[Mapbender-commits] r3768 - branches/2.5/license
svn_mapbender at osgeo.org
Tue Mar 17 07:48:02 EDT 2009
Author: christoph
Date: 2009-03-17 07:48:02 -0400 (Tue, 17 Mar 2009)
New Revision: 3768
Added:
branches/2.5/license/Liberation-License.txt
branches/2.5/license/bitstream-COPYRIGHT.TXT
branches/2.5/license/dejavu-LICENSE
fonts licenses
Added: branches/2.5/license/Liberation-License.txt
--- branches/2.5/license/Liberation-License.txt (rev 0)
+++ branches/2.5/license/Liberation-License.txt 2009-03-17 11:48:02 UTC (rev 3768)
@@ -0,0 +1,19 @@
+LICENSE AGREEMENT AND LIMITED PRODUCT WARRANTY
+LIBERATION FONT SOFTWARE
+This agreement governs the use of the Software and any updates to the Software, regardless of the delivery mechanism. Subject to the following terms, Red Hat, Inc. ("Red Hat") grants to the user ("Client") a license to this work pursuant to the GNU General Public License v.2 with the exceptions set forth below and such other terms as are set forth in this End User License Agreement.
+ 1. The Software and License Exception. LIBERATION font software (the "Software") consists of TrueType-OpenType formatted font software for rendering LIBERATION typefaces in sans-serif, serif, and monospaced character styles. You are licensed to use, modify, copy, and distribute the Software pursuant to the GNU General Public License v.2 with the following exceptions:
+ (a) As a special exception, if you create a document which uses this font, and embed this font or unaltered portions of this font into the document, this font does not by itself cause the resulting document to be covered by the GNU General Public License. This exception does not however invalidate any other reasons why the document might be covered by the GNU General Public License. If you modify this font, you may extend this exception to your version of the font, but you are not obligated to do so. If you do not wish to do so, delete this exception statement from your version.
+ (b) As a further exception, any distribution of the object code of the Software in a physical product must provide you the right to access and modify the source code for the Software and to reinstall that modified version of the Software in object code form on the same physical product on which you received it.
+ 2. Intellectual Property Rights. The Software and each of its components, including the source code, documentation, appearance, structure and organization are owned by Red Hat and others and are protected under copyright and other laws. Title to the Software and any component, or to any copy, modification, or merged portion shall remain with the aforementioned, subject to the applicable license. The "LIBERATION" trademark is a trademark of Red Hat, Inc. in the U.S. and other countries. This agreement does not permit Client to distribute modified versions of the Software using Red Hat's trademarks. If Client makes a redistribution of a modified version of the Software, then Client must modify the files names to remove any reference to the Red Hat trademarks and must not use the Red Hat trademarks in any way to reference or promote the modified Software.
+ 3. Limited Warranty. To the maximum extent permitted under applicable law, the Software is provided and licensed "as is" without warranty of any kind, expressed or implied, including the implied warranties of merchantability, non-infringement or fitness for a particular purpose. Red Hat does not warrant that the functions contained in the Software will meet Client's requirements or that the operation of the Software will be entirely error free or appear precisely as described in the accompanying documentation.
+ 4. Limitation of Remedies and Liability. To the maximum extent permitted by applicable law, Red Hat or any Red Hat authorized dealer will not be liable to Client for any incidental or consequential damages, including lost profits or lost savings arising out of the use or inability to use the Software, even if Red Hat or such dealer has been advised of the possibility of such damages.
+ 5. General. If any provision of this agreement is held to be unenforceable, that shall not affect the enforceability of the remaining provisions. This agreement shall be governed by the laws of the State of North Carolina and of the United States, without regard to any conflict of laws provisions, except that the United Nations Convention on the International Sale of Goods shall not apply.
+Copyright © 2007 Red Hat, Inc. All rights reserved. LIBERATION is a trademark of Red Hat, Inc.
Added: branches/2.5/license/bitstream-COPYRIGHT.TXT
--- branches/2.5/license/bitstream-COPYRIGHT.TXT (rev 0)
+++ branches/2.5/license/bitstream-COPYRIGHT.TXT 2009-03-17 11:48:02 UTC (rev 3768)
@@ -0,0 +1,124 @@
+Bitstream Vera Fonts Copyright
+The fonts have a generous copyright, allowing derivative works (as
+long as "Bitstream" or "Vera" are not in the names), and full
+redistribution (so long as they are not *sold* by themselves). They
+can be be bundled, redistributed and sold with any software.
+The fonts are distributed under the following copyright:
+Copyright
+Copyright (c) 2003 by Bitstream, Inc. All Rights Reserved. Bitstream
+Vera is a trademark of Bitstream, Inc.
+Permission is hereby granted, free of charge, to any person obtaining
+a copy of the fonts accompanying this license ("Fonts") and associated
+documentation files (the "Font Software"), to reproduce and distribute
+the Font Software, including without limitation the rights to use,
+copy, merge, publish, distribute, and/or sell copies of the Font
+Software, and to permit persons to whom the Font Software is furnished
+to do so, subject to the following conditions:
+The above copyright and trademark notices and this permission notice
+shall be included in all copies of one or more of the Font Software
+typefaces.
+The Font Software may be modified, altered, or added to, and in
+particular the designs of glyphs or characters in the Fonts may be
+modified and additional glyphs or characters may be added to the
+Fonts, only if the fonts are renamed to names not containing either
+the words "Bitstream" or the word "Vera".
+This License becomes null and void to the extent applicable to Fonts
+or Font Software that has been modified and is distributed under the
+"Bitstream Vera" names.
+The Font Software may be sold as part of a larger software package but
+no copy of one or more of the Font Software typefaces may be sold by
+itself.
+THE FONT SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO ANY WARRANTIES OF
+MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT
+OF COPYRIGHT, PATENT, TRADEMARK, OR OTHER RIGHT. IN NO EVENT SHALL
+BITSTREAM OR THE GNOME FOUNDATION BE LIABLE FOR ANY CLAIM, DAMAGES OR
+OTHER LIABILITY, INCLUDING ANY GENERAL, SPECIAL, INDIRECT, INCIDENTAL,
+OR CONSEQUENTIAL DAMAGES, WHETHER IN AN ACTION OF CONTRACT, TORT OR
+OTHERWISE, ARISING FROM, OUT OF THE USE OR INABILITY TO USE THE FONT
+SOFTWARE OR FROM OTHER DEALINGS IN THE FONT SOFTWARE.
+Except as contained in this notice, the names of Gnome, the Gnome
+Foundation, and Bitstream Inc., shall not be used in advertising or
+otherwise to promote the sale, use or other dealings in this Font
+Software without prior written authorization from the Gnome Foundation
+or Bitstream Inc., respectively. For further information, contact:
+fonts at gnome dot org.
+Copyright FAQ
+ 1. I don't understand the resale restriction... What gives?
+ Bitstream is giving away these fonts, but wishes to ensure its
+ competitors can't just drop the fonts as is into a font sale system
+ and sell them as is. It seems fair that if Bitstream can't make money
+ from the Bitstream Vera fonts, their competitors should not be able to
+ do so either. You can sell the fonts as part of any software package,
+ however.
+ 2. I want to package these fonts separately for distribution and
+ sale as part of a larger software package or system. Can I do so?
+ Yes. A RPM or Debian package is a "larger software package" to begin
+ with, and you aren't selling them independently by themselves.
+ See 1. above.
+ 3. Are derivative works allowed?
+ Yes!
+ 4. Can I change or add to the font(s)?
+ Yes, but you must change the name(s) of the font(s).
+ 5. Under what terms are derivative works allowed?
+ You must change the name(s) of the fonts. This is to ensure the
+ quality of the fonts, both to protect Bitstream and Gnome. We want to
+ ensure that if an application has opened a font specifically of these
+ names, it gets what it expects (though of course, using fontconfig,
+ substitutions could still could have occurred during font
+ opening). You must include the Bitstream copyright. Additional
+ copyrights can be added, as per copyright law. Happy Font Hacking!
+ 6. If I have improvements for Bitstream Vera, is it possible they might get
+ adopted in future versions?
+ Yes. The contract between the Gnome Foundation and Bitstream has
+ provisions for working with Bitstream to ensure quality additions to
+ the Bitstream Vera font family. Please contact us if you have such
+ additions. Note, that in general, we will want such additions for the
+ entire family, not just a single font, and that you'll have to keep
+ both Gnome and Jim Lyles, Vera's designer, happy! To make sense to add
+ glyphs to the font, they must be stylistically in keeping with Vera's
+ design. Vera cannot become a "ransom note" font. Jim Lyles will be
+ providing a document describing the design elements used in Vera, as a
+ guide and aid for people interested in contributing to Vera.
+ 7. I want to sell a software package that uses these fonts: Can I do so?
+ Sure. Bundle the fonts with your software and sell your software
+ with the fonts. That is the intent of the copyright.
+ 8. If applications have built the names "Bitstream Vera" into them,
+ can I override this somehow to use fonts of my choosing?
+ This depends on exact details of the software. Most open source
+ systems and software (e.g., Gnome, KDE, etc.) are now converting to
+ use fontconfig (see www.fontconfig.org) to handle font configuration,
+ selection and substitution; it has provisions for overriding font
+ names and subsituting alternatives. An example is provided by the
+ supplied local.conf file, which chooses the family Bitstream Vera for
+ "sans", "serif" and "monospace". Other software (e.g., the XFree86
+ core server) has other mechanisms for font substitution.
Added: branches/2.5/license/dejavu-LICENSE
--- branches/2.5/license/dejavu-LICENSE (rev 0)
+++ branches/2.5/license/dejavu-LICENSE 2009-03-17 11:48:02 UTC (rev 3768)
@@ -0,0 +1,99 @@
+Fonts are (c) Bitstream (see below). DejaVu changes are in public domain.
+Glyphs imported from Arev fonts are (c) Tavmjong Bah (see below)
+Copyright (c) 2003 by Bitstream, Inc. All Rights Reserved. Bitstream Vera is
+a trademark of Bitstream, Inc.
+Permission is hereby granted, free of charge, to any person obtaining a copy
+of the fonts accompanying this license ("Fonts") and associated
+documentation files (the "Font Software"), to reproduce and distribute the
+Font Software, including without limitation the rights to use, copy, merge,
+publish, distribute, and/or sell copies of the Font Software, and to permit
+persons to whom the Font Software is furnished to do so, subject to the
+following conditions:
+The above copyright and trademark notices and this permission notice shall
+be included in all copies of one or more of the Font Software typefaces.
+The Font Software may be modified, altered, or added to, and in particular
+the designs of glyphs or characters in the Fonts may be modified and
+additional glyphs or characters may be added to the Fonts, only if the fonts
+are renamed to names not containing either the words "Bitstream" or the word
+"Vera".
+This License becomes null and void to the extent applicable to Fonts or Font
+Software that has been modified and is distributed under the "Bitstream
+Vera" names.
+The Font Software may be sold as part of a larger software package but no
+copy of one or more of the Font Software typefaces may be sold by itself.
+THE FONT SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+OR IMPLIED, INCLUDING BUT NOT LIMITED TO ANY WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT OF COPYRIGHT, PATENT,
+TRADEMARK, OR OTHER RIGHT. IN NO EVENT SHALL BITSTREAM OR THE GNOME
+FOUNDATION BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, INCLUDING
+ANY GENERAL, SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES,
+WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
+THE USE OR INABILITY TO USE THE FONT SOFTWARE OR FROM OTHER DEALINGS IN THE
+FONT SOFTWARE.
+otherwise to promote the sale, use or other dealings in this Font Software
+without prior written authorization from the Gnome Foundation or Bitstream
+Inc., respectively. For further information, contact: fonts at gnome dot
+org.
+Arev Fonts Copyright
+Copyright (c) 2006 by Tavmjong Bah. All Rights Reserved.
+associated documentation files (the "Font Software"), to reproduce
+and distribute the modifications to the Bitstream Vera Font Software,
+including without limitation the rights to use, copy, merge, publish,
+distribute, and/or sell copies of the Font Software, and to permit
+the following conditions:
+typefaces.
+the words "Tavmjong Bah" or the word "Arev".
+"Tavmjong Bah Arev" names.
+itself.
+TAVMJONG BAH BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
+INCLUDING ANY GENERAL, SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL
+DAMAGES, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+FROM, OUT OF THE USE OR INABILITY TO USE THE FONT SOFTWARE OR FROM
+OTHER DEALINGS IN THE FONT SOFTWARE.
+Except as contained in this notice, the name of Tavmjong Bah shall not
+be used in advertising or otherwise to promote the sale, use or other
+dealings in this Font Software without prior written authorization
+from Tavmjong Bah. For further information, contact: tavmjong @ free
+. fr.
+$Id: LICENSE 2133 2007-11-28 02:46:28Z lechimp $
More information about the Mapbender_commits
