[Mapbender-commits] r4260 - branches/kmq_dev/http/classes
svn_mapbender at osgeo.org
Sun Jun 28 17:05:35 EDT 2009
Author: kmq
Date: 2009-06-28 17:05:35 -0400 (Sun, 28 Jun 2009)
New Revision: 4260
branches/kmq_dev/http/classes/class_user.php
User object mostly finished
Modified: branches/kmq_dev/http/classes/class_user.php
--- branches/kmq_dev/http/classes/class_user.php 2009-06-27 06:32:51 UTC (rev 4259)
+++ branches/kmq_dev/http/classes/class_user.php 2009-06-28 21:05:35 UTC (rev 4260)
@@ -63,6 +63,7 @@
* @return String the ID of this user
@@ -79,7 +80,7 @@
$result = '{"name":"'. $this->name .'",'
- .'"password": "*************",'
+ .'"password": "*************",'
.'"owner":"'. $this->owner .'",'
.'"descr":"'. $this->descr .'",'
.'"loginCount":"'. $this->loginCount .'",'
@@ -146,6 +147,35 @@
+ * @param $changes JSON keys and their values of what to change in the object
+ public function change($changes)
+ $this->name = $changes->name ? $changes->name : $this->name;
+ print "MY NAME IS $changes->name";
+ $this->owner = $changes->owner ? $changes->owner : $this->owner;
+ $this->description = $changes->description ? $changes->description : $this->description;
+ $this->email = $changes->email ? $changes->email : $this->email;
+ $this->phone = $changes->phone ? $changes->phone : $this->phone;
+ $this->department = $changes->department ? $changes->department : $this->department;
+ $this->resolution = $changes->resolution ? $changes->resolution : $this->resolution;
+ $this->organization = $changes->organization ? $changes->organization : $this->organization;
+ $this->position = $changes->position ? $changes->position : $this->position;
+ $this->phone1 = $changes->phone1 ? $changes->phone1 : $this->phone1;
+ $this->facsimile = $changes->facsimile ? $changes->facsimile : $this->facsimile;
+ $this->deliveryPoint = $changes->deliveryPoint ? $changes->deliveryPoint : $this->deliveryPoint;
+ $this->city = $changes->city ? $changes->city : $this->city;
+ $this->postalCode = $changes->postalCode ? $changes->postalCode : $this->postalCode;
+ $this->country = $changes->country ? $changes->country : $this->country;
+ $this->url = $changes->url ? $changes->url : $this->url;
+ $this->id = $changes->id ? $changes->id : $this->id;
+ return true;
public function commit()
@@ -198,8 +228,6 @@
return true;
public function remove()
@@ -253,8 +281,51 @@
return false;
+ * @return Array of Users
+ * @param $filter UNUSED! string that must be contained in the username
+ public static function getList($filter)
+ $users = Array();
+ $sql_userlist = "SELECT mb_user_id FROM mb_user";
+ $res_users = db_query($sql_userlist);
+ while($row = db_fetch_array($res_users))
+ try{
+ $users[] = new User($row['mb_user_id']);
+ catch(Exception $E)
+ continue;
+ //FIXME: should catch some errors here
+ return $users;
+ * tries to initialize a userobject by Name
+ * @return A user Object
+ * @param $name the name of the user to find
+ public static function byName($name)
+ $sql_user = "SELECT mb_user_id FROM mb_user WHERE mb_user_name = '$name'";
+ $res_user = db_query($sql_user);
+ if($row = db_fetch_array($res_user))
+ return new User($row['mb_user_id']);
+ return null;
* Returns an array of application IDs that the user is allowed to access.
* @return Array an array of application IDs
More information about the Mapbender_commits
