[Mapbender-commits] r3776 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Tue Mar 17 12:05:53 EDT 2009
Author: christoph
Date: 2009-03-17 12:05:53 -0400 (Tue, 17 Mar 2009)
New Revision: 3776
Added:
trunk/mapbender/resources/db/install_2.6rc1.sh
new install script
Added: trunk/mapbender/resources/db/install_2.6rc1.sh
--- trunk/mapbender/resources/db/install_2.6rc1.sh (rev 0)
+++ trunk/mapbender/resources/db/install_2.6rc1.sh 2009-03-17 16:05:53 UTC (rev 3776)
@@ -0,0 +1,122 @@
+#!/bin/bash
+rm log_*.txt
+# Disclaimer
+echo ""
+echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
+echo ""
+echo "Continue? (y)es or (n)o"
+read disclaimer
+if test $disclaimer != "y"
+then
+ exit 1
+fi
+# ask for db version
+echo ""
+echo "Database version? (p)ostgresql or (m)ysql?"
+read dbversion
+if test $dbversion != "p" -a $dbversion != "m"
+then
+ echo ""
+ echo "Incorrect database type. Terminating the script..."
+ exit 1
+fi
+# ask for db character encoding
+echo ""
+echo "Database character encoding? (i)so-8859-1 or (u)tf-8?"
+read dbenc
+if test $dbenc != "i" -a $dbenc != "u"
+then
+ echo ""
+ echo "Incorrect database character encoding. Terminating the script..."
+ exit 1
+fi
+# ask for database name
+echo ""
+echo "Name of database?"
+read dbname
+if test $dbversion = "m"
+then
+ echo "Not available!!!"
+ exit 1
+ echo ""
+ echo "Enter your MySQL password:"
+ stty -echo
+ read password
+ stty echo
+ echo ""
+ if test $dbenc = "i"
+ then
+ echo ""
+ echo "Installing Mapbender with MySQL (ISO-8859-1) in database $dbname";
+ echo ""
+ mysql -e "create database $dbname CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$password
+ mysql $dbname -p$password < mysql/mysql_schema_2.5.sql > log_schema.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/mysql_data_2.5.sql > log_data.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql > log_update.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql > log_update.txt
+ mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql > log_update.txt
+ elif test $dbenc = "u"
+ then
+ echo ""
+ echo "Installing Mapbender with MySQL (UTF-8) in database $dbname";
+ echo ""
+ mysql -e "create database $dbname CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$password
+ mysql $dbname -p$password < mysql/UTF-8/mysql_data_2.5.sql > log_data.txt
+ mysql $dbname -p$password < mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql > log_update.txt
+ mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql > log_update.txt
+ mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql > log_update.txt
+ fi
+elif test $dbversion = "p" -a $dbenc = "i"
+then
+ exit 1
+ echo ""
+ echo "Installing Mapbender with PostgreSQL (ISO-8859-1) in database $dbname";
+ echo ""
+ createdb -E ISO-8859-1 $dbname
+ psql -f pgsql/pgsql_schema_2.5.sql $dbname > log_schema.txt
+ psql -f pgsql/ISO-8859-1/pgsql_data_2.5.sql $dbname > log_data.txt
+ psql -f pgsql/pgsql_serial_set_sequences_2.5.sql $dbname > log_sequences.txt
+ psql -f pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+ psql -f pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+ psql -f pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+elif test $dbversion = "p" -a $dbenc = "u"
+then
+ echo ""
+ echo "Installing Mapbender with PostgreSQL (UTF-8) in database $dbname";
+ echo ""
+ createdb -E UTF-8 $dbname
+ psql -f pgsql/UTF-8/pgsql_data_2.5.sql $dbname > log_data.txt
+ psql -f pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+ psql -f pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql $dbname > log_update.txt
+ psql -f pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+fi
+echo ""
+echo "Compiling .po files..."
+cd ../../tools/
+./i18n_update_mo.sh
+echo ""
+echo ""
+echo "Finished...check the log files to see if an error occured.";
\ No newline at end of file
More information about the Mapbender_commits
