[Mapbender-commits] r3638 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Mar 6 08:31:50 EST 2009
Author: verenadiewald
Date: 2009-03-06 08:31:49 -0500 (Fri, 06 Mar 2009)
New Revision: 3638
trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php
bug fix show popup + don't show windows or popups if featureInfo is empty
Modified: trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php
--- trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php 2009-03-06 09:07:18 UTC (rev 3637)
+++ trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php 2009-03-06 13:31:49 UTC (rev 3638)
@@ -57,14 +57,13 @@
mod_featureInfoTunnel_map.getDomElement().onclick = null;
function mod_featureInfoTunnel_event(e){
- mod_featureInfoTunnel_map.getMousePos(e);
eventBeforeFeatureInfo.trigger({"fName":mod_featureInfoTunnel_target});
var point = mod_featureInfoTunnel_map.getMousePos(e);
var path = '../extensions/ext_featureInfoTunnel.php';
//TODO that code should go to featureInfo Redirect module
+ var ind = getMapObjIndexByName(mod_featureInfoTunnel_target);
if(document.getElementById("FeatureInfoRedirect")){
//fill the frames
for(var i=0; i<mod_featureInfoTunnel_map.wms.length; i++){
@@ -77,22 +76,33 @@
urls = mod_featureInfoTunnel_map.getFeatureInfoRequests(point);
if(urls){
for(var i=0;i<urls.length;i++){
- if(featureInfoLayerPopup == 'true'){
- var p = new mb_popup({
- title:<?php echo _mb("Informations");?>,
- url:path+"?url="+escape(urls[i]),
- width:parseInt(featureInfoPopupWidth, 10),
- height:parseInt(featureInfoPopupHeight, 10),
- top:200,
- left:600
+ (function () {
+ var currentRequest = escape(urls[i]);
+ mb_ajax_post(path, {'url':currentRequest},function(js_code,status){
+ if(js_code){
+ if(featureInfoLayerPopup == 'true'){
+ var p = new mb_popup({
+ title:"Information",
+ url:path+"?url="+currentRequest,
+ width:parseInt(featureInfoPopupWidth, 10),
+ height:parseInt(featureInfoPopupHeight, 10),
+ top:200 + i*25,
+ left:600 + i*25
+ p.show();
+ else{
+ window.open(path+"?url="+currentRequest, "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
+ else{
+ var e = new Mb_exception("No featureInfo results.");
- else
- window.open(path+"?url="+escape(urls[i]), "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
else
alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
-// setFeatureInfoRequest(mod_featureInfoTunnel_target,clickX,clickY, '../extensions/ext_featureInfoTunnel.php');
More information about the Mapbender_commits
