[Mapbender-commits] r3944 - trunk/documents/videos
svn_mapbender at osgeo.org
Fri May 15 09:23:21 EDT 2009
Author: saith
Date: 2009-05-15 09:23:20 -0400 (Fri, 15 May 2009)
New Revision: 3944
Added:
trunk/documents/videos/mapbender_customize.htm
trunk/documents/videos/mapbender_customize.swf
trunk/documents/videos/mapbender_customize.wnk
video: How to use Customize Tree - Module
Added: trunk/documents/videos/mapbender_customize.htm
--- trunk/documents/videos/mapbender_customize.htm (rev 0)
+++ trunk/documents/videos/mapbender_customize.htm 2009-05-15 13:23:20 UTC (rev 3944)
@@ -0,0 +1,11 @@
+<HTML>
+<BODY><center><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="1105" HEIGHT="827" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0">
+<PARAM NAME=movie VALUE="mapbender_customize.swf">
+<PARAM NAME=play VALUE=true>
+<PARAM NAME=loop VALUE=false>
+<PARAM NAME=quality VALUE=low>
+<EMBED SRC="mapbender_customize.swf" WIDTH=1105 HEIGHT=827 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash">
+</EMBED>
+</OBJECT>
+</center>
+</BODY></HTML>
Property changes on: trunk/documents/videos/mapbender_customize.htm
___________________________________________________________________
+ text/html
Added: trunk/documents/videos/mapbender_customize.swf
(Binary files differ)
Property changes on: trunk/documents/videos/mapbender_customize.swf
+ application/octet-stream
Added: trunk/documents/videos/mapbender_customize.wnk
Property changes on: trunk/documents/videos/mapbender_customize.wnk
More information about the Mapbender_commits
