[Mapbender-commits] r3748 - tags/2.5/http/classes
    svn_mapbender at osgeo.org
    Mon Mar 16 09:23:26 EDT 2009
Author: christoph
Date: 2009-03-16 09:23:26 -0400 (Mon, 16 Mar 2009)
New Revision: 3748
   tags/2.5/http/classes/class_locale.php
properly formatted
Modified: tags/2.5/http/classes/class_locale.php
--- tags/2.5/http/classes/class_locale.php	2009-03-16 13:16:56 UTC (rev 3747)
+++ tags/2.5/http/classes/class_locale.php	2009-03-16 13:23:26 UTC (rev 3748)
@@ -27,120 +27,126 @@
 class Mb_locale {
-        var $knownLanguages = null;
-        var $systemLocales = null;
-        var $browserLanguages = null;
-        var $os = null;
-        var $name = null;
-        var $defaultLanguage = "en";
-        var $status = "No locale set.";
+	var $knownLanguages = null;
+	var $systemLocales = null;
+	var $browserLanguages = null;
+	var $os = null;
+	var $name = null;
+	var $defaultLanguage = "en";
+	var $status = "No locale set.";
-        function Mb_locale($languageId) {
-                if (!$languageId) {
-                        $languageId = LANGUAGE;
-                  $e = new Mb_notice("class_locale: setting locale to " . $languageId);
-                if (USE_I18N) {
-                        if (!$this->setCurrentLocale($languageId)) {
-                                $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
-                else {
-                        $this->setCurrentLocale($this->defaultLanguage);
+	function Mb_locale($languageId) {
+		if (!$languageId) {
+			$languageId = LANGUAGE;
+		$e = new Mb_notice("class_locale: setting locale to " . $languageId);
+		if (USE_I18N) {
+			if (!$this->setCurrentLocale($languageId)) {
+				$e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+		else {
+			$this->setCurrentLocale($this->defaultLanguage);
-         * Get the current locale, evaluating GET/POST variables, browser languages
-         * and a default locale (in that preference)
-         * @returns current locale
-        function setCurrentLocale($languageId) {
+	 * Get the current locale, evaluating GET/POST variables, browser languages
+     * and a default locale (in that preference)
+	 * @returns current locale
+	function setCurrentLocale($languageId) {
-                  // try to set the locale to $languageId
-                if ($this->checkAndSetLocale($languageId)) {
-                        return true;
-                  else {
-                          $e = new Mb_notice("class_locale: no input parameter specified.");
+		// try to set the locale to $languageId
+		if ($this->checkAndSetLocale($languageId)) {
+			return true;
+		else {
+			$e = new Mb_notice("class_locale: no input parameter specified.");
-                // determine the browser setting and try to set locale according to that
-                if ($this->browserLanguage == null) {
-                        $this->setBrowserLanguages();
-                foreach ($this->browserLanguages as $lang) {
-                        $e = new Mb_notice("trying browser setting " . $lang);
-                        if ($this->checkAndSetLocale($lang)) {
-                                return true;
+		// determine the browser setting and try to set locale according to that
+		if ($this->browserLanguage == null) {
+			$this->setBrowserLanguages();
+		foreach ($this->browserLanguages as $lang) {
+			$e = new Mb_notice("trying browser setting " . $lang);
+			if ($this->checkAndSetLocale($lang)) {
+				return true;
-                // set to default language
-                $e = new Mb_notice("trying default language " . $this->defaultLanguage);
-                return $this->checkAndSetLocale($this->defaultLanguage);
+		// set to default language
+		$e = new Mb_notice("trying default language " . $this->defaultLanguage);
+		return $this->checkAndSetLocale($this->defaultLanguage);
-         * checks if a locale is available; if yes, it is set via setlocale
-         * @returns true if the the locale is set successfully; otherwise false
-        function checkAndSetLocale($languageId) {
-                if ($this->os == null) {
-                        $this->os = $this->guessHostOS();
+	 * checks if a locale is available; if yes, it is set via setlocale
+	 * @returns true if the the locale is set successfully; otherwise false
+	function checkAndSetLocale($languageId) {
+		if ($this->os == null) {
+			$this->os = $this->guessHostOS();
+		if (!USE_I18N || ($this->os != null && isset($languageId))) {
+			if ($this->isKnownLanguage($languageId)) {
+				if ($this->systemLocales == null) {
+					$this->setSystemLocales();
+				$locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
+				$selectedLocale = setlocale(LC_MESSAGES, $locale);
-                if (!USE_I18N || ($this->os != null && isset($languageId))) {
-                        if ($this->isKnownLanguage($languageId)) {
+				if ($selectedLocale) {
+					$this->name = $selectedLocale;
+					$_SESSION["mb_lang"] = $languageId;
+					$_SESSION["mb_locale"] = $this->name;
+					$e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
-                                if ($this->systemLocales == null) {
-                                        $this->setSystemLocales();
+					// from http://de3.php.net/manual/de/function.gettext.php
+					$path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
+					$enc = bind_textdomain_codeset("Mapbender", "UTF-8");
+					$dom = textdomain("Mapbender");
+					return true;
+		$e = new Mb_notice("locale " . $locale . " not found.");
+		return false;
-                                $locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
-                                $selectedLocale = setlocale(LC_MESSAGES, $locale);
-                                if ($selectedLocale) {
-                                        $this->name = $selectedLocale;
-                                        $_SESSION["mb_lang"] = $languageId;
-                                        $_SESSION["mb_locale"] = $this->name;
-                                        $e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
-                                        // from http://de3.php.net/manual/de/function.gettext.php
-                                        $path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
-                                        $enc = bind_textdomain_codeset("Mapbender", "UTF-8");
-                                        $dom = textdomain("Mapbender");
-                                        return true;
-                $e = new Mb_notice("locale " . $locale . " not found.");
-                return false;
+	* Guess the operating system which on which this code is running
+	* multiple methods are tested for reliably guessing the os
+	* @private
+	* @returns string with os name
+	function guessHostOS(){
+		if (strncasecmp(php_uname(), 'Windows', 7) == 0) {
+			return 'windows';
+		else if (strncasecmp(php_uname(), 'Linux', 5) == 0) {
+			return 'linux';
+		else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0) {
+			return 'bsd';
+		else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0) {
+			return 'bsd';
+		else {
+			throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
+			return null;
-         * Guess the operating system which on which this code is running
-         * multiple methods are tested for reliably guessing the os
-         * @private
-         * @returns string with os name
-        function guessHostOS(){
-          if (strncasecmp(php_uname(), 'Windows', 7) == 0)
-            return 'windows';
-          else if (strncasecmp(php_uname(), 'Linux', 5) == 0)
-            return 'linux';
-          else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0)
-            return 'bsd';
-          else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0)
-            return 'bsd';
-          else {
-            throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
-            return null;
          * checks if a language is supported
          * @returns true if the language is supported; otherwise false
@@ -183,21 +189,21 @@
         function setKnownLanguages() {
                 $this->knownLanguages = array('en_US' => 'en_US',
-                      'en' => 'en_US',
-                      'de_DE' => 'de_DE',
-                      'de' => 'de_DE',
-                      'bg_BG' => 'bg_BG',
-                      'bg' => 'bg_BG',
-                      'es_ES' => 'es_ES',
-                      'es' => 'es_ES',
-                      'nl_NL' => 'nl_NL',
-                      'nl' => 'nl_NL',
-					  'fr_FR' => 'fr_FR',
-                      'fr' => 'fr_FR',
-                      'gr_GR' => 'gr_GR',
-                      'gr' => 'gr_GR',
-                      'it_IT' => 'it_IT',
-                      'it' => 'it_IT');
+						'en' => 'en_US',
+						'de_DE' => 'de_DE',
+						'de' => 'de_DE',
+						'bg_BG' => 'bg_BG',
+						'bg' => 'bg_BG',
+						'es_ES' => 'es_ES',
+						'es' => 'es_ES',
+						'nl_NL' => 'nl_NL',
+						'nl' => 'nl_NL',
+						'fr_FR' => 'fr_FR',
+						'fr' => 'fr_FR',
+						'gr_GR' => 'gr_GR',
+						'gr' => 'gr_GR',
+						'it_IT' => 'it_IT',
+						'it' => 'it_IT');
@@ -215,4 +221,4 @@
\ No newline at end of file
More information about the Mapbender_commits
