javascripts/mod_highlightPOI.php 1237887369 0 /home/install/workspace/trunk/http/javascripts/mod_highlightPOI.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ko.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ko.js
+/home/install/workspace/trunk/http/classes/class_gui.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_gui.php
+/home/install/workspace/trunk/http/javascripts/mod_measure.php 1241379560 0 /home/install/workspace/trunk/http/javascripts/mod_measure.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/mail.php 1208966513 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/mail.php
+/home/install/workspace/trunk/http/javascripts/mod_tooltip.php 1239870590 0 /home/install/workspace/trunk/http/javascripts/mod_tooltip.php
+/home/install/workspace/trunk/http/classes/class_gml_line.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_line.php
+/home/install/workspace/trunk/http/php/mb_listKMLs.php 1208967664 0 /home/install/workspace/trunk/http/php/mb_listKMLs.php
+/home/install/workspace/trunk/http/javascripts/mod_key.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_key.php
+/home/install/workspace/trunk/http/sld/classes/AddOperationModule.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/AddOperationModule.php
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql
+/home/install/workspace/trunk/http/classes/class_kml_placemark.php 1222869057 0 /home/install/workspace/trunk/http/classes/class_kml_placemark.php
+/home/install/workspace/trunk/http/javascripts/mapnf.php 1245778752 0 /home/install/workspace/trunk/http/javascripts/mapnf.php
+/home/install/workspace/trunk/lib/ajax.php 1239182831 0 /home/install/workspace/trunk/lib/ajax.php
+/home/install/workspace/trunk/http/classes/class.pdf.php 1200385469 0 /home/install/workspace/trunk/http/classes/class.pdf.php
+/home/install/workspace/trunk/http/php/mod_category_filteredGUI.php 1245855925 0 /home/install/workspace/trunk/http/php/mod_category_filteredGUI.php
+/home/install/workspace/trunk/license/gpl_short.txt 1144962192 0 /home/install/workspace/trunk/license/gpl_short.txt
+/home/install/workspace/trunk/http/javascripts/wfs.php 1238149835 0 /home/install/workspace/trunk/http/javascripts/wfs.php
+/home/install/workspace/trunk/http/classes/class_kml_polygon.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_kml_polygon.php
+/home/install/workspace/trunk/http/php/mod_edit_element_vars.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_edit_element_vars.php
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/javascripts/mod_pan.php 1239119530 0 /home/install/workspace/trunk/http/javascripts/mod_pan.php
+/home/install/workspace/trunk/http/javascripts/core.php 1245856626 1 Mapbender
+/home/install/workspace/trunk/http/classes/class_wms.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_wms.php
+/home/install/workspace/trunk/http/php/mod_deleteFilteredGUI.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_deleteFilteredGUI.php
+/home/install/workspace/trunk/docs/Languages.txt 1245847652 0 /home/install/workspace/trunk/docs/Languages.txt
+/home/install/workspace/trunk/http/sld/classes/Rule.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Rule.php
+/home/install/workspace/trunk/lib/div.js 1232466013 0 /home/install/workspace/trunk/lib/div.js
+/home/install/workspace/trunk/http/php/mod_map1.php 1226479717 0 /home/install/workspace/trunk/http/php/mod_map1.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMS.php 1245772744 0 /home/install/workspace/trunk/http/javascripts/mod_addWMS.php
+/home/install/workspace/trunk/http/php/mod_orphanWMS.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_orphanWMS.php
+/home/install/workspace/trunk/http/javascripts/mod_setBackground_all.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_setBackground_all.php
+/home/install/workspace/trunk/http/classes/class_gml_envelope.php 1233657361 0 /home/install/workspace/trunk/http/classes/class_gml_envelope.php
+/home/install/workspace/trunk/http/php/mod_gazLayerObj_edit.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gazLayerObj_edit.php
+/home/install/workspace/trunk/http/javascripts/mod_horizTab.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_horizTab.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromList.php 1245838522 0 /home/install/workspace/trunk/http/javascripts/mod_addWMSfromList.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php
+/home/install/workspace/trunk/docs/Menu.txt 1245847652 0 /home/install/workspace/trunk/docs/Menu.txt
+/home/install/workspace/trunk/http/extensions/jquery.mousewheel.min.js 1214236582 0 /home/install/workspace/trunk/http/extensions/jquery.mousewheel.min.js
+/home/install/workspace/trunk/http/print/print_functions.php 1218808363 0 /home/install/workspace/trunk/http/print/print_functions.php
+/home/install/workspace/trunk/http/classes/class_gml2.php 1229347647 0 /home/install/workspace/trunk/http/classes/class_gml2.php
+/home/install/workspace/trunk/http/php/mod_editApplication.php 1237368148 0 /home/install/workspace/trunk/http/php/mod_editApplication.php
+/home/install/workspace/trunk/http/php/mod_gazLayerObj_conf.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gazLayerObj_conf.php
+/home/install/workspace/trunk/http/javascripts/mod_selArea.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_selArea.php
+/home/install/workspace/trunk/http/classes/class_gml_feature.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_gml_feature.php
+/home/install/workspace/trunk/sql/update_wfs_conf_element.sql 1245418009 0 /home/install/workspace/trunk/sql/update_wfs_conf_element.sql
+/home/install/workspace/trunk/http/extensions/jqjson.js 1191832183 0 /home/install/workspace/trunk/http/extensions/jqjson.js
+/home/install/workspace/trunk/http/php/mod_editElementVars.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editElementVars.php
+/home/install/workspace/trunk/http/php/mod_layerMetadata.php 1209634442 0 /home/install/workspace/trunk/http/php/mod_layerMetadata.php
+/home/install/workspace/trunk/http/javascripts/mod_dependentDiv.php 1230887236 0 /home/install/workspace/trunk/http/javascripts/mod_dependentDiv.php
+/home/install/workspace/trunk/http/javascripts/mod_forward.php 1237199301 0 /home/install/workspace/trunk/http/javascripts/mod_forward.php
+/home/install/workspace/trunk/http/php/mod_createUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_createUser.php
+/home/install/workspace/trunk/http/sld/classes/CssParameter.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/CssParameter.php
+/home/install/workspace/trunk/http/sld/classes/FeatureTypeStyle.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/FeatureTypeStyle.php
+/home/install/workspace/trunk/http/javascripts/mod_fisheye.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_fisheye.php
+/home/install/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php
+/home/install/workspace/trunk/http/php/mod_loadwms_temp.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_loadwms_temp.php
+/home/install/workspace/trunk/resources/db/reload.sql 1245681909 0 /home/install/workspace/trunk/resources/db/reload.sql
+/home/install/workspace/trunk/http/sld/classes/DbUtils.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/DbUtils.php
+/home/install/workspace/trunk/http/php/mod_user_filteredGui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_user_filteredGui.php
+/home/install/workspace/trunk/sql/update_wfs_conf.sql 1244558916 0 /home/install/workspace/trunk/sql/update_wfs_conf.sql
+/home/install/workspace/trunk/http/classes/class_mb_log.php 1208966371 0 /home/install/workspace/trunk/http/classes/class_mb_log.php
+/home/install/workspace/trunk/http/classes/class_wfs_1_1.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_wfs_1_1.php
+/home/install/workspace/trunk/http/javascripts/mod_dynamicOverview.php 1237200458 0 /home/install/workspace/trunk/http/javascripts/mod_dynamicOverview.php
+/home/install/workspace/trunk/http/php/mod_filteredGroup_User.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGroup_User.php
+/home/install/workspace/trunk/http/classes/class_kml_ows.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_kml_ows.php
+/home/install/workspace/trunk/http/php/nestedSets.php 1218790491 0 /home/install/workspace/trunk/http/php/nestedSets.php
+/home/install/workspace/trunk/http/sld/classes/Halo.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Halo.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-it.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-it.js
+/home/install/workspace/trunk/tools/mapbender_setup.php 1227084639 0 /home/install/workspace/trunk/tools/mapbender_setup.php
+/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php
+/home/install/workspace/trunk/http/javascripts/mod_adminNavigation.js 1229072942 0 /home/install/workspace/trunk/http/javascripts/mod_adminNavigation.js
+/home/install/workspace/trunk/lib/class_Singleton.php 1245838522 0 /home/install/workspace/trunk/lib/class_Singleton.php
+/home/install/workspace/trunk/tools/mapFiler.php 1231858528 0 /home/install/workspace/trunk/tools/mapFiler.php
+/home/install/workspace/trunk/http/php/mod_gazetteerSQL_server.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gazetteerSQL_server.php
+/home/install/workspace/trunk/http/javascripts/wfsFilter.js 1236351449 0 /home/install/workspace/trunk/http/javascripts/wfsFilter.js
+/home/install/workspace/trunk/http/php/mod_editGroup.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editGroup.php
+/home/install/workspace/trunk/sql/insert_wfs_conf_element.sql 1245246454 0 /home/install/workspace/trunk/sql/insert_wfs_conf_element.sql
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sv.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sv.js
+/home/install/workspace/trunk/license/Liberation-License.txt 1237290442 0 /home/install/workspace/trunk/license/Liberation-License.txt
+/home/install/workspace/trunk/http/php/mod_user_gui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_user_gui.php
+/home/install/workspace/trunk/http/php/mod_wfs_server.php 1237225534 0 /home/install/workspace/trunk/http/php/mod_wfs_server.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
+/home/install/workspace/trunk/http/javascripts/mod_resize_mapsize.php 1230894465 0 /home/install/workspace/trunk/http/javascripts/mod_resize_mapsize.php
+/home/install/workspace/trunk/http/php/mod_customTree.php 1236961566 0 /home/install/workspace/trunk/http/php/mod_customTree.php
+/home/install/workspace/trunk/http/javascripts/mod_saveWmcKml.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_saveWmcKml.php
+/home/install/workspace/trunk/http/php/mod_editGuiWms.php 1236956732 0 /home/install/workspace/trunk/http/php/mod_editGuiWms.php
+/home/install/workspace/trunk/http/php/mod_digitize_differencePolygon.php 1223458316 0 /home/install/workspace/trunk/http/php/mod_digitize_differencePolygon.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lv.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lv.js
+/home/install/workspace/trunk/http/php/mod_group_filteredUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_group_filteredUser.php
+/home/install/workspace/trunk/http/php/mod_editUser.php 1225985335 0 /home/install/workspace/trunk/http/php/mod_editUser.php
+/home/install/workspace/trunk/http/php/mod_customTree_server.php 1245856564 0 /home/install/workspace/trunk/http/php/mod_customTree_server.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php
+/home/install/workspace/trunk/http/php/mod_displayKML.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_displayKML.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lt.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lt.js
+/home/install/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php 1236875614 0 /home/install/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php
+/home/install/workspace/trunk/http/javascripts/mod_digitize_tab.php 1245413563 0 /home/install/workspace/trunk/http/javascripts/mod_digitize_tab.php
+/home/install/workspace/trunk/http/classes/class_element.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_element.php
+/home/install/workspace/trunk/http/classes/class_json.php 1227084639 0 /home/install/workspace/trunk/http/classes/class_json.php
+/home/install/workspace/trunk/http/classes/class_bbox.php 1231151408 0 /home/install/workspace/trunk/http/classes/class_bbox.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql
+/home/install/workspace/trunk/http/classes/class_gml_polygon.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_polygon.php
+/home/install/workspace/trunk/http/javascripts/mod_perimeter.php 1214236736 0 /home/install/workspace/trunk/http/javascripts/mod_perimeter.php
+/home/install/workspace/trunk/http/extensions/DifferenceEngine.php 1235406337 0 /home/install/workspace/trunk/http/extensions/DifferenceEngine.php
+/home/install/workspace/trunk/http/sld/classes/Filter.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Filter.php
+/home/install/workspace/trunk/http/php/mod_showLoggedUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_showLoggedUser.php
+/home/install/workspace/trunk/http/php/mod_treefolderAdmin.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_treefolderAdmin.php
+/home/install/workspace/trunk/http/classes/class_kml_line.php 1222869057 0 /home/install/workspace/trunk/http/classes/class_kml_line.php
+/home/install/workspace/trunk/http/php/mod_wfs_conf.php 1235136381 0 /home/install/workspace/trunk/http/php/mod_wfs_conf.php
+/home/install/workspace/trunk/http/html/mod_sync_treefolder.php 1208967270 0 /home/install/workspace/trunk/http/html/mod_sync_treefolder.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ar.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ar.js
+/home/install/workspace/trunk/http/php/mod_getStyles.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_getStyles.php
+/home/install/workspace/trunk/http/php/mod_forgottenPassword.php 1229013681 0 /home/install/workspace/trunk/http/php/mod_forgottenPassword.php
+/home/install/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php 1230887236 0 /home/install/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php
+/home/install/workspace/trunk/resources/db/pgsql/openlayers_application.sql 1214236631 0 /home/install/workspace/trunk/resources/db/pgsql/openlayers_application.sql
+/home/install/workspace/trunk/http/javascripts/mod_add_SLD.php 1236875384 0 /home/install/workspace/trunk/http/javascripts/mod_add_SLD.php
+/home/install/workspace/trunk/http/php/mod_gui_filteredUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_gui_filteredUser.php
+/home/install/workspace/trunk/http/php/mod_loadwmc_server.php 1240923997 0 /home/install/workspace/trunk/http/php/mod_loadwmc_server.php
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fr.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fr.js
+/home/install/workspace/trunk/http/php/mod_owsproxy_conf.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_owsproxy_conf.php
+/home/install/workspace/trunk/resources/db/mysql/mysql_gettext.sql 1218723822 0 /home/install/workspace/trunk/resources/db/mysql/mysql_gettext.sql
+/home/install/workspace/trunk/http/php/mod_simpleWMSpreferences.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_simpleWMSpreferences.php
+/home/install/workspace/trunk/http/extensions/jquery.tablesorter.js 1234864590 0 /home/install/workspace/trunk/http/extensions/jquery.tablesorter.js
+/home/install/workspace/trunk/http/php/mod_savewmc_server.php 1240921307 0 /home/install/workspace/trunk/http/php/mod_savewmc_server.php
+/home/install/workspace/trunk/lib/buttonNew.js 1236875384 0 /home/install/workspace/trunk/lib/buttonNew.js
+/home/install/workspace/trunk/http/javascripts/mod_usemap.php 1213021210 0 /home/install/workspace/trunk/http/javascripts/mod_usemap.php
+/home/install/workspace/trunk/http/php/mod_gazetteerMetadata.php 1235475918 0 /home/install/workspace/trunk/http/php/mod_gazetteerMetadata.php
+/home/install/workspace/trunk/http/javascripts/mod_repaint.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_repaint.php
+/home/install/workspace/trunk/http/javascripts/ovnf.php 1245778750 0 /home/install/workspace/trunk/http/javascripts/ovnf.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pl.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pl.js
+/home/install/workspace/trunk/http/php/mod_wfs_gazetteer_server.php 1236005925 0 /home/install/workspace/trunk/http/php/mod_wfs_gazetteer_server.php
+/home/install/workspace/trunk/tools/send_post.php 1186389031 0 /home/install/workspace/trunk/tools/send_post.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-bg.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-bg.js
+/home/install/workspace/trunk/core/i18n.php 1245838522 0 /home/install/workspace/trunk/core/i18n.php
+/home/install/workspace/trunk/http/classes/class_wmcToXml.php 1236782767 0 /home/install/workspace/trunk/http/classes/class_wmcToXml.php
+/home/install/workspace/trunk/http/javascripts/wfs_obj.js 1208967664 0 /home/install/workspace/trunk/http/javascripts/wfs_obj.js
+/home/install/workspace/trunk/http/classes/class_kml_geometry.php 1216711579 0 /home/install/workspace/trunk/http/classes/class_kml_geometry.php
+/home/install/workspace/trunk/http/javascripts/requestGeometryConstructor.js 1235982146 0 /home/install/workspace/trunk/http/javascripts/requestGeometryConstructor.js
+/home/install/workspace/trunk/http/php/mod_filteredUser_Gui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredUser_Gui.php
+/home/install/workspace/trunk/http/javascripts/mod_loadKML.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_loadKML.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/classes/class_gml_point.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_point.php
+/home/install/workspace/trunk/http/classes/class_wfs_deprecated.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_wfs_deprecated.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php 1214236698 0 /home/install/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php
+/home/install/workspace/trunk/http/sld/classes/RasterSymbolizer.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/RasterSymbolizer.php
+/home/install/workspace/trunk/license/bitstream-COPYRIGHT.TXT 1237290442 0 /home/install/workspace/trunk/license/bitstream-COPYRIGHT.TXT
+/home/install/workspace/trunk/http/classes/class_gml_2_factory.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_2_factory.php
+/home/install/workspace/trunk/http/extensions/geom2wfst.php 1235739677 0 /home/install/workspace/trunk/http/extensions/geom2wfst.php
+/home/install/workspace/trunk/lib/button.js 1230887532 0 /home/install/workspace/trunk/lib/button.js
+/home/install/workspace/trunk/http/php/mod_filteredUser_Group.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredUser_Group.php
+/home/install/workspace/trunk/http/sld/classes/NamedLayer.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/NamedLayer.php
+/home/install/workspace/trunk/http/php/mod_wfs_edit.php 1238145768 0 /home/install/workspace/trunk/http/php/mod_wfs_edit.php
+/home/install/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php 1245854203 0 /home/install/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php
+/home/install/workspace/trunk/http/php/mod_filteredGui_filteredUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGui_filteredUser.php
+/home/install/workspace/trunk/http/php/mod_editSelf.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editSelf.php
+/home/install/workspace/trunk/http/javascripts/mod_saveWKT.js 1230887149 0 /home/install/workspace/trunk/http/javascripts/mod_saveWKT.js
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/Install.txt 1237308524 0 /home/install/workspace/trunk/Install.txt
+/home/install/workspace/trunk/http/javascripts/mod_openlayers.php 1214236840 0 /home/install/workspace/trunk/http/javascripts/mod_openlayers.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hy.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hy.js
+/home/install/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_write.php 1208967270 0 /home/install/workspace/trunk/tools/mod_monitorCapabilities_write.php
+/home/install/workspace/trunk/http/extensions/jquery-ui-1.7.1.w.o.effects.min.js 1244215918 0 /home/install/workspace/trunk/http/extensions/jquery-ui-1.7.1.w.o.effects.min.js
+/home/install/workspace/trunk/http/php/mod_group_gui.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_group_gui.php
+/home/install/workspace/trunk/http/php/mod_group_user.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_group_user.php
+/home/install/workspace/trunk/http/php/mod_deleteGUI.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_deleteGUI.php
+/home/install/workspace/trunk/lib/customTreeModel.js 1236961566 0 /home/install/workspace/trunk/lib/customTreeModel.js
+/home/install/workspace/trunk/http/sld/classes/PropertyIsLike.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/PropertyIsLike.php
+/home/install/workspace/trunk/http/sld/sld_config.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_config.php
+/home/install/workspace/trunk/http/php/mod_wfs_conf_interface.js 1245314856 0 /home/install/workspace/trunk/http/php/mod_wfs_conf_interface.js
+/home/install/workspace/trunk/http/javascripts/mod_exportMapImage.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_exportMapImage.php
+/home/install/workspace/trunk/http/javascripts/mod_log.php 1216711579 0 /home/install/workspace/trunk/http/javascripts/mod_log.php
+/home/install/workspace/trunk/http/classes/class_wmc.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_wmc.php
+/home/install/workspace/trunk/http/php/mod_printView1.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_printView1.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-de.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-de.js
+/home/install/workspace/trunk/Changes.txt 1237308497 0 /home/install/workspace/trunk/Changes.txt
+/home/install/workspace/trunk/http/classes/class_map.php 1236951293 0 /home/install/workspace/trunk/http/classes/class_map.php
+/home/install/workspace/trunk/http/php/mod_featuretypeMetadata.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_featuretypeMetadata.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php
+/home/install/workspace/trunk/http/sld/sld_filter_parse.php 1208967270 0 /home/install/workspace/trunk/http/sld/sld_filter_parse.php
+/home/install/workspace/trunk/http/javascripts/mod_setBackground.php 1230887149 0 /home/install/workspace/trunk/http/javascripts/mod_setBackground.php
+/home/install/workspace/trunk/lib/basic.js 1240904723 0 /home/install/workspace/trunk/lib/basic.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-th.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-th.js
+/home/install/workspace/trunk/http/php/mod_editElements.php 1245746857 0 /home/install/workspace/trunk/http/php/mod_editElements.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fi.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fi.js
+/home/install/workspace/trunk/http/php/mod_exportElement.php 1242242094 0 /home/install/workspace/trunk/http/php/mod_exportElement.php
+/home/install/workspace/trunk/http/php/mod_digitize_splitPolygon.php 1223458316 0 /home/install/workspace/trunk/http/php/mod_digitize_splitPolygon.php
+/home/install/workspace/trunk/http/javascripts/mod_permanentHighlight.js 1164040412 0 /home/install/workspace/trunk/http/javascripts/mod_permanentHighlight.js
+/home/install/workspace/trunk/http/print/mod_printPDF.php 1237200647 0 /home/install/workspace/trunk/http/print/mod_printPDF.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-es.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-es.js
+/home/install/workspace/trunk/http/sld/classes/ExternalGraphic.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/ExternalGraphic.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sk.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sk.js
+/home/install/workspace/trunk/http/php/mod_deleteWMS.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_deleteWMS.php
+/home/install/workspace/trunk/http/php/mod_user_group.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_user_group.php
+/home/install/workspace/trunk/http/classes/class_connector.php 1239128635 0 /home/install/workspace/trunk/http/classes/class_connector.php
+/home/install/workspace/trunk/http/sld/classes/LineSymbolizer.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/LineSymbolizer.php
+/home/install/workspace/trunk/http/php/mod_meetingPoint.php 1237887556 0 /home/install/workspace/trunk/http/php/mod_meetingPoint.php
+/home/install/workspace/trunk/http/javascripts/mod_renderGML.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_renderGML.php
+/home/install/workspace/trunk/http/classes/class_weldOverview2PNG.php 1186386971 0 /home/install/workspace/trunk/http/classes/class_weldOverview2PNG.php
+/home/install/workspace/trunk/http/extensions/markResult.php 1208966985 0 /home/install/workspace/trunk/http/extensions/markResult.php
+/home/install/workspace/trunk/http/sld/classes/BinaryLogicOp.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/BinaryLogicOp.php
+/home/install/workspace/trunk/http/javascripts/mod_reload.php 1245856626 1 Reload
+/home/install/workspace/trunk/http/include/gui1_splash.php 1231153927 0 /home/install/workspace/trunk/http/include/gui1_splash.php
+/home/install/workspace/trunk/http/php/mod_logout.php 1218442761 0 /home/install/workspace/trunk/http/php/mod_logout.php
+/home/install/workspace/trunk/core/system.php 1245772744 0 /home/install/workspace/trunk/core/system.php
+/home/install/workspace/trunk/http/classes/class_wfs.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_wfs.php
+/home/install/workspace/trunk/http/classes/class_universal_gml_factory.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_universal_gml_factory.php
+/home/install/workspace/trunk/http/sld/classes/PointSymbolizer.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/PointSymbolizer.php
+/home/install/workspace/trunk/http/php/mod_SelectKeyword.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_SelectKeyword.php
+/home/install/workspace/trunk/http/sld/classes/AnchorPoint.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/AnchorPoint.php
+/home/install/workspace/trunk/http/sld/classes/PropertyIsBetween.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/PropertyIsBetween.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_loadwms.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_loadwms.php
+/home/install/workspace/trunk/http/extensions/JSON.php 1173171435 0 /home/install/workspace/trunk/http/extensions/JSON.php
+/home/install/workspace/trunk/http/sld/classes/Stroke.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/Stroke.php
+/home/install/workspace/trunk/http/javascripts/mod_changeEPSG.php 1232465591 0 /home/install/workspace/trunk/http/javascripts/mod_changeEPSG.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_changeEPSG_dynamic.php 1245856041 0 /home/install/workspace/trunk/http/php/mod_changeEPSG_dynamic.php
+/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.2.js 1236961566 0 /home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.2.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php
+/home/install/workspace/trunk/http/sld/classes/ColorMapEntry.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/ColorMapEntry.php
+/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php 1245779180 1 ZoomIn1
+/home/install/workspace/trunk/sql/insert_wfs_conf.sql 1244558916 0 /home/install/workspace/trunk/sql/insert_wfs_conf.sql
+/home/install/workspace/trunk/http/classes/class_mb_warning.php 1199464420 0 /home/install/workspace/trunk/http/classes/class_mb_warning.php
+/home/install/workspace/trunk/http/sld/classes/PointPlacement.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/PointPlacement.php
+/home/install/workspace/trunk/http/php/mod_setLocale.php 1216713787 0 /home/install/workspace/trunk/http/php/mod_setLocale.php
+/home/install/workspace/trunk/http/javascripts/wms.js 1238749127 0 /home/install/workspace/trunk/http/javascripts/wms.js
+/home/install/workspace/trunk/http/php/mod_filteredWms_layer_topic.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredWms_layer_topic.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js
+/home/install/workspace/trunk/http/php/mod_editFilteredUser.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editFilteredUser.php
+/home/install/workspace/trunk/http/javascripts/mod_setBBOX1.php 1239129168 0 /home/install/workspace/trunk/http/javascripts/mod_setBBOX1.php
+/home/install/workspace/trunk/http/php/mod_updateKmlInDb.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_updateKmlInDb.php
+/home/install/workspace/trunk/tools/wms_extent/wms_geometry.sql 1153388414 0 /home/install/workspace/trunk/tools/wms_extent/wms_geometry.sql
+/home/install/workspace/trunk/http/javascripts/mod_setPOI2Scale.php 1230887149 0 /home/install/workspace/trunk/http/javascripts/mod_setPOI2Scale.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-TW.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-TW.js
+/home/install/workspace/trunk/http/classes/class_wfs_1_0_factory.php 1236703351 0 /home/install/workspace/trunk/http/classes/class_wfs_1_0_factory.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php 1245838522 0 /home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php
+/home/install/workspace/trunk/http/php/mod_loadwfs.php 1236703245 0 /home/install/workspace/trunk/http/php/mod_loadwfs.php
+/home/install/workspace/trunk/http/php/mod_loadWFSCapabilities.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_loadWFSCapabilities.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/classes/class_gml_factory.php 1239895398 0 /home/install/workspace/trunk/http/classes/class_gml_factory.php
+/home/install/workspace/trunk/http/php/mod_filteredGui_group.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_filteredGui_group.php
+/home/install/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php 1245856324 0 /home/install/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php
+/home/install/workspace/trunk/http/php/mb_listGUIs.php 1236876057 0 /home/install/workspace/trunk/http/php/mb_listGUIs.php
+/home/install/workspace/trunk/http/javascripts/jsTree.js 1230902123 0 /home/install/workspace/trunk/http/javascripts/jsTree.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php
+/home/install/workspace/trunk/http/javascripts/mod_initWmc.php 1231425706 0 /home/install/workspace/trunk/http/javascripts/mod_initWmc.php
+/home/install/workspace/trunk/http/sld/classes/ColorMap.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/ColorMap.php
+/home/install/workspace/trunk/http/javascripts/mod_scaleHint.php 1237199301 0 /home/install/workspace/trunk/http/javascripts/mod_scaleHint.php
+/home/install/workspace/trunk/http/javascripts/mod_zoomOut1.php 1245779180 0 /home/install/workspace/trunk/http/javascripts/mod_zoomOut1.php
+/home/install/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php
+/home/install/workspace/trunk/http/php/mb_js_exception.php 1208967664 0 /home/install/workspace/trunk/http/php/mb_js_exception.php
+/home/install/workspace/trunk/http/html/mod_treefolderPlain.php 1245838522 0 /home/install/workspace/trunk/http/html/mod_treefolderPlain.php
+/home/install/workspace/trunk/http/frames/index.php 1245838522 0 /home/install/workspace/trunk/http/frames/index.php
+/home/install/workspace/trunk/http/extensions/jquery.ajaxmanager.js 1208966985 0 /home/install/workspace/trunk/http/extensions/jquery.ajaxmanager.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-nl.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-nl.js
+/home/install/workspace/trunk/http/classes/class_gml_geometry.php 1234978564 0 /home/install/workspace/trunk/http/classes/class_gml_geometry.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php
+/home/install/workspace/trunk/http/extensions/jquery-1.3.2.min.js 1244215918 0 /home/install/workspace/trunk/http/extensions/jquery-1.3.2.min.js
+/home/install/workspace/trunk/tools/url_code.php 1164106450 0 /home/install/workspace/trunk/tools/url_code.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/classes/class_gml_3.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_gml_3.php
+/home/install/workspace/trunk/http/php/mod_WMSpreferences.php 1236330438 0 /home/install/workspace/trunk/http/php/mod_WMSpreferences.php
+/home/install/workspace/trunk/http/javascripts/mod_featureInfo.php 1240326844 0 /home/install/workspace/trunk/http/javascripts/mod_featureInfo.php
+/home/install/workspace/trunk/http/javascripts/mod_coords_div.php 1230893633 0 /home/install/workspace/trunk/http/javascripts/mod_coords_div.php
+/home/install/workspace/trunk/http/php/mod_log.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_log.php
+/home/install/workspace/trunk/http/php/mod_changePassword.php 1245856206 0 /home/install/workspace/trunk/http/php/mod_changePassword.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql 1237306575 0 /home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/javascripts/mod_tab.php 1208967664 0 /home/install/workspace/trunk/http/javascripts/mod_tab.php
+/home/install/workspace/trunk/http/javascripts/mod_help.php 1245779179 0 /home/install/workspace/trunk/http/javascripts/mod_help.php
+/home/install/workspace/trunk/http/classes/class_kml_linearring.php 1222869057 0 /home/install/workspace/trunk/http/classes/class_kml_linearring.php
+/home/install/workspace/trunk/http/classes/class_monitor.php 1235406337 0 /home/install/workspace/trunk/http/classes/class_monitor.php
+/home/install/workspace/trunk/http/classes/class_log.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_log.php
+/home/install/workspace/trunk/http/php/mod_wfs_conf_server.php 1244215918 0 /home/install/workspace/trunk/http/php/mod_wfs_conf_server.php
+/home/install/workspace/trunk/lib/database-mysql.php 1220516326 0 /home/install/workspace/trunk/lib/database-mysql.php
+/home/install/workspace/trunk/http/php/mod_editWMS_Metadata.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editWMS_Metadata.php
+/home/install/workspace/trunk/http/php/mod_editGuiWmsMeta.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_editGuiWmsMeta.php
+/home/install/workspace/trunk/http/classes/class_wfs_1_0.php 1235985010 0 /home/install/workspace/trunk/http/classes/class_wfs_1_0.php
+/home/install/workspace/trunk/http/classes/class_wfsToDb.php 1245838522 0 /home/install/workspace/trunk/http/classes/class_wfsToDb.php
+/home/install/workspace/trunk/http/php/mod_evalArea.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_evalArea.php
+/home/install/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php 1238152673 0 /home/install/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql 1237306055 0 /home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
+/home/install/workspace/trunk/resources/db/update/update_2.7.sql 1245745690 0 /home/install/workspace/trunk/resources/db/update/update_2.7.sql
+/home/install/workspace/trunk/http/php/mod_edit_metadata.php 1208967664 0 /home/install/workspace/trunk/http/php/mod_edit_metadata.php
+/home/install/workspace/trunk/http/php/mod_showGuiName.php 1221056958 0 /home/install/workspace/trunk/http/php/mod_showGuiName.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js 1234281206 0 /home/install/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-is.js 1244216857 0 /home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-is.js
+/home/install/workspace/trunk/http/javascripts/mod_zoomFull.php 1245779180 0 /home/install/workspace/trunk/http/javascripts/mod_zoomFull.php
+/home/install/workspace/trunk/http/sld/classes/TextSymbolizer.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/TextSymbolizer.php
+/home/install/workspace/trunk/lib/saveButton.js 1214236663 0 /home/install/workspace/trunk/lib/saveButton.js
+/home/install/workspace/trunk/http/classes/class_gml_2.php 1234978564 0 /home/install/workspace/trunk/http/classes/class_gml_2.php
+/home/install/workspace/trunk/http/include/dyn_php.php 1200384506 0 /home/install/workspace/trunk/http/include/dyn_php.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php 1144957108 0 /home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php
+/home/install/workspace/trunk/http/sld/classes/BinaryComparisonOp.php 1208967270 0 /home/install/workspace/trunk/http/sld/classes/BinaryComparisonOp.php
+/home/install/workspace/trunk/http/extensions/json.js 1190794313 0 /home/install/workspace/trunk/http/extensions/json.js
Property changes on: trunk/mapbender/documents/api_js/Data/FileInfo.nd
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
--- trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,3 @@
+( B/home/install/workspace/trunk/http/img/button_gray/addlist_off.pngD>¯g B/home/install/workspace/trunk/http/img/button_blink_red/pan_on.pngD>¡ L/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_on.pngHZ3£ H/home/install/workspace/trunk/http/img/button_blink_red/repaint_over.pngD>¡ I/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_over.pngDÎ @/home/install/workspace/trunk/http/img/button_gray/user_over.pngD>¯g I/home/install/workspace/trunk/http/img/button_silver_blue/getArea_off.pngHZ3£ ?/home/install/workspace/trunk/http/img/openlayers/east-mini.pngHw]à F/home/install/workspace/trunk/http/img/button_digitize/new_node_on.pngD@Ò D/home/install/workspace/trunk/http/img/button_gray/zoomFull_over.gifD>¯g @/home/install/workspace/trunk/http/img/button_blue/query_off.pngDì J/home/install/workspace/trunk/http/img/button_silver_blue/measure_over.pngHZ3£ ?/home/install/workspace/trunk/http/img/button_gray/pan_over.pngD>¯g I/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_over.pngD>¡ ?/home/install/workspace/trunk/http/img/button_gray/back_off.pngD>¯g ?/home/install/workspace/trunk/http/img/button_gray/add_over.pngD>¯g H/home/install/workspace/trunk/http/img/button_gray/select_point_over.pngD </home/install/workspace/trunk/http/img/openlayers/marker.pngHw]à E/home/install/workspace/trunk/http/img/button_digitize/geomRemove.pngIäà F/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_on.pngD>¡ :/home/install/workspace/trunk/http/img/arrows/arrow_ne.gifD>¬¡ ?/home/install/workspace/trunk/http/img/button_gray/query_on.pngD>¯g F/home/install/workspace/trunk/http/img/button_digitize/polygon_off.pngD@Ò I/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_on.pngHZ3£ U/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_plus.gifJ)? I/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_over.pngD>¡ E/home/install/workspace/trunk/http/img/button_blink_red/help3_off.pngD>¡ K/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_over.pngHZ3£ F/home/install/workspace/trunk/http/img/button_blue/select_point_on.pngDZ H/home/install/workspace/trunk/http/img/openlayers/measuring-stick-on.pngHw]à H/home/install/workspace/trunk/http/img/button_gray/select_choose_off.pngD F/home/install/workspace/trunk/http/img/button_blink_red/print_over.pngD>¡ E/home/install/workspace/trunk/http/img/button_digitize/point_over.pngD@Ò I/home/install/workspace/trunk/http/img/button_blue/select_choose_over.pngDZ I/home/install/workspace/trunk/http/img/button_silver_blue/polygon_off.pngHZ3£ A/home/install/workspace/trunk/http/img/button_gray/print_over.gifD>¯g C/home/install/workspace/trunk/http/img/button_blue/forward_over.pngDì @/home/install/workspace/trunk/http/img/button_gray/coods_off.pngD>¯g :/home/install/workspace/trunk/http/img/indicator_wheel.gifFå
+ A/home/install/workspace/trunk/http/img/button_gray/query_over.pngD>¯g K/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_over.pngHZ3£ F/home/install/workspace/trunk/http/img/button_silver_blue/leg_over.pngHZ3£ 9/home/install/workspace/trunk/http/img/arrows/arrow_w.gifD>¬¡ G/home/install/workspace/trunk/http/img/button_blink_red/selArea_off.pngD>¡ G/home/install/workspace/trunk/http/img/button_blink_red/reload_over.pngHb¸ 9/home/install/workspace/trunk/http/img/arrows/arrow_s.gifD>¬¡ A/home/install/workspace/trunk/http/img/button_gray/measure_on.pngD>¯g E/home/install/workspace/trunk/http/img/button_gray/metadata_layer.gifEè3 K/home/install/workspace/trunk/http/img/button_blink_red/preferences_off.pngD>¡ C/home/install/workspace/trunk/http/img/button_gray/perimeter_on.pngDFYÌ F/home/install/workspace/trunk/http/img/button_blink_red/repaint_on.pngD>¡ =/home/install/workspace/trunk/http/img/openlayers/zoombar.pngHw]à I/home/install/workspace/trunk/http/css/images/ui-icons_888888_256x240.pngJ)>© E/home/install/workspace/trunk/http/img/button_silver_blue/help_on.pngHZ3£ D/home/install/workspace/trunk/http/img/button_silver_blue/add_on.pngHZ3£ //home/install/workspace/trunk/http/img/help.pngJ8½Ã D/home/install/workspace/trunk/http/img/button_gray/zoomfull2_off.pngD>¯g ;/home/install/workspace/trunk/http/img/trafficlights/go.bmpDHþ D/home/install/workspace/trunk/http/img/button_blink_red/tiles_on.pngD>¡ =/home/install/workspace/trunk/http/img/trafficlights/wait.bmpDHþ C/home/install/workspace/trunk/http/img/button_gray/metadata_off.pngD>½È H/home/install/workspace/trunk/http/img/button_silver_blue/repaint_on.pngHZ3£ L/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_off.pngD>¯g G/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_on.pngDÎ I/home/install/workspace/trunk/http/img/button_blink_red/metadata_over.pngD>¡ G/home/install/workspace/trunk/http/img/button_blink_red/repaint_off.pngD>¡ 9/home/install/workspace/trunk/http/img/mapbender_logo.pngD>±h D/home/install/workspace/trunk/http/img/button_gray/perimeter_off.gifD>¯g a/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_arrows_leftright.gifJ)? R/home/install/workspace/trunk/http/img/button_silver_blue/forward_off_disabled.pngHZ3£ E/home/install/workspace/trunk/http/img/openlayers/panning-hand-on.pngHw]à G/home/install/workspace/trunk/http/img/button_digitize/new_node_off.pngD@Ò E/home/install/workspace/trunk/http/img/button_blink_red/query_off.pngD>¡ M/home/install/workspace/trunk/http/img/button_blink_red/resizemapsize_off.pngE5± H/home/install/workspace/trunk/http/img/button_silver_blue/center_off.pngHZ3£ F/home/install/workspace/trunk/http/img/button_blink_red/addlist_on.pngD>¡ A/home/install/workspace/trunk/http/img/button_gray/rubber_off.gifD>¯g 9/home/install/workspace/trunk/http/img/arrows/arrow_n.gifD>¬¡ I/home/install/workspace/trunk/http/img/button_gray/overviewgermany_on.gifD>½È J/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_off.pngHZ3£ T/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_doc.gifJ)? H/home/install/workspace/trunk/http/img/button_silver_blue/logout_off.pngHZ3£ @/home/install/workspace/trunk/http/img/button_blue/help_over.pngDì @/home/install/workspace/trunk/http/img/button_gray/coords_on.pngD>½È ;/home/install/workspace/trunk/http/img/tree_orange/file.gifD>°Ø B/home/install/workspace/trunk/http/img/button_blue/metadata_on.pngDì D/home/install/workspace/trunk/http/img/button_blink_red/add_over.pngD>¡ I/home/install/workspace/trunk/http/img/button_blue/select_extent_over.pngDZ G/home/install/workspace/trunk/http/img/button_digitize/move_node_on.pngD@Ò @/home/install/workspace/trunk/http/img/button_gray/print_off.gifD>¯g ^/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_folder_closed.gifJ)? 9/home/install/workspace/trunk/http/img/tree_gray/file.gifD>°¤ 5/home/install/workspace/trunk/http/img/close_icon.pngFú >/home/install/workspace/trunk/http/img/button_gray/help_on.pngD>¯g T/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_down.gifJ)? F/home/install/workspace/trunk/http/img/button_blue/preferences_off.pngDì A/home/install/workspace/trunk/http/img/button_gray/selArea_on.gifD>½È A/home/install/workspace/trunk/http/img/button_blue/rubber_off.pngDì V/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_close.gifJ)? K/home/install/workspace/trunk/http/img/button_gray/forward_off_disabled.pngD>¯g G/home/install/workspace/trunk/http/img/button_blue/select_choose_on.pngDZ >/home/install/workspace/trunk/http/img/tree_gray/folder_on.gifD>°¤ E/home/install/workspace/trunk/http/img/openlayers/zoom-world-mini.pngHw]à >/home/install/workspace/trunk/http/img/button_blue/pan_off.pngHb¸ 5/home/install/workspace/trunk/http/img/OSGeo_logo.pngIÃrÄ U/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_plus.gifJ)? >/home/install/workspace/trunk/http/img/button_gray/pan_off.pngD>¯g ?/home/install/workspace/trunk/http/img/button_gray/user_off.gifD>½È H/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_on.pngHZ3£ H/home/install/workspace/trunk/http/img/button_silver_blue/rubber_off.pngHZ3£ 9/home/install/workspace/trunk/http/img/button_gray/up.pngDÀ¼
+ B/home/install/workspace/trunk/http/img/button_digitize/line_on.pngDAo 8/home/install/workspace/trunk/http/img/tree_new/hide.pngE´l A/home/install/workspace/trunk/http/img/button_gray/addlist_on.pngD>¯g I/home/install/workspace/trunk/http/img/button_silver_blue/metadata_on.pngHZ3£ K/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_off.pngHZ3£ H/home/install/workspace/trunk/http/img/openlayers/drag-rectangle-off.pngHw]à J/home/install/workspace/trunk/http/img/button_gray/overviewgermany_off.gifD>¯g :/home/install/workspace/trunk/http/sld/img/script_save.pngH`f B/home/install/workspace/trunk/http/img/button_gray/wmc_save_on.pngD>¯g D/home/install/workspace/trunk/http/img/button_blink_red/down_off.pngH_ÇM G/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_on.pngD>¡ ?/home/install/workspace/trunk/http/img/button_gray/leg_over.pngD>½È //home/install/workspace/trunk/http/img/desc.gifIû M/home/install/workspace/trunk/http/img/button_silver_blue/preferences_off.pngHZ3£ K/home/install/workspace/trunk/http/img/button_blue/select_rectangle_off.pngDZ 7/home/install/workspace/trunk/http/img/wfs_digitize.pngDï O/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_over.pngHZ3£ N/home/install/workspace/trunk/http/img/button_silver_blue/preferences_over.pngHZ3£ P/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_over.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/gazetteer_on.pngD>¯g ?/home/install/workspace/trunk/http/img/tree_new/last_closed.pngE´l G/home/install/workspace/trunk/http/img/button_silver_blue/logout_on.pngHZ3£ @/home/install/workspace/trunk/http/img/button_digitize/trans.pngD>® F/home/install/workspace/trunk/http/img/button_blink_red/coords_off.pngD>¡ U/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_plus.gifJ)? V/home/install/workspace/trunk/http/css/images/ui-bg_highlight-soft_75_cccccc_1x100.pngJ)>© >/home/install/workspace/trunk/http/img/button_gray/add_off.pngD>¯g D/home/install/workspace/trunk/http/img/button_digitize/geomClone.pngIÈÚß F/home/install/workspace/trunk/http/img/button_gray/preferences_off.pngD>½È O/home/install/workspace/trunk/http/img/button_blink_red/change_password_off.pngD>¡ I/home/install/workspace/trunk/http/img/button_gray/select_polygon_off.pngD a/home/install/workspace/trunk/http/extensions/theme/images/ffffff_40x100_textures_02_glass_65.pngJ)? L/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_off.pngDì C/home/install/workspace/trunk/http/img/button_gray/zoomIn2_over.gifD>¯g P/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_off.pngHZ3£ A/home/install/workspace/trunk/http/img/button_blink_red/up_on.pngH_ÇM L/home/install/workspace/trunk/http/img/button_gray/select_rectangle_over.pngD B/home/install/workspace/trunk/http/img/button_blue/zoomOut2_on.pngDì P/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_over.pngHZ3£ H/home/install/workspace/trunk/http/img/button_silver_blue/coords_off.pngHZ3£ H/home/install/workspace/trunk/http/img/button_blue/select_choose_off.pngDZ 4/home/install/workspace/trunk/http/img/sandclock.gifD>±h >/home/install/workspace/trunk/http/img/button_gray/add_off.gifD>¯g C/home/install/workspace/trunk/http/img/button_digitize/line_off.pngDAo C/home/install/workspace/trunk/http/img/button_gray/metadata_wms.gifEè3¹ O/home/install/workspace/trunk/http/img/button_silver_blue/select_point_over.pngHZ3£ 9/home/install/workspace/trunk/http/img/tree_blue/file.gifD¥â >/home/install/workspace/trunk/http/img/button_blue/back_on.pngDì B/home/install/workspace/trunk/http/img/button_gray/center_over.gifD>¯g N/home/install/workspace/trunk/http/img/button_silver_blue/back_on_disabled.pngHZ3£ E/home/install/workspace/trunk/http/img/button_silver_blue/add_off.pngHZ3£ >/home/install/workspace/trunk/http/img/button_blue/add_off.pngDì B/home/install/workspace/trunk/http/img/button_blue/zoomFull_on.pngDì T/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_down.gifJ)? A/home/install/workspace/trunk/http/img/button_gray/rubber_off.pngD>¯g E/home/install/workspace/trunk/http/img/button_blink_red/user_over.pngD>¡ I/home/install/workspace/trunk/http/img/button_digitize/move_node_over.pngD@Ò C/home/install/workspace/trunk/http/img/button_gray/selArea_over.gifD>¯g 2/home/install/workspace/trunk/http/img/no_info.gifD>±h Q/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_off.pngD>¡ L/home/install/workspace/trunk/http/img/button_blue/forward_over_disabled.pngDì C/home/install/workspace/trunk/http/img/button_gray/helpbook_off.pngD>½È B/home/install/workspace/trunk/http/img/tree_new/expanded_error.pngE´l 7/home/install/workspace/trunk/http/img/tree_blue/1w.gifD¥â J/home/install/workspace/trunk/http/img/openlayers/cloud-popup-relative.pngHw]à E/home/install/workspace/trunk/http/img/button_gray/perimeter_over.pngDFYÝ B/home/install/workspace/trunk/http/img/tree_new/loading_folder.gifE´l L/home/install/workspace/trunk/http/img/button_silver_blue/preferences_on.pngHZ3£ I/home/install/workspace/trunk/http/img/button_gray/select_extent_over.pngD J/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_on.pngHZ3£ 0/home/install/workspace/trunk/http/img/white.gifD>±h K/home/install/workspace/trunk/http/img/button_gray/overviewgermany_over.pngD>¯g B/home/install/workspace/trunk/http/img/button_blue/wmc_load_on.pngDì K/home/install/workspace/trunk/http/img/button_silver_blue/new_node_over.pngHZ3£ B/home/install/workspace/trunk/http/img/button_blue/center_over.pngDì A/home/install/workspace/trunk/http/img/tree_new/closed_folder.pngE´l >/home/install/workspace/trunk/http/img/button_gray/user_on.pngD>¯g P/home/install/workspace/trunk/http/img/button_blink_red/forward_off_disabled.pngD>¡ M/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_on.pngHZ3£ N/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_off.pngHZ3£ O/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_off.pngD>¡ H/home/install/workspace/trunk/http/img/button_silver_blue/addlist_on.pngHZ3£ :/home/install/workspace/trunk/http/img/tree/file_empty.gifD>¯É ?/home/install/workspace/trunk/http/print/img/mapbender_logo.pngD>¹` J/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_on.pngI¾p C/home/install/workspace/trunk/http/img/button_blue/metadata_off.pngDì :/home/install/workspace/trunk/http/img/arrows/arrow_se.gifD>¬¡ =/home/install/workspace/trunk/http/img/button_gray/pan_on.gifD>¯g A/home/install/workspace/trunk/http/img/button_gray/logout_off.gifD>¯g F/home/install/workspace/trunk/http/img/button_blink_red/selArea_on.pngD>¡ Q/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_on.pngHZ3£ H/home/install/workspace/trunk/http/img/button_silver_blue/geomRemove.pngHZ3£ J/home/install/workspace/trunk/http/img/button_silver_blue/geomRemoveDb.pngHZ3£ F/home/install/workspace/trunk/http/img/button_silver_blue/help_off.pngHZ3£ F/home/install/workspace/trunk/http/img/button_blink_red/tiles_over.pngD>¡ @/home/install/workspace/trunk/http/img/button_gray/wmc_merge.pngD>¯g U/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_right.gifJ)? I/home/install/workspace/trunk/http/img/button_gray/back_over_disabled.pngD>½È 6/home/install/workspace/trunk/http/img/transparent.gifD>±h G/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_off.pngD>¡ I/home/install/workspace/trunk/http/img/button_silver_blue/new_node_on.pngHZ3£ @/home/install/workspace/trunk/http/img/button_blue/coords_on.pngDì D/home/install/workspace/trunk/http/img/button_gray/gazetteer_off.pngD>¯g G/home/install/workspace/trunk/http/img/button_blink_red/logout_over.pngD>¡ C/home/install/workspace/trunk/http/img/button_blue/getArea_over.pngDì @/home/install/workspace/trunk/http/img/tree_orange/file_last.gifD>°Ø @/home/install/workspace/trunk/http/img/button_gray/user_over.gifD>¯g D/home/install/workspace/trunk/http/img/button_blue/metadata_over.pngDì F/home/install/workspace/trunk/http/img/button_silver_blue/add_over.pngHZ3£ K/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_over.pngHZ3£ >/home/install/workspace/trunk/http/img/button_gray/smaller.gifD>½È B/home/install/workspace/trunk/http/img/button_gray/zoomIn2_off.gifD>¯g @/home/install/workspace/trunk/http/img/button_blue/print_off.pngDì N/home/install/workspace/trunk/http/img/button_blink_red/select_extent_over.pngD M/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_over.pngD>¯g I/home/install/workspace/trunk/http/img/button_blink_red/zoomfull2_off.pngD>¡ >/home/install/workspace/trunk/http/img/button_gray/wmc_xml.pngD>½È G/home/install/workspace/trunk/http/img/button_silver_blue/point_off.pngHZ3£ M/home/install/workspace/trunk/http/css/images/ui-bg_glass_75_dadada_1x400.pngJ)>© a/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_arrows_leftright.gifJ)? A/home/install/workspace/trunk/http/img/button_blue/getArea_on.pngDì 9/home/install/workspace/trunk/http/img/tree/file_last.gifD>¯É @/home/install/workspace/trunk/http/img/button_gray/print_off.pngD>¯g F/home/install/workspace/trunk/http/img/button_silver_blue/query_on.pngHZ3£ A/home/install/workspace/trunk/http/img/button_blue/selArea_on.pngDì H/home/install/workspace/trunk/http/img/button_silver_blue/print_over.pngHZ3£ S/home/install/workspace/trunk/http/img/button_silver_blue/forward_over_disabled.pngHZ3£ J/home/install/workspace/trunk/http/img/button_silver_blue/repaint_over.pngHZ3£ B/home/install/workspace/trunk/http/img/button_gray/getArea_off.pngD>¯g ?/home/install/workspace/trunk/http/img/button_blue/print_on.pngDì :/home/install/workspace/trunk/http/sld/img/script_link.pngH`f K/home/install/workspace/trunk/http/img/button_blink_red/addwmsblink_off.pngD>¡ F/home/install/workspace/trunk/http/img/button_silver_blue/shape_on.pngHZ3£ ./home/install/workspace/trunk/http/img/wms.gifEìM ?/home/install/workspace/trunk/http/img/button_gray/leg_over.gifD>½È I/home/install/workspace/trunk/http/img/button_silver_blue/rubber_over.pngHZ3£ L/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_over.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/zoomOut2_off.pngD>½È =/home/install/workspace/trunk/http/img/trafficlights/stop.bmpDHþ P/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_over.pngHZ3£ @/home/install/workspace/trunk/http/img/button_blue/reload_on.pngHb¸ J/home/install/workspace/trunk/http/img/button_digitize/delete_node_off.pngDAL =/home/install/workspace/trunk/http/img/button_gray/pan_on.pngD>¯g N/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_on.pngD>¡ F/home/install/workspace/trunk/http/img/button_silver_blue/point_on.pngHZ3£ K/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_off.pngI¾p =/home/install/workspace/trunk/http/img/button_gray/add_on.pngD>¯g C/home/install/workspace/trunk/http/img/button_gray/selArea_over.pngD>¯g @/home/install/workspace/trunk/http/img/button_gray/reload_on.pngHb¸ B/home/install/workspace/trunk/http/img/button_blue/wmc_save_on.pngDì C/home/install/workspace/trunk/http/img/button_gray/zoomOut2_off.gifD>¯g E/home/install/workspace/trunk/http/img/button_blink_red/reload_on.pngHb¸ A/home/install/workspace/trunk/http/img/button_blue/print_over.pngDì C/home/install/workspace/trunk/http/img/button_blue/zoomOut2_off.pngDì A/home/install/workspace/trunk/http/img/button_blue/logout_off.pngDì L/home/install/workspace/trunk/http/img/button_gray/forward_over_disabled.gifD>¯g ;/home/install/workspace/trunk/http/img/button_gray/logo.jpgD>½È E/home/install/workspace/trunk/http/img/button_gray/logoutred_over.pngD>¯g B/home/install/workspace/trunk/http/img/button_gray/reload_over.pngHb¸ D/home/install/workspace/trunk/http/img/button_blink_red/exit_off.pngD>¡ ;/home/install/workspace/trunk/http/img/button_gray/save.pngD>¯g B/home/install/workspace/trunk/http/img/button_blue/logout_over.pngDì D/home/install/workspace/trunk/http/img/button_blink_red/leg_over.pngD>¡ =/home/install/workspace/trunk/http/img/button_blue/add_on.pngDì ?/home/install/workspace/trunk/http/img/button_gray/print_on.gifD>½È A/home/install/workspace/trunk/http/img/button_blue/reload_off.pngHb¸ D/home/install/workspace/trunk/http/img/button_gray/zoomOut2_over.gifD>¯g C/home/install/workspace/trunk/http/img/button_blink_red/user_on.pngD>¡ O/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_over.pngD M/home/install/workspace/trunk/http/img/openlayers/layer-switcher-maximize.pngHw]à M/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_off.pngHZ3£ E/home/install/workspace/trunk/http/img/button_blue/gazetteer_over.pngDì B/home/install/workspace/trunk/http/img/button_blue/repaint_off.pngDì >/home/install/workspace/trunk/http/img/tree_blue/file_last.gifD¥â K/home/install/workspace/trunk/http/img/button_silver_blue/metadata_over.pngHZ3£ D/home/install/workspace/trunk/http/img/button_digitize/point_off.pngD@Ò D/home/install/workspace/trunk/http/img/button_blink_red/pan_over.pngD>¡ G/home/install/workspace/trunk/http/img/button_gray/closePolygon_off.pngD>¯g C/home/install/workspace/trunk/http/img/button_blink_red/exit_on.pngD>¡ J/home/install/workspace/trunk/http/img/button_silver_blue/addlist_over.pngHZ3£ E/home/install/workspace/trunk/http/img/button_silver_blue/back_on.pngHZ3£ I/home/install/workspace/trunk/http/img/button_silver_blue/measure_off.pngHZ3£ J/home/install/workspace/trunk/http/img/button_blue/select_polygon_over.pngDZ G/home/install/workspace/trunk/http/img/button_gray/preferences_over.pngD>¯g I/home/install/workspace/trunk/http/img/button_gray/zoomFullarrow_over.pngD>¯g A/home/install/workspace/trunk/http/img/button_gray/logout_off.pngD>¯g B/home/install/workspace/trunk/http/img/button_gray/selArea_off.gifD>¯g U/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_right.gifJ)? J/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_off.pngHZ3£ 5/home/install/workspace/trunk/http/img/balloon_lr.gifHë« G/home/install/workspace/trunk/http/img/button_silver_blue/coords_on.pngHZ3£ D/home/install/workspace/trunk/http/img/button_gray/zoomFull_over.pngD>¯g I/home/install/workspace/trunk/http/img/button_blue/select_polygon_off.pngDZ H/home/install/workspace/trunk/http/img/button_silver_blue/shape_over.pngHZ3£ E/home/install/workspace/trunk/http/img/button_gray/gazetteer_over.gifD>¯g H/home/install/workspace/trunk/http/img/button_blink_red/addlist_over.pngD>¡ ?/home/install/workspace/trunk/http/img/button_blue/help_off.pngDì a/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_arrows_leftright.gifJ)? @/home/install/workspace/trunk/http/img/button_gray/back_over.pngD>¯g Q/home/install/workspace/trunk/http/img/button_silver_blue/forward_on_disabled.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/gazetteer_on.gifD>¯g @/home/install/workspace/trunk/http/extensions/datepicker/cal.gifH_I ?/home/install/workspace/trunk/http/img/tree_gray/file_empty.gifD>°¤ I/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_over.pngDÎ I/home/install/workspace/trunk/http/css/images/ui-icons_cd0a0a_256x240.pngJ)>© C/home/install/workspace/trunk/http/img/button_gray/zoomFull_off.gifD>¯g A/home/install/workspace/trunk/http/img/button_gray/coods_over.pngD>¯g V/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_minus.gifJ)? 3/home/install/workspace/trunk/http/sld/img/plus.gifH`f D/home/install/workspace/trunk/http/img/button_blink_red/user_off.pngD>¡ A/home/install/workspace/trunk/http/img/tree_orange/folder_off.gifD>°Ø C/home/install/workspace/trunk/http/img/button_gray/repaint_over.pngD>¯g M/home/install/workspace/trunk/http/img/button_blink_red/select_choose_off.pngD B/home/install/workspace/trunk/http/img/button_blue/zoomIn2_off.pngDì B/home/install/workspace/trunk/http/img/button_gray/getArea_off.gifD>¯g 5/home/install/workspace/trunk/http/img/balloon_ll.pngHë« R/home/install/workspace/trunk/http/img/button_silver_blue/change_password_over.pngHZ3£ H/home/install/workspace/trunk/http/img/button_digitize/new_node_over.pngD@Ò M/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_over.gifD>¯g J/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_off.pngHZ3£ D/home/install/workspace/trunk/http/img/button_gray/zoomOut2_over.pngD>¯g 9/home/install/workspace/trunk/http/img/tree/folder_on.gifD>¯É \/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_folder_open.gifJ)? @/home/install/workspace/trunk/http/img/button_blue/rubber_on.pngDì J/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_on.pngH¾
Å F/home/install/workspace/trunk/http/img/button_blue/closePolygon_on.pngDì V/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_minus.gifJ)? D/home/install/workspace/trunk/http/img/button_gray/perimeter_off.pngDFY± =/home/install/workspace/trunk/http/img/tree_new/move_down.pngE´l H/home/install/workspace/trunk/http/img/button_blink_red/selArea_over.pngD>¡ N/home/install/workspace/trunk/http/img/button_blink_red/resizemapsize_over.pngE5Ë H/home/install/workspace/trunk/http/img/button_blink_red/metadata_off.pngD>¡ J/home/install/workspace/trunk/http/img/button_silver_blue/metadata_off.pngHZ3£ T/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_down.gifJ)? B/home/install/workspace/trunk/http/img/button_gray/rubber_over.gifD>¯g @/home/install/workspace/trunk/http/img/tree_new/delete_wmsmy.pngE´l B/home/install/workspace/trunk/http/img/button_gray/measure_off.pngD>½È C/home/install/workspace/trunk/http/img/button_gray/zoomIn2_over.pngD>½È ?/home/install/workspace/trunk/http/img/button_gray/tiles_on.pngD>¯g K/home/install/workspace/trunk/http/img/button_blink_red/select_point_on.pngD O/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_off2.pngHZ3£ </home/install/workspace/trunk/http/img/tree_new/expanded.pngE´l H/home/install/workspace/trunk/http/img/button_silver_blue/forward_on.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/addlist_over.pngD>¯g G/home/install/workspace/trunk/http/img/button_blink_red/addlist_off.pngD>¡ K/home/install/workspace/trunk/http/img/button_blue/change_password_over.pngDì @/home/install/workspace/trunk/http/img/button_gray/query_off.pngD>¯g ?/home/install/workspace/trunk/http/img/button_gray/query_on.gifD>½È ?/home/install/workspace/trunk/http/img/button_gray/add_over.gifD>¯g A/home/install/workspace/trunk/http/img/button_gray/coords_off.pngD>¯g L/home/install/workspace/trunk/http/img/button_blink_red/select_point_off.pngD B/home/install/workspace/trunk/http/img/button_gray/zoomIn2_off.pngD>¯g E/home/install/workspace/trunk/http/img/button_blink_red/tiles_off.pngD>¡ L/home/install/workspace/trunk/http/img/button_blink_red/select_choose_on.pngD C/home/install/workspace/trunk/http/img/button_blink_red/help_on.pngEbÿî >/home/install/workspace/trunk/http/img/button_blue/home_on.pngDì >/home/install/workspace/trunk/http/img/button_blue/help_on.pngDì F/home/install/workspace/trunk/http/img/button_blink_red/addwms_off.pngD>¡ G/home/install/workspace/trunk/http/img/button_digitize/geomRemoveDb.pngE¸¹ö G/home/install/workspace/trunk/http/img/button_digitize/polygon_over.pngD@Ò O/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_off.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/zoomfull2_on.pngD>¯g S/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_off.pngHZ3£ I/home/install/workspace/trunk/http/img/button_silver_blue/coords_over.pngHZ3£ K/home/install/workspace/trunk/http/img/button_gray/select_rectangle_off.pngD H/home/install/workspace/trunk/http/img/button_digitize/move_node_off.pngD@Ò B/home/install/workspace/trunk/http/img/button_blue/rubber_over.pngDì A/home/install/workspace/trunk/http/img/button_gray/tiles_over.pngD>¯g B/home/install/workspace/trunk/http/img/button_gray/zoomOut2_on.gifD>½È I/home/install/workspace/trunk/http/img/button_silver_blue/forward_off.pngHZ3£ T/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_left.gifJ)? 9/home/install/workspace/trunk/http/img/arrows/arrow_e.gifD>¬¡ I/home/install/workspace/trunk/http/img/button_gray/back_over_disabled.gifD>¯g H/home/install/workspace/trunk/http/img/button_gray/exportMapimage_on.pngHb¸ T/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_over.pngHZ3£ N/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_on.pngHZ3£ M/home/install/workspace/trunk/http/img/button_blink_red/select_extent_off.pngDÕ O/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_off.pngHZ3£ H/home/install/workspace/trunk/http/img/button_blue/select_point_over.pngDZ A/home/install/workspace/trunk/http/img/button_gray/measure_on.gifD>¯g P/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_off.pngD 8/home/install/workspace/trunk/http/img/button_gray/x.pngD>¯g C/home/install/workspace/trunk/http/img/button_gray/forward_over.gifD>¯g C/home/install/workspace/trunk/http/img/button_blue/zoomFull_off.pngDì ?/home/install/workspace/trunk/http/img/tree_blue/folder_off.gifD¥â :/home/install/workspace/trunk/http/img/tree_new/branch.pngE´l B/home/install/workspace/trunk/http/img/button_digitize/polygon.pngHb¸ ?/home/install/workspace/trunk/http/img/button_gray/wmc_save.pngD>¯g N/home/install/workspace/trunk/http/img/button_silver_blue/select_point_off.pngHZ3£ >/home/install/workspace/trunk/http/img/button_gray/home_on.pngD>¯g L/home/install/workspace/trunk/http/img/button_blink_red/preferences2_off.pngD>¡ 8/home/install/workspace/trunk/http/img/tree_new/leaf.pngE´l V/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_close.gifJ)? 4/home/install/workspace/trunk/http/img/tree/file.gifD>¯É G/home/install/workspace/trunk/http/img/button_silver_blue/center_on.pngHZ3£ D/home/install/workspace/trunk/http/img/button_gray/helpbook_over.pngD>¯g B/home/install/workspace/trunk/http/img/button_gray/forward_off.pngD>¯g >/home/install/workspace/trunk/http/img/tree_new/delete_wms.pngE´l 5/home/install/workspace/trunk/http/img/balloon_ur.gifHë« L/home/install/workspace/trunk/http/css/images/ui-bg_flat_0_aaaaaa_40x100.pngJ)>© B/home/install/workspace/trunk/http/img/button_blue/reload_over.pngHb¸ ./home/install/workspace/trunk/http/img/add.pngF¤Ù I/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_on.pngHZ3£ >/home/install/workspace/trunk/http/img/tree_gray/file_last.gifD>°¤ D/home/install/workspace/trunk/http/img/button_gray/logoutred_off.pngD>¯g ^/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_arrows_updown.gifJ)? F/home/install/workspace/trunk/http/img/button_gray/preferences_off.gifD>½È B/home/install/workspace/trunk/http/img/button_blue/selArea_off.pngDì ;/home/install/workspace/trunk/http/print/img/northarrow.pngFû A/home/install/workspace/trunk/http/img/button_gray/wmc_append.pngD>¯g A/home/install/workspace/trunk/http/img/button_gray/zoomIn2_on.gifD>¯g J/home/install/workspace/trunk/http/img/button_silver_blue/new_node_off.pngHZ3£ N/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_off.pngHb¸ G/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_on.pngDÎ @/home/install/workspace/trunk/http/img/button_digitize/point.pngHb¸ S/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_over.pngHZ3£ T/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_doc.gifJ)? M/home/install/workspace/trunk/http/css/images/ui-bg_flat_75_ffffff_40x100.pngJ)>© G/home/install/workspace/trunk/http/img/openlayers/drag-rectangle-on.pngHw]à 5/home/install/workspace/trunk/http/img/balloon_ul.pngHë« J/home/install/workspace/trunk/http/img/button_gray/overviewgermany_off.pngD>½È >/home/install/workspace/trunk/http/img/tree_blue/folder_on.gifD¥â >/home/install/workspace/trunk/http/img/button_gray/user_on.gifD>¯g @/home/install/workspace/trunk/http/img/button_blue/logout_on.pngDì C/home/install/workspace/trunk/http/img/button_gray/forward_over.pngD>¯g @/home/install/workspace/trunk/http/img/button_gray/query_off.gifD>¯g ?/home/install/workspace/trunk/http/img/button_blue/add_over.pngDì G/home/install/workspace/trunk/http/img/button_blue/closePolygon_off.pngDì A/home/install/workspace/trunk/http/img/openlayers/marker-gold.pngHw]à A/home/install/workspace/trunk/http/img/button_gray/reload_off.pngHb¸ A/home/install/workspace/trunk/http/img/button_digitize/del_on.pngE¬Ìú @/home/install/workspace/trunk/http/img/button_blue/home_over.pngDì H/home/install/workspace/trunk/http/img/button_silver_blue/query_over.pngHZ3£ H/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_off.pngDÎ B/home/install/workspace/trunk/http/img/button_gray/rubber_over.pngD>¯g ^/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_folder_closed.gifJ)? ;/home/install/workspace/trunk/http/img/tree_new/move_up.pngE´l A/home/install/workspace/trunk/http/img/button_gray/query_over.gifD>½È K/home/install/workspace/trunk/http/img/button_digitize/delete_node_over.pngDAL H/home/install/workspace/trunk/http/img/button_silver_blue/point_over.pngHZ3£ M/home/install/workspace/trunk/http/css/images/ui-bg_glass_65_ffffff_1x400.pngJ)>© O/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_on.pngD H/home/install/workspace/trunk/http/img/button_silver_blue/getArea_on.pngHZ3£ I/home/install/workspace/trunk/http/img/button_silver_blue/rubber_off2.pngHZ3£ >/home/install/workspace/trunk/http/img/button_gray/pan_off.gifD>¯g C/home/install/workspace/trunk/http/img/button_gray/zoomFull_off.pngD>¯g J/home/install/workspace/trunk/http/img/button_silver_blue/selArea_over.pngHZ3£ C/home/install/workspace/trunk/http/img/button_digitize/geomInfo.pngIäà a/home/install/workspace/trunk/http/extensions/theme/images/e6e6e6_40x100_textures_02_glass_75.pngJ)? J/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_off.pngHZ3£ O/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_on.pngHZ3£ C/home/install/workspace/trunk/http/img/button_blue/wmc_load_off.pngDì C/home/install/workspace/trunk/http/img/button_blue/repaint_over.pngDì M/home/install/workspace/trunk/http/img/openlayers/layer-switcher-minimize.pngHw]à R/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_up.gifJ)? J/home/install/workspace/trunk/http/img/button_silver_blue/forward_over.pngHZ3£ D/home/install/workspace/trunk/http/img/button_gray/metadata_over.pngD>¯g A/home/install/workspace/trunk/http/img/button_blue/forward_on.pngDì C/home/install/workspace/trunk/http/img/button_gray/measure_over.pngD>¯g ?/home/install/workspace/trunk/http/img/button_blue/back_off.pngDì A/home/install/workspace/trunk/http/img/button_gray/selArea_on.pngD>¯g ?/home/install/workspace/trunk/http/img/button_gray/user_off.pngD>¯g 8/home/install/workspace/trunk/http/img/tree_new/info.pngE´l 2/home/install/workspace/trunk/http/img/info_on.gifD>±h H/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_off.pngD>¡ A/home/install/workspace/trunk/http/img/button_gray/repaint_on.pngD>¯g `/home/install/workspace/trunk/http/extensions/theme/images/ffffff_40x100_textures_01_flat_75.pngJ)? R/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_on.pngHZ3£ H/home/install/workspace/trunk/http/img/button_blue/back_off_disabled.pngDì N/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_on.pngHZ3£ @/home/install/workspace/trunk/http/img/button_gray/tiles_off.pngD>½È @/home/install/workspace/trunk/http/img/button_gray/back_over.gifD>¯g ?/home/install/workspace/trunk/http/img/tree_new/move_downmy.pngE´l E/home/install/workspace/trunk/http/img/button_gray/zoomfull2_over.pngD>½È B/home/install/workspace/trunk/http/img/button_gray/coords_over.pngD>¯g E/home/install/workspace/trunk/http/img/button_silver_blue/line_on.pngHZ3£ I/home/install/workspace/trunk/http/img/button_silver_blue/logout_over.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/repaint_over.gifD>¯g C/home/install/workspace/trunk/http/img/button_blue/wmc_save_off.pngDì J/home/install/workspace/trunk/http/img/button_silver_blue/move_node_on.pngHZ3£ C/home/install/workspace/trunk/http/img/button_blue/selArea_over.pngDì G/home/install/workspace/trunk/http/img/button_blink_red/center_over.pngD>¡ ,/home/install/workspace/trunk/http/img/x.gifD>±h :/home/install/workspace/trunk/http/img/arrows/arrow_sw.gifD>¬¡ I/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_off.pngHZ3£ 6/home/install/workspace/trunk/http/img/scalebar_bw.gifD>±h ?/home/install/workspace/trunk/http/img/button_gray/print_on.pngD>¯g I/home/install/workspace/trunk/http/img/button_digitize/delete_node_on.pngDAL H/home/install/workspace/trunk/http/img/button_gray/select_polygon_on.pngD J/home/install/workspace/trunk/http/img/button_blue/forward_on_disabled.pngDì 5/home/install/workspace/trunk/http/img/balloon_ll.gifHë« H/home/install/workspace/trunk/http/img/button_blink_red/forward_over.pngD>¡ I/home/install/workspace/trunk/http/img/openlayers/measuring-stick-off.pngHw]à 5/home/install/workspace/trunk/http/img/balloon_ul.gifHë« K/home/install/workspace/trunk/http/img/button_gray/forward_off_disabled.gifD>¯g P/home/install/workspace/trunk/http/img/button_blink_red/change_password_over.pngD>¡ =/home/install/workspace/trunk/http/img/button_blue/pan_on.pngHb¸ B/home/install/workspace/trunk/http/img/button_blue/coords_over.pngDì I/home/install/workspace/trunk/http/img/button_gray/exportMapimage_off.pngHb¸ J/home/install/workspace/trunk/http/img/button_gray/select_polygon_over.pngD @/home/install/workspace/trunk/http/img/button_blue/back_over.pngDì D/home/install/workspace/trunk/http/img/button_blink_red/query_on.pngD>¡ ./home/install/workspace/trunk/http/img/map.pngInQc L/home/install/workspace/trunk/http/img/button_blue/select_rectangle_over.pngDZ 0/home/install/workspace/trunk/http/img/black.gifD>±h D/home/install/workspace/trunk/http/img/button_blink_red/print_on.pngD>¡ ?/home/install/workspace/trunk/http/img/button_blue/home_off.pngDì O/home/install/workspace/trunk/http/img/button_silver_blue/back_off_disabled.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/wmc_load_off.pngD>¯g 4/home/install/workspace/trunk/http/sld/img/minus.gifH`f H/home/install/workspace/trunk/http/img/button_gray/zoomFullarrow_off.pngD>¯g L/home/install/workspace/trunk/http/img/button_blink_red/preferences_over.pngD>¡ ?/home/install/workspace/trunk/http/img/button_gray/back_off.gifD>¯g ?/home/install/workspace/trunk/http/img/button_gray/wmc_load.pngD>½È =/home/install/workspace/trunk/http/img/tree_new/last_leaf.pngE´l M/home/install/workspace/trunk/http/img/button_blink_red/select_point_over.pngD M/home/install/workspace/trunk/http/css/images/ui-bg_glass_75_e6e6e6_1x400.pngJ)>© 8/home/install/workspace/trunk/http/img/button_gray/x.gifD>¯g N/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_over.pngHZ3£ M/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_over.pngI¾Y ./home/install/workspace/trunk/http/img/asc.gifIû G/home/install/workspace/trunk/http/img/button_blink_red/measure_off.pngD>¡ B/home/install/workspace/trunk/http/img/button_blink_red/up_off.pngH_ÇM T/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_doc.gifJ)? G/home/install/workspace/trunk/http/img/button_blink_red/addwms_over.pngD>¡ G/home/install/workspace/trunk/http/img/button_silver_blue/reload_on.pngHZ3£ D/home/install/workspace/trunk/http/img/button_blink_red/help3_on.pngD>¡ A/home/install/workspace/trunk/http/img/button_blue/repaint_on.pngDì R/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_over.pngD>¡ ?/home/install/workspace/trunk/http/img/button_gray/coods_on.gifD>½È J/home/install/workspace/trunk/http/img/button_silver_blue/polygon_over.pngHZ3£ G/home/install/workspace/trunk/http/img/button_silver_blue/help_over.pngHZ3£ M/home/install/workspace/trunk/http/img/button_blink_red/preferences2_over.pngD>¡ E/home/install/workspace/trunk/http/img/button_blink_red/center_on.pngD>¡ M/home/install/workspace/trunk/http/img/button_silver_blue/select_point_on.pngHZ3£ :/home/install/workspace/trunk/http/img/tree_new/closed.pngE´l Q/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_over.pngHZ3£ B/home/install/workspace/trunk/http/img/button_blue/measure_off.pngDì 9/home/install/workspace/trunk/http/img/tree/file_vert.gifD>¯É I/home/install/workspace/trunk/http/css/images/ui-icons_2e83ff_256x240.pngJ)>© :/home/install/workspace/trunk/http/sld/img/map_magnify.pngH`f J/home/install/workspace/trunk/http/img/button_blue/select_rectangle_on.pngDZ A/home/install/workspace/trunk/http/img/button_gray/coods_over.gifD>¯g A/home/install/workspace/trunk/http/img/button_gray/center_off.pngD>¯g K/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_on.pngD>¯g K/home/install/workspace/trunk/http/img/button_gray/change_password_over.pngD>¯g G/home/install/workspace/trunk/http/img/button_blue/preferences_over.pngDì D/home/install/workspace/trunk/http/img/button_silver_blue/del_on.pngHZ3£ A/home/install/workspace/trunk/http/img/button_blue/query_over.pngDì F/home/install/workspace/trunk/http/img/button_silver_blue/line_off.pngHZ3£ R/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_up.gifJ)? ?/home/install/workspace/trunk/http/img/tree_blue/file_empty.gifD¥â E/home/install/workspace/trunk/http/img/button_blink_red/print_off.pngD>¡ E/home/install/workspace/trunk/http/img/button_blink_red/help_over.pngD>¡ 2/home/install/workspace/trunk/http/img/tree/1w.gifD>¯É 5/home/install/workspace/trunk/http/sld/img/script.pngH`f 1/home/install/workspace/trunk/http/img/resize.gifFú J/home/install/workspace/trunk/http/img/button_gray/change_password_off.gifD>¯g A/home/install/workspace/trunk/http/img/button_gray/zoomIn2_on.pngD>½È R/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_off.pngHZ3£ G/home/install/workspace/trunk/http/img/button_silver_blue/query_off.pngHZ3£ O/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_over.pngHb¸ 8/home/install/workspace/trunk/http/img/tree_new/menu.pngE´l J/home/install/workspace/trunk/http/img/button_gray/change_password_off.pngD>¯g 5/home/install/workspace/trunk/http/img/balloon_ur.pngHë« A/home/install/workspace/trunk/http/img/button_gray/repaint_on.gifD>¯g G/home/install/workspace/trunk/http/img/button_blue/select_point_off.pngDZ B/home/install/workspace/trunk/http/img/button_blue/forward_off.pngDì H/home/install/workspace/trunk/http/img/button_silver_blue/polygon_on.pngHZ3£ J/home/install/workspace/trunk/http/img/button_blink_red/preferences_on.pngD>¡ 3/home/install/workspace/trunk/http/img/digitize.pngInQc O/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_on.pngHZ3£ @/home/install/workspace/trunk/http/img/tree_orange/file_vert.gifD>°Ø 7/home/install/workspace/trunk/http/img/tree_gray/1w.gifD>°¤ G/home/install/workspace/trunk/http/img/button_silver_blue/shape_off.pngHZ3£ G/home/install/workspace/trunk/http/img/button_blue/select_extent_on.pngDø ^/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_arrows_updown.gifJ)? D/home/install/workspace/trunk/http/img/button_blink_red/help_off.pngD>¡ G/home/install/workspace/trunk/http/img/button_blue/wmc_save_off_old.pngDì Q/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_over.pngHZ3£ B/home/install/workspace/trunk/http/img/button_gray/wmc_load_on.pngD>¯g B/home/install/workspace/trunk/http/img/button_gray/selArea_off.pngD>¯g :/home/install/workspace/trunk/http/img/button_gray/del.pngD>½È G/home/install/workspace/trunk/http/img/button_gray/select_extent_on.pngD®s P/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_on.pngD>¡ B/home/install/workspace/trunk/http/img/button_digitize/del_off.pngE¬Ìú C/home/install/workspace/trunk/http/img/button_digitize/point_on.pngD@Ò K/home/install/workspace/trunk/http/img/button_blue/forward_off_disabled.pngDì G/home/install/workspace/trunk/http/img/button_gray/closePolygon_off.gifD>¯g D/home/install/workspace/trunk/http/img/button_gray/gazetteer_off.gifD>¯g B/home/install/workspace/trunk/http/img/button_gray/helpbook_on.pngD>¯g K/home/install/workspace/trunk/http/img/button_gray/overviewgermany_over.gifD>¯g :/home/install/workspace/trunk/http/img/tree/folder_off.gifD>¯É A/home/install/workspace/trunk/http/img/tree_orange/file_empty.gifD>°Ø 9/home/install/workspace/trunk/http/img/tree_new/error.pngE´l 7/home/install/workspace/trunk/http/img/sandclock_oo.gifD>±h G/home/install/workspace/trunk/http/img/button_silver_blue/line_over.pngHZ3£ E/home/install/workspace/trunk/http/img/button_digitize/polygon_on.pngD@Ò ?/home/install/workspace/trunk/http/img/button_digitize/line.pngHb¸ D/home/install/workspace/trunk/http/img/button_silver_blue/pan_on.pngHZ3£ G/home/install/workspace/trunk/http/img/button_blink_red/coords_over.pngD>¡ E/home/install/workspace/trunk/http/img/button_silver_blue/del_off.pngHZ3£ 6/home/install/workspace/trunk/http/img/exclamation.pngJ. K/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_over.pngHZ3£ U/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_right.gifJ)? H/home/install/workspace/trunk/http/img/button_silver_blue/measure_on.pngHZ3£ ;/home/install/workspace/trunk/http/img/button_gray/save.gifD>½È B/home/install/workspace/trunk/http/img/button_gray/repaint_off.pngD>¯g L/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_off.pngI¾Y P/home/install/workspace/trunk/http/img/button_silver_blue/back_over_disabled.pngHZ3£ >/home/install/workspace/trunk/http/img/tree_gray/file_vert.gifD>°¤ E/home/install/workspace/trunk/http/img/button_blink_red/exit_over.pngD>¡ 0/home/install/workspace/trunk/http/img/admin.pngInQc >/home/install/workspace/trunk/http/img/tree_blue/file_vert.gifD¥â </home/install/workspace/trunk/http/img/background_yellow.jpgDÀË, O/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_off.pngHZ3£ G/home/install/workspace/trunk/http/img/button_silver_blue/print_off.pngHZ3£ J/home/install/workspace/trunk/http/img/button_blue/change_password_off.pngDì Q/home/install/workspace/trunk/http/img/button_silver_blue/change_password_off.pngHZ3£ @/home/install/workspace/trunk/http/img/button_gray/coods_off.gifD>¯g >/home/install/workspace/trunk/http/img/button_gray/smaller.pngD>½È Q/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_over.pngD D/home/install/workspace/trunk/http/img/button_gray/wmc_load_over.pngD>¯g I/home/install/workspace/trunk/http/css/images/ui-icons_222222_256x240.pngJ)>© N/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_on.pngHZ3£ G/home/install/workspace/trunk/http/img/button_silver_blue/back_over.pngHZ3£ B/home/install/workspace/trunk/http/img/button_blink_red/add_on.pngD>¡ G/home/install/workspace/trunk/http/img/button_gray/select_choose_on.pngD J/home/install/workspace/trunk/http/img/button_gray/exportMapimage_over.pngHb¸ 9/home/install/workspace/trunk/http/img/tree_orange/1w.gifD>°Ø A/home/install/workspace/trunk/http/img/button_blue/zoomIn2_on.pngDì F/home/install/workspace/trunk/http/img/button_blink_red/measure_on.pngD>¡ L/home/install/workspace/trunk/http/img/button_silver_blue/move_node_over.pngHZ3£ H/home/install/workspace/trunk/http/img/button_gray/back_off_disabled.pngD>¯g C/home/install/workspace/trunk/http/img/button_blue/gazetteer_on.pngDì I/home/install/workspace/trunk/http/img/button_silver_blue/selArea_off.pngHZ3£ C/home/install/workspace/trunk/http/img/button_gray/measure_over.gifD>¯g C/home/install/workspace/trunk/http/img/button_gray/wmc_save_off.pngD>¯g 8/home/install/workspace/trunk/http/img/header_yellow.jpgD8B E/home/install/workspace/trunk/http/img/button_blink_red/back_over.pngD>¡ L/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_off.gifD>¯g C/home/install/workspace/trunk/http/img/button_blue/measure_over.pngDì I/home/install/workspace/trunk/http/img/button_silver_blue/reload_over.pngHZ3£ B/home/install/workspace/trunk/http/img/button_gray/repaint_off.gifD>¯g 2/home/install/workspace/trunk/http/img/eye_on_.gifD>±h H/home/install/workspace/trunk/http/img/button_blink_red/logout_over2.pngD>¡ 8/home/install/workspace/trunk/http/img/tree_new/zoom.pngE´l C/home/install/workspace/trunk/http/img/tree_new/expanded_folder.pngE´l V/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_minus.gifJ)? A/home/install/workspace/trunk/http/img/tree_new/last_expanded.pngE´l K/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_off.pngH¾
Å B/home/install/workspace/trunk/http/img/button_gray/zoomOut2_on.pngD>¯g I/home/install/workspace/trunk/http/img/button_blue/back_over_disabled.pngDì >/home/install/workspace/trunk/http/sld/img/script_code_red.pngH`f H/home/install/workspace/trunk/http/img/button_silver_blue/selArea_on.pngHZ3£ B/home/install/workspace/trunk/http/img/button_gray/measure_off.gifD>¯g G/home/install/workspace/trunk/http/img/button_blue/back_on_disabled.pngDì F/home/install/workspace/trunk/http/img/button_silver_blue/pan_over.pngHZ3£ 1/home/install/workspace/trunk/http/img/eye_on.gifD>±h H/home/install/workspace/trunk/http/img/button_blue/select_polygon_on.pngDZ R/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_up.gifJ)? ?/home/install/workspace/trunk/http/img/tree_gray/folder_off.gifD>°¤ I/home/install/workspace/trunk/http/img/button_gray/select_choose_over.pngD E/home/install/workspace/trunk/http/img/button_gray/gazetteer_over.pngD>¯g L/home/install/workspace/trunk/http/img/button_blink_red/select_extent_on.pngDÕ @/home/install/workspace/trunk/http/img/openlayers/north-mini.pngHw]Ã L/home/install/workspace/trunk/http/img/button_gray/forward_over_disabled.pngD>¯g 8/home/install/workspace/trunk/http/sld/img/lightning.pngH`f D/home/install/workspace/trunk/http/img/button_blue/wmc_load_over.pngDì F/home/install/workspace/trunk/http/img/button_blink_red/reload_off.pngHb¸ P/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_off.pngHZ3£ ?/home/install/workspace/trunk/http/img/button_gray/pan_over.gifD>¯g D/home/install/workspace/trunk/http/img/button_blue/wmc_save_over.pngDì F/home/install/workspace/trunk/http/img/button_silver_blue/geomInfo.pngHZ3£ 1/home/install/workspace/trunk/http/img/pencil.pngGJÌ F/home/install/workspace/trunk/http/img/button_blink_red/logout_off.pngD>¡ H/home/install/workspace/trunk/http/img/button_silver_blue/reload_off.pngHZ3£ -/home/install/workspace/trunk/http/img/bg.gifIû C/home/install/workspace/trunk/http/img/button_blink_red/pan_off.pngD>¡ F/home/install/workspace/trunk/http/img/button_gray/select_point_on.pngD 3/home/install/workspace/trunk/http/img/info_off.gifD>±h F/home/install/workspace/trunk/http/img/button_blink_red/center_off.pngD>¡ B/home/install/workspace/trunk/http/img/button_gray/forward_off.gifD>¯g M/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_on.pngD E/home/install/workspace/trunk/http/img/button_blink_red/coords_on.pngD>¡ 2/home/install/workspace/trunk/http/img/eye_off.gifD>±h @/home/install/workspace/trunk/http/img/button_blue/center_on.pngDì F/home/install/workspace/trunk/http/img/openlayers/panning-hand-off.pngHw]Ã a/home/install/workspace/trunk/http/extensions/theme/images/dadada_40x100_textures_02_glass_75.pngJ)? P/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_over.pngD>¡ ?/home/install/workspace/trunk/http/img/button_gray/help_off.pngD>¯g G/home/install/workspace/trunk/http/img/button_silver_blue/rubber_on.pngHZ3£ 5/home/install/workspace/trunk/http/img/balloon_lr.pngHë« C/home/install/workspace/trunk/http/img/button_blink_red/add_off.pngD>¡ M/home/install/workspace/trunk/http/css/images/ui-bg_glass_55_fbf9ee_1x400.pngJ)>© A/home/install/workspace/trunk/http/img/openlayers/marker-blue.pngHw]Ã B/home/install/workspace/trunk/http/img/button_gray/center_over.pngD>¯g N/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_off.pngD M/home/install/workspace/trunk/http/css/images/ui-bg_glass_95_fef1ec_1x400.pngJ)>© @/home/install/workspace/trunk/http/img/openlayers/south-mini.pngHw]Ã B/home/install/workspace/trunk/http/img/openlayers/marker-green.pngHw]Ã @/home/install/workspace/trunk/http/img/tree_orange/folder_on.gifD>°Ø L/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_over.pngH¾
Å F/home/install/workspace/trunk/http/img/button_silver_blue/del_over.pngHZ3£ @/home/install/workspace/trunk/http/img/button_gray/center_on.gifD>¯g \/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_folder_open.gifJ)? ^/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_arrows_updown.gifJ)? @/home/install/workspace/trunk/http/img/tree_new/error_folder.pngE´l I/home/install/workspace/trunk/http/img/button_silver_blue/repaint_off.pngHZ3£ A/home/install/workspace/trunk/http/img/button_blue/coords_off.pngDì I/home/install/workspace/trunk/http/img/button_blue/change_password_on.pngDì C/home/install/workspace/trunk/http/img/button_digitize/del_over.pngE¬Ìú I/home/install/workspace/trunk/http/img/button_gray/overviewgermany_on.pngD>¯g C/home/install/workspace/trunk/http/img/button_blue/zoomIn2_over.pngDì T/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_left.gifJ)? @/home/install/workspace/trunk/http/img/button_gray/center_on.pngD>¯g ?/home/install/workspace/trunk/http/img/button_blue/query_on.pngDì I/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_on.pngHZ3£ I/home/install/workspace/trunk/http/img/button_silver_blue/center_over.pngHZ3£ M/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_over.pngDì I/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_on.pngHZ3£ H/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_off.pngDÎ Z/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_resize_se.gifJ)? K/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_on.gifD>½È D/home/install/workspace/trunk/http/img/button_blue/zoomOut2_over.pngDì G/home/install/workspace/trunk/http/img/button_gray/select_point_off.pngD ;/home/install/workspace/trunk/http/img/openlayers/blank.gifHw]à I/home/install/workspace/trunk/http/img/button_silver_blue/addlist_off.pngHZ3£ ?/home/install/workspace/trunk/http/img/button_gray/coods_on.pngD>¯g T/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_left.gifJ)? B/home/install/workspace/trunk/http/img/button_gray/zoomFull_on.pngD>¯g D/home/install/workspace/trunk/http/img/button_blue/gazetteer_off.pngDì ?/home/install/workspace/trunk/http/img/button_blue/pan_over.pngHb¸ M/home/install/workspace/trunk/http/img/button_blink_red/back_off_disabled.pngD>¡ K/home/install/workspace/trunk/http/img/button_silver_blue/move_node_off.pngHZ3£ D/home/install/workspace/trunk/http/img/button_gray/wmc_save_over.pngD>¯g L/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_over.pngI¾p D/home/install/workspace/trunk/http/img/openlayers/zoom-plus-mini.pngHw]à J/home/install/workspace/trunk/http/img/button_blink_red/zoomfull2_over.pngD>¡ G/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_on.pngD>¡ G/home/install/workspace/trunk/http/img/button_gray/preferences_over.gifD>¯g D/home/install/workspace/trunk/http/img/button_digitize/line_over.pngDAo K/home/install/workspace/trunk/http/img/button_gray/change_password_over.gifD>¯g 0/home/install/workspace/trunk/http/img/layer.gifEìM A/home/install/workspace/trunk/http/img/button_gray/print_over.pngD>¯g G/home/install/workspace/trunk/http/img/button_blink_red/forward_off.pngD>¡ B/home/install/workspace/trunk/http/img/button_gray/logout_over.pngD>½È C/home/install/workspace/trunk/http/img/button_gray/metadata_off.gifD>¯g =/home/install/workspace/trunk/http/img/tree_new/move_upmy.pngE´l @/home/install/workspace/trunk/http/img/button_gray/home_over.pngD>¯g H/home/install/workspace/trunk/http/img/button_gray/back_off_disabled.gifD>¯g E/home/install/workspace/trunk/http/img/openlayers/zoom-minus-mini.pngHw]à M/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_on.pngHb¸ A/home/install/workspace/trunk/http/img/button_blue/measure_on.pngDì H/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_off.pngD>¡ D/home/install/workspace/trunk/http/img/button_blink_red/back_off.pngD>¡ N/home/install/workspace/trunk/http/img/button_blink_red/select_choose_over.pngD ;/home/install/workspace/trunk/http/img/button_gray/down.pngDÀ¼ C/home/install/workspace/trunk/http/img/button_blink_red/down_on.pngH_ÇM ?/home/install/workspace/trunk/http/img/openlayers/west-mini.pngHw]à 2/home/install/workspace/trunk/http/img/redball.gifD>±h H/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/rocks.pngD>¨´ J/home/install/workspace/trunk/http/img/button_silver_blue/getArea_over.pngHZ3£ J/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_over.pngHZ3£ F/home/install/workspace/trunk/http/img/button_blink_red/query_over.pngD>¡ H/home/install/workspace/trunk/http/img/button_blink_red/measure_over.pngD>¡ D/home/install/workspace/trunk/http/img/button_blue/zoomFull_over.pngDì D/home/install/workspace/trunk/http/img/button_gray/metadata_over.gifD>¯g B/home/install/workspace/trunk/http/img/button_blue/getArea_off.pngDì :/home/install/workspace/trunk/http/img/arrows/arrow_nw.gifD>¬¡ I/home/install/workspace/trunk/http/css/images/ui-icons_454545_256x240.pngJ)>© E/home/install/workspace/trunk/http/img/button_blink_red/addwms_on.pngD>¡ E/home/install/workspace/trunk/http/img/button_silver_blue/pan_off.pngHZ3£ </home/install/workspace/trunk/http/img/openlayers/slider.pngHw]à H/home/install/workspace/trunk/http/img/button_gray/select_extent_off.pngD 7/home/install/workspace/trunk/http/img/mapbender_oo.pngD?ä E/home/install/workspace/trunk/http/img/button_blue/preferences_on.pngDì K/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_on.pngDì A/home/install/workspace/trunk/http/img/button_blue/center_off.pngDì K/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_on.pngI¾Y F/home/install/workspace/trunk/http/img/button_silver_blue/back_off.pngHZ3£ A/home/install/workspace/trunk/http/img/button_gray/center_off.gifD>¯g H/home/install/workspace/trunk/http/img/button_blue/closePolygon_over.pngDì >/home/install/workspace/trunk/http/img/button_gray/logo_en.jpgD>½È @/home/install/workspace/trunk/http/img/button_gray/help_over.pngD>¯g H/home/install/workspace/trunk/http/img/button_blue/select_extent_off.pngDZ H/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_over.pngD>¡ J/home/install/workspace/trunk/http/img/button_silver_blue/getArea_off2.pngHZ3£ F/home/install/workspace/trunk/http/img/button_silver_blue/print_on.pngHZ3£ J/home/install/workspace/trunk/http/img/button_gray/select_rectangle_on.pngD ?/home/install/workspace/trunk/http/img/button_gray/home_off.pngD>¯g
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd
--- trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1 @@
Property changes on: trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd
+ text/html
Added: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1 @@
+( General Function Variable Class
Property changes on: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
+ text/html
Added: trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
--- trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,2 @@
+( Mapbender Mapbender 7/home/install/workspace/trunk/http/javascripts/core.php Event */home/install/workspace/trunk/lib/event.js Map 9/home/install/workspace/trunk/http/javascripts/map_obj.js modules Reload =/home/install/workspace/trunk/http/javascripts/mod_reload.php Sandclock @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php ZoomIn1 >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js Index
+Everything general Classes class Functions function Variables variable
Property changes on: trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
+ text/html
Added: trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
--- trunk/mapbender/documents/api_js/Data/PreviousSettings.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/PreviousSettings.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1 @@
+( /home/install/workspace/trunk 1 ./home/install/workspace/trunk/documents/api_js HTML
Property changes on: trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
+ text/html
Added: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
--- trunk/mapbender/documents/api_js/Data/SymbolTable.nd (rev 0)
+++ trunk/mapbender/documents/api_js/Data/SymbolTable.nd 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+( SearchPanel mode 5/home/install/workspace/trunk/docs/javascript/main.js variable this.mode \The mode the search is going to work in, such as "HTML" or "FramedHTML".
+SearchResults Toggle 5/home/install/workspace/trunk/docs/javascript/main.js function this.Toggle = function(id) 0Toggles the visibility of the passed element ID. SearchPanel deactivateTimeout 5/home/install/workspace/trunk/docs/javascript/main.js variable aThe timeout used between when a control is deactivated and when the entire panel is deactivated. Reload Functions =/home/install/workspace/trunk/http/javascripts/mod_reload.php group SearchPanel Action Functions 5/home/install/workspace/trunk/docs/javascript/main.js group SearchPanel lastResultsPage 5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastResultsPage The last results page. SearchPanel DOMSearchField 5/home/install/workspace/trunk/docs/javascript/main.js function this.DOMSearchField = function() SearchPanel
+keyTimeout 5/home/install/workspace/trunk/docs/javascript/main.js variable this.keyTimeout DThe timeout used between a keystroke and when a search is performed. Reload =/home/install/workspace/trunk/http/javascripts/mod_reload.php class 'A button that reloads the whole window. SearchPanel InactivateAfterTimeout 5/home/install/workspace/trunk/docs/javascript/main.js function (this.InactivateAfterTimeout = function() ÇCalled by <link target="inactivateTimeout" name="inactivateTimeout" original="<inactivateTimeout>">, which is set by <link target="Activate()" name="Activate()" original="<Activate()>">. SearchPanel OnSearchTypeChange 5/home/install/workspace/trunk/docs/javascript/main.js function $this.OnSearchTypeChange = function() 'Called when the search type is changed. SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js class =A class handling everything associated with the search panel. SearchPanel
+DOMSearchType 5/home/install/workspace/trunk/docs/javascript/main.js function this.DOMSearchType = function()
+SearchResults mode 5/home/install/workspace/trunk/docs/javascript/main.js variable this.mode \The mode the search is going to work in, such as "HTML" or "FramedHTML".
+SearchResults Variables 5/home/install/workspace/trunk/docs/javascript/main.js group Sandclock hide @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php function this.hide = function () Hides the sandclock Map Map 9/home/install/workspace/trunk/http/javascripts/map_obj.js function KMapbender.Map = function (frameName, elementName, width, height, wms_index) SearchPanel name 5/home/install/workspace/trunk/docs/javascript/main.js variable this.name PThe name of the global variable that will be storing this instance of the class.
+SearchResults Search 5/home/install/workspace/trunk/docs/javascript/main.js function this.Search = function(search) Searches for the passed string. Sandclock Functions @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php group SearchPanel Event Handlers 5/home/install/workspace/trunk/docs/javascript/main.js group Mapbender 7/home/install/workspace/trunk/http/javascripts/core.php class 4All Mapbender functionality is within this namespace SearchPanel lastSearchValue 5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastSearchValue <The last search string executed, or an empty string if none. Sandclock @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php class .Displays an arbitrary sandclock image on a map SearchPanel DOMPopupSearchResultsWindow 5/home/install/workspace/trunk/docs/javascript/main.js function -this.DOMPopupSearchResultsWindow = function()
+SearchResults lastMatchCount 5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastMatchCount pThe number of matches from the last run of <link target="Search()" name="Search()" original="<Search()>">. SearchPanel DOMSearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js function this.DOMSearchPanel = function() SearchPanel Activate 5/home/install/workspace/trunk/docs/javascript/main.js function 9this.Activate = function(isActive, ignoreDeactivateDelay) bActivates or deactivates the search panel, resetting things to their default values if necessary. Map 9/home/install/workspace/trunk/http/javascripts/map_obj.js class DThis is the central module for displaying the composite map overlay.
+SearchResults 5/home/install/workspace/trunk/docs/javascript/main.js class =The class that handles everything on the search results page. SearchPanel deactivateTimeoutLength 5/home/install/workspace/trunk/docs/javascript/main.js variable this.deactivateTimeoutLength The length of <link target="deactivateTimeout" name="deactivateTimeout" original="<deactivateTimeout>"> in thousandths of a second.
+SearchResults Functions 5/home/install/workspace/trunk/docs/javascript/main.js group SearchPanel DOM Elements 5/home/install/workspace/trunk/docs/javascript/main.js group SearchPanel Activation Functions 5/home/install/workspace/trunk/docs/javascript/main.js group @Functions that handle whether the entire panel is active or not. Event */home/install/workspace/trunk/lib/event.js class
+An event. SearchPanel keyTimeoutLength 5/home/install/workspace/trunk/docs/javascript/main.js variable this.keyTimeoutLength tThe length of <link target="keyTimeout" name="keyTimeout" original="<keyTimeout>"> in thousandths of a second. SearchPanel DOMPopupSearchResults 5/home/install/workspace/trunk/docs/javascript/main.js function 'this.DOMPopupSearchResults = function() SearchPanel Search 5/home/install/workspace/trunk/docs/javascript/main.js function this.Search = function() Performs a search. Reload reload =/home/install/workspace/trunk/http/javascripts/mod_reload.php function this.reload = function () Reloads the window. Map setExtent 9/home/install/workspace/trunk/http/javascripts/map_obj.js function 1this.setExtent = function(minx, miny, maxx, maxy) set the extent of the wms SearchPanel resultsPath 5/home/install/workspace/trunk/docs/javascript/main.js variable this.resultsPath KThe relative path from the current HTML page to the results page directory. SearchPanel OnSearchFieldFocus 5/home/install/workspace/trunk/docs/javascript/main.js function ,this.OnSearchFieldFocus = function(isActive) <Called when focus is added or removed from the search field. SearchPanel CloseResultsWindow 5/home/install/workspace/trunk/docs/javascript/main.js function $this.CloseResultsWindow = function() Closes the results window. ZoomIn1 >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php class Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Map Functions 9/home/install/workspace/trunk/http/javascripts/map_obj.js group SearchPanel Variables 5/home/install/workspace/trunk/docs/javascript/main.js group SearchPanel OnSearchTypeFocus 5/home/install/workspace/trunk/docs/javascript/main.js function +this.OnSearchTypeFocus = function(isActive) ;Called when focus is added or removed from the search type. SearchPanel OnSearchFieldChange 5/home/install/workspace/trunk/docs/javascript/main.js function %this.OnSearchFieldChange = function() 7Called when the content of the search field is changed. Sandclock show @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php function this.show = function (mapId) Displays the sandclock Search
+JavaScript
+SearchResults 5/home/install/workspace/trunk/docs/javascript/main.js inactivateTimeout
+JavaScript SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js lastSearchValue
+JavaScript SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js Activate
+JavaScript SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js NaturalDocs Builder Base CommandLineOption
+JavaScript SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js deactivateTimeout
+keyTimeout
Property changes on: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
+ text/html
Added: trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html
--- trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,106 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>SearchPanel</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="SearchPanel"></a>SearchPanel</h1><div class=CBody><p>A class handling everything associated with the search panel.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>name</td><td class=CDLDescription>The name of the global variable that will be storing this instance. Is needed to be able to set timeouts.</td></tr><tr><td class=CDLEntry>mode</td><td class=CDLDescription>The mode the search is going to work in. Pass <NaturalDocs::Builder::Base->CommandLineOption()>, so the value will be something like “HTML” or “FramedHTML”.</td></tr></table><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#SearchPanel" >SearchPanel</a></td><td class=SDescription>A class handling everything associated with the search panel.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">name</a></td><td class=SDescription>The name of the global variable that will be storing this instance of the class.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.mode" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.resultsPath" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">resultsPath</a></td><td class=SDescription>The relative path from the current HTML page to the results page directory.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.keyTimeout" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">keyTimeout</a></td><td class=SDescription>The timeout used between a keystroke and when a search is performed.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.keyTimeoutLength" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">keyTimeoutLength</a></td><td class=SDescription>The length of <a href="#SearchPanel.keyTimeout" class=LVariable id=link6 onMouseOver="ShowTip(event, 'tt4', 'link6')" onMouseOut="HideTip('tt4')">keyTimeout</a> in thousandths of a second.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.lastSearchValue" id=link7 onMouseOver="ShowTip(event, 'tt6', 'link7')" onMouseOut="HideTip('tt6')">lastSearchValue</a></td><td class=SDescription>The last search string executed, or an empty string if none.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.lastResultsPage" id=link8 onMouseOver="ShowTip(event, 'tt7', 'link8')" onMouseOut="HideTip('tt7')">lastResultsPage</a></td><td class=SDescription>The last results page. </td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.deactivateTimeout" >deactivateTimeout</a></td><td class=SDescription>The timeout used between when a control is deactivated and when the entire panel is deactivated. </td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.deactivateTimeoutLength" id=link9 onMouseOver="ShowTip(event, 'tt8', 'link9')" onMouseOut="HideTip('tt8')">deactivateTimeoutLength</a></td><td class=SDescription>The length of <a href="#SearchPanel.deactivateTimeout" class=LVariable id=link10 onMouseOver="ShowTip(event, 'tt9', 'link10')" onMouseOut="HideTip('tt9')">deactivateTimeout</a> in thousandths of a second.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.DOM_Elements" >DOM Elements</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMSearchField" id=link11 onMouseOver="ShowTip(event, 'tt10', 'link11')" onMouseOut="HideTip('tt10')">DOMSearchField</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.DOMSearchType" id=link12 onMouseOver="ShowTip(event, 'tt11', 'link12')" onMouseOut="HideTip('tt11')">DOMSearchType</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMPopupSearchResults" id=link13 onMouseOver="ShowTip(event, 'tt12', 'link13')" onMouseOut="HideTip('tt12')">DOMPopupSearchResults</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.DOMPopupSearchResultsWindow" id=link14 onMouseOver="ShowTip(event, 'tt13', 'link14')" onMouseOut="HideTip('tt13')">DOMPopupSearchResultsWindow</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMSearchPanel" id=link15 onMouseOver="ShowTip(event, 'tt14', 'link15')" onMouseOut="HideTip('tt14')">DOMSearchPanel</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Event_Handlers" >Event Handlers</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.OnSearchFieldFocus" id=link16 onMouseOver="ShowTip(event, 'tt15', 'link16')" onMouseOut="HideTip('tt15')">OnSearchFieldFocus</a></td><td class=SDescription>Called when focus is added or removed from the search field.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.OnSearchFieldChange" id=link17 onMouseOver="ShowTip(event, 'tt16', 'link17')" onMouseOut="HideTip('tt16')">OnSearchFieldChange</a></td><td class=SDescription>Called when the content of the search field is changed.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.OnSearchTypeFocus" id=link18 onMouseOver="ShowTip(event, 'tt17', 'link18')" onMouseOut="HideTip('tt17')">OnSearchTypeFocus</a></td><td class=SDescription>Called when focus is added or removed from the search type.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.OnSearchTypeChange" id=link19 onMouseOver="ShowTip(event, 'tt18', 'link19')" onMouseOut="HideTip('tt18')">OnSearchTypeChange</a></td><td class=SDescription>Called when the search type is changed.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Action_Functions" >Action Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.CloseResultsWindow" id=link20 onMouseOver="ShowTip(event, 'tt19', 'link20')" onMouseOut="HideTip('tt19')">CloseResultsWindow</a></td><td class=SDescription>Closes the results window.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.Search" id=link21 onMouseOver="ShowTip(event, 'tt20', 'link21')" onMouseOut="HideTip('tt20')">Search</a></td><td class=SDescription>Performs a search.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Activation_Functions" >Activation Functions</a></td><td class=SDescription>Functions that handle whether the entire panel is active or not.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.Activate" id=link22 onMouseOver="ShowTip(event, 'tt21', 'link22')" onMouseOut="HideTip('tt21')">Activate</a></td><td class=SDescription>Activates or deactivates the search panel, resetting things to their default values if necessary. </td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.InactivateAfterTimeout" id=link23 onMouseOver="ShowTip(event, 'tt22', 'link23')" onMouseOut="HideTip('tt22')">InactivateAfterTimeout</a></td><td class=SDescription>Called by <inactivateTimeout>, which is set by <a href="#SearchPanel.Activate" class=LFunction id=link24 onMouseOver="ShowTip(event, 'tt21', 'link24')" onMouseOut="HideTip('tt21')">Activate()</a>. </td></tr><tr class="SClass"><td class=SEntry><a href="#SearchResults" >SearchResults</a></td><td class=SDescription>The class that handles everything on the search results page.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchResults.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchResults.mode" id=link25 onMouseOver="ShowTip(event, 'tt23', 'link25')" onMouseOut="HideTip('tt23')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchResults.lastMatchCount" id=link26 onMouseOver="ShowTip(event, 'tt24', 'link26')" onMouseOut="HideTip('tt24')">lastMatchCount</a></td><td class=SDescription>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link27 onMouseOver="ShowTip(event, 'tt25', 'link27')" onMouseOut="HideTip('tt25')">Search()</a>.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchResults.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchResults.Toggle" id=link28 onMouseOver="ShowTip(event, 'tt26', 'link28')" onMouseOut="HideTip('tt26')">Toggle</a></td><td class=SDescription>Toggles the visibility of the passed element ID.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchResults.Search" id=link29 onMouseOver="ShowTip(event, 'tt25', 'link29')" onMouseOut="HideTip('tt25')">Search</a></td><td class=SDescription>Searches for the passed string. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Variables"></a>Variables</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.name"></a>name</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote><p>The name of the global variable that will be storing this instance of the class.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.mode"></a>mode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote><p>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.resultsPath"></a>resultsPath</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote><p>The relative path from the current HTML page to the results page directory.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.keyTimeout"></a>keyTimeout</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote><p>The timeout used between a keystroke and when a search is performed.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.keyTimeoutLength"></a>keyTimeoutLength</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote><p>The length of <a href="#SearchPanel.keyTimeout" class=LVariable id=link30 onMouseOver="ShowTip(event, 'tt4', 'link30')" onMouseOut="HideTip('tt4')">keyTimeout</a> in thousandths of a second.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.lastSearchValue"></a>lastSearchValue</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote><p>The last search string executed, or an empty string if none.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.lastResultsPage"></a>lastResultsPage</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote><p>The last results page. The value is only relevant if <a href="#SearchPanel.lastSearchValue" class=LVariable id=link31 onMouseOver="ShowTip(event, 'tt6', 'link31')" onMouseOut="HideTip('tt6')">lastSearchValue</a> is set.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.deactivateTimeout"></a>deactivateTimeout</h3><div class=CBody><p>The timeout used between when a control is deactivated and when the entire panel is deactivated. Is necessary because a control may be deactivated in favor of another control in the same panel, in which case it should stay active.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.deactivateTimeoutLength"></a>deactivateTimeoutLength</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote><p>The length of <a href="#SearchPanel.deactivateTimeout" class=LVariable id=link32 onMouseOver="ShowTip(event, 'tt9', 'link32')" onMouseOut="HideTip('tt9')">deactivateTimeout</a> in thousandths of a second.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOM_Elements"></a>DOM Elements</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchField"></a>DOMSearchField</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchType"></a>DOMSearchType</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMPopupSearchResults"></a>DOMPopupSearchResults</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMPopupSearchResultsWindow"></a>DOMPopupSearchResultsWindow</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchPanel"></a>DOMSearchPanel</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Event_Handlers"></a>Event Handlers</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchFieldFocus"></a>OnSearchFieldFocus</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Called when focus is added or removed from the search field.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchFieldChange"></a>OnSearchFieldChange</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote><p>Called when the content of the search field is changed.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchTypeFocus"></a>OnSearchTypeFocus</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Called when focus is added or removed from the search type.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchTypeChange"></a>OnSearchTypeChange</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote><p>Called when the search type is changed.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Action_Functions"></a>Action Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.CloseResultsWindow"></a>CloseResultsWindow</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote><p>Closes the results window.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Search"></a>Search</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote><p>Performs a search.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Activation_Functions"></a>Activation Functions</h3><div class=CBody><p>Functions that handle whether the entire panel is active or not.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Activate"></a>Activate</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Activates or deactivates the search panel, resetting things to their default values if necessary. You can call this on every control’s OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>isActive</td><td class=CDLDescription>Whether you’re activating or deactivating the panel.</td></tr><tr><td class=CDLEntry>ignoreDeactivateDelay</td><td class=CDLDescription>Set if you’re positive the action will deactivate the panel and thus want to skip the delay.</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.InactivateAfterTimeout"></a>InactivateAfterTimeout</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote><p>Called by <inactivateTimeout>, which is set by <a href="#SearchPanel.Activate" class=LFunction id=link33 onMouseOver="ShowTip(event, 'tt21', 'link33')" onMouseOut="HideTip('tt21')">Activate()</a>. Inactivation occurs on a timeout because a control may receive OnBlur() when focus is really transferring to another control in the search panel. In this case we don’t want to actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value. So by doing it on a timeout instead, there’s a short period where the second control’s OnFocus() can cancel the deactivation.</p></div></div></div>
+<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="SearchResults"></a>SearchResults</h2><div class=CBody><p>The class that handles everything on the search results page.</p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#SearchResults.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#SearchResults.mode" id=link34 onMouseOver="ShowTip(event, 'tt23', 'link34')" onMouseOut="HideTip('tt23')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</td></tr><tr class="SVariable SIndent1"><td class=SEntry><a href="#SearchResults.lastMatchCount" id=link35 onMouseOver="ShowTip(event, 'tt24', 'link35')" onMouseOut="HideTip('tt24')">lastMatchCount</a></td><td class=SDescription>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link36 onMouseOver="ShowTip(event, 'tt25', 'link36')" onMouseOut="HideTip('tt25')">Search()</a>.</td></tr><tr class="SGroup"><td class=SEntry><a href="#SearchResults.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#SearchResults.Toggle" id=link37 onMouseOver="ShowTip(event, 'tt26', 'link37')" onMouseOut="HideTip('tt26')">Toggle</a></td><td class=SDescription>Toggles the visibility of the passed element ID.</td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#SearchResults.Search" id=link38 onMouseOver="ShowTip(event, 'tt25', 'link38')" onMouseOut="HideTip('tt25')">Search</a></td><td class=SDescription>Searches for the passed string. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Variables"></a>Variables</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchResults.mode"></a>mode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote><p>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchResults.lastMatchCount"></a>lastMatchCount</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote><p>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link39 onMouseOver="ShowTip(event, 'tt25', 'link39')" onMouseOut="HideTip('tt25')">Search()</a>.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Toggle"></a>Toggle</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Toggles the visibility of the passed element ID.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Search"></a>Search</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Searches for the passed string. If there is no parameter, it takes it from the URL query.</p><p>Always returns true, since other documents may try to call it and that may or may not be possible.</p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile id=MSelected>SearchPanel</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><div class=CToolTip id="tt2"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</div></div><div class=CToolTip id="tt3"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><div class=CToolTip id="tt4"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt6"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><div class=CToolTip id="tt7"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt8"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt9"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><div class=CToolTip id="tt23"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</div></div><div class=CToolTip id="tt24"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Property changes on: trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,38 @@
+<html><head><title>Mapbender</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Mapbender"></a>Mapbender</h1><div class=CBody><p>All Mapbender functionality is within this namespace</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,44 @@
+<html><head><title>Map</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Map"></a>Map</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This is the central module for displaying the composite map overlay.</p><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Mapframe" class=LURL target=_top>http://www.mapbender.org/Mapframe</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Map" >Map</a></td><td class=SDescription>This is the central module for displaying the composite map overlay.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Map.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Map.Map" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Map</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Map.setExtent" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">setExtent</a></td><td class=SDescription>set the extent of the wms</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Map.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.Map"></a>Map</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>frameName</td><td class=CDLDescription><b>[deprecated]</b> the name of the iframe, for backwards compatibility only, use “” for maps in DIVs</td></tr><tr><td class=CDLEntry>elementName</td><td class=CDLDescription>the ID of the DOM node</td></tr><tr><td class=CDLEntry>width</td><td class=CDLDescription>width of the map in pixel</td></tr><tr><td class=CDLEntry>height</td><td class=CDLDescription>height of the map in pixel</td></tr><tr><td class=CDLEntry>wms_index</td><td class=CDLDescription>restrict the WMS in the map to the WMS with this ID (useful for overview maps)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.setExtent"></a>setExtent</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>set the extent of the wms</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>minx</td><td class=CDLDescription>x of south west</td></tr><tr><td class=CDLEntry>miny</td><td class=CDLDescription>y of south west</td></tr><tr><td class=CDLEntry>maxx</td><td class=CDLDescription>x of north east</td></tr><tr><td class=CDLEntry>maxy</td><td class=CDLDescription>y of north east</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,48 @@
+<html><head><title>Reload</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Reload"></a>Reload</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A button that reloads the whole window.</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>', 'reload',
+2,1,'reload','img','../img/button_blink_red/reload_off.png', '',335,
+60,24,24,1,'','','','mod_reload.php','','mapframe1','',
+'http://www.mapbender.org/index.php/Reload');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/index.php/Reload" class=LURL target=_top>http://www.mapbender.org/index.php/Reload</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Vera_Schulze" class=LURL target=_top>http://www.mapbender.org/User:Vera_Schulze</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Reload" >Reload</a></td><td class=SDescription>A button that reloads the whole window.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Reload.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Reload.reload" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">reload</a></td><td class=SDescription>Reloads the window.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Reload.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Reload.reload"></a>reload</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote><p>Reloads the window.</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,55 @@
+<html><head><title>Sandclock</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Sandclock"></a>Sandclock</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Displays an arbitrary sandclock image on a map</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+e_height, e_z_index, e_more_styles, e_content, e_closeTag, e_js_file,
+e_mb_mod, e_target, e_requires) VALUES ('<gui_id>', 'sandclock', '0002',
+'1', 'displays a sand clock while waiting for requests', 'div', '',
+'', '', '', '', '', '', '', '', 'div', 'mod_sandclock.php', '',
+'mapframe1', '');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('<gui_id>', 'sandclock',
+'mod_sandclock_image', '../img/sandclock.gif',
+'define a sandclock-image', 'var');</pre></blockquote><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>mod_sandclock_img</td><td class=CDLDescription><b>[optional]</b> the filename and path to the sandclock image</td></tr></table><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Sandclock" >Sandclock</a></td><td class=SDescription>Displays an arbitrary sandclock image on a map</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Sandclock.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Sandclock.show" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">show</a></td><td class=SDescription>Displays the sandclock</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Sandclock.hide" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">hide</a></td><td class=SDescription>Hides the sandclock</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Sandclock.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.show"></a>show</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Displays the sandclock</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.hide"></a>hide</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote><p>Hides the sandclock</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,45 @@
+<html><head><title>ZoomIn1</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ZoomIn1"></a>ZoomIn1</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Image size is not affected.</p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_title, e_element, e_src, e_attributes, e_left,
+e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
+'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+'','','','mod_zoomIn1.php','','mapframe1','',
+'http://www.mapbender.org/index.php/ZoomIn');</pre></blockquote><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_zoomIn1.php</li></ul></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/event-js.html
--- trunk/mapbender/documents/api_js/files/lib/event-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/event-js.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,47 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Event</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Event"></a>Event</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An event. What happens, when the event occurs, depends on which functions have been registered with the event.</p><h4 class=CHeading>usage</h4><blockquote><pre>// create a new Event
+var eventAfterMapRequest = new MapbenderEvent();
+// register a function with that event
+eventAfterMapRequest.register(function () {
+// trigger the event
+eventAfterMapRequest.trigger();</pre></blockquote></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>Event</div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../search");
Property changes on: trunk/mapbender/documents/api_js/files/lib/event-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/index/Classes.html
--- trunk/mapbender/documents/api_js/index/Classes.html (rev 0)
+++ trunk/mapbender/documents/api_js/index/Classes.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,49 @@
+<html><head><title>Class Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar>$#! · 0-9 · A · B · C · D · <a href="#E">E</a> · F · G · H · I · J · K · L · <a href="#M">M</a> · N · O · P · Q · <a href="#R">R</a> · <a href="#S">S</a> · T · U · V · W · X · Y · <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Event</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Map</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Mapbender</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Reload</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>SearchPanel</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>SearchResults</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>ZoomIn1</a></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CClass>An event. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt3"><div class=CClass>All Mapbender functionality is within this namespace</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CClass>A button that reloads the whole window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt6"><div class=CClass>A class handling everything associated with the search panel.</div></div><div class=CToolTip id="tt7"><div class=CClass>The class that handles everything on the search results page.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
Property changes on: trunk/mapbender/documents/api_js/index/Classes.html
+ text/html
Added: trunk/mapbender/documents/api_js/index/Files.html
--- trunk/mapbender/documents/api_js/index/Files.html (rev 0)
+++ trunk/mapbender/documents/api_js/index/Files.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,33 @@
+<html><head><title>File Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! · 0-9 · A · B · C · D · E · F · G · H · I · J · K · L · <a href="#M">M</a> · N · O · P · Q · R · S · T · U · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php" class=ISymbol>mod_addWMSfromfilteredList.php</a></td></tr></table>
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html">mod_addWMSfromfilteredList.php</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
Property changes on: trunk/mapbender/documents/api_js/index/Files.html
+ text/html
Added: trunk/mapbender/documents/api_js/index/Functions.html
--- trunk/mapbender/documents/api_js/index/Functions.html (rev 0)
+++ trunk/mapbender/documents/api_js/index/Functions.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,69 @@
+<html><head><title>Function Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · B · <a href="#C">C</a> · <a href="#D">D</a> · E · F · G · <a href="#H">H</a> · <a href="#I">I</a> · J · K · L · <a href="#M">M</a> · N · <a href="#O">O</a> · P · Q · <a href="#R">R</a> · <a href="#S">S</a> · <a href="#T">T</a> · U · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Search</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=IParent>SearchResults</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
Property changes on: trunk/mapbender/documents/api_js/index/Functions.html
+ text/html
Added: trunk/mapbender/documents/api_js/index/General.html
--- trunk/mapbender/documents/api_js/index/General.html (rev 0)
+++ trunk/mapbender/documents/api_js/index/General.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,97 @@
+<html><head><title>Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · B · <a href="#C">C</a> · <a href="#D">D</a> · <a href="#E">E</a> · <a href="#F">F</a> · G · <a href="#H">H</a> · <a href="#I">I</a> · J · <a href="#K">K</a> · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · <a href="#O">O</a> · P · Q · <a href="#R">R</a> · <a href="#S">S</a> · <a href="#T">T</a> · U · <a href="#V">V</a> · W · X · Y · <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Action_Functions" class=ISymbol>Action Functions</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activation_Functions" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Activation Functions</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOM_Elements" class=ISymbol>DOM Elements</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Event_Handlers" class=ISymbol>Event Handlers</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" class=IParent>Map</a><a href="../files/http/javascripts/mod_reload-php.html#Reload.Functions" class=IParent>Reload</a><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.Functions" class=IParent>Sandclock</a><a href="../files/docs/javascript/main-js.html#SearchResults.Functions" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="K"></a>K</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><span class=ISymbol>mode</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Search</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>SearchResults</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>SearchPanel</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>SearchResults</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=IHeading><a name="V"></a>V</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><span class=ISymbol>Variables</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Variables" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Variables" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>ZoomIn1</a></td></tr></table>
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><div class=CToolTip id="tt2"><div class=CGroup>Functions that handle whether the entire panel is active or not.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CClass>An event. </div></div><!--END_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt15"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt17"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt18"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt19"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt21"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt22"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</div></div><div class=CToolTip id="tt23"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt24"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt30"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt31"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt32"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt35"><div class=CClass>A class handling everything associated with the search panel.</div></div><div class=CToolTip id="tt36"><div class=CClass>The class that handles everything on the search results page.</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt40"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/index/General.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/index/Variables.html
--- trunk/mapbender/documents/api_js/index/Variables.html (rev 0)
+++ trunk/mapbender/documents/api_js/index/Variables.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,53 @@
+<html><head><title>Variable Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>Variable Index</div><div class=INavigationBar>$#! · 0-9 · A · B · C · <a href="#D">D</a> · E · F · G · H · I · J · <a href="#K">K</a> · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · O · P · Q · <a href="#R">R</a> · S · T · U · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="K"></a>K</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><span class=ISymbol>mode</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt2"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt4"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt6"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt7"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</div></div><div class=CToolTip id="tt9"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as “HTML” or “FramedHTML”.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Variables</div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/index/Variables.html
+ text/html
Added: trunk/mapbender/documents/api_js/javascript/main.js
--- trunk/mapbender/documents/api_js/javascript/main.js (rev 0)
+++ trunk/mapbender/documents/api_js/javascript/main.js 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,836 @@
+// This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
+// Natural Docs is licensed under the GPL
+// Browser Styles
+// ____________________________________________________________________________
+var agt=navigator.userAgent.toLowerCase();
+var browserType;
+var browserVer;
+if (agt.indexOf("opera") != -1)
+ browserType = "Opera";
+ if (agt.indexOf("opera 7") != -1 || agt.indexOf("opera/7") != -1)
+ { browserVer = "Opera7"; }
+ else if (agt.indexOf("opera 8") != -1 || agt.indexOf("opera/8") != -1)
+ { browserVer = "Opera8"; }
+ else if (agt.indexOf("opera 9") != -1 || agt.indexOf("opera/9") != -1)
+ { browserVer = "Opera9"; }
+else if (agt.indexOf("applewebkit") != -1)
+ browserType = "Safari";
+ if (agt.indexOf("version/3") != -1)
+ { browserVer = "Safari3"; }
+ else if (agt.indexOf("safari/4") != -1)
+ { browserVer = "Safari2"; }
+else if (agt.indexOf("khtml") != -1)
+ browserType = "Konqueror";
+else if (agt.indexOf("msie") != -1)
+ browserType = "IE";
+ if (agt.indexOf("msie 6") != -1)
+ { browserVer = "IE6"; }
+ else if (agt.indexOf("msie 7") != -1)
+ { browserVer = "IE7"; }
+else if (agt.indexOf("gecko") != -1)
+ browserType = "Firefox";
+ if (agt.indexOf("rv:1.7") != -1)
+ { browserVer = "Firefox1"; }
+ else if (agt.indexOf("rv:1.8)") != -1 || agt.indexOf("rv:1.8.0") != -1)
+ { browserVer = "Firefox15"; }
+ else if (agt.indexOf("rv:1.8.1") != -1)
+ { browserVer = "Firefox2"; }
+// Support Functions
+function GetXPosition(item)
+ var position = 0;
+ if (item.offsetWidth != null)
+ while (item != document.body && item != null)
+ position += item.offsetLeft;
+ item = item.offsetParent;
+ return position;
+function GetYPosition(item)
+ var position = 0;
+ position += item.offsetTop;
+ return position;
+function MoveToPosition(item, x, y)
+ // Opera 5 chokes on the px extension, so it can use the Microsoft one instead.
+ if (item.style.left != null)
+ item.style.left = x + "px";
+ item.style.top = y + "px";
+ else if (item.style.pixelLeft != null)
+ item.style.pixelLeft = x;
+ item.style.pixelTop = y;
+// Menu
+function ToggleMenu(id)
+ if (!window.document.getElementById)
+ { return; };
+ var display = window.document.getElementById(id).style.display;
+ if (display == "none")
+ { display = "block"; }
+ else
+ { display = "none"; }
+ window.document.getElementById(id).style.display = display;
+function HideAllBut(ids, max)
+ if (document.getElementById)
+ ids.sort( function(a,b) { return a - b; } );
+ var number = 1;
+ while (number < max)
+ if (ids.length > 0 && number == ids[0])
+ { ids.shift(); }
+ else
+ document.getElementById("MGroupContent" + number).style.display = "none";
+ number++;
+// Tooltips
+var tooltipTimer = 0;
+function ShowTip(event, tooltipID, linkID)
+ if (tooltipTimer)
+ { clearTimeout(tooltipTimer); };
+ var docX = event.clientX + window.pageXOffset;
+ var docY = event.clientY + window.pageYOffset;
+ var showCommand = "ReallyShowTip('" + tooltipID + "', '" + linkID + "', " + docX + ", " + docY + ")";
+ tooltipTimer = setTimeout(showCommand, 1000);
+function ReallyShowTip(tooltipID, linkID, docX, docY)
+ tooltipTimer = 0;
+ var tooltip;
+ var link;
+ tooltip = document.getElementById(tooltipID);
+ link = document.getElementById(linkID);
+/* else if (document.all)
+ tooltip = eval("document.all['" + tooltipID + "']");
+ link = eval("document.all['" + linkID + "']");
+ if (tooltip)
+ var left = GetXPosition(link);
+ var top = GetYPosition(link);
+ top += link.offsetHeight;
+ // The fallback method is to use the mouse X and Y relative to the document. We use a separate if and test if its a number
+ // in case some browser snuck through the above if statement but didn't support everything.
+ if (!isFinite(top) || top == 0)
+ left = docX;
+ top = docY;
+ // Some spacing to get it out from under the cursor.
+ top += 10;
+ // Make sure the tooltip doesnt get smushed by being too close to the edge, or in some browsers, go off the edge of the
+ // page. We do it here because Konqueror does get offsetWidth right even if it doesnt get the positioning right.
+ if (tooltip.offsetWidth != null)
+ var width = tooltip.offsetWidth;
+ var docWidth = document.body.clientWidth;
+ if (left + width > docWidth)
+ { left = docWidth - width - 1; }
+ // If there's a horizontal scroll bar we could go past zero because it's using the page width, not the window width.
+ if (left < 0)
+ { left = 0; };
+ MoveToPosition(tooltip, left, top);
+ tooltip.style.visibility = "visible";
+function HideTip(tooltipID)
+ if (tooltipTimer)
+ clearTimeout(tooltipTimer);
+ tooltipTimer = 0;
+ var tooltip;
+ { tooltip = document.getElementById(tooltipID); }
+ else if (document.all)
+ { tooltip = eval("document.all['" + tooltipID + "']"); }
+ if (tooltip)
+ { tooltip.style.visibility = "hidden"; }
+// Blockquote fix for IE
+function NDOnLoad()
+ if (browserVer == "IE6")
+ var scrollboxes = document.getElementsByTagName('blockquote');
+ if (scrollboxes.item(0))
+ NDDoResize();
+ window.onresize=NDOnResize;
+var resizeTimer = 0;
+function NDOnResize()
+ if (resizeTimer != 0)
+ { clearTimeout(resizeTimer); };
+ resizeTimer = setTimeout(NDDoResize, 250);
+function NDDoResize()
+ var i;
+ var item;
+ i = 0;
+ while (item = scrollboxes.item(i))
+ item.style.width = 100;
+ i++;
+ i = 0;
+ item.style.width = item.parentNode.offsetWidth;
+ i++;
+ clearTimeout(resizeTimer);
+ resizeTimer = 0;
+/* ________________________________________________________________________________________________________
+ Class: SearchPanel
+ ________________________________________________________________________________________________________
+ A class handling everything associated with the search panel.
+ Parameters:
+ name - The name of the global variable that will be storing this instance. Is needed to be able to set timeouts.
+ mode - The mode the search is going to work in. Pass <NaturalDocs::Builder::Base->CommandLineOption()>, so the
+ value will be something like "HTML" or "FramedHTML".
+function SearchPanel(name, mode, resultsPath)
+ if (!name || !mode || !resultsPath)
+ { alert("Incorrect parameters to SearchPanel."); };
+ // Group: Variables
+ // ________________________________________________________________________
+ var: name
+ The name of the global variable that will be storing this instance of the class.
+ this.name = name;
+ var: mode
+ The mode the search is going to work in, such as "HTML" or "FramedHTML".
+ this.mode = mode;
+ var: resultsPath
+ The relative path from the current HTML page to the results page directory.
+ this.resultsPath = resultsPath;
+ var: keyTimeout
+ The timeout used between a keystroke and when a search is performed.
+ this.keyTimeout = 0;
+ var: keyTimeoutLength
+ The length of <keyTimeout> in thousandths of a second.
+ this.keyTimeoutLength = 500;
+ var: lastSearchValue
+ The last search string executed, or an empty string if none.
+ this.lastSearchValue = "";
+ var: lastResultsPage
+ The last results page. The value is only relevant if <lastSearchValue> is set.
+ this.lastResultsPage = "";
+ var: deactivateTimeout
+ The timeout used between when a control is deactivated and when the entire panel is deactivated. Is necessary
+ because a control may be deactivated in favor of another control in the same panel, in which case it should stay
+ active.
+ this.deactivateTimout = 0;
+ var: deactivateTimeoutLength
+ The length of <deactivateTimeout> in thousandths of a second.
+ this.deactivateTimeoutLength = 200;
+ // Group: DOM Elements
+ // Function: DOMSearchField
+ this.DOMSearchField = function()
+ { return document.getElementById("MSearchField"); };
+ // Function: DOMSearchType
+ this.DOMSearchType = function()
+ { return document.getElementById("MSearchType"); };
+ // Function: DOMPopupSearchResults
+ this.DOMPopupSearchResults = function()
+ { return document.getElementById("MSearchResults"); };
+ // Function: DOMPopupSearchResultsWindow
+ this.DOMPopupSearchResultsWindow = function()
+ { return document.getElementById("MSearchResultsWindow"); };
+ // Function: DOMSearchPanel
+ this.DOMSearchPanel = function()
+ { return document.getElementById("MSearchPanel"); };
+ // Group: Event Handlers
+ Function: OnSearchFieldFocus
+ Called when focus is added or removed from the search field.
+ this.OnSearchFieldFocus = function(isActive)
+ this.Activate(isActive);
+ Function: OnSearchFieldChange
+ Called when the content of the search field is changed.
+ this.OnSearchFieldChange = function()
+ if (this.keyTimeout)
+ clearTimeout(this.keyTimeout);
+ var searchValue = this.DOMSearchField().value.replace(/ +/g, "");
+ if (searchValue != this.lastSearchValue)
+ if (searchValue != "")
+ this.keyTimeout = setTimeout(this.name + ".Search()", this.keyTimeoutLength);
+ else
+ if (this.mode == "HTML")
+ { this.DOMPopupSearchResultsWindow().style.display = "none"; };
+ Function: OnSearchTypeFocus
+ Called when focus is added or removed from the search type.
+ this.OnSearchTypeFocus = function(isActive)
+ Function: OnSearchTypeChange
+ Called when the search type is changed.
+ this.OnSearchTypeChange = function()
+ this.Search();
+ // Group: Action Functions
+ Function: CloseResultsWindow
+ Closes the results window.
+ this.CloseResultsWindow = function()
+ this.DOMPopupSearchResultsWindow().style.display = "none";
+ this.Activate(false, true);
+ Function: Search
+ Performs a search.
+ this.Search = function()
+ var searchValue = this.DOMSearchField().value.replace(/^ +/, "");
+ var searchTopic = this.DOMSearchType().value;
+ var pageExtension = searchValue.substr(0,1);
+ if (pageExtension.match(/^[a-z]/i))
+ { pageExtension = pageExtension.toUpperCase(); }
+ else if (pageExtension.match(/^[0-9]/))
+ { pageExtension = 'Numbers'; }
+ else
+ { pageExtension = "Symbols"; };
+ var resultsPage;
+ var resultsPageWithSearch;
+ var hasResultsPage;
+ // indexSectionsWithContent is defined in searchdata.js
+ if (indexSectionsWithContent[searchTopic][pageExtension] == true)
+ resultsPage = this.resultsPath + '/' + searchTopic + pageExtension + '.html';
+ resultsPageWithSearch = resultsPage+'?'+escape(searchValue);
+ hasResultsPage = true;
+ else
+ resultsPage = this.resultsPath + '/NoResults.html';
+ resultsPageWithSearch = resultsPage;
+ hasResultsPage = false;
+ var resultsFrame;
+ { resultsFrame = window.frames.MSearchResults; }
+ else if (this.mode == "FramedHTML")
+ { resultsFrame = window.top.frames['Content']; };
+ if (resultsPage != this.lastResultsPage ||
+ // Bug in IE. If everything becomes hidden in a run, none of them will be able to be reshown in the next for some
+ // reason. It counts the right number of results, and you can even read the display as "block" after setting it, but it
+ // just doesn't work in IE 6 or IE 7. So if we're on the right page but the previous search had no results, reload the
+ // page anyway to get around the bug.
+ (browserType == "IE" && hasResultsPage &&
+ (!resultsFrame.searchResults || resultsFrame.searchResults.lastMatchCount == 0)) )
+ resultsFrame.location.href = resultsPageWithSearch;
+ // So if the results page is right and there's no IE bug, reperform the search on the existing page. We have to check if there
+ // are results because NoResults.html doesn't have any JavaScript, and it would be useless to do anything on that page even
+ // if it did.
+ else if (hasResultsPage)
+ // We need to check if this exists in case the frame is present but didn't finish loading.
+ if (resultsFrame.searchResults)
+ { resultsFrame.searchResults.Search(searchValue); }
+ // Otherwise just reload instead of waiting.
+ else
+ { resultsFrame.location.href = resultsPageWithSearch; };
+ var domPopupSearchResultsWindow = this.DOMPopupSearchResultsWindow();
+ if (this.mode == "HTML" && domPopupSearchResultsWindow.style.display != "block")
+ var domSearchType = this.DOMSearchType();
+ var left = GetXPosition(domSearchType);
+ var top = GetYPosition(domSearchType) + domSearchType.offsetHeight;
+ MoveToPosition(domPopupSearchResultsWindow, left, top);
+ domPopupSearchResultsWindow.style.display = 'block';
+ this.lastSearchValue = searchValue;
+ this.lastResultsPage = resultsPage;
+ // Group: Activation Functions
+ // Functions that handle whether the entire panel is active or not.
+ Function: Activate
+ Activates or deactivates the search panel, resetting things to their default values if necessary. You can call this on every
+ control's OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.
+ Parameters:
+ isActive - Whether you're activating or deactivating the panel.
+ ignoreDeactivateDelay - Set if you're positive the action will deactivate the panel and thus want to skip the delay.
+ this.Activate = function(isActive, ignoreDeactivateDelay)
+ // We want to ignore isActive being false while the results window is open.
+ if (isActive || (this.mode == "HTML" && this.DOMPopupSearchResultsWindow().style.display == "block"))
+ if (this.inactivateTimeout)
+ clearTimeout(this.inactivateTimeout);
+ this.inactivateTimeout = 0;
+ this.DOMSearchPanel().className = 'MSearchPanelActive';
+ var searchField = this.DOMSearchField();
+ if (searchField.value == 'Search')
+ { searchField.value = ""; }
+ else if (!ignoreDeactivateDelay)
+ this.inactivateTimeout = setTimeout(this.name + ".InactivateAfterTimeout()", this.inactivateTimeoutLength);
+ else
+ this.InactivateAfterTimeout();
+ Function: InactivateAfterTimeout
+ Called by <inactivateTimeout>, which is set by <Activate()>. Inactivation occurs on a timeout because a control may
+ receive OnBlur() when focus is really transferring to another control in the search panel. In this case we don't want to
+ actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value.
+ So by doing it on a timeout instead, there's a short period where the second control's OnFocus() can cancel the deactivation.
+ this.InactivateAfterTimeout = function()
+ this.DOMSearchPanel().className = 'MSearchPanelInactive';
+ this.DOMSearchField().value = "Search";
+ Class: SearchResults
+ _________________________________________________________________________________________________________
+ The class that handles everything on the search results page.
+function SearchResults(name, mode)
+ var: mode
+ this.mode = mode;
+ var: lastMatchCount
+ The number of matches from the last run of <Search()>.
+ this.lastMatchCount = 0;
+ Function: Toggle
+ Toggles the visibility of the passed element ID.
+ this.Toggle = function(id)
+ if (this.mode == "FramedHTML")
+ { return; };
+ var parentElement = document.getElementById(id);
+ var element = parentElement.firstChild;
+ while (element && element != parentElement)
+ if (element.nodeName == 'DIV' && element.className == 'ISubIndex')
+ if (element.style.display == 'block')
+ { element.style.display = "none"; }
+ else
+ { element.style.display = 'block'; }
+ if (element.nodeName == 'DIV' && element.hasChildNodes())
+ { element = element.firstChild; }
+ else if (element.nextSibling)
+ { element = element.nextSibling; }
+ else
+ do
+ element = element.parentNode;
+ while (element && element != parentElement && !element.nextSibling);
+ if (element && element != parentElement)
+ { element = element.nextSibling; };
+ Function: Search
+ Searches for the passed string. If there is no parameter, it takes it from the URL query.
+ Always returns true, since other documents may try to call it and that may or may not be possible.
+ this.Search = function(search)
+ if (!search)
+ search = window.location.search;
+ search = search.substring(1); // Remove the leading ?
+ search = unescape(search);
+ search = search.replace(/^ +/, "");
+ search = search.replace(/ +$/, "");
+ search = search.toLowerCase();
+ if (search.match(/[^a-z0-9]/)) // Just a little speedup so it doesn't have to go through the below unnecessarily.
+ search = search.replace(/\_/g, "_und");
+ search = search.replace(/\ +/gi, "_spc");
+ search = search.replace(/\~/g, "_til");
+ search = search.replace(/\!/g, "_exc");
+ search = search.replace(/\@/g, "_att");
+ search = search.replace(/\#/g, "_num");
+ search = search.replace(/\$/g, "_dol");
+ search = search.replace(/\%/g, "_pct");
+ search = search.replace(/\^/g, "_car");
+ search = search.replace(/\&/g, "_amp");
+ search = search.replace(/\*/g, "_ast");
+ search = search.replace(/\(/g, "_lpa");
+ search = search.replace(/\)/g, "_rpa");
+ search = search.replace(/\-/g, "_min");
+ search = search.replace(/\+/g, "_plu");
+ search = search.replace(/\=/g, "_equ");
+ search = search.replace(/\{/g, "_lbc");
+ search = search.replace(/\}/g, "_rbc");
+ search = search.replace(/\[/g, "_lbk");
+ search = search.replace(/\]/g, "_rbk");
+ search = search.replace(/\:/g, "_col");
+ search = search.replace(/\;/g, "_sco");
+ search = search.replace(/\"/g, "_quo");
+ search = search.replace(/\'/g, "_apo");
+ search = search.replace(/\</g, "_lan");
+ search = search.replace(/\>/g, "_ran");
+ search = search.replace(/\,/g, "_com");
+ search = search.replace(/\./g, "_per");
+ search = search.replace(/\?/g, "_que");
+ search = search.replace(/\//g, "_sla");
+ search = search.replace(/[^a-z0-9\_]i/gi, "_zzz");
+ var resultRows = document.getElementsByTagName("div");
+ var matches = 0;
+ var i = 0;
+ while (i < resultRows.length)
+ var row = resultRows.item(i);
+ if (row.className == "SRResult")
+ var rowMatchName = row.id.toLowerCase();
+ rowMatchName = rowMatchName.replace(/^sr\d*_/, '');
+ if (search.length <= rowMatchName.length && rowMatchName.substr(0, search.length) == search)
+ row.style.display = "block";
+ matches++;
+ else
+ { row.style.display = "none"; };
+ i++;
+ document.getElementById("Searching").style.display="none";
+ if (matches == 0)
+ { document.getElementById("NoMatches").style.display="block"; }
+ else
+ { document.getElementById("NoMatches").style.display="none"; }
+ this.lastMatchCount = matches;
+ return true;
Property changes on: trunk/mapbender/documents/api_js/javascript/main.js
+ text/html
Added: trunk/mapbender/documents/api_js/javascript/searchdata.js
--- trunk/mapbender/documents/api_js/javascript/searchdata.js (rev 0)
+++ trunk/mapbender/documents/api_js/javascript/searchdata.js 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,122 @@
+var indexSectionsWithContent = {
+ "General": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": true,
+ "B": false,
+ "C": true,
+ "D": true,
+ "E": true,
+ "F": true,
+ "G": false,
+ "H": true,
+ "I": true,
+ "J": false,
+ "K": true,
+ "L": true,
+ "M": true,
+ "N": true,
+ "O": true,
+ "P": false,
+ "Q": false,
+ "R": true,
+ "S": true,
+ "T": true,
+ "U": false,
+ "V": true,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": true
+ "Variables": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": false,
+ "B": false,
+ "C": false,
+ "D": true,
+ "E": false,
+ "F": false,
+ "G": false,
+ "H": false,
+ "I": false,
+ "J": false,
+ "K": true,
+ "L": true,
+ "M": true,
+ "N": true,
+ "O": false,
+ "P": false,
+ "Q": false,
+ "R": true,
+ "S": false,
+ "T": false,
+ "U": false,
+ "V": false,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": false
+ "Functions": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": true,
+ "B": false,
+ "C": true,
+ "D": true,
+ "E": false,
+ "F": false,
+ "G": false,
+ "H": true,
+ "I": true,
+ "J": false,
+ "K": false,
+ "L": false,
+ "M": true,
+ "N": false,
+ "O": true,
+ "P": false,
+ "Q": false,
+ "R": true,
+ "S": true,
+ "T": true,
+ "U": false,
+ "V": false,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": false
+ "Classes": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": false,
+ "B": false,
+ "C": false,
+ "D": false,
+ "E": true,
+ "F": false,
+ "G": false,
+ "H": false,
+ "I": false,
+ "J": false,
+ "K": false,
+ "L": false,
+ "M": true,
+ "N": false,
+ "O": false,
+ "P": false,
+ "Q": false,
+ "R": true,
+ "S": true,
+ "T": false,
+ "U": false,
+ "V": false,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": true
Property changes on: trunk/mapbender/documents/api_js/javascript/searchdata.js
+ text/html
Added: trunk/mapbender/documents/api_js/search/ClassesE.html
--- trunk/mapbender/documents/api_js/search/ClassesE.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/ClassesE.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+document.getElementById("Loading").style.display="none";
+document.getElementById("NoMatches").style.display="none";
+var searchResults = new SearchResults("searchResults", "HTML");
+searchResults.Search();
+--></script></div><script language=JavaScript><!--
Property changes on: trunk/mapbender/documents/api_js/search/ClassesE.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/ClassesM.html
--- trunk/mapbender/documents/api_js/search/ClassesM.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/ClassesM.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=ISymbol>Map</a></div></div><div class=SRResult id=SR_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/ClassesM.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/ClassesR.html
--- trunk/mapbender/documents/api_js/search/ClassesR.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/ClassesR.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" target=_parent class=ISymbol>Reload</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/ClassesR.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/ClassesS.html
--- trunk/mapbender/documents/api_js/search/ClassesS.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/ClassesS.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_SearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" target=_parent class=ISymbol>SearchPanel</a></div></div><div class=SRResult id=SR_SearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" target=_parent class=ISymbol>SearchResults</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/ClassesS.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/ClassesZ.html
--- trunk/mapbender/documents/api_js/search/ClassesZ.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/ClassesZ.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_ZoomIn1><div class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" target=_parent class=ISymbol>ZoomIn1</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/ClassesZ.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FilesM.html
--- trunk/mapbender/documents/api_js/search/FilesM.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FilesM.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mod_undaddWMSfromfilteredList_perphp><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php" target=_parent class=ISymbol>mod_addWMSfromfilteredList.php</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FilesM.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsA.html
--- trunk/mapbender/documents/api_js/search/FunctionsA.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsA.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Activate><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" target=_parent class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsA.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsC.html
--- trunk/mapbender/documents/api_js/search/FunctionsC.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsC.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_CloseResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" target=_parent class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsC.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsD.html
--- trunk/mapbender/documents/api_js/search/FunctionsD.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsD.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_DOMPopupSearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" target=_parent class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" target=_parent class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchField><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" target=_parent class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" target=_parent class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchType><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" target=_parent class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsD.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsH.html
--- trunk/mapbender/documents/api_js/search/FunctionsH.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsH.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_hide><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" target=_parent class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsH.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsI.html
--- trunk/mapbender/documents/api_js/search/FunctionsI.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsI.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_InactivateAfterTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" target=_parent class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsI.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsM.html
--- trunk/mapbender/documents/api_js/search/FunctionsM.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsM.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=ISymbol>Map</a>, <span class=IParent>Map</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsM.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsO.html
--- trunk/mapbender/documents/api_js/search/FunctionsO.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsO.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_OnSearchFieldChange><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" target=_parent class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchFieldFocus><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" target=_parent class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchTypeChange><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" target=_parent class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchTypeFocus><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" target=_parent class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsO.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsR.html
--- trunk/mapbender/documents/api_js/search/FunctionsR.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsR.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsR.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsS.html
--- trunk/mapbender/documents/api_js/search/FunctionsS.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsS.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Search><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Search')" class=ISymbol>Search</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" target=_parent class=IParent>SearchResults</a></div></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsS.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/FunctionsT.html
--- trunk/mapbender/documents/api_js/search/FunctionsT.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsT.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Toggle><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" target=_parent class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsT.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralA.html
--- trunk/mapbender/documents/api_js/search/GeneralA.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralA.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Action_spcFunctions><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Action_Functions" target=_parent class=ISymbol>Action Functions</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_Activate><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" target=_parent class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_Activation_spcFunctions><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activation_Functions" target=_parent class=ISymbol>Activation Functions</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralA.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralC.html
--- trunk/mapbender/documents/api_js/search/GeneralC.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralC.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/GeneralC.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralD.html
--- trunk/mapbender/documents/api_js/search/GeneralD.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralD.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deactivateTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" target=_parent class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_deactivateTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" target=_parent class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOM_spcElements><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOM_Elements" target=_parent class=ISymbol>DOM Elements</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" target=_parent class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" target=_parent class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchField><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" target=_parent class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" target=_parent class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchType><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" target=_parent class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralD.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralE.html
--- trunk/mapbender/documents/api_js/search/GeneralE.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralE.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Event_spcHandlers><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Event_Handlers" target=_parent class=ISymbol>Event Handlers</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralE.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralF.html
--- trunk/mapbender/documents/api_js/search/GeneralF.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralF.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/http/javascripts/mod_reload-php.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/docs/javascript/main-js.html#SearchResults.Functions" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralF.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralH.html
--- trunk/mapbender/documents/api_js/search/GeneralH.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralH.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/GeneralH.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralI.html
--- trunk/mapbender/documents/api_js/search/GeneralI.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralI.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/GeneralI.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralK.html
--- trunk/mapbender/documents/api_js/search/GeneralK.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralK.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_keyTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" target=_parent class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_keyTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" target=_parent class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralK.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralL.html
--- trunk/mapbender/documents/api_js/search/GeneralL.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralL.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_lastMatchCount><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" target=_parent class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></div></div><div class=SRResult id=SR_lastResultsPage><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" target=_parent class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_lastSearchValue><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" target=_parent class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralL.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralM.html
--- trunk/mapbender/documents/api_js/search/GeneralM.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralM.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Map')" class=ISymbol>Map</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=IParent>Map</a></div></div></div><div class=SRResult id=SR_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralM.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralN.html
--- trunk/mapbender/documents/api_js/search/GeneralN.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralN.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_name><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" target=_parent class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralN.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralO.html
--- trunk/mapbender/documents/api_js/search/GeneralO.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralO.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/GeneralO.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralR.html
--- trunk/mapbender/documents/api_js/search/GeneralR.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralR.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralR.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralS.html
--- trunk/mapbender/documents/api_js/search/GeneralS.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralS.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_Search><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Search')" class=ISymbol>Search</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" target=_parent class=IParent>SearchResults</a></div></div></div><div class=SRResult id=SR_SearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" target=_parent class=ISymbol>SearchPanel</a></div></div><div class=SRResult id=SR_SearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" target=_parent class=ISymbol>SearchResults</a></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/search/GeneralS.html
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralT.html
--- trunk/mapbender/documents/api_js/search/GeneralT.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralT.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/GeneralT.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralV.html
--- trunk/mapbender/documents/api_js/search/GeneralV.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralV.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Variables><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Variables')" class=ISymbol>Variables</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Variables" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Variables" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/GeneralV.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/GeneralZ.html
--- trunk/mapbender/documents/api_js/search/GeneralZ.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/GeneralZ.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/GeneralZ.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/NoResults.html
--- trunk/mapbender/documents/api_js/search/NoResults.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/NoResults.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,15 @@
+<div id=Index><div class=SRStatus id=NoMatches>No Matches</div></div><script language=JavaScript><!--
Property changes on: trunk/mapbender/documents/api_js/search/NoResults.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/VariablesD.html
--- trunk/mapbender/documents/api_js/search/VariablesD.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/VariablesD.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deactivateTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" target=_parent class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_deactivateTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" target=_parent class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/VariablesD.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/VariablesK.html
--- trunk/mapbender/documents/api_js/search/VariablesK.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/VariablesK.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/VariablesK.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/VariablesL.html
--- trunk/mapbender/documents/api_js/search/VariablesL.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/VariablesL.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/VariablesL.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/VariablesM.html
--- trunk/mapbender/documents/api_js/search/VariablesM.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/VariablesM.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/VariablesM.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/VariablesN.html
--- trunk/mapbender/documents/api_js/search/VariablesN.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/VariablesN.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
Property changes on: trunk/mapbender/documents/api_js/search/VariablesN.html
+ text/html
Added: trunk/mapbender/documents/api_js/search/VariablesR.html
--- trunk/mapbender/documents/api_js/search/VariablesR.html (rev 0)
+++ trunk/mapbender/documents/api_js/search/VariablesR.html 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/search/VariablesR.html
+ text/html
Added: trunk/mapbender/documents/api_js/styles/main.css
--- trunk/mapbender/documents/api_js/styles/main.css (rev 0)
+++ trunk/mapbender/documents/api_js/styles/main.css 2009-06-24 15:47:55 UTC (rev 4134)
@@ -0,0 +1,767 @@
+ IMPORTANT: If you're editing this file in the output directory of one of
+ your projects, your changes will be overwritten the next time you run
+ Natural Docs. Instead, copy this file to your project directory, make your
+ changes, and you can use it with -s. Even better would be to make a CSS
+ file in your project directory with only your changes, which you can then
+ use with -s [original style] [your changes].
+ On the other hand, if you're editing this file in the Natural Docs styles
+ directory, the changes will automatically be applied to all your projects
+ that use this style the next time Natural Docs is run on them.
+ This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
+ Natural Docs is licensed under the GPL
+body {
+ font: 10pt Verdana, Arial, sans-serif;
+ color: #000000;
+ margin: 0; padding: 0;
+.ContentPage,
+.IndexPage,
+.FramedMenuPage {
+ background-color: #E8E8E8;
+.FramedContentPage,
+.FramedIndexPage,
+.FramedSearchResultsPage,
+.PopupSearchResultsPage {
+ background-color: #FFFFFF;
+a:link,
+a:visited { color: #900000; text-decoration: none }
+a:hover { color: #900000; text-decoration: underline }
+a:active { color: #FF0000; text-decoration: underline }
+td {
+ vertical-align: top }
+img { border: 0; }
+ Comment out this line to use web-style paragraphs (blank line between
+ paragraphs, no indent) instead of print-style paragraphs (no blank line,
+ indented.)
+p {
+ text-indent: 5ex; margin: 0 }
+/* Opera doesn't break with just wbr, but will if you add this. */
+.Opera wbr:after {
+ content: "\00200B";
+/* Blockquotes are used as containers for things that may need to scroll. */
+blockquote {
+ padding: 0;
+ margin: 0;
+ overflow: auto;
+.Firefox1 blockquote {
+ padding-bottom: .5em;
+/* Turn off scrolling when printing. */
+ at media print {
+ blockquote {
+ overflow: visible;
+ .IE blockquote {
+ width: auto;
+#Menu {
+ font-size: 9pt;
+ padding: 10px 0 0 0;
+.ContentPage #Menu,
+.IndexPage #Menu {
+ position: absolute;
+ top: 0;
+ left: 0;
+ width: 31ex;
+ overflow: hidden;
+.ContentPage .Firefox #Menu,
+.IndexPage .Firefox #Menu {
+ width: 27ex;
+ .MTitle {
+ font-size: 16pt; font-weight: bold; font-variant: small-caps;
+ text-align: center;
+ padding: 5px 10px 15px 10px;
+ border-bottom: 1px dotted #000000;
+ margin-bottom: 15px }
+ .MSubTitle {
+ font-size: 9pt; font-weight: normal; font-variant: normal;
+ margin-top: 1ex; margin-bottom: 5px }
+ .MEntry a:link,
+ .MEntry a:hover,
+ .MEntry a:visited { color: #606060; margin-right: 0 }
+ .MEntry a:active { color: #A00000; margin-right: 0 }
+ .MGroup {
+ font-variant: small-caps; font-weight: bold;
+ margin: 1em 0 1em 10px;
+ .MGroupContent {
+ font-variant: normal; font-weight: normal }
+ .MGroup a:link,
+ .MGroup a:hover,
+ .MGroup a:visited { color: #545454; margin-right: 10px }
+ .MGroup a:active { color: #A00000; margin-right: 10px }
+ .MFile,
+ .MText,
+ .MLink,
+ .MIndex {
+ padding: 1px 17px 2px 10px;
+ margin: .25em 0 .25em 0;
+ .MText {
+ font-size: 8pt; font-style: italic }
+ .MLink {
+ font-style: italic }
+ #MSelected {
+ color: #000000; background-color: #FFFFFF;
+ /* Replace padding with border. */
+ padding: 0 10px 0 10px;
+ border-width: 1px 2px 2px 0; border-style: solid; border-color: #000000;
+ margin-right: 5px;
+ /* Close off the left side when its in a group. */
+ .MGroup #MSelected {
+ padding-left: 9px; border-left-width: 1px }
+ /* A treat for Mozilla users. Blatantly non-standard. Will be replaced with CSS 3 attributes when finalized/supported. */
+ .Firefox #MSelected {
+ -moz-border-radius-topright: 10px;
+ -moz-border-radius-bottomright: 10px }
+ .Firefox .MGroup #MSelected {
+ -moz-border-radius-topleft: 10px;
+ -moz-border-radius-bottomleft: 10px }
+ #MSearchPanel {
+ padding: 0px 6px;
+ margin: .25em 0;
+ #MSearchField {
+ font: italic 9pt Verdana, sans-serif;
+ color: #606060;
+ border: none;
+ padding: 2px 4px;
+ width: 100%;
+ /* Only Opera gets it right. */
+ .Firefox #MSearchField,
+ .IE #MSearchField,
+ .Safari #MSearchField {
+ width: 94%;
+ .Opera9 #MSearchField,
+ .Konqueror #MSearchField {
+ width: 97%;
+ .FramedMenuPage .Firefox #MSearchField,
+ .FramedMenuPage .Safari #MSearchField,
+ .FramedMenuPage .Konqueror #MSearchField {
+ width: 98%;
+ /* Firefox doesn't do this right in frames without #MSearchPanel added on.
+ It's presence doesn't hurt anything other browsers. */
+ #MSearchPanel.MSearchPanelInactive:hover #MSearchField {
+ border: 1px solid #C0C0C0;
+ padding: 1px 3px;
+ .MSearchPanelActive #MSearchField {
+ font-style: normal;
+ padding: 1px 3px;
+ #MSearchType {
+ visibility: hidden;
+ font: 8pt Verdana, sans-serif;
+ width: 98%;
+ padding: 0;
+ .MSearchPanelActive #MSearchType,
+ /* As mentioned above, Firefox doesn't do this right in frames without #MSearchPanel added on. */
+ #MSearchPanel.MSearchPanelInactive:hover #MSearchType,
+ #MSearchType:focus {
+ visibility: visible;
+ color: #606060;
+ #MSearchType option#MSearchEverything {
+ font-weight: bold;
+ .Opera8 .MSearchPanelInactive:hover,
+ .Opera8 .MSearchPanelActive {
+ margin-left: -1px;
+ iframe#MSearchResults {
+ width: 60ex;
+ height: 15em;
+ #MSearchResultsWindow {
+ display: none;
+ left: 0; top: 0;
+ border: 1px solid #000000;
+ #MSearchResultsWindowClose {
+ font-size: 8pt;
+ display: block;
+ padding: 2px 5px;
+ #MSearchResultsWindowClose:link,
+ #MSearchResultsWindowClose:visited {
+ color: #000000;
+ text-decoration: none;
+ #MSearchResultsWindowClose:active,
+ #MSearchResultsWindowClose:hover {
+ color: #800000;
+ background-color: #F4F4F4;
+#Content {
+ padding-bottom: 15px;
+.ContentPage #Content {
+ border-width: 0 0 1px 1px;
+ border-style: solid;
+ border-color: #000000;
+ font-size: 9pt; /* To make 31ex match the menu's 31ex. */
+ margin-left: 31ex;
+.ContentPage .Firefox #Content {
+ margin-left: 27ex;
+ .CTopic {
+ font-size: 10pt;
+ margin-bottom: 3em;
+ .CTitle {
+ font-size: 12pt; font-weight: bold;
+ border-width: 0 0 1px 0; border-style: solid; border-color: #A0A0A0;
+ margin: 0 15px .5em 15px }
+ .CGroup .CTitle {
+ font-size: 16pt; font-variant: small-caps;
+ padding-left: 15px; padding-right: 15px;
+ border-width: 0 0 2px 0; border-color: #000000;
+ margin-left: 0; margin-right: 0 }
+ .CClass .CTitle,
+ .CInterface .CTitle,
+ .CDatabase .CTitle,
+ .CDatabaseTable .CTitle,
+ .CSection .CTitle {
+ font-size: 18pt;
+ color: #FFFFFF; background-color: #A0A0A0;
+ padding: 10px 15px 10px 15px;
+ border-width: 2px 0; border-color: #000000;
+ #MainTopic .CTitle {
+ font-size: 20pt;
+ color: #FFFFFF; background-color: #7070C0;
+ border-width: 0 0 3px 0; border-color: #000000;
+ .CBody {
+ margin-left: 15px; margin-right: 15px }
+ .CToolTip {
+ position: absolute; visibility: hidden;
+ left: 0; top: 0;
+ background-color: #FFFFE0;
+ padding: 5px;
+ border-width: 1px 2px 2px 1px; border-style: solid; border-color: #000000;
+ font-size: 8pt;
+ .Opera .CToolTip {
+ max-width: 98%;
+ /* Scrollbars would be useless. */
+ .CToolTip blockquote {
+ overflow: hidden;
+ .IE6 .CToolTip blockquote {
+ .CHeading {
+ font-weight: bold; font-size: 10pt;
+ margin: 1.5em 0 .5em 0;
+ .CBody pre {
+ font: 10pt "Courier New", Courier, monospace;
+ margin: 1em 0;
+ .CBody ul {
+ /* I don't know why CBody's margin doesn't apply, but it's consistent across browsers so whatever.
+ Reapply it here as padding. */
+ margin: .5em 5ex .5em 5ex;
+ .CDescriptionList {
+ margin: .5em 5ex 0 5ex }
+ .CDLEntry {
+ font: 10pt "Courier New", Courier, monospace; color: #808080;
+ padding-bottom: .25em;
+ white-space: nowrap }
+ .CDLDescription {
+ font-size: 10pt; /* For browsers that don't inherit correctly, like Opera 5. */
+ padding-bottom: .5em; padding-left: 5ex }
+ .CTopic img {
+ display: block;
+ margin: 1em auto;
+ .CImageCaption {
+ font-size: 8pt;
+ color: #808080;
+ position: relative;
+ top: 1em;
+ .CImageLink {
+ color: #808080;
+ font-style: italic;
+ a.CImageLink:link,
+ a.CImageLink:visited,
+ a.CImageLink:hover { color: #808080 }
+.Prototype {
+ padding: 5px 3ex;
+ border-width: 1px; border-style: solid;
+ margin: 0 5ex 1.5em 5ex;
+ .Prototype td {
+ font-size: 10pt;
+ .PDefaultValue,
+ .PDefaultValuePrefix,
+ .PTypePrefix {
+ color: #8F8F8F;
+ .PTypePrefix {
+ text-align: right;
+ .PAfterParameters {
+ vertical-align: bottom;
+ .IE .Prototype table {
+ padding: 0;
+ .CFunction .Prototype {
+ background-color: #F4F4F4; border-color: #D0D0D0 }
+ .CProperty .Prototype {
+ background-color: #F4F4FF; border-color: #C0C0E8 }
+ .CVariable .Prototype {
+ background-color: #FFFFF0; border-color: #E0E0A0 }
+ .CClass .Prototype {
+ border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0A0;
+ .CInterface .Prototype {
+ border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0D0;
+ .CDatabaseIndex .Prototype,
+ .CConstant .Prototype {
+ background-color: #D0D0D0; border-color: #000000 }
+ .CType .Prototype,
+ .CEnumeration .Prototype {
+ background-color: #FAF0F0; border-color: #E0B0B0;
+ .CDatabaseTrigger .Prototype,
+ .CEvent .Prototype,
+ .CDelegate .Prototype {
+ background-color: #F0FCF0; border-color: #B8E4B8 }
+ .CToolTip .Prototype {
+ margin: 0 0 .5em 0;
+ white-space: nowrap;
+.Summary {
+ margin: 1.5em 5ex 0 5ex }
+ .STitle {
+ margin-bottom: .5em }
+ .SBorder {
+ padding: 15px;
+ border: 1px solid #C0C060 }
+ /* In a frame IE 6 will make them too long unless you set the width to 100%. Without frames it will be correct without a width
+ or slightly too long (but not enough to scroll) with a width. This arbitrary weirdness simply astounds me. IE 7 has the same
+ problem with frames, haven't tested it without. */
+ .FramedContentPage .IE .SBorder {
+ width: 100% }
+ .Firefox .SBorder {
+ -moz-border-radius: 20px }
+ .STable {
+ font-size: 9pt; width: 100% }
+ .SEntry {
+ width: 30% }
+ .SDescription {
+ width: 70% }
+ .SMarked {
+ background-color: #F8F8D8 }
+ .SDescription { padding-left: 2ex }
+ .SIndent1 .SEntry { padding-left: 1.5ex } .SIndent1 .SDescription { padding-left: 3.5ex }
+ .SIndent2 .SEntry { padding-left: 3.0ex } .SIndent2 .SDescription { padding-left: 5.0ex }
+ .SIndent3 .SEntry { padding-left: 4.5ex } .SIndent3 .SDescription { padding-left: 6.5ex }
+ .SIndent4 .SEntry { padding-left: 6.0ex } .SIndent4 .SDescription { padding-left: 8.0ex }
+ .SIndent5 .SEntry { padding-left: 7.5ex } .SIndent5 .SDescription { padding-left: 9.5ex }
+ .SDescription a { color: #800000}
+ .SDescription a:active { color: #A00000 }
+ .SGroup td {
+ padding-top: .5em; padding-bottom: .25em }
+ .SGroup .SEntry {
+ font-weight: bold; font-variant: small-caps }
+ .SGroup .SEntry a { color: #800000 }
+ .SGroup .SEntry a:active { color: #F00000 }
+ .SMain td,
+ .SClass td,
+ .SDatabase td,
+ .SDatabaseTable td,
+ .SSection td {
+ font-size: 10pt;
+ padding-bottom: .25em }
+ .SClass td,
+ .SDatabase td,
+ .SSection td {
+ padding-top: 1em }
+ .SMain .SEntry,
+ .SClass .SEntry,
+ .SDatabase .SEntry,
+ .SDatabaseTable .SEntry,
+ .SSection .SEntry {
+ .SMain .SEntry a,
+ .SClass .SEntry a,
+ .SDatabase .SEntry a,
+ .SDatabaseTable .SEntry a,
+ .SSection .SEntry a { color: #000000 }
+ .SMain .SEntry a:active,
+ .SClass .SEntry a:active,
+ .SDatabase .SEntry a:active,
+ .SDatabaseTable .SEntry a:active,
+ .SSection .SEntry a:active { color: #A00000 }
+.ClassHierarchy {
+ margin: 0 15px 1em 15px }
+ .CHEntry {
+ margin-bottom: 3px;
+ padding: 2px 2ex;
+ font-size: 10pt;
+ background-color: #F4F4F4; color: #606060;
+ .Firefox .CHEntry {
+ -moz-border-radius: 4px;
+ .CHCurrent .CHEntry {
+ color: #000000;
+ .CHChildNote .CHEntry {
+ font-size: 8pt;
+ .CHIndent {
+ margin-left: 3ex;
+ .CHEntry a:link,
+ .CHEntry a:visited,
+ .CHEntry a:hover {
+ color: #606060;
+ .CHEntry a:active {
+ color: #800000;
+#Index {
+/* As opposed to .PopupSearchResultsPage #Index */
+.IndexPage #Index,
+.FramedIndexPage #Index,
+.FramedSearchResultsPage #Index {
+ padding: 15px;
+.IndexPage #Index {
+ font-size: 9pt; /* To make 27ex match the menu's 27ex. */
+ .IPageTitle {
+ font-size: 20pt; font-weight: bold;
+ border-width: 0 0 3px 0; border-color: #000000; border-style: solid;
+ margin: -15px -15px 0 -15px }
+ .FramedSearchResultsPage .IPageTitle {
+ margin-bottom: 15px;
+ .INavigationBar {
+ font-size: 10pt;
+ padding: 5px;
+ border-bottom: solid 1px black;
+ margin: 0 -15px 15px -15px;
+ .INavigationBar a {
+ font-weight: bold }
+ .IHeading {
+ padding: 2.5em 0 .5em 0;
+ width: 3.5ex;
+ #IFirstHeading {
+ padding-top: 0;
+ .IEntry {
+ font-size: 10pt;
+ padding-left: 1ex;
+ .PopupSearchResultsPage .IEntry {
+ font-size: 8pt;
+ padding: 1px 5px;
+ .PopupSearchResultsPage .Opera9 .IEntry,
+ .FramedSearchResultsPage .Opera9 .IEntry {
+ text-align: left;
+ .FramedSearchResultsPage .IEntry {
+ padding: 0;
+ .ISubIndex {
+ padding-left: 3ex; padding-bottom: .5em }
+ .PopupSearchResultsPage .ISubIndex {
+ display: none;
+ /* While it may cause some entries to look like links when they aren't, I found it's much easier to read the
+ index if everything's the same color. */
+ .ISymbol {
+ font-weight: bold; color: #900000 }
+ .IndexPage .ISymbolPrefix,
+ .FramedIndexPage .ISymbolPrefix {
+ font-size: 10pt;
+ color: #C47C7C;
+ background-color: #F8F8F8;
+ border-right: 3px solid #E0E0E0;
+ border-left: 1px solid #E0E0E0;
+ padding: 0 1px 0 2px;
+ .PopupSearchResultsPage .ISymbolPrefix,
+ .FramedSearchResultsPage .ISymbolPrefix {
+ color: #900000;
+ .PopupSearchResultsPage .ISymbolPrefix {
+ font-size: 8pt;
+ .IndexPage #IFirstSymbolPrefix,
+ .FramedIndexPage #IFirstSymbolPrefix {
+ border-top: 1px solid #E0E0E0;
+ .IndexPage #ILastSymbolPrefix,
+ .FramedIndexPage #ILastSymbolPrefix {
+ border-bottom: 1px solid #E0E0E0;
+ .IndexPage #IOnlySymbolPrefix,
+ .FramedIndexPage #IOnlySymbolPrefix {
+ a.IParent,
+ a.IFile {
+ display: block;
+ .PopupSearchResultsPage .SRStatus {
+ padding: 2px 5px;
+ font-size: 8pt;
+ .FramedSearchResultsPage .SRStatus {
+ font-size: 10pt;
+ .SRResult {
+ display: none;
+#Footer {
+ font-size: 8pt;
+ color: #989898;
+#Footer p {
+ text-indent: 0;
+ margin-bottom: .5em;
+.ContentPage #Footer,
+.IndexPage #Footer {
+ margin: 2px;
+.FramedMenuPage #Footer {
+ margin: 5em 10px 10px 10px;
+ padding-top: 1em;
+ border-top: 1px solid #C8C8C8;
+ #Footer a:link,
+ #Footer a:hover,
+ #Footer a:visited { color: #989898 }
+ #Footer a:active { color: #A00000 }
Property changes on: trunk/mapbender/documents/api_js/styles/main.css
+ text/html
More information about the Mapbender_commits
