[Mapbender-commits] r4253 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Fri Jun 26 10:12:08 EDT 2009
Author: christoph
Date: 2009-06-26 10:12:08 -0400 (Fri, 26 Jun 2009)
New Revision: 4253
trunk/mapbender/lib/button.js
new button class
Mapbender.Button
Modified: trunk/mapbender/lib/button.js
--- trunk/mapbender/lib/button.js 2009-06-26 14:09:50 UTC (rev 4252)
+++ trunk/mapbender/lib/button.js 2009-06-26 14:12:08 UTC (rev 4253)
@@ -3,42 +3,63 @@
* button handling
+Mapbender.Button = function (options) {
+ mb_regButton(options);
var mb_button = [];
function mb_regButton_frame(wii, frameName, param){
var ind = mb_button.length;
mb_button[ind] = new mb_conButton(wii, ind);
- if (frameName === null) {
- if (param === null) {
- if (typeof(wii) == "string") {
- eval(wii+"("+ind+")");
- else {
- wii(ind);
+ if (typeof wii === "object") {
+ var options = wii;
+ mb_button[ind] = options.domElement;
+ mb_button[ind].img_over = options.over ? options.over : "";
+ mb_button[ind].img_on = options.on ? options.on : ""
+ mb_button[ind].img_off = options.off ? options.off : "";
+ mb_button[ind].status = options.status ? options.status : 0;
+ mb_button[ind].elName = options.name ? options.name : "";
+ mb_button[ind].fName = options.frameName ? options.frameName : "";
+ if (options.go && typeof options.go === "function") {
+ mb_button[ind].go = options.go;
else {
- eval(wii + "(" + ind + ", " + param + ")");
- else {
- wii(ind, param);
+ mb_button[ind].go = function () {
+ if (options.stop && typeof options.stop === "function") {
+ mb_button[ind].stop = options.stop;
+ else {
+ mb_button[ind].stop = function () {
- else if (param === null) {
- eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
+ else if (typeof wii === "string") {
+ var str = "";
+ if (frameName !== null) {
+ str += "window.frames.['" + frameName + "'].";
+ str += wii + "(" + ind;
+ if (param !== null) {
+ str += "," + param;
+ str += ");";
+ console.log(str);
+ eval(str);
- else {
- eval("window.frames['" + frameName + "']."+ wii + "(" + ind + ", " + param + ")");
+ else if (typeof wii == "function") {
+ if (param === null) {
+ wii(ind);
else {
wii(ind, param);
mb_button[ind].prev = mb_button[ind].src;
mb_button[ind].src = mb_button[ind].img_off;
mb_button[ind].onmouseover = function () {
@@ -63,7 +84,6 @@
function mb_conButton(wii, ind){
- this.wii = wii;
return true;
function mb_button_over(ind){
@@ -156,8 +176,11 @@
function mb_localizeButtons(){
- var req = new Mapbender.Ajax.Request();
- req.send("../php/mod_button_tooltips.php", updateButtonTooltips);
+ var req = new Mapbender.Ajax.Request({
+ url: "../php/mod_button_tooltips.php",
+ callback: updateButtonTooltips
+ req.send();
eventLocalize.register(function () {
More information about the Mapbender_commits
