[Mapbender-commits] r3713 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Sat Mar 14 04:56:26 EDT 2009
Author: christoph
Date: 2009-03-14 04:56:26 -0400 (Sat, 14 Mar 2009)
New Revision: 3713
trunk/mapbender/resources/db/update/update_2.6.sql
tested via psql -f
fixed 2 bugs
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-13 16:27:05 UTC (rev 3712)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-14 08:56:26 UTC (rev 3713)
@@ -458,7 +458,7 @@
-- element vars for tooltip
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_destinationFrame', '', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', '["Kein Ergebnis.","<body onLoad=\"javascript:window.close()\">"]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\"javascript:window.close()\">"]', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
@@ -500,6 +500,6 @@
where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
--- custimsable tree in admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Customize Tree',0002,1,'Create a set of nested folders that contain the applications WMS','Customize Tree','a','','href = \\\"../php/mod_customTree.php?sessionID\\\" target=\\\"AdminFrame\\\"',10,975,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CUSTOMIZE TREE','a','','','','AdminFrame','');
+-- customisable tree in admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Customize Tree',0002,1,'Create a set of nested folders that contain the applications WMS','Customize Tree','a','','href = "../php/mod_customTree.php?sessionID" target="AdminFrame"',10,975,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CUSTOMIZE TREE','a','','','','AdminFrame','');
More information about the Mapbender_commits
