[Mapbender-commits] r3622 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Mar 3 03:25:06 EST 2009
Author: astrid_emde
Date: 2009-03-03 03:25:06 -0500 (Tue, 03 Mar 2009)
New Revision: 3622
Added:
trunk/mapbender/http/php/mod_createCategory.php
skript to create gui-categories
http://trac.osgeo.org/mapbender/ticket/344
http://www.mapbender.org/GUI_Category
Added: trunk/mapbender/http/php/mod_createCategory.php
--- trunk/mapbender/http/php/mod_createCategory.php (rev 0)
+++ trunk/mapbender/http/php/mod_createCategory.php 2009-03-03 08:25:06 UTC (rev 3622)
@@ -0,0 +1,127 @@
+<?php
+# $Id:$
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>New Category</title>
+<?php include '../include/dyn_css.php'; ?>
+<?php
+if(isset($newCategory) && $newCategory != ""){
+ $sql = "SELECT category_name FROM gui_category WHERE category_name = $1";
+ $v = array($newCategory);
+ $t = array('s');
+ $res = db_prep_query($sql,$v,$t);
+ if(db_fetch_row($res)){
+ echo "<script type='text/javascript'>";
+ echo "alert('Error: Category already exists!');";
+ echo "</script>";
+ else{
+ $sql = "INSERT INTO gui_category (category_name,category_description) ";
+ $sql .= "VALUES($1, $2)";
+ $v = array($newCategory,$newDesc);
+ $t = array('s','s');
+ $categoryCreated=true;
+<script type="text/javascript">
+function setFocus(){
+ document.form1.newCategory.focus();
+function validate(){
+ if(document.form1.newCategory.value == ""){
+ alert("<?php echo _mb("Please enter a category name!")?>");
+ return;
+ else if(document.form1.newDesc.value == ""){
+ alert("<?php echo _mb("Please enter a category description!")?>");
+ document.form1.newDesc.focus();
+ return;
+ else{
+ document.form1.submit();
+</script>
+</head>
+<body onload='setFocus()'>
+<form name='form1' action="<?php echo $self; ?>" method="POST">
+<?php
+ $v = array();
+ $t = array();
+ $c = 1;
+ $sql = "SELECT * from gui_category";
+ $sql .= " order by lower(category_name);";
+ $count=0;
+ while($row = db_fetch_array($res)){
+ $category_name[$count]= $row["category_name"];
+ $category_description[$count]=$row["category_description"];
+ $count++;
+ echo "<p\n";
+ echo "<div class= 'guiList1_text'>"._mb("existing Categories").":</div>\n";
+#echo "<select class='categoryList' size='14' name='categoryList' onchange='setCategory(this.value)'>\n";
+ echo "<select class='categoryList' size='14' name='categoryList' onchange=''>\n";
+ for ($i=0; $i<count($category_name);$i++){
+ echo "<option value='".$category_name[$i]."' ";
+ echo ">".$category_name[$i]. " - ".$category_description[$i]."</option>\n";
+ echo "</select>\n";
+ echo "</p\n";
+<table>
+<tr><td><?php echo _mb("Category Name"); ?>: </td><td><input type='text' name='newCategory'></td></tr>
+<tr><td><?php echo _mb("Description"); ?>: </td><td><input type='text' name='newDesc'></td></tr>
+<tr><td></td><td><input type='button' onclick='validate()' value="<?php echo _mb("new"); ?>"></td></tr>
+</table>
+<?php
+ if ($categoryCreated==true){
+ echo "<p class = 'categroyList'>";
+ echo "<b>".$newCategory."</b> - "._mb("The Category has been created successfully.");
+ echo "<p>";
+ }else{
+ echo"error";
+</form>
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
