[Mapbender-commits] r3798 - in branches: .
pseudoSlippy/http/javascripts pseudoSlippy/lib
svn_mapbender at osgeo.org
Sun Mar 22 16:13:17 EDT 2009
Author: christoph
Date: 2009-03-22 16:13:16 -0400 (Sun, 22 Mar 2009)
New Revision: 3798
Added:
branches/pseudoSlippy/
branches/pseudoSlippy/http/javascripts/map_obj.js
branches/pseudoSlippy/http/javascripts/mod_box1.js
branches/pseudoSlippy/http/javascripts/mod_pan.php
branches/pseudoSlippy/http/javascripts/mod_zoomIn1.php
branches/pseudoSlippy/lib/exception.js
pseudo slippy map
Copied: branches/pseudoSlippy (from rev 3797, trunk/mapbender)
Modified: branches/pseudoSlippy/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2009-03-20 14:31:03 UTC (rev 3797)
+++ branches/pseudoSlippy/http/javascripts/map_obj.js 2009-03-22 20:13:16 UTC (rev 3798)
@@ -213,6 +213,7 @@
var wmsExtent = new Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
+ this.oldExtent = null;
this.calculateExtent(wmsExtent);
@@ -289,6 +290,9 @@
* @param {Object} direction
this.pan = function (direction) {
+ var extent = this.getExtentInfos();
+ this.oldExtent = extent;
var arrayBBox = this.extent.split(",");
var minx = parseFloat(arrayBBox[0]);
var miny = parseFloat(arrayBBox[1]);
@@ -296,8 +300,10 @@
var maxy = parseFloat(arrayBBox[3]);
var xtentx = maxx - minx;
var xtenty = maxy - miny;
- var factor = 0.5;
+ var factor = 0.4;
+// var oldPoint = this.convertRealToPixel(new Point(minx, miny));
switch (direction) {
case "NW" :
minx -= (xtentx * factor);
@@ -340,12 +346,18 @@
maxx -= (xtentx * factor);
break;
+// var newPoint = this.convertRealToPixel(new Point(minx, miny));
+// var diff = oldPoint.minus(newPoint);
+// this.arrangeElements(diff.y, diff.x);
this.extent = minx + "," + miny + "," + maxx + "," + maxy;
this.setMapRequest();
this.zoomFull = function () {
for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
if (this.epsg == this.wms[0].gui_epsg[i]) {
@@ -369,7 +381,7 @@
* @param {float} y center to y-position
this.zoom = function(in_, factor, x, y){
- factor = parseFloat(factor);
+ var factor = parseFloat(factor);
if (!in_) {
factor = 1 / factor;
@@ -379,11 +391,14 @@
var disty = extent.maxy - extent.miny;
if (x && y) {
var centerx = parseFloat(x);
var centery = parseFloat(y);
else {
+ // the image is already moved if x and y are given
var centerx = extent.minx + distx / 2;
var centery = extent.miny + disty / 2;
@@ -719,11 +734,17 @@
this.setMapRequest = function(){
- var functionName = 'setMapRequest';
+ if (this.oldExtent) {
+ this.arrangeElements();
+ firstMapReady = false;
var ret = eventBeforeMapRequest.trigger({
map: this
- }, "AND");
+ }, "AND"
if (ret === false) {
return true;
@@ -732,6 +753,19 @@
var newMapRequest = "";
+ // once the first map is ready, the old ones will be deleted
+ removeOldMaps = function () {
+ for (var ii = 0; ii < that.wms.length; ii++) {
+ var myDivId = that.elementName + "_div_" + ii;
+ var $div = $('#' + myDivId);
+ if (!firstMapRequest) {
+ while ($div.children().size() > 1) {
+ $div.children().eq(0).remove();
for (var ii = 0; ii < this.wms.length; ii++) {
var currentWms = this.wms[ii];
@@ -743,8 +777,9 @@
newMapRequest += getLayerHtmlCode(ii);
- writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
+// writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
eventAfterMapRequest.trigger({
"map": this,
"myMapId": myMapId.join(",")
@@ -752,7 +787,46 @@
var that = this;
+ var firstMapReady = false;
+ var firstMapRequest = true;
+ var removeOldMaps = function () {
+ // is written in setMapRequest
+ return null;
+ this.arrangeElements = function () {
+ var oldLL = new Point(this.oldExtent.minx, this.oldExtent.miny);
+ var oldUR = new Point(this.oldExtent.maxx, this.oldExtent.maxy);
+ var oldLLPix = this.convertRealToPixel(oldLL);
+ var oldURPix = this.convertRealToPixel(oldUR);
+ var left = oldLLPix.x;
+ var top = oldURPix.y;
+ var width = oldURPix.x - oldLLPix.x;
+ var height = oldLLPix.y - oldURPix.y;
+ var mapDiv = $("#" + this.elementName + "_maps div");
+ mapDiv.animate({
+ left: left + "px",
+ top: top + "px"
+ duration: "slow"
+ var mapImg = $("#" + this.elementName + "_maps div img");
+ mapImg.animate({
+ width: width + "px",
+ height: height + "px"
+ duration: "slow"
var getLayerHtmlCode = function (ii) {
var currentWms = that.wms[ii];
@@ -779,21 +853,40 @@
var imageString = "";
if (newMapURL) {
imageString = "<img id='"+myMapId+"' name='mapimage' ";
- imageString += "src='" + newMapURL + "' ";
imageString += "width='"+that.width+"' ";
imageString += "height='"+that.height+"' ";
- imageString += "border='0'>";
+ imageString += "border='0' />";
var newMapRequest = "<div id='"+myDivId+"' ";
newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
- newMapRequest += imageString;
newMapRequest += "</div>";
+ if ($('#' + myDivId).size() === 0) {
+ $('#' + that.elementName+"_maps").append($(newMapRequest));
+ $(imageString).attr('src', newMapURL).load(function () {
+ $div.css({
+ left: "0px", top: "0px"
+ }).append( $(this) );
+ if (!firstMapReady) {
+ mb_arrangeElement(that.frameName, that.elementName+"_maps", 0, 0);
+ for(var i=0; i<mb_PanSubElements.length; i++){
+ mb_arrangeElement(that.frameName, mb_PanSubElements[i], 0, 0);
+ firstMapReady = true;
+ removeOldMaps();
+ firstMapRequest = false;
that.mapURL[ii]= newMapURL;
currentWms.mapURL = newMapURL;
Modified: branches/pseudoSlippy/http/javascripts/mod_box1.js
--- trunk/mapbender/http/javascripts/mod_box1.js 2009-03-20 14:31:03 UTC (rev 3797)
+++ branches/pseudoSlippy/http/javascripts/mod_box1.js 2009-03-22 20:13:16 UTC (rev 3798)
@@ -14,7 +14,7 @@
var mb_offset_bottom = 0;
var mb_offset_left = 0;
-function mod_box_start(e){
+function mod_box_start(e){
mb_boxMapObj = getMapObjByName(mb_isBF);
mb_isActive = true;
mb_boxMapObj.getMousePos(e);
@@ -176,10 +176,11 @@
function mod_box_setValidClipping(coords){
if(coords.length > 2){
- mb_calculateExtent(mb_zF,coords[0],coords[1],coords[2],coords[3]);
- setMapRequest(mb_zF);
+ mb_boxMapObj.oldExtent = mb_boxMapObj.getExtentInfos();
+ mb_boxMapObj.calculateExtent(new Extent(coords[0],coords[1],coords[2],coords[3]));
+ mb_boxMapObj.setMapRequest();
else{
- zoom(mb_zF,true,1.0,coords[0], coords[1]);
+ mb_boxMapObj.zoom(true, 1.0, coords[0], coords[1]);
Modified: branches/pseudoSlippy/http/javascripts/mod_pan.php
--- trunk/mapbender/http/javascripts/mod_pan.php 2009-03-20 14:31:03 UTC (rev 3797)
+++ branches/pseudoSlippy/http/javascripts/mod_pan.php 2009-03-22 20:13:16 UTC (rev 3798)
@@ -93,13 +93,14 @@
var el = mod_pan_MapObj.getDomElement();
var center_x = (width / 2) - dif_x;
var center_y = (height / 2) - dif_y;
- var real_center = makeClickPos2RealWorldPos(mod_pan_target,center_x, center_y);
+ var real_center = mod_pan_MapObj.convertPixelToReal(new Point(center_x, center_y));
- mb_arrangeElement(mod_pan_MapObj.frameName, mod_pan_target+"_maps", 0, 0);
- for(var i=0; i<mb_PanSubElements.length; i++){
- mb_arrangeElement(mod_pan_MapObj.frameName, mb_PanSubElements[i], 0, 0);
- zoom(mod_pan_target,false, 1.0, real_center[0], real_center[1]);
+// mb_arrangeElement(mod_pan_MapObj.frameName, mod_pan_target+"_maps", 0, 0);
+// for(var i=0; i<mb_PanSubElements.length; i++){
+// mb_arrangeElement(mod_pan_MapObj.frameName, mb_PanSubElements[i], 0, 0);
+ mod_pan_MapObj.oldExtent = null;
+ mod_pan_MapObj.zoom(false, 1.0, real_center.x, real_center.y);
function mod_pan_move_map(){
var dif_x = mb_end_x - mb_start_x;
Modified: branches/pseudoSlippy/http/javascripts/mod_zoomIn1.php
--- trunk/mapbender/http/javascripts/mod_zoomIn1.php 2009-03-20 14:31:03 UTC (rev 3797)
+++ branches/pseudoSlippy/http/javascripts/mod_zoomIn1.php 2009-03-22 20:13:16 UTC (rev 3798)
@@ -27,8 +27,10 @@
var $zoomin1Button = $("#"+zoomin1Id);
+var zoomin1_mapObj = getMapObjByName("<?php echo $e_target[0]; ?>");
$zoomin1Button.click(function () {
- zoom("<?php echo $e_target[0]; ?>", true, 2.0);
+ zoomin1_mapObj.zoom(true, 2.0);
function mod_zoomIn1_init(obj){
Modified: branches/pseudoSlippy/lib/exception.js
--- trunk/mapbender/lib/exception.js 2009-03-20 14:31:03 UTC (rev 3797)
+++ branches/pseudoSlippy/lib/exception.js 2009-03-22 20:13:16 UTC (rev 3798)
@@ -51,26 +51,31 @@
alert(message);
else if (log_js == "console") {
- if ($.browser.msie) {
- try {
- mb_ajax_post('../php/mb_js_exception.php', {level:level,text:message});
- catch(e) {
- alert(e + ": " + message);
- else {
+ if (!$.browser.msie && window.console) {
if (level == "warning") {
console.warn("%s", message);
- else if (level == "error") {
- console.error("%s", message);
else {
- console.log("%s", message);
+ if (level == "error") {
+ console.error("%s", message);
+ else {
+ console.log("%s", message);
+ else {
+ try {
+ mb_ajax_post('../php/mb_js_exception.php', {
+ level: level,
+ text: message
+ catch (e) {
+ alert(e + ": " + message);
More information about the Mapbender_commits
