[Mapbender-commits] r3642 - trunk/mapbender/resources/db/update
    svn_mapbender at osgeo.org
    Fri Mar  6 10:37:08 EST 2009
Author: astrid_emde
Date: 2009-03-06 10:37:07 -0500 (Fri, 06 Mar 2009)
New Revision: 3642
   trunk/mapbender/resources/db/update/update_2.6.sql
increase size for columns: gui_element.e_js_file , e_mb_mod, e_requires
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-03-06 14:57:29 UTC (rev 3641)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-03-06 15:37:07 UTC (rev 3642)
@@ -390,4 +390,10 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
\ No newline at end of file
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+-- increase size
+ALTER TABLE gui_element ALTER e_js_file TYPE varchar(255);
+ALTER TABLE gui_element ALTER  e_mb_mod  TYPE varchar(255);
+ALTER TABLE gui_element ALTER  e_requires  TYPE varchar(255);
More information about the Mapbender_commits
