[Mapbender-commits] r3650 - in branches/print_dev/http/print: .
	classes
    svn_mapbender at osgeo.org
    Mon Mar  9 07:16:06 EDT 2009
Author: mschulz
Date: 2009-03-09 07:16:06 -0400 (Mon, 09 Mar 2009)
New Revision: 3650
Added:
   branches/print_dev/http/print/classes/mbImageDecorator.php
   branches/print_dev/http/print/classes/mbMapDecorator.php
   branches/print_dev/http/print/classes/mbOverviewDecorator.php
   branches/print_dev/http/print/classes/mbTemplatePdf.php
   branches/print_dev/http/print/testConfigTemplate.json
added image decorator class (logo, northarrow), fixed bug in mbOverviewDecorator
Added: branches/print_dev/http/print/classes/mbImageDecorator.php
--- branches/print_dev/http/print/classes/mbImageDecorator.php	                        (rev 0)
+++ branches/print_dev/http/print/classes/mbImageDecorator.php	2009-03-09 11:16:06 UTC (rev 3650)
@@ -0,0 +1,27 @@
+<?php
+class mbImageDecorator extends mbTemplatePdfDecorator {
+	protected $pageElementType = "image";
+	protected $elementId;
+	public function __construct($pdfObj, $elementId, $mapConf, $controls) {
+		parent::__construct($pdfObj, $mapConf, $controls);
+		$this->elementId = $elementId;
+		$this->override();
+		$this->decorate();
+	public function override() {}
+	public function decorate() {
+		$width = $this->conf->width;
+		$height = $this->conf->height;
+		$filename = $this->conf->filename;
+		$this->pdf->objPdf->Image($this->conf->filename, $this->conf->x_ul, $this->conf->y_ul);
Modified: branches/print_dev/http/print/classes/mbMapDecorator.php
--- branches/print_dev/http/print/classes/mbMapDecorator.php	2009-03-09 09:08:08 UTC (rev 3649)
+++ branches/print_dev/http/print/classes/mbMapDecorator.php	2009-03-09 11:16:06 UTC (rev 3650)
@@ -53,8 +53,7 @@
 		$res = $this->pdf->objPdf->k * ($this->res_dpi/72);
 		$myURL = new stripRequest($array_urls[0]);
 		$e = new mb_notice("mbMapDecorator: original bbox: ".$myURL->get('BBOX'));
-		#$this->pdf->setMapExtent($this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
-		$this->pdf->setMapInfo($this->conf->x_ul, $this->conf->y_ul, $width, $height, $this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
+		$this->pdf->setMapInfo($this->conf->x_ul, $this->conf->y_ul, $width, $height, $this->pdf->adjustBbox($this->conf, explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
 		$e = new mb_notice("mbMapDecorator: adjusted bbox: ".$this->pdf->getMapExtent());
 		for($i=0; $i<count($array_urls); $i++){
 			$m = new stripRequest($array_urls[$i]);
@@ -67,16 +66,7 @@
 		$i = new weldMaps2PNG(implode("___",$array_urls), $this->filename);
 		$this->pdf->objPdf->Image($this->filename, $this->conf->x_ul, $this->conf->y_ul, $width, $height,'png');
-	protected function adjustBbox($aBboxArray, $aSrsString) {
-		$aMbBbox = new Mapbender_bbox($aBboxArray[0],$aBboxArray[1],$aBboxArray[2],$aBboxArray[3],$aSrsString);
-		$aMap = new Map();
-		$aMap->setWidth($this->conf->width);
-		$aMap->setHeight($this->conf->height);
-		$aMap->calculateExtent($aMbBbox);
-		$adjustedMapExt = $aMap->getExtentInfo();
-		return implode(",",$adjustedMapExt);
\ No newline at end of file
Modified: branches/print_dev/http/print/classes/mbOverviewDecorator.php
--- branches/print_dev/http/print/classes/mbOverviewDecorator.php	2009-03-09 09:08:08 UTC (rev 3649)
+++ branches/print_dev/http/print/classes/mbOverviewDecorator.php	2009-03-09 11:16:06 UTC (rev 3650)
@@ -27,6 +27,7 @@
 		$res = $this->pdf->objPdf->k*($this->conf->res_dpi/72);
 		$o_url->set('width',intval($width*$res));
 		$o_url->set('height',intval($height*$res));
+		$o_url->set('bbox', $this->pdf->adjustBbox($this->conf, explode(",",$o_url->get('BBOX')), $o_url->get('srs')));
 		$overview_url = $o_url->url;
 		$urls = $_REQUEST["map_url"];
Modified: branches/print_dev/http/print/classes/mbTemplatePdf.php
--- branches/print_dev/http/print/classes/mbTemplatePdf.php	2009-03-09 09:08:08 UTC (rev 3649)
+++ branches/print_dev/http/print/classes/mbTemplatePdf.php	2009-03-09 11:16:06 UTC (rev 3650)
@@ -41,6 +41,16 @@
 		$e = new mb_notice("mbTemplatePdf: getting mapExtent as ".$this->mapinfo["extent"]);
 		return $this->mapinfo["extent"];
+	public function adjustBbox($elementConf, $aBboxArray, $aSrsString) {
+		$aMbBbox = new Mapbender_bbox($aBboxArray[0],$aBboxArray[1],$aBboxArray[2],$aBboxArray[3],$aSrsString);
+		$aMap = new Map();
+		$aMap->setWidth($elementConf->width);
+		$aMap->setHeight($elementConf->height);
+		$aMap->calculateExtent($aMbBbox);
+		$adjustedMapExt = $aMap->getExtentInfo();
+		return implode(",",$adjustedMapExt);
 	public function render() {
 		foreach ($this->confPdf->pages as $pageConf) {
@@ -67,7 +77,10 @@
 						break;
 					case "measure":
 						$err = new mbMeasureDecorator($this, $pageElementId, $pageElementConf, $controls);
-						break;
+						break;
+					case "image":
+						$err = new mbImageDecorator($this, $pageElementId, $pageElementConf, $controls);
+						break;
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json	2009-03-09 09:08:08 UTC (rev 3649)
+++ branches/print_dev/http/print/testConfigTemplate.json	2009-03-09 11:16:06 UTC (rev 3650)
@@ -102,6 +102,14 @@
 	    		"border" : 1,
 	    		"fill" : 1,
 	    		"border_width" : 0.5
+	   		"nordpfeil" : {
+    			"type" : "image",
+    			"x_ul" : 270.1,
+	    		"y_ul" : 15.2,
+	    		"width" : 37,
+	    		"height" : 76,
+				"filename" : "./img/northarrow.png"
More information about the Mapbender_commits
