[Mapbender-commits] r3925 - trunk/documents/videos
svn_mapbender at osgeo.org
Tue May 5 03:55:17 EDT 2009
Author: saith
Date: 2009-05-05 03:55:17 -0400 (Tue, 05 May 2009)
New Revision: 3925
Added:
trunk/documents/videos/mb_login.htm
trunk/documents/videos/mb_login.swf
trunk/documents/videos/mb_print_dynamic.htm
trunk/documents/videos/mb_print_dynamic.swf
Added: trunk/documents/videos/mb_login.htm
--- trunk/documents/videos/mb_login.htm (rev 0)
+++ trunk/documents/videos/mb_login.htm 2009-05-05 07:55:17 UTC (rev 3925)
@@ -0,0 +1,11 @@
+<HTML>
+<BODY><center><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="739" HEIGHT="850" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0">
+<PARAM NAME=movie VALUE="mapbender_test.swf">
+<PARAM NAME=play VALUE=true>
+<PARAM NAME=loop VALUE=false>
+<PARAM NAME=quality VALUE=low>
+<EMBED SRC="mb_login.swf" WIDTH=739 HEIGHT=850 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash">
+</EMBED>
+</OBJECT>
+</center>
+</BODY></HTML>
Added: trunk/documents/videos/mb_login.swf
(Binary files differ)
Property changes on: trunk/documents/videos/mb_login.swf
___________________________________________________________________
+ application/octet-stream
Added: trunk/documents/videos/mb_print_dynamic.htm
--- trunk/documents/videos/mb_print_dynamic.htm (rev 0)
+++ trunk/documents/videos/mb_print_dynamic.htm 2009-05-05 07:55:17 UTC (rev 3925)
@@ -0,0 +1,11 @@
+<HTML>
+<BODY><center><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="1280" HEIGHT="839" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0">
+<PARAM NAME=movie VALUE="mb_print_dynamic.swf">
+<EMBED SRC="mb_print_dynamic.swf" WIDTH=1280 HEIGHT=839 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash">
+</EMBED>
+</OBJECT>
+</center>
+</BODY></HTML>
Added: trunk/documents/videos/mb_print_dynamic.swf
Property changes on: trunk/documents/videos/mb_print_dynamic.swf
More information about the Mapbender_commits
