[Mapbender-commits] r3937 - trunk/documents/videos
    svn_mapbender at osgeo.org
    Mon May 11 18:31:46 EDT 2009
Author: saith
Date: 2009-05-11 18:31:45 -0400 (Mon, 11 May 2009)
New Revision: 3937
Added:
   trunk/documents/videos/mapbender_login.htm
   trunk/documents/videos/mapbender_login.swf
   trunk/documents/videos/mapbender_login.wnk
   trunk/documents/videos/mapbender_new_gui.htm
   trunk/documents/videos/mapbender_new_gui.swf
   trunk/documents/videos/mapbender_new_gui.wnk
   trunk/documents/videos/mapbender_print_dynamic.htm
   trunk/documents/videos/mapbender_print_dynamic.swf
   trunk/documents/videos/mapbender_print_dynamic.wnk
rename mb_* to mapbender_*
Copied: trunk/documents/videos/mapbender_login.htm (from rev 3936, trunk/documents/videos/mb_login.htm)
--- trunk/documents/videos/mapbender_login.htm	                        (rev 0)
+++ trunk/documents/videos/mapbender_login.htm	2009-05-11 22:31:45 UTC (rev 3937)
@@ -0,0 +1,11 @@
+<HTML>
+<BODY><center><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="739" HEIGHT="850" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0">
+<PARAM NAME=movie VALUE="mapbender_test.swf">
+<PARAM NAME=play VALUE=true>
+<PARAM NAME=loop VALUE=false>
+<PARAM NAME=quality VALUE=low>
+<EMBED SRC="mapbender_login.swf" WIDTH=739 HEIGHT=850 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash">
+</EMBED>
+</OBJECT>
+</center>
+</BODY></HTML>
Copied: trunk/documents/videos/mapbender_login.swf (from rev 3936, trunk/documents/videos/mb_login.swf)
(Binary files differ)
Copied: trunk/documents/videos/mapbender_login.wnk (from rev 3936, trunk/documents/videos/mb_login.wnk)
Copied: trunk/documents/videos/mapbender_new_gui.htm (from rev 3936, trunk/documents/videos/mb_new_gui.htm)
--- trunk/documents/videos/mapbender_new_gui.htm	                        (rev 0)
+++ trunk/documents/videos/mapbender_new_gui.htm	2009-05-11 22:31:45 UTC (rev 3937)
@@ -0,0 +1,11 @@
+<HTML>
+<BODY><center><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="1280" HEIGHT="828" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0">
+<PARAM NAME=movie VALUE="mb_new_gui.swf">
+<EMBED SRC="mapbender_new_gui.swf" WIDTH=1280 HEIGHT=828 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash">
+</EMBED>
+</OBJECT>
+</center>
+</BODY></HTML>
Copied: trunk/documents/videos/mapbender_new_gui.swf (from rev 3936, trunk/documents/videos/mb_new_gui.swf)
Copied: trunk/documents/videos/mapbender_new_gui.wnk (from rev 3936, trunk/documents/videos/mb_new_gui.wnk)
Copied: trunk/documents/videos/mapbender_print_dynamic.htm (from rev 3936, trunk/documents/videos/mb_print_dynamic.htm)
--- trunk/documents/videos/mapbender_print_dynamic.htm	                        (rev 0)
+++ trunk/documents/videos/mapbender_print_dynamic.htm	2009-05-11 22:31:45 UTC (rev 3937)
@@ -0,0 +1,11 @@
+<HTML>
+<BODY><center><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="1280" HEIGHT="839" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0">
+<PARAM NAME=movie VALUE="mb_print_dynamic.swf">
+<EMBED SRC="mapbender_print_dynamic.swf" WIDTH=1280 HEIGHT=839 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash">
+</EMBED>
+</OBJECT>
+</center>
+</BODY></HTML>
Copied: trunk/documents/videos/mapbender_print_dynamic.swf (from rev 3936, trunk/documents/videos/mb_print_dynamic.swf)
Copied: trunk/documents/videos/mapbender_print_dynamic.wnk (from rev 3936, trunk/documents/videos/mb_print_dynamic.wnk)
More information about the Mapbender_commits
