[Mapbender-commits] r3612 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Mar 2 03:25:00 EST 2009
Author: verenadiewald
Date: 2009-03-02 03:25:00 -0500 (Mon, 02 Mar 2009)
New Revision: 3612
trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
use of class requestGeometryConstructor to get valid geom for spatial request
Modified: trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
--- trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php 2009-03-02 08:23:49 UTC (rev 3611)
+++ trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php 2009-03-02 08:25:00 UTC (rev 3612)
@@ -1,865 +1,696 @@
-<?php
-#$Id$
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_wfs_spatialRequest.php,v 1.4 2006/03/08 15:26:26 c_baudson Exp $
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-$wfs_conf_filename = "wfs_default.conf";
-include '../include/dyn_php.php';
-$fname = dirname(__FILE__) . "/../../conf/" . $wfs_conf_filename;
-if (file_exists($fname)) {
- include($fname);
-else {
- $e = new mb_exception("mod_wfs_SpatialRequest.php: Configuration file " . $wfs_conf_filename . " not found.");
-include '../include/dyn_js.php';
-echo "var mod_wfs_spatialRequest_target = '".$e_target[0]."';\n";
-//element var openLinkFromSearch for opening attribute link directly onclick of searchResult entry
-try{
- if (openLinkFromSearch){}
-catch(e){
- openLinkFromSearch =0;
-var wfsAreaType_point = "point";
-var wfsAreaType_polygon = "polygon";
-var wfsAreaType_rectangle = "rectangle";
-var wfsAreaType_extent = "extent";
-var wfsAreaType_current = "";
-var mod_wfs_spatialRequest_frameName = "";
-var mod_wfs_spatialRequest_epsg;
-var mod_wfs_spatialRequest_width;
-var mod_wfs_spatialRequest_height;
-var mod_wfs_spatialRequest_bg = "";
-var mod_wfs_spatialRequest_pgsql = true;
-var mod_wfs_spatialRequest_win = null;
-var mod_wfs_spatialRequest_thema = false;
-var button_point = "point";
-var button_polygon = "polygon";
-var button_rectangle = "rectangle";
-var button_extent = "extent";
-var button_dialogue = "dialogue";
-var activeButton = null;
-var mod_wfs_spatialRequest_geometry = null;
-var mod_wfs_spatialRequestSubFunctions = [];
-var buttonWfs_id = [];
-var buttonWfs_on = [];
-var buttonWfs_src = [];
-var buttonWfs_title_off = [];
-var buttonWfs_title_on = [];
-var buttonWfs_x = [];
-var buttonWfs_y = [];
-var numberOfAjaxCalls = 0;
-var numberOfFinishedAjaxCalls = 0;
-var resultGeometryPopup;
-var _geomArray = new GeometryArray();
-try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
-function addButtonWfs(id, isOn, src, title, x, y) {
- buttonWfs_id.push(id);
- buttonWfs_on.push(isOn);
- buttonWfs_src.push(src);
- buttonWfs_title_off.push(title);
- buttonWfs_title_on.push(title);
- buttonWfs_x.push(x);
- buttonWfs_y.push(y);
-var msgObj;
-mb_registerInitFunctions("init_wfsSpatialRequest()");
-//mb_registerL10nFunctions("init_wfsSpatialRequest()");
-function init_wfsSpatialRequest() {
- mb_ajax_json("../php/mod_wfsSpatialRequest_messages.php", function(obj, status) {
- msgObj = obj;
- buttonWfs_id = [];
- buttonWfs_on = [];
- buttonWfs_src = [];
- buttonWfs_title_off = [];
- buttonWfs_title_on = [];
- buttonWfs_x = [];
- buttonWfs_y = [];
- addButtonWfs("rectangle", buttonRectangle.status, buttonRectangle.img, msgObj.buttonLabelRectangle, buttonRectangle.x, buttonRectangle.y);
- addButtonWfs("polygon", buttonPolygon.status, buttonPolygon.img, msgObj.buttonLabelPolygon, buttonPolygon.x, buttonPolygon.y);
- addButtonWfs("point", buttonPoint.status, buttonPoint.img, msgObj.buttonLabelPoint, buttonPoint.x, buttonPoint.y);
- addButtonWfs("extent", buttonExtent.status, buttonExtent.img, msgObj.buttonLabelExtent, buttonExtent.x, buttonExtent.y);
- addButtonWfs("dialogue", buttonDialogue.status, buttonDialogue.img, msgObj.buttonLabelDialogue, buttonDialogue.x, buttonDialogue.y);
- displayButtons();
-// ------------ button handling -------------------------------------------------------------
-function wfsInitFunction (j) {
- var functionCall = "mb_regButton_frame('initWfsButton', null, "+j+")";
- var x = new Function ("", functionCall);
- x();
-function displayButtons() {
- for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
- if (parseInt(buttonWfs_on[i])==1) {
- var currentDiv = document.createElement("div");
- currentDiv.id = buttonWfs_id[i]+"Div";
- currentDiv.style.position = "absolute";
- currentDiv.style.left = buttonWfs_x[i]
- currentDiv.style.top = buttonWfs_y[i];
- currentDiv.style.zIndex = buttonWfs_zIndex;
- var currentImg = document.createElement("img");
- currentImg.id = buttonWfs_id[i];
- currentImg.name = buttonWfs_id[i];
- currentImg.title = buttonWfs_title_off[i];
- currentImg.src = buttonWfs_imgdir+buttonWfs_src[i];
- currentImg.onmouseover = new Function("wfsInitFunction("+i+")");
- currentDiv.appendChild(currentImg);
- document.getElementsByTagName('body')[0].appendChild(currentDiv);
-function initWfsButton(ind, pos) {
- mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
- mb_button[ind].img_over = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_over");
- mb_button[ind].img_on = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_on");
- mb_button[ind].img_off = buttonWfs_imgdir + buttonWfs_src[pos];
- mb_button[ind].status = 0;
- mb_button[ind].elName = buttonWfs_id[pos];
- mb_button[ind].fName = "";
- mb_button[ind].go = new Function ("wfsEnable(mb_button["+ind+"], " + pos + ")");
- mb_button[ind].stop = new Function ("wfsDisable(mb_button["+ind+"], " + pos + ")");
- var ind = getMapObjIndexByName(mod_wfs_spatialRequest_target);
- mod_wfs_spatialRequest_width = mb_mapObj[ind].width;
- mod_wfs_spatialRequest_height = mb_mapObj[ind].height;
- mod_wfs_spatialRequest_epsg = mb_mapObj[ind].epsg;
- mb_registerSubFunctions("drawDashedLineExt()");
- mb_registerPanSubElement("measuring");
-function wfsEnable(obj) {
- var el = getMapDoc();
- el.onmouseover = null;
- el.onmousedown = null;
- el.onmouseup = null;
- el.onmousemove = null;
- if (obj.id == button_point) {
- if (activeButton == null) {
- activeButton = obj;
- mod_wfs_spatialRequest_geometry = new Geometry(geomType.point);
- wfsAreaType_current = wfsAreaType_point;
- mod_wfs_spatialRequest_digitize_go(geomType.point);
- if (obj.id == button_polygon) {
- mod_wfs_spatialRequest_geometry = new Geometry(geomType.polygon);
- wfsAreaType_current = wfsAreaType_polygon;
- mod_wfs_spatialRequest_digitize_go(geomType.polygon);
- var measureSub = "";
- for(var i=0; i<mod_wfs_spatialRequestSubFunctions.length; i++){
- measureSub += eval(mod_wfs_spatialRequestSubFunctions[i]);
- if (mb_mapObj[ind].type == "IFRAME") {
- writeTag(mod_wfs_spatialRequest_target ,"measure_sub",measureSub);
- else {
- writeTag("" ,"measure_sub",measureSub);
- else if (obj.id == button_rectangle){
- mod_wfs_spatialRequest_geometry = new Geometry(geomType.line);
- wfsAreaType_current = wfsAreaType_rectangle;
- mod_selAreaExt_click();
- else if (obj.id == button_extent){
- wfsAreaType_current = wfsAreaType_extent;
- var p0 = mapToReal(mod_wfs_spatialRequest_target, new Point(0,0));
- var p1 = mapToReal(mod_wfs_spatialRequest_target, new Point(mb_mapObj[ind].width,mb_mapObj[ind].height));
- mod_wfs_spatialRequest_geometry.addPoint(p0);
- mod_wfs_spatialRequest_geometry.addPoint(p1);
- mod_getAreaExt_send();
- else if (obj.id == button_dialogue) {
- mod_wfs_SpatialRequest_dialog();
-function getMapDoc () {
- var mapIndex = getMapObjIndexByName(mod_wfs_spatialRequest_target);
- var mapDomElement = mb_mapObj[mapIndex].getDomElement();
- var mapType = mapDomElement.tagName.toUpperCase();
- if (mapType == "IFRAME") {
- return mapDomElement.window.document;
- return window.document;
-function wfsDisable(obj) {
- el.ondblclick = null;
- writeTag(mod_wfs_spatialRequest_target,"measure_display","");
- writeTag(mod_wfs_spatialRequest_target,"measure_sub","");
- else {
- writeTag("", "measure_display", "");
- writeTag("", "measure_sub", "");
- activeButton = null;
-// -------------------- rectangle -----------------------------------------------------------------
-function mod_selAreaExt_click(){
- el.onmouseover = mod_selAreaExt_init;
- el.onmousedown = mod_box_start;
- el.onmouseup = mod_selAreaExt_get;
- el.onmousemove = mod_box_run;
-function mod_selAreaExt_init(e){
- mb_isBF = mod_wfs_spatialRequest_target;
- mb_zF = mod_wfs_spatialRequest_target;
-function mod_selAreaExt_get(e){
- mod_selAreaExt_setValidClipping(mod_box_stop(e));
-function mod_selAreaExt_setValidClipping(coords){
- if (mod_wfs_spatialRequest_geometry != null) {
- mod_wfs_spatialRequest_geometry.addPoint(new Point(coords[0],coords[1]));
- mod_wfs_spatialRequest_geometry.addPoint(new Point(coords[2],coords[3]));
- if(mod_wfs_spatialRequest_geometry.count() == 2){
- else{
- alert(errorMessageInvalidExtent[selectedLanguage]);
- mb_disableThisButton(activeButton.id);
-// -------------------- polygon && point --------------------------------------------------------
-function mod_wfs_spatialRequest_digitize_go(geomType){
- if (geomType == geomType.polygon) {
- s = new Snapping(mod_wfs_spatialRequest_target);
- el.onmousedown = mod_wfs_spatialRequest_start;
- el.onmousemove = mod_wfs_spatialRequest_run;
- writeTag(mod_wfs_spatialRequest_target,"measure_sub",measureSub);
- else {
- writeTag("", "measure_sub", measureSub);
-function mod_wfs_getMousePosition(e) {
- mb_getMousePos(e, mod_wfs_spatialRequest_target);
- var currentPos = null;
- if (mb_mapObj[ind].type == "DIV") {
- var mapDomElement = mb_mapObj[ind].getDomElement();
- currentPos = new parent.Point(
- parent.clickX - parseInt(mapDomElement.style.left),
- parent.clickY - parseInt(mapDomElement.style.top)
- else {
- parent.clickX,
- parent.clickY
- return currentPos;
-function mod_wfs_spatialRequest_run(e) {
- if (mod_wfs_spatialRequest_geometry.count() >= 3) {
- var pos = mod_wfs_getMousePosition(e);
- s.check(pos);
-function mod_wfs_spatialRequest_start(e){
- var realWorldPos;
- if (s.isSnapped() == true) {
- realWorldPos = s.getSnappedPoint();
- s.clean();
- else {
- var pt = mod_wfs_getMousePosition(e);
- realWorldPos = mapToReal(mod_wfs_spatialRequest_target, pt);
- mod_wfs_spatialRequest_geometry.addPoint(realWorldPos);
- if (mod_wfs_spatialRequest_geometry.count() == 1) {
- s.add(mod_wfs_spatialRequest_geometry.get(0));
- if (s.isSnapped() && mod_wfs_spatialRequest_geometry.count() >= 3 && mod_wfs_spatialRequest_geometry.get(-1).equals(mod_wfs_spatialRequest_geometry.get(0))) {
- mod_wfs_spatialRequest_geometry.close();
- return;
- if(wfsAreaType_current == wfsAreaType_point){
- return;
- drawDashedLineExt();
-function drawDashedLineExt(){
- var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mod_wfs_spatialRequest_width+"' height='0'></div>";
- str_mPoints += "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mod_wfs_spatialRequest_height+"'></div>";
- for(var i=0; i<mod_wfs_spatialRequest_geometry.count(); i++){
- var pos = realToMap(mod_wfs_spatialRequest_target,mod_wfs_spatialRequest_geometry.get(i));
- str_mPoints += "<div style='font-size:1px;position:absolute;top:"+(pos.y-2)+"px;left:"+(pos.x-2)+"px;width:3px;height:3px;background-color:#ff0000'></div>";
- if(mod_wfs_spatialRequest_geometry.count()>1){
- for(var k=1; k<mod_wfs_spatialRequest_geometry.count(); k++){
- var pos0 = realToMap(mod_wfs_spatialRequest_target,mod_wfs_spatialRequest_geometry.get(k));
- var pos1 = realToMap(mod_wfs_spatialRequest_target,mod_wfs_spatialRequest_geometry.get(k-1));
- str_mPoints += evaluateDashesExt(pos1,pos0,k);
- writeTag(mod_wfs_spatialRequest_target,"measuring",str_mPoints);
- else {
- writeTag("", "measuring", str_mPoints);
-function evaluateDashesExt(p1,p0,count){
- var str_dashedLine = "";
- var d = p0.dist(p1);
- var n = Math.round(d);
- var s = p0.minus(p1).dividedBy(n);
- for(var i=1; i<n; i++){
- var currPoint = p1.plus(s.times(i)).minus(new Point(2,2)).round(0);
- if(currPoint.x >= 0 && currPoint.x <= mod_wfs_spatialRequest_width && currPoint.y >= 0 && currPoint.y <= mod_wfs_spatialRequest_height){
- str_dashedLine += "<div style='font-size:1px;position:absolute;top:"+currPoint.y+"px;left:"+currPoint.x+"px;width:3px;height:3px;background-color:#ff0000'></div>";
- return str_dashedLine;
-function mod_wfs_spatialRequest_close(){
- if(mod_wfs_spatialRequest_geometry.count() < 3){
- return;
- mod_wfs_spatialRequest_geometry.closeGeometry();
-function register_setExtRequestSubFunctions(stringFunction){
- mod_wfs_spatialRequestSubFunctions[mod_wfs_spatialRequestSubFunctions.length] = stringFunction;
-function mod_getAreaExt_send(){
- mb_setwfsrequest(mod_wfs_spatialRequest_target,mod_wfs_spatialRequest_geometry);
- mod_wfs_spatialRequest_delete();
- mod_wfs_spatialRequest_geometry = null;
-function mod_wfs_spatialRequest_delete(){
- writeTag(mod_wfs_spatialRequest_target,"measuring","");
- else {
- writeTag("","measuring","");
- writeTag("","measure_display","");
-function mod_wfs_spatialRequest_timeout(){
-function mod_wfs_spatialRequest_disableTimeout(){
-function isSetWfsResultToDigitize() {
- if (parseInt(buttonWfs_toDigitize_on)==1) return true;
- return false;
-function mod_wfs_SpatialRequest_dialog(){
- if(!mod_wfs_spatialRequest_win || mod_wfs_spatialRequest_win == null || mod_wfs_spatialRequest_win.closed == true){
- mod_wfs_spatialRequest_win = window.open("","mod_wfs_spatialRequest_win","width=200,height=150,resizable=yes");
- mod_wfs_spatialRequest_win.document.open("text/html");
- mod_wfs_spatialRequest_win.document.writeln('<script language="JavaScript" type="text/javascript">');
- mod_wfs_spatialRequest_win.document.writeln('function set(obj){');
- mod_wfs_spatialRequest_win.document.writeln('for(var i=0; i< document.getElementsByName("geom").length; i++){');
- mod_wfs_spatialRequest_win.document.writeln('if(document.getElementsByName("geom")[i].checked){');
- mod_wfs_spatialRequest_win.document.writeln('window.opener.mod_setExtRequest_geom = document.getElementsByName("geom")[i].value;');
- mod_wfs_spatialRequest_win.document.writeln('}');
- mod_wfs_spatialRequest_win.document.writeln('window.opener.wfsEnable(obj);');
- mod_wfs_spatialRequest_win.document.writeln('window.close();');
- mod_wfs_spatialRequest_win.document.writeln('return false; ');
- mod_wfs_spatialRequest_win.document.writeln('</script>');
- mod_wfs_spatialRequest_win.document.writeln("<form>");
- mod_wfs_spatialRequest_win.document.writeln("<input id='point' name='geom' type='radio' value='"+button_point+"' onclick='set(this)'> Punkt<br>");
- mod_wfs_spatialRequest_win.document.writeln("<input id='rectangle' name='geom' type='radio' value='"+button_rectangle+"' onclick='set(this)'> Rechteck<br>");
- mod_wfs_spatialRequest_win.document.writeln("<input id='polygon' name='geom' type='radio' value='"+button_polygon+"'onclick='set(this)'> Polygon<br>");
- mod_wfs_spatialRequest_win.document.writeln("<input id='extent' name='geom' type='radio' value='"+button_extent+"'onclick='set(this)'> Extent<br>");
- var checked = "";
- mod_wfs_spatialRequest_win.document.writeln("</form>");
- mod_wfs_spatialRequest_win.document.close();
- else{
- mod_wfs_spatialRequest_win.focus();
-function mb_setwfsrequest(target,queryGeom){
- if (typeof(wfsPopup) != "undefined") {
- wfsPopup.hide();
- //mb_wfs_reset();
- var ind = getMapObjIndexByName(target);
- var db_wfs_conf_id = [];
- js_wfs_conf_id = [];
- _geomArray = new GeometryArray();
- if (typeof(resultGeometryPopup) != "undefined") {
- resultGeometryPopup.hide();
- wfs_config = window.frames["wfs_conf"].get_wfs_conf();
- for (var i=0; i<mb_mapObj[ind].wms.length; i++){
- for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
- var o = mb_mapObj[ind].wms[i].objLayer[ii];
- if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_visible == '1'){
- // db_wfs_conf_id entries have to be unique
- var exists = false;
- for (var iii = 0; iii < db_wfs_conf_id.length; iii++) {
- if (db_wfs_conf_id[iii] == o.gui_layer_wfs_featuretype) {
- exists = true;
- break;
- if (!exists) {
- db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
- for(var i=0; i<db_wfs_conf_id.length; i++){
- for(var ii in wfs_config){
- if(wfs_config[ii]['wfs_conf_id'] == db_wfs_conf_id[i]) {
- // js_wfs_conf_id entries have to be unique
- for (var iii = 0; iii < js_wfs_conf_id.length; iii++) {
- var n = js_wfs_conf_id[iii];
- if (wfs_config[ii]['wfs_conf_id'] == wfs_config[n]['wfs_conf_id']) {
- exists = true;
- break;
- if (!exists) {
- js_wfs_conf_id[js_wfs_conf_id.length] = ii;
- numberOfAjaxCalls = js_wfs_conf_id.length;
- if(queryGeom.geomType==geomType.polygon){
- for(var i=0; i<js_wfs_conf_id.length; i++){
- var srs = wfs_config[js_wfs_conf_id[i]]['featuretype_srs'];
- var filter = "<ogc:Filter xmlns:ogc=\"http://ogc.org\" xmlns:gml=\"http://www.opengis.net/gml\">";
- if(buttonPolygon.filteroption=='within'){
- filter += "<Within><ogc:PropertyName>";
- for(var j=0; j<wfs_config[js_wfs_conf_id[i]]['element'].length; j++){
- if(wfs_config[js_wfs_conf_id[i]]['element'][j]['f_geom'] == 1){
- filter += wfs_config[js_wfs_conf_id[i]]['element'][j]['element_name'];
- filter += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
- filter += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
- for(var k=0; k<queryGeom.count(); k++){
- if(k>0) filter += " ";
- filter += queryGeom.get(k).x+","+queryGeom.get(k).y;
- filter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
- filter += "</gml:Polygon></Within>";
- else if(buttonPolygon.filteroption=='intersects'){
- filter += "<Intersects><ogc:PropertyName>";
- filter += "</ogc:PropertyName><gml:Polygon srsName='"+srs+"'>";
- filter += "</gml:Polygon></Intersects>";
- filter += '</ogc:Filter>';
- mb_get_geom(filter, i, wfs_config[js_wfs_conf_id[i]]['featuretype_name'], js_wfs_conf_id[i], db_wfs_conf_id[i]);
- else if(queryGeom.geomType==geomType.line){
- var rectangle = [];
- if(queryGeom.geomType == geomType.line){
- var rectangle = queryGeom.getBBox();
- var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>";
- if(buttonRectangle.filteroption=='within'){
- filter += rectangle[0].x+","+rectangle[0].y;
- filter += " ";
- filter += rectangle[0].x+","+rectangle[1].y;
- filter += " ";
- filter += rectangle[1].x+","+rectangle[1].y;
- filter += " ";
- filter += rectangle[1].x+","+rectangle[0].y;
- filter += " ";
- else if(buttonRectangle.filteroption=='intersects'){
- filter += " ";
- filter += " ";
- filter += " ";
- filter += " ";
- filter += "</ogc:Filter>";
- else if(queryGeom.geomType == geomType.point){
- var tmp = queryGeom.get(0);
- var mapPos = makeRealWorld2mapPos("mapframe1",tmp.x, tmp.y);
- var buffer = mb_wfs_tolerance/2;
- var mapPosXAddPix = mapPos[0] + buffer;
- var mapPosYAddPix = mapPos[1] +buffer;
- var mapPosXRemovePix = mapPos[0] - buffer;
- var mapPosYRemovePix = mapPos[1] - buffer;
- var realWorld1 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYRemovePix);
- var realWorld2 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
- var realWorld3 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
- var realWorld4 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
- filter += "</ogc:PropertyName><gml:Polygon srsName='"+srs+"'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
- filter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] + " ";
- filter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
- filter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter>";
-// highlight = new Highlight(mb_wfs_targets, highlight_tag_id, {"position":"absolute", "top":"0px", "left":"0px", "z-index":generalHighlightZIndex}, generalHighlightLineWidth);
- return true;
-function mb_get_geom(filter, index, typename, js_wfs_conf_id, db_wfs_conf_id) {
- mb_ajax_post(
- "../" + wfsResultModulePath + wfsResultModuleFilename,
- 'filter' : filter,
- 'typename' : typename,
- 'js_wfs_conf_id' : js_wfs_conf_id,
- 'db_wfs_conf_id' : db_wfs_conf_id
- function(json,status){
- var geom = new GeometryArray();
- geom.importGeoJSON(json);
- for (var i = 0; i < geom.count(); i++) {
- geom.get(i).wfs_conf = parseInt(js_wfs_conf_id);
- checkIfAllAjaxCallsFinished(geom);
-function checkIfAllAjaxCallsFinished (geom) {
- numberOfFinishedAjaxCalls++;
- if (typeof(geom) == 'object'){
- _geomArray.union(geom);
- if (numberOfFinishedAjaxCalls == numberOfAjaxCalls) {
- numberOfFinishedAjaxCalls = 0;
- mb_execWfsReadSubFunctions(_geomArray);
-function useExtentIsSet () {
- return mod_wfs_spatialRequest_useExtent;
-function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
- return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
-function Numsort (a, b) {
- return a - b;
-function getListTitle (geom) {
- wfsConfId = geom.wfs_conf;
- wfsConf = get_complete_wfs_conf();
- if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
- var resultArray = [];
- var resultName = "";
- for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
- if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1 && geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) !=false) {
- var pos = wfsConf[wfsConfId]['element'][i]['f_respos'];
- if (typeof(resultArray[pos]) != "undefined") {
- resultArray[pos] += " " + geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
- else {
- resultArray[pos] = geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
- resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
- resultArray.sort(Numsort);
- var resultName = resultArray.join(" ");
- if (resultName == "") {
- resultName = wfsConf[wfsConfId]['g_label'];
- return resultName;
- else {
- return msgObj.digitizeDefaultGeometryName;
-function appendGeometryArrayToDigitize(geom){
- parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);
- parent.tab_open(mod_digitize_elName);
-function appendGeometryToDigitize(i){
- var digitizeArray = new GeometryArray();
- digitizeArray.addCopy(_geomArray.get(i));
- parent.window.frames[mod_digitize_elName].appendGeometryArray(digitizeArray);
-function createListOfGeometries(){
- var listOfGeom = "<table style='background-color:#EEEEEE;'>\n";
- if (_geomArray.count() > 0) {
- if(buttonWfs_toDigitize_on==1){
- listOfGeom += "<tr><td style='color:black;font-size:12px;'>edit all</td>\n";
- listOfGeom += "<td><img title='edit all' src='"+buttonWfs_toDigitize_src+"' style='cursor:pointer' onclick='appendGeometryArrayToDigitize(_geomArray);'></img>";
- listOfGeom += "</td>\n</tr>\n";
- listOfGeom += "<tr>\n<td> </td>\n</tr>\n";
- for (var i = 0 ; i < _geomArray.count(); i ++) {
- if (_geomArray.get(i).get(-1).isComplete()) {
- listOfGeom += "\t<tr>\n\t\t<td style = 'color:blue;font-size:12px;cursor:pointer;'\n";
- listOfGeom += "\t\t\t onmouseover='mb_wfs_perform(\"over\",_geomArray.get("+i+"));' ";
- listOfGeom += " onmouseout='mb_wfs_perform(\"out\",_geomArray.get("+i+"))' ";
- listOfGeom += " onclick='mb_wfs_perform(\"click\",_geomArray.get("+i+")); showWfs("+i+");' ";
- var geomName = getListTitle(_geomArray.get(i));
- //if (_geomArray.get(i).geomType == geomType.polygon) {geomName += "(polygon)";}
- //else if (_geomArray.get(i).geomType == geomType.line) {geomName += "(line)";}
- //else if (_geomArray.get(i).geomType == geomType.point) {geomName += "(point)";}
- listOfGeom += ">" + geomName +"</td>";
- listOfGeom += "<td><img title='edit geometry object' src='"+buttonWfs_toDigitize_src+"' style='cursor:pointer' onclick='appendGeometryToDigitize("+i+");'></img></td>";
- listOfGeom += "\t\t</tr>\n";
- listOfGeom += "</table>\n";
- return listOfGeom;
-function displayPopup(geom){
- _geomArray = geom;
- if (typeof(resultGeometryPopup) == "undefined") {
- resultGeometryPopup = new mb_popup(searchPopupTitle,createListOfGeometries(),searchPopupWidth,searchPopupHeight,searchPopupX,searchPopupY);
- else {
- resultGeometryPopup.setWidth(searchPopupWidth);
- resultGeometryPopup.setHtml(createListOfGeometries());
- resultGeometryPopup.show();
-function showWfs(geometryIndex) {
- var wfsConfIndex = _geomArray.get(geometryIndex).wfs_conf;
- var currentWfsConf = wfsConf[wfsConfIndex];
- var resultHtml = "";
- resultHtml += "<table style='background-color:#EEEEEE;'>\n";
- for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
- if(currentWfsConf.element[i].f_show_detail==1){
- if( _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
- //console.log(currentWfsConf.element[i].element_name+"---"+currentWfsConf.element[i].f_respos);
- resultHtml +="<tr><td>\n";
- resultHtml += currentWfsConf.element[i].f_label;
- resultHtml +="</td>\n";
- resultHtml += "<td>\n";
- var elementVal = _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name);
- if(currentWfsConf.element[i].f_form_element_html.indexOf("href")!=-1){
- var setUrl = currentWfsConf.element[i].f_form_element_html.replace(/href\s*=\s*['|"]\s*['|"]/, "href='"+elementVal+"' target='_blank'");
- if(setUrl.match(/><\/a>/)){
- var newLink = setUrl.replace(/><\/a>/, ">"+elementVal+"</a>");
- else{
- var newLink = setUrl;
- if(openLinkFromSearch=='1'){
- window.open(elementVal, elementVal,"width=500, height=400,left=100,top=100,scrollbars=yes");
- resultHtml += newLink;
- else{
- resultHtml += elementVal;
- resultHtml += "</td></tr>\n";
- resultHtml += "</table>\n";
- var getCenter = _geomArray.get(geometryIndex).getCenter();
- // getMapPos for positioning of new PopupDiv near object in mapframe1
- //var getMapPos = makeRealWorld2mapPos("mapframe1",getCenter.x, getCenter.y);
- if (typeof(wfsPopup) == "undefined") {
- wfsPopup = new mb_popup(detailPopupTitle,resultHtml,detailPopupWidth,detailPopupHeight,detailPopupX,detailPopupY);
- else {
- wfsPopup.hide();
- wfsPopup.show();
-try{
- if (wfsResultToPopupDiv){}
-catch(e){
- wfsResultToPopupDiv =0;
-if(wfsResultToPopupDiv==1){
- mb_registerWfsReadSubFunctions(function(geom){displayPopup(geom);});
+<?php
+#$Id$
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_wfs_spatialRequest.php,v 1.4 2006/03/08 15:26:26 c_baudson Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+$wfs_conf_filename = "wfs_default.conf";
+include '../include/dyn_php.php';
+$fname = dirname(__FILE__) . "/../../conf/" . $wfs_conf_filename;
+if (file_exists($fname)) {
+ include($fname);
+else {
+ $e = new mb_exception("mod_wfs_SpatialRequest.php: Configuration file " . $wfs_conf_filename . " not found.");
+include '../include/dyn_js.php';
+echo "var mod_wfs_spatialRequest_target = '".$e_target[0]."';\n";
+//element var openLinkFromSearch for opening attribute link directly onclick of searchResult entry
+try{
+ if (openLinkFromSearch){}
+catch(e){
+ openLinkFromSearch =0;
+var wfsAreaType_point = "point";
+var wfsAreaType_polygon = "polygon";
+var wfsAreaType_rectangle = "rectangle";
+var wfsAreaType_extent = "extent";
+var wfsAreaType_current = "";
+var mod_wfs_spatialRequest_frameName = "";
+var mod_wfs_spatialRequest_epsg;
+var mod_wfs_spatialRequest_width;
+var mod_wfs_spatialRequest_height;
+var mod_wfs_spatialRequest_bg = "";
+var mod_wfs_spatialRequest_pgsql = true;
+var mod_wfs_spatialRequest_win = null;
+var mod_wfs_spatialRequest_thema = false;
+var button_point = "point";
+var button_polygon = "polygon";
+var button_rectangle = "rectangle";
+var button_extent = "extent";
+var button_dialogue = "dialogue";
+var activeButton = null;
+var mod_wfs_spatialRequestSubFunctions = [];
+var buttonWfs_id = [];
+var buttonWfs_on = [];
+var buttonWfs_src = [];
+var buttonWfs_title_off = [];
+var buttonWfs_title_on = [];
+var buttonWfs_x = [];
+var buttonWfs_y = [];
+var numberOfAjaxCalls = 0;
+var numberOfFinishedAjaxCalls = 0;
+var resultGeometryPopup;
+ * This Geometry contains the geometry of the optinal spatial constraint
+var requestGeom = null;
+ * Something like box, polygon, point, extent
+var spatialRequestType = null;
+ * This Geometry contains the result from the WFS request
+var geomArray;
+try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+function addButtonWfs(id, isOn, src, title, x, y) {
+ buttonWfs_id.push(id);
+ buttonWfs_on.push(isOn);
+ buttonWfs_src.push(src);
+ buttonWfs_title_off.push(title);
+ buttonWfs_title_on.push(title);
+ buttonWfs_x.push(x);
+ buttonWfs_y.push(y);
+var msgObj;
+mb_registerInitFunctions("init_wfsSpatialRequest()");
+//mb_registerL10nFunctions("init_wfsSpatialRequest()");
+function init_wfsSpatialRequest() {
+ mb_ajax_json("../php/mod_wfsSpatialRequest_messages.php", function(obj, status) {
+ msgObj = obj;
+ buttonWfs_id = [];
+ buttonWfs_on = [];
+ buttonWfs_src = [];
+ buttonWfs_title_off = [];
+ buttonWfs_title_on = [];
+ buttonWfs_x = [];
+ buttonWfs_y = [];
+ addButtonWfs("rectangle", buttonRectangle.status, buttonRectangle.img, msgObj.buttonLabelRectangle, buttonRectangle.x, buttonRectangle.y);
+ addButtonWfs("polygon", buttonPolygon.status, buttonPolygon.img, msgObj.buttonLabelPolygon, buttonPolygon.x, buttonPolygon.y);
+ addButtonWfs("point", buttonPoint.status, buttonPoint.img, msgObj.buttonLabelPoint, buttonPoint.x, buttonPoint.y);
+ addButtonWfs("extent", buttonExtent.status, buttonExtent.img, msgObj.buttonLabelExtent, buttonExtent.x, buttonExtent.y);
+ addButtonWfs("dialogue", buttonDialogue.status, buttonDialogue.img, msgObj.buttonLabelDialogue, buttonDialogue.x, buttonDialogue.y);
+ displayButtons();
+// ------------ button handling -------------------------------------------------------------
+function wfsInitFunction (j) {
+ var functionCall = "mb_regButton_frame('initWfsButton', null, "+j+")";
+ var x = new Function ("", functionCall);
+ x();
+function displayButtons() {
+ for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
+ if (parseInt(buttonWfs_on[i])==1) {
+ var currentDiv = document.createElement("div");
+ currentDiv.id = buttonWfs_id[i]+"Div";
+ currentDiv.style.position = "absolute";
+ currentDiv.style.left = buttonWfs_x[i]
+ currentDiv.style.top = buttonWfs_y[i];
+ currentDiv.style.zIndex = buttonWfs_zIndex;
+ var currentImg = document.createElement("img");
+ currentImg.id = buttonWfs_id[i];
+ currentImg.name = buttonWfs_id[i];
+ currentImg.title = buttonWfs_title_off[i];
+ currentImg.src = buttonWfs_imgdir+buttonWfs_src[i];
+ currentImg.onmouseover = new Function("wfsInitFunction("+i+")");
+ currentDiv.appendChild(currentImg);
+ document.getElementsByTagName('body')[0].appendChild(currentDiv);
+function initWfsButton(ind, pos) {
+ mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
+ mb_button[ind].img_over = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_over");
+ mb_button[ind].img_on = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_on");
+ mb_button[ind].img_off = buttonWfs_imgdir + buttonWfs_src[pos];
+ mb_button[ind].status = 0;
+ mb_button[ind].elName = buttonWfs_id[pos];
+ mb_button[ind].fName = "";
+ mb_button[ind].go = new Function ("wfsEnable(mb_button["+ind+"], " + pos + ")");
+ mb_button[ind].stop = new Function ("wfsDisable(mb_button["+ind+"], " + pos + ")");
+ var ind = getMapObjIndexByName(mod_wfs_spatialRequest_target);
+ mod_wfs_spatialRequest_width = mb_mapObj[ind].width;
+ mod_wfs_spatialRequest_height = mb_mapObj[ind].height;
+ mod_wfs_spatialRequest_epsg = mb_mapObj[ind].epsg;
+ mb_registerSubFunctions("drawDashedLineExt()");
+ mb_registerPanSubElement("measuring");
+ geomArray = new GeometryArray();
+function wfsEnable(obj) {
+ var el = getMapDoc();
+ el.onmouseover = null;
+ el.onmousedown = null;
+ el.onmouseup = null;
+ el.onmousemove = null;
+ if (obj.id == button_point) {
+ if (activeButton == null) {
+ activeButton = obj;
+ if (obj.id == button_polygon) {
+ else if (obj.id == button_rectangle){
+ else if (obj.id == button_extent){
+ else if (obj.id == button_dialogue) {
+ mod_wfs_SpatialRequest_dialog();
+ callRequestGeometryConstructor(obj.id,"mapframe1");
+function callRequestGeometryConstructor(selectedType,target){
+ spatialRequestType = selectedType;
+ var geometryConstructor = new RequestGeometryConstructor(target);
+ geometryConstructor.getGeometry(selectedType,function(target,queryGeom){
+ if(queryGeom !=''){
+ requestGeom = queryGeom;
+ mb_disableThisButton(selectedType);
+ // requestGeom is a Geometry, but for the highlight
+ // a MultiGeometry is needed.
+ var multiGeom;
+ // a line represents a bbox...but highlight must be a polyon
+ // (extent or box selection)
+ if (requestGeom.geomType == geomType.line) {
+ multiGeom = new MultiGeometry(geomType.polygon);
+ newGeom = new Geometry(geomType.polygon);
+ var p1 = requestGeom.get(0);
+ var p2 = requestGeom.get(1);
+ newGeom.addPoint(p1);
+ newGeom.addPointByCoordinates(p1.x, p2.y);
+ newGeom.addPoint(p2);
+ newGeom.addPointByCoordinates(p2.x, p1.y);
+ newGeom.close();
+ multiGeom.add(newGeom);
+ // standard case
+ // (polygon and point selection)
+ else {
+ multiGeom = new MultiGeometry(requestGeom.geomType);
+ multiGeom.add(requestGeom);
+ // add highlight of geometry
+ //requestGeometryHighlight.add(multiGeom);
+ //requestGeometryHighlight.paint();
+function getMapDoc () {
+ var mapIndex = getMapObjIndexByName(mod_wfs_spatialRequest_target);
+ var mapDomElement = mb_mapObj[mapIndex].getDomElement();
+ var mapType = mapDomElement.tagName.toUpperCase();
+ if (mapType == "IFRAME") {
+ return mapDomElement.window.document;
+ return window.document;
+function wfsDisable(obj) {
+ var ind = getMapObjIndexByName("mapframe1");
+ var el = mb_mapObj[ind].getDomElement();
+ el.ondblclick = null;
+ activeButton = null;
+ writeTag("","measure_display","");
+ writeTag("","measure_sub","");
+ mb_setwfsrequest(mod_wfs_spatialRequest_target);
+function register_setExtRequestSubFunctions(stringFunction){
+ mod_wfs_spatialRequestSubFunctions[mod_wfs_spatialRequestSubFunctions.length] = stringFunction;
+function isSetWfsResultToDigitize() {
+ if (parseInt(buttonWfs_toDigitize_on)==1) return true;
+ return false;
+function mod_wfs_SpatialRequest_dialog(){
+ if(!mod_wfs_spatialRequest_win || mod_wfs_spatialRequest_win == null || mod_wfs_spatialRequest_win.closed == true){
+ mod_wfs_spatialRequest_win = window.open("","mod_wfs_spatialRequest_win","width=200,height=150,resizable=yes");
+ mod_wfs_spatialRequest_win.document.open("text/html");
+ mod_wfs_spatialRequest_win.document.writeln('<script language="JavaScript" type="text/javascript">');
+ mod_wfs_spatialRequest_win.document.writeln('function set(obj){');
+ mod_wfs_spatialRequest_win.document.writeln('for(var i=0; i< document.getElementsByName("geom").length; i++){');
+ mod_wfs_spatialRequest_win.document.writeln('if(document.getElementsByName("geom")[i].checked){');
+ mod_wfs_spatialRequest_win.document.writeln('window.opener.mod_setExtRequest_geom = document.getElementsByName("geom")[i].value;');
+ mod_wfs_spatialRequest_win.document.writeln('}');
+ mod_wfs_spatialRequest_win.document.writeln('window.opener.wfsEnable(obj);');
+ mod_wfs_spatialRequest_win.document.writeln('window.close();');
+ mod_wfs_spatialRequest_win.document.writeln('return false; ');
+ mod_wfs_spatialRequest_win.document.writeln('</script>');
+ mod_wfs_spatialRequest_win.document.writeln("<form>");
+ mod_wfs_spatialRequest_win.document.writeln("<input id='point' name='geom' type='radio' value='"+button_point+"' onclick='set(this)'> Punkt<br>");
+ mod_wfs_spatialRequest_win.document.writeln("<input id='rectangle' name='geom' type='radio' value='"+button_rectangle+"' onclick='set(this)'> Rechteck<br>");
+ mod_wfs_spatialRequest_win.document.writeln("<input id='polygon' name='geom' type='radio' value='"+button_polygon+"'onclick='set(this)'> Polygon<br>");
+ mod_wfs_spatialRequest_win.document.writeln("<input id='extent' name='geom' type='radio' value='"+button_extent+"'onclick='set(this)'> Extent<br>");
+ var checked = "";
+ mod_wfs_spatialRequest_win.document.writeln("</form>");
+ mod_wfs_spatialRequest_win.document.close();
+ else{
+ mod_wfs_spatialRequest_win.focus();
+function mb_setwfsrequest(target){
+ if(geomArray.count()>0){
+ geomArray.empty();
+ if (typeof(wfsPopup) != "undefined") {
+ wfsPopup.destroy();
+ //mb_wfs_reset();
+ var ind = getMapObjIndexByName(target);
+ var db_wfs_conf_id = [];
+ js_wfs_conf_id = [];
+ if (typeof(resultGeometryPopup) != "undefined") {
+ resultGeometryPopup.destroy();
+ wfs_config = window.frames["wfs_conf"].get_wfs_conf();
+ for (var i=0; i<mb_mapObj[ind].wms.length; i++){
+ for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
+ var o = mb_mapObj[ind].wms[i].objLayer[ii];
+ if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_visible == '1'){
+ // db_wfs_conf_id entries have to be unique
+ var exists = false;
+ for (var iii = 0; iii < db_wfs_conf_id.length; iii++) {
+ if (db_wfs_conf_id[iii] == o.gui_layer_wfs_featuretype) {
+ exists = true;
+ break;
+ if (!exists) {
+ db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
+ for(var i=0; i<db_wfs_conf_id.length; i++){
+ for(var ii in wfs_config){
+ if(wfs_config[ii]['wfs_conf_id'] == db_wfs_conf_id[i]) {
+ // js_wfs_conf_id entries have to be unique
+ for (var iii = 0; iii < js_wfs_conf_id.length; iii++) {
+ var n = js_wfs_conf_id[iii];
+ if (wfs_config[ii]['wfs_conf_id'] == wfs_config[n]['wfs_conf_id']) {
+ exists = true;
+ break;
+ if (!exists) {
+ js_wfs_conf_id[js_wfs_conf_id.length] = ii;
+ numberOfAjaxCalls = js_wfs_conf_id.length;
+ if(requestGeom!=null){
+ if(requestGeom.geomType==geomType.polygon){
+ for(var i=0; i<js_wfs_conf_id.length; i++){
+ var srs = wfs_config[js_wfs_conf_id[i]]['featuretype_srs'];
+ var filter = "<ogc:Filter xmlns:ogc=\"http://ogc.org\" xmlns:gml=\"http://www.opengis.net/gml\">";
+ if(buttonPolygon.filteroption=='within'){
+ filter += "<Within><ogc:PropertyName>";
+ for(var j=0; j<wfs_config[js_wfs_conf_id[i]]['element'].length; j++){
+ if(wfs_config[js_wfs_conf_id[i]]['element'][j]['f_geom'] == 1){
+ filter += wfs_config[js_wfs_conf_id[i]]['element'][j]['element_name'];
+ filter += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
+ filter += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ for(var k=0; k<requestGeom.count(); k++){
+ if(k>0) filter += " ";
+ filter += requestGeom.get(k).x+","+requestGeom.get(k).y;
+ filter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+ filter += "</gml:Polygon></Within>";
+ else if(buttonPolygon.filteroption=='intersects'){
+ filter += "<Intersects><ogc:PropertyName>";
+ filter += "</ogc:PropertyName><gml:Polygon srsName='"+srs+"'>";
+ filter += "</gml:Polygon></Intersects>";
+ filter += '</ogc:Filter>';
+ mb_get_geom(filter, i, wfs_config[js_wfs_conf_id[i]]['featuretype_name'], js_wfs_conf_id[i], db_wfs_conf_id[i]);
+ else if(requestGeom.geomType==geomType.line){
+ var rectangle = [];
+ if(requestGeom.geomType == geomType.line){
+ var rectangle = requestGeom.getBBox();
+ var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>";
+ if(buttonRectangle.filteroption=='within'){
+ filter += rectangle[0].x+","+rectangle[0].y;
+ filter += " ";
+ filter += rectangle[0].x+","+rectangle[1].y;
+ filter += " ";
+ filter += rectangle[1].x+","+rectangle[1].y;
+ filter += " ";
+ filter += rectangle[1].x+","+rectangle[0].y;
+ filter += " ";
+ else if(buttonRectangle.filteroption=='intersects'){
+ filter += " ";
+ filter += " ";
+ filter += " ";
+ filter += " ";
+ filter += "</ogc:Filter>";
+ else if(requestGeom.geomType == geomType.point){
+ var tmp = requestGeom.get(0);
+ var mapPos = makeRealWorld2mapPos("mapframe1",tmp.x, tmp.y);
+ var buffer = mb_wfs_tolerance/2;
+ var mapPosXAddPix = mapPos[0] + buffer;
+ var mapPosYAddPix = mapPos[1] +buffer;
+ var mapPosXRemovePix = mapPos[0] - buffer;
+ var mapPosYRemovePix = mapPos[1] - buffer;
+ var realWorld1 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYRemovePix);
+ var realWorld2 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
+ var realWorld3 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
+ var realWorld4 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
+ filter += "</ogc:PropertyName><gml:Polygon srsName='"+srs+"'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ filter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] + " ";
+ filter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+ filter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter>";
+// highlight = new Highlight(mb_wfs_targets, highlight_tag_id, {"position":"absolute", "top":"0px", "left":"0px", "z-index":generalHighlightZIndex}, generalHighlightLineWidth);
+ return true;
+function mb_get_geom(filter, index, typename, js_wfs_conf_id, db_wfs_conf_id) {
+ mb_ajax_post(
+ "../" + wfsResultModulePath + wfsResultModuleFilename,
+ 'filter' : filter,
+ 'typename' : typename,
+ 'js_wfs_conf_id' : js_wfs_conf_id,
+ 'db_wfs_conf_id' : db_wfs_conf_id
+ function(json,status){
+ var geom = new GeometryArray();
+ geom.importGeoJSON(json);
+ for (var i = 0; i < geom.count(); i++) {
+ geom.get(i).wfs_conf = parseInt(js_wfs_conf_id);
+ checkIfAllAjaxCallsFinished(geom);
+function checkIfAllAjaxCallsFinished (geom) {
+ numberOfFinishedAjaxCalls++;
+ if (typeof(geom) == 'object'){
+ geomArray.union(geom);
+ if (numberOfFinishedAjaxCalls == numberOfAjaxCalls) {
+ numberOfFinishedAjaxCalls = 0;
+ mb_execWfsReadSubFunctions(geomArray);
+function useExtentIsSet () {
+ return mod_wfs_spatialRequest_useExtent;
+function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
+ return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
+function Numsort (a, b) {
+ return a - b;
+function getListTitle (geom) {
+ wfsConfId = geom.wfs_conf;
+ wfsConf = get_complete_wfs_conf();
+ if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
+ var resultArray = [];
+ var resultName = "";
+ for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+ if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1 && geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) !=false) {
+ var pos = wfsConf[wfsConfId]['element'][i]['f_respos'];
+ if (typeof(resultArray[pos]) != "undefined") {
+ resultArray[pos] += " " + geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
+ else {
+ resultArray[pos] = geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
+ resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
+ resultArray.sort(Numsort);
+ var resultName = resultArray.join(" ");
+ if (resultName == "") {
+ resultName = wfsConf[wfsConfId]['g_label'];
+ return resultName;
+ else {
+ return msgObj.digitizeDefaultGeometryName;
+function appendGeometryArrayToDigitize(geom){
+ parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);
+ parent.tab_open(mod_digitize_elName);
+function appendGeometryToDigitize(i){
+ var digitizeArray = new GeometryArray();
+ digitizeArray.addCopy(geomArray.get(i));
+ parent.window.frames[mod_digitize_elName].appendGeometryArray(digitizeArray);
+function createListOfGeometries(){
+ var listOfGeom = "<table style='background-color:#EEEEEE;'>\n";
+ if (geomArray.count() > 0) {
+ if(buttonWfs_toDigitize_on==1){
+ listOfGeom += "<tr><td style='color:black;font-size:12px;'>edit all</td>\n";
+ listOfGeom += "<td><img title='edit all' src='"+buttonWfs_toDigitize_src+"' style='cursor:pointer' onclick='appendGeometryArrayToDigitize(geomArray);'></img>";
+ listOfGeom += "</td>\n</tr>\n";
+ listOfGeom += "<tr>\n<td> </td>\n</tr>\n";
+ for (var i = 0 ; i < geomArray.count(); i ++) {
+ if (geomArray.get(i).get(-1).isComplete()) {
+ listOfGeom += "\t<tr>\n\t\t<td style = 'color:blue;font-size:12px;cursor:pointer;'\n";
+ listOfGeom += "\t\t\t onmouseover='mb_wfs_perform(\"over\",geomArray.get("+i+"));' ";
+ listOfGeom += " onmouseout='mb_wfs_perform(\"out\",geomArray.get("+i+"))' ";
+ listOfGeom += " onclick='mb_wfs_perform(\"click\",geomArray.get("+i+")); showWfs("+i+");' ";
+ var geomName = getListTitle(geomArray.get(i));
+ //if (geomArray.get(i).geomType == geomType.polygon) {geomName += "(polygon)";}
+ //else if (geomArray.get(i).geomType == geomType.line) {geomName += "(line)";}
+ //else if (geomArray.get(i).geomType == geomType.point) {geomName += "(point)";}
+ listOfGeom += ">" + geomName +"</td>";
+ listOfGeom += "<td><img title='edit geometry object' src='"+buttonWfs_toDigitize_src+"' style='cursor:pointer' onclick='appendGeometryToDigitize("+i+");'></img></td>";
+ listOfGeom += "\t\t</tr>\n";
+ listOfGeom += "</table>\n";
+ return listOfGeom;
+function displayPopup(geom){
+ geomArray = geom;
+ if (typeof(resultGeometryPopup) == "undefined") {
+ resultGeometryPopup = new mb_popup(searchPopupTitle,createListOfGeometries(),searchPopupWidth,searchPopupHeight,searchPopupX,searchPopupY);
+ else {
+ resultGeometryPopup.setWidth(searchPopupWidth);
+ resultGeometryPopup.setHtml(createListOfGeometries());
+ resultGeometryPopup.show();
+function showWfs(geometryIndex) {
+ var wfsConfIndex = geomArray.get(geometryIndex).wfs_conf;
+ var currentWfsConf = wfsConf[wfsConfIndex];
+ var resultHtml = "";
+ resultHtml += "<table style='background-color:#EEEEEE;'>\n";
+ for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
+ if(currentWfsConf.element[i].f_show_detail==1){
+ if( geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
+ //console.log(currentWfsConf.element[i].element_name+"---"+currentWfsConf.element[i].f_respos);
+ resultHtml +="<tr><td>\n";
+ resultHtml += currentWfsConf.element[i].f_label;
+ resultHtml +="</td>\n";
+ resultHtml += "<td>\n";
+ var elementVal = geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name);
+ if(currentWfsConf.element[i].f_form_element_html.indexOf("href")!=-1){
+ var setUrl = currentWfsConf.element[i].f_form_element_html.replace(/href\s*=\s*['|"]\s*['|"]/, "href='"+elementVal+"' target='_blank'");
+ if(setUrl.match(/><\/a>/)){
+ var newLink = setUrl.replace(/><\/a>/, ">"+elementVal+"</a>");
+ else{
+ var newLink = setUrl;
+ if(openLinkFromSearch=='1'){
+ window.open(elementVal, elementVal,"width=500, height=400,left=100,top=100,scrollbars=yes");
+ resultHtml += newLink;
+ else{
+ resultHtml += elementVal;
+ resultHtml += "</td></tr>\n";
+ resultHtml += "</table>\n";
+ var getCenter = geomArray.get(geometryIndex).getCenter();
+ // getMapPos for positioning of new PopupDiv near object in mapframe1
+ //var getMapPos = makeRealWorld2mapPos("mapframe1",getCenter.x, getCenter.y);
+ if (typeof(wfsPopup) == "undefined") {
+ wfsPopup = new mb_popup(detailPopupTitle,resultHtml,detailPopupWidth,detailPopupHeight,detailPopupX,detailPopupY);
+ else {
+ wfsPopup.hide();
+ wfsPopup.show();
+try{
+ if (wfsResultToPopupDiv){}
+catch(e){
+ wfsResultToPopupDiv =0;
+if(wfsResultToPopupDiv==1){
+ mb_registerWfsReadSubFunctions(function(geom){displayPopup(geom);});
More information about the Mapbender_commits
