[Mapbender-commits] r3699 - in branches/print_dev/http/print: .
	classes
    svn_mapbender at osgeo.org
    Fri Mar 13 05:39:46 EDT 2009
Author: mschulz
Date: 2009-03-13 05:39:43 -0400 (Fri, 13 Mar 2009)
New Revision: 3699
   branches/print_dev/http/print/classes/mbMapDecorator.php
   branches/print_dev/http/print/classes/mbTextDecorator.php
   branches/print_dev/http/print/mod_printPDF_div.php
fixed bug when overriding values from request
Modified: branches/print_dev/http/print/classes/mbMapDecorator.php
--- branches/print_dev/http/print/classes/mbMapDecorator.php	2009-03-13 07:57:51 UTC (rev 3698)
+++ branches/print_dev/http/print/classes/mbMapDecorator.php	2009-03-13 09:39:43 UTC (rev 3699)
@@ -31,7 +31,8 @@
 			$e = new mb_notice("mbMapDecorator: checking Request: ".$k."=".$v);
-		foreach ($this->overrideMembersFromRequest as $overrideMemberFromRequest) {
+		foreach ($this->overrideMembersFromRequest as $overrideMemberFromRequest) {
+			$this->{$overrideMemberFromRequest} = $this->conf->{$overrideMemberFromRequest};
 			foreach ($idsFromRequest as $requestKey => $memberId) {
 				$e = new mb_notice("mbMapDecorator: before override: set ".$memberId." to ".$requestKey);
 				if ($overrideMemberFromRequest==$memberId && isset($_REQUEST[$requestKey]) && $_REQUEST[$requestKey] != "") {
@@ -40,6 +41,7 @@
 				else {
 					$this->{$overrideMemberFromRequest} = $this->conf->{$memberId};
+					$e = new mb_notice("mbMapDecorator: override from conf: ".$overrideMemberFromRequest." to ".$this->conf->{$memberId});
@@ -88,4 +90,4 @@
\ No newline at end of file
Modified: branches/print_dev/http/print/classes/mbTextDecorator.php
--- branches/print_dev/http/print/classes/mbTextDecorator.php	2009-03-13 07:57:51 UTC (rev 3698)
+++ branches/print_dev/http/print/classes/mbTextDecorator.php	2009-03-13 09:39:43 UTC (rev 3699)
@@ -27,6 +27,17 @@
+			switch ($this->conf->{$overrideMemberFromRequest})  {
+				case "date":
+					$this->{$overrideMemberFromRequest} = date("d.m.y");
+					break;
+				case "scale":
+					$this->{$overrideMemberFromRequest} = "1 : ".$_REQUEST["map_scale"];
+					break;
+				default:
+					break;
 				$e = new mb_notice("mbTextDecorator: before override: set ".$memberId." to ".$requestKey);
@@ -49,4 +60,4 @@
Modified: branches/print_dev/http/print/mod_printPDF_div.php
--- branches/print_dev/http/print/mod_printPDF_div.php	2009-03-13 07:57:51 UTC (rev 3698)
+++ branches/print_dev/http/print/mod_printPDF_div.php	2009-03-13 09:39:43 UTC (rev 3699)
@@ -135,6 +135,7 @@
 		updateFormField(formData, "overview_url", mb_mapObj[ind_overview].mapURL);
+	updateFormField(formData, "map_scale", mb_getScale(myTarget));
 	// write the measured coordinates
 	if (mod_measure_RX != undefined && mod_measure_RY != undefined) {
 		var tmp_x = '';
@@ -233,4 +234,4 @@
 function stripslashes( str ) {
     return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
More information about the Mapbender_commits
