[Mapbender-commits] r3762 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Tue Mar 17 06:25:23 EDT 2009
Author: christoph
Date: 2009-03-17 06:25:23 -0400 (Tue, 17 Mar 2009)
New Revision: 3762
trunk/mapbender/resources/db/schema_2.5.dia
added fkey constraint wfs_element / wfs_conf_element
Modified: trunk/mapbender/resources/db/schema_2.5.dia
--- trunk/mapbender/resources/db/schema_2.5.dia 2009-03-17 10:23:18 UTC (rev 3761)
+++ trunk/mapbender/resources/db/schema_2.5.dia 2009-03-17 10:25:23 UTC (rev 3762)
@@ -5898,13 +5898,13 @@
<dia:point val="98,-48.9"/>
</dia:attribute>
<dia:attribute name="obj_bb">
- <dia:rectangle val="95.7,-49.985;144.75,-15.5825"/>
+ <dia:rectangle val="95.7,-49.985;144.75,-16.3825"/>
</dia:attribute>
<dia:attribute name="orth_points">
<dia:point val="96,-48.9"/>
- <dia:point val="96,-16.5"/>
- <dia:point val="144,-16.5"/>
+ <dia:point val="96,-17.3"/>
+ <dia:point val="144,-17.3"/>
</dia:attribute>
<dia:attribute name="orth_orient">
<dia:enum val="0"/>
@@ -5958,7 +5958,7 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O25" connection="16"/>
- <dia:connection handle="1" to="O41" connection="22"/>
+ <dia:connection handle="1" to="O41" connection="20"/>
</dia:connections>
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O32">
@@ -9696,14 +9696,14 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O66">
<dia:attribute name="obj_pos">
- <dia:point val="144,-14.9"/>
+ <dia:point val="144,-15.7"/>
</dia:attribute>
- <dia:rectangle val="90.25,-40.05;144.05,-14.385"/>
+ <dia:rectangle val="90.25,-40.05;144.05,-15.185"/>
</dia:attribute>
- <dia:point val="95,-14.9"/>
+ <dia:point val="95,-15.7"/>
<dia:point val="95,-39.3"/>
<dia:point val="91,-39.3"/>
</dia:attribute>
@@ -9758,7 +9758,7 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O41" connection="26"/>
+ <dia:connection handle="0" to="O41" connection="24"/>
<dia:connection handle="1" to="O65" connection="4"/>
</dia:connections>
</dia:object>
@@ -13707,7 +13707,7 @@
<dia:string>##</dia:string>
</dia:attribute>
<dia:attribute name="visibility">
- <dia:enum val="0"/>
+ <dia:enum val="2"/>
</dia:attribute>
<dia:attribute name="abstract">
<dia:boolean val="false"/>
@@ -16384,5 +16384,73 @@
</dia:composite>
</dia:attribute>
</dia:object>
+ <dia:object type="UML - Association" version="1" id="O129">
+ <dia:attribute name="obj_pos">
+ <dia:point val="160,-58.5"/>
+ </dia:attribute>
+ <dia:attribute name="obj_bb">
+ <dia:rectangle val="91.4,-59.585;160.05,-13.5825"/>
+ </dia:attribute>
+ <dia:attribute name="orth_points">
+ <dia:point val="119.796,-58.5"/>
+ <dia:point val="119.796,-14.5"/>
+ <dia:point val="92.15,-14.5"/>
+ </dia:attribute>
+ <dia:attribute name="orth_orient">
+ <dia:enum val="0"/>
+ <dia:enum val="1"/>
+ </dia:attribute>
+ <dia:attribute name="autorouting">
+ <dia:boolean val="false"/>
+ </dia:attribute>
+ <dia:attribute name="name">
+ <dia:string>##</dia:string>
+ </dia:attribute>
+ <dia:attribute name="direction">
+ </dia:attribute>
+ <dia:attribute name="ends">
+ <dia:composite>
+ <dia:attribute name="role">
+ <dia:string>#element_id#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="multiplicity">
+ </dia:attribute>
+ <dia:attribute name="arrow">
+ </dia:attribute>
+ <dia:attribute name="aggregate">
+ </dia:attribute>
+ <dia:attribute name="visibility">
+ </dia:attribute>
+ </dia:composite>
+ <dia:composite>
+ <dia:string>#f_id#</dia:string>
+ </dia:attribute>
+ <dia:string>#on delete cascade on update cascade#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ <dia:connections>
+ <dia:connection handle="0" to="O46" connection="12"/>
+ <dia:connection handle="1" to="O94" connection="43"/>
+ </dia:connections>
+ </dia:object>
</dia:layer>
</dia:diagram>
More information about the Mapbender_commits
