[Mapbender-commits] r3929 - branches/2.6/conf
    svn_mapbender at osgeo.org
    Wed May  6 04:48:50 EDT 2009
Author: verenadiewald
Date: 2009-05-06 04:48:49 -0400 (Wed, 06 May 2009)
New Revision: 3929
   branches/2.6/conf/wfs_additional_spatial_search.conf
http://trac.osgeo.org/mapbender/ticket/446
Modified: branches/2.6/conf/wfs_additional_spatial_search.conf
--- branches/2.6/conf/wfs_additional_spatial_search.conf	2009-05-05 14:24:38 UTC (rev 3928)
+++ branches/2.6/conf/wfs_additional_spatial_search.conf	2009-05-06 08:48:49 UTC (rev 3929)
@@ -1,3 +1,9 @@
+// Settings of spatial request buttons
  * definition of buttons for spatialRequest
@@ -2,4 +8,5 @@
  * [@param {integer} status show this button (value is 1 or 0)
+ * [@param {integer} x position left
+ * [@param {integer} y position top
  * [@param {string} img image for the button
- * [@param {string} title for the button
  * [@param {string} filteroption type of filter for search (values: "intersects" or "within"), used for buttons buttonRectangle and buttonPolygon
@@ -12,30 +19,99 @@
 var buttonPoint = {"status":1, "img":"select_point_off.png","title":"<?php echo _mb("select by point");?>"};
 var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"<?php echo _mb("select by extent");?>"};
+ * directory that contains the buttons mentioned above
+var buttonWfs_imgdir = "../img/button_gray/";
+ * z-Index of the buttons mentioned above
+var buttonWfs_zIndex = 10;
+// General WFS request settings
+ * This is the buffer around query points for spatial requests (in pixel)
 var mb_wfs_tolerance = 8;
+ * If spatialRequest is set, show this message
 var spatialRequestIsSetMessage = '<?php echo _mb("Spatial filter is set.");?>';
+ * Label of the clearFilter-Button
 var clearFilterButtonLabel = '<?php echo _mb("new");?>';
+ * If no results are found, show this message
 var noResultMsg = '<?php _mb("No result");?>';
-var buttonWfs_imgdir = "../img/button_gray/";
-var buttonWfs_zIndex = 10;
+ * Path to the server-side module that performs the WFS request
+var wfsResultModulePath = "php/";
+ * File name of the server-side module that performs the WFS request
+var wfsResultModuleFilename = "mod_wfs_result.php";
+// Result geometry highlight settings
+ * z-Index of the highlighted geometries
 var generalHighlightZIndex = 90;
+ * Line width of the highlighted geometries in pixel
 var generalHighlightLineWidth = 2;
-var wfsResultModulePath = "php/";
-var wfsResultModuleFilename = "mod_wfs_result.php";
+ * Title of the result popup
+var searchPopupTitle = '<?php echo _mb("Search results");?>';
-var searchPopupTitle = '<?php echo _mb("Search results");?>';
+ * Width and height of the result popup (in pixel)
 var searchPopupWidth = 400;
-var searchPopupHeight =250;
+var searchPopupHeight = 250;
+ * Absolute position of the result popup (in pixel)
 var searchPopupX = 750;
 var searchPopupY = 80;
+ * Title of the result details popup
 var detailPopupTitle = '<?php echo _mb("Details");?>';
+ * Width and height of the result details popup (in pixel)
 var detailPopupWidth = 400;
 var detailPopupHeight = 200;
+ * Absolute position of the result details popup (in pixel)
 var detailPopupX = 750;
 var detailPopupY = 410;
More information about the Mapbender_commits
