[Mapbender-commits] r3954 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Wed May 20 02:26:50 EDT 2009
Author: verenadiewald
Date: 2009-05-20 02:26:46 -0400 (Wed, 20 May 2009)
New Revision: 3954
branches/2.6/http/javascripts/map_obj.js
var functionName in block add vendor-specific
Modified: branches/2.6/http/javascripts/map_obj.js
--- branches/2.6/http/javascripts/map_obj.js 2009-05-18 13:59:27 UTC (rev 3953)
+++ branches/2.6/http/javascripts/map_obj.js 2009-05-20 06:26:46 UTC (rev 3954)
@@ -535,6 +535,7 @@
// add vendor-specific
for (var v = 0; v < mb_vendorSpecific.length; v++) {
+ var functionName = 'setMapRequest';
var vendorSpecificString = eval(mb_vendorSpecific[v]);
// if eval doesn't evaluate a function, the result is undefined.
// Sometimes it is necessary not to evaluate a function, for
@@ -719,8 +720,6 @@
this.setMapRequest = function(){
- var functionName = 'setMapRequest';
var ret = eventBeforeMapRequest.trigger({
map: this
}, "AND");
More information about the Mapbender_commits
