[Mapbender-commits] r3820 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Fri Mar 27 05:22:48 EDT 2009
Author: verenadiewald
Date: 2009-03-27 05:22:48 -0400 (Fri, 27 Mar 2009)
New Revision: 3820
trunk/mapbender/http/php/mod_wfs.php
trunk/mapbender/http/php/mod_wfs_edit.php
argument charset UTF-8 for function htmlentities for correct display of wfs_conf elements: http://trac.osgeo.org/mapbender/ticket/423
Modified: trunk/mapbender/http/php/mod_wfs.php
--- trunk/mapbender/http/php/mod_wfs.php 2009-03-27 09:17:59 UTC (rev 3819)
+++ trunk/mapbender/http/php/mod_wfs.php 2009-03-27 09:22:48 UTC (rev 3820)
@@ -151,20 +151,20 @@
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_search'] = ".$row["f_search"].";";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_style_id'] = '".$row["f_style_id"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_toupper'] = '".$row["f_toupper"]."';";
- echo "wfs_conf[".$i."]['element'][".$cnt."]['f_label'] = '".htmlentities($row["f_label"], ENT_QUOTES)."';";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['f_label'] = '".htmlentities($row["f_label"], ENT_QUOTES, "UTF-8")."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_label_id'] = '".$row["f_label_id"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_show'] = '".$row["f_show"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_show_detail'] = '".$row["f_show_detail"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_respos'] = '".$row["f_respos"]."';";
- echo "wfs_conf[".$i."]['element'][".$cnt."]['element_name'] = '".htmlentities($row["element_name"], ENT_QUOTES)."';";
- echo "wfs_conf[".$i."]['element'][".$cnt."]['element_type'] = '".htmlentities($row["element_type"], ENT_QUOTES)."';";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['element_name'] = '".htmlentities($row["element_name"], ENT_QUOTES, "UTF-8")."';";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['element_type'] = '".htmlentities($row["element_type"], ENT_QUOTES, "UTF-8")."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_geom'] = '".$row["f_geom"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_gid'] = '".$row["f_gid"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"".(preg_replace("/\n/", "", preg_replace("/\r/", "", $row["f_form_element_html"])))."\";";
// echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"\";";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_edit'] = '".$row["f_edit"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_mandatory'] = '".$row["f_mandatory"]."';";
- echo "wfs_conf[".$i."]['element'][".$cnt."]['f_auth_varname'] = '".htmlentities($row["f_auth_varname"], ENT_QUOTES)."';";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['f_auth_varname'] = '".htmlentities($row["f_auth_varname"], ENT_QUOTES, "UTF-8")."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_operator'] = '".$row["f_operator"]."';";
$cnt++;
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
--- trunk/mapbender/http/php/mod_wfs_edit.php 2009-03-27 09:17:59 UTC (rev 3819)
+++ trunk/mapbender/http/php/mod_wfs_edit.php 2009-03-27 09:22:48 UTC (rev 3820)
@@ -313,8 +313,8 @@
echo "<td><input name='f_toupper".$cnt."' type='checkbox'";
if($row["f_toupper"] == 1){ echo " checked"; }
echo "></td>";
- echo "<td><input name='f_label".$cnt."' type='text' size='4' value=\"".htmlentities($row["f_label"])."\"></td>";
- echo "<td><input name='f_label_id".$cnt."' type='text' size='2' value=\"".htmlentities($row["f_label_id"])."\"></td>";
+ echo "<td><input name='f_label".$cnt."' type='text' size='4' value=\"".htmlentities($row["f_label"], ENT_QUOTES, "UTF-8")."\"></td>";
+ echo "<td><input name='f_label_id".$cnt."' type='text' size='2' value=\"".htmlentities($row["f_label_id"], ENT_QUOTES, "UTF-8")."\"></td>";
echo "<td><input name='f_show".$cnt."' type='checkbox'";
if($row["f_show"] == 1){ echo " checked"; }
echo "></td>";
@@ -329,8 +329,8 @@
echo "<td><input name='f_edit".$cnt."' type='checkbox'";
if($row["f_edit"] == 1){ echo " checked"; }
echo "></td>";
- echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".htmlentities($row["f_form_element_html"])."</textarea></td>";
- echo "<td><input name='f_auth_varname$cnt' type='text' size='8' value=\"" . htmlentities($row["f_auth_varname"]) . "\"></td>";
+ echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".htmlentities($row["f_form_element_html"], ENT_QUOTES, "UTF-8")."</textarea></td>";
+ echo "<td><input name='f_auth_varname$cnt' type='text' size='8' value=\"" . htmlentities($row["f_auth_varname"], ENT_QUOTES, "UTF-8") . "\"></td>";
echo "<td><select name='f_operator".$cnt."' id='f_operator".$cnt."' ";
if($row["f_search"] != 1){
echo "disabled";
More information about the Mapbender_commits
