[Mapbender-commits] r3957 - in branches/print_dev: http/extensions
http/img http/img/button_digitize http/javascripts http/php
lib resources/db/update
svn_mapbender at osgeo.org
Fri May 22 08:10:55 EDT 2009
Author: mschulz
Date: 2009-05-22 08:10:55 -0400 (Fri, 22 May 2009)
New Revision: 3957
Added:
branches/print_dev/http/extensions/jquery-ui-personalized-1.5.2.js
branches/print_dev/http/extensions/jquery.contextmenu.r2.js
branches/print_dev/http/img/OSGeo_logo.png
branches/print_dev/http/img/button_digitize/geomClone.png
branches/print_dev/http/javascripts/mod_addWmsFromFilteredList_button.php
branches/print_dev/http/php/mod_customTree.php
branches/print_dev/http/php/mod_customTree_server.php
branches/print_dev/lib/customTreeController.js
branches/print_dev/lib/customTreeModel.js
branches/print_dev/resources/db/update/update_2.7.sql
merged from trunk
Added: branches/print_dev/http/extensions/jquery-ui-personalized-1.5.2.js
--- branches/print_dev/http/extensions/jquery-ui-personalized-1.5.2.js (rev 0)
+++ branches/print_dev/http/extensions/jquery-ui-personalized-1.5.2.js 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,1134 @@
+ * jQuery UI @VERSION
+ * Copyright (c) 2008 Paul Bakaus (ui.jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * http://docs.jquery.com/UI
+;(function($) {
+$.ui = {
+ plugin: {
+ add: function(module, option, set) {
+ var proto = $.ui[module].prototype;
+ for(var i in set) {
+ proto.plugins[i] = proto.plugins[i] || [];
+ proto.plugins[i].push([option, set[i]]);
+ call: function(instance, name, args) {
+ var set = instance.plugins[name];
+ if(!set) { return; }
+ for (var i = 0; i < set.length; i++) {
+ if (instance.options[set[i][0]]) {
+ set[i][1].apply(instance.element, args);
+ cssCache: {},
+ css: function(name) {
+ if ($.ui.cssCache[name]) { return $.ui.cssCache[name]; }
+ var tmp = $('<div class="ui-gen">').addClass(name).css({position:'absolute', top:'-5000px', left:'-5000px', display:'block'}).appendTo('body');
+ //if (!$.browser.safari)
+ //tmp.appendTo('body');
+ //Opera and Safari set width and height to 0px instead of auto
+ //Safari returns rgba(0,0,0,0) when bgcolor is not set
+ $.ui.cssCache[name] = !!(
+ (!(/auto|default/).test(tmp.css('cursor')) || (/^[1-9]/).test(tmp.css('height')) || (/^[1-9]/).test(tmp.css('width')) ||
+ !(/none/).test(tmp.css('backgroundImage')) || !(/transparent|rgba\(0, 0, 0, 0\)/).test(tmp.css('backgroundColor')))
+ try { $('body').get(0).removeChild(tmp.get(0)); } catch(e){}
+ return $.ui.cssCache[name];
+ disableSelection: function(el) {
+ $(el).attr('unselectable', 'on').css('MozUserSelect', 'none');
+ enableSelection: function(el) {
+ $(el).attr('unselectable', 'off').css('MozUserSelect', '');
+ hasScroll: function(e, a) {
+ var scroll = /top/.test(a||"top") ? 'scrollTop' : 'scrollLeft', has = false;
+ if (e[scroll] > 0) return true; e[scroll] = 1;
+ has = e[scroll] > 0 ? true : false; e[scroll] = 0;
+ return has;
+/** jQuery core modifications and additions **/
+var _remove = $.fn.remove;
+$.fn.remove = function() {
+ $("*", this).add(this).triggerHandler("remove");
+ return _remove.apply(this, arguments );
+// $.widget is a factory to create jQuery plugins
+// taking some boilerplate code out of the plugin code
+// created by Scott González and Jörn Zaefferer
+function getter(namespace, plugin, method) {
+ var methods = $[namespace][plugin].getter || [];
+ methods = (typeof methods == "string" ? methods.split(/,?\s+/) : methods);
+ return ($.inArray(method, methods) != -1);
+$.widget = function(name, prototype) {
+ var namespace = name.split(".")[0];
+ name = name.split(".")[1];
+ // create plugin method
+ $.fn[name] = function(options) {
+ var isMethodCall = (typeof options == 'string'),
+ args = Array.prototype.slice.call(arguments, 1);
+ if (isMethodCall && getter(namespace, name, options)) {
+ var instance = $.data(this[0], name);
+ return (instance ? instance[options].apply(instance, args)
+ : undefined);
+ return this.each(function() {
+ var instance = $.data(this, name);
+ if (isMethodCall && instance && $.isFunction(instance[options])) {
+ instance[options].apply(instance, args);
+ } else if (!isMethodCall) {
+ $.data(this, name, new $[namespace][name](this, options));
+ // create widget constructor
+ $[namespace][name] = function(element, options) {
+ var self = this;
+ this.widgetName = name;
+ this.widgetBaseClass = namespace + '-' + name;
+ this.options = $.extend({}, $.widget.defaults, $[namespace][name].defaults, options);
+ this.element = $(element)
+ .bind('setData.' + name, function(e, key, value) {
+ return self.setData(key, value);
+ .bind('getData.' + name, function(e, key) {
+ return self.getData(key);
+ .bind('remove', function() {
+ return self.destroy();
+ this.init();
+ // add widget prototype
+ $[namespace][name].prototype = $.extend({}, $.widget.prototype, prototype);
+$.widget.prototype = {
+ init: function() {},
+ destroy: function() {
+ this.element.removeData(this.widgetName);
+ getData: function(key) {
+ return this.options[key];
+ setData: function(key, value) {
+ this.options[key] = value;
+ if (key == 'disabled') {
+ this.element[value ? 'addClass' : 'removeClass'](
+ this.widgetBaseClass + '-disabled');
+ enable: function() {
+ this.setData('disabled', false);
+ disable: function() {
+ this.setData('disabled', true);
+$.widget.defaults = {
+ disabled: false
+/** Mouse Interaction Plugin **/
+$.ui.mouse = {
+ mouseInit: function() {
+ var self = this;
+ this.element.bind('mousedown.'+this.widgetName, function(e) {
+ return self.mouseDown(e);
+ // Prevent text selection in IE
+ if ($.browser.msie) {
+ this._mouseUnselectable = this.element.attr('unselectable');
+ this.element.attr('unselectable', 'on');
+ this.started = false;
+ // TODO: make sure destroying one instance of mouse doesn't mess with
+ // other instances of mouse
+ mouseDestroy: function() {
+ this.element.unbind('.'+this.widgetName);
+ // Restore text selection in IE
+ ($.browser.msie
+ && this.element.attr('unselectable', this._mouseUnselectable));
+ mouseDown: function(e) {
+ // we may have missed mouseup (out of window)
+ (this._mouseStarted && this.mouseUp(e));
+ this._mouseDownEvent = e;
+ var self = this,
+ btnIsLeft = (e.which == 1),
+ elIsCancel = (typeof this.options.cancel == "string" ? $(e.target).parents().add(e.target).filter(this.options.cancel).length : false);
+ if (!btnIsLeft || elIsCancel || !this.mouseCapture(e)) {
+ return true;
+ this._mouseDelayMet = !this.options.delay;
+ if (!this._mouseDelayMet) {
+ this._mouseDelayTimer = setTimeout(function() {
+ self._mouseDelayMet = true;
+ }, this.options.delay);
+ if (this.mouseDistanceMet(e) && this.mouseDelayMet(e)) {
+ this._mouseStarted = (this.mouseStart(e) !== false);
+ if (!this._mouseStarted) {
+ e.preventDefault();
+ return true;
+ // these delegates are required to keep context
+ this._mouseMoveDelegate = function(e) {
+ return self.mouseMove(e);
+ this._mouseUpDelegate = function(e) {
+ return self.mouseUp(e);
+ $(document)
+ .bind('mousemove.'+this.widgetName, this._mouseMoveDelegate)
+ .bind('mouseup.'+this.widgetName, this._mouseUpDelegate);
+ return false;
+ mouseMove: function(e) {
+ // IE mouseup check - mouseup happened when mouse was out of window
+ if ($.browser.msie && !e.button) {
+ return this.mouseUp(e);
+ if (this._mouseStarted) {
+ this.mouseDrag(e);
+ return false;
+ (this.mouseStart(this._mouseDownEvent, e) !== false);
+ (this._mouseStarted ? this.mouseDrag(e) : this.mouseUp(e));
+ return !this._mouseStarted;
+ mouseUp: function(e) {
+ $(document)
+ .unbind('mousemove.'+this.widgetName, this._mouseMoveDelegate)
+ .unbind('mouseup.'+this.widgetName, this._mouseUpDelegate);
+ this._mouseStarted = false;
+ this.mouseStop(e);
+ return false;
+ mouseDistanceMet: function(e) {
+ return (Math.max(
+ Math.abs(this._mouseDownEvent.pageX - e.pageX),
+ Math.abs(this._mouseDownEvent.pageY - e.pageY)
+ ) >= this.options.distance
+ mouseDelayMet: function(e) {
+ return this._mouseDelayMet;
+ // These are placeholder methods, to be overriden by extending plugin
+ mouseStart: function(e) {},
+ mouseDrag: function(e) {},
+ mouseStop: function(e) {},
+ mouseCapture: function(e) { return true; }
+$.ui.mouse.defaults = {
+ cancel: null,
+ distance: 1,
+ delay: 0
+})(jQuery);
+ * jQuery UI Draggable
+ * http://docs.jquery.com/UI/Draggables
+ * Depends:
+ * ui.core.js
+(function($) {
+$.widget("ui.draggable", $.extend({}, $.ui.mouse, {
+ //Initialize needed constants
+ var o = this.options;
+ //Position the node
+ if (o.helper == 'original' && !(/(relative|absolute|fixed)/).test(this.element.css('position')))
+ this.element.css('position', 'relative');
+ this.element.addClass('ui-draggable');
+ (o.disabled && this.element.addClass('ui-draggable-disabled'));
+ this.mouseInit();
+ if (this.helper || o.disabled || $(e.target).is('.ui-resizable-handle')) return false;
+ var handle = !this.options.handle || !$(this.options.handle, this.element).length ? true : false;
+ $(this.options.handle, this.element).find("*").andSelf().each(function() {
+ if(this == e.target) handle = true;
+ if (!handle) return false;
+ if($.ui.ddmanager) $.ui.ddmanager.current = this;
+ //Create and append the visible helper
+ this.helper = $.isFunction(o.helper) ? $(o.helper.apply(this.element[0], [e])) : (o.helper == 'clone' ? this.element.clone() : this.element);
+ if(!this.helper.parents('body').length) this.helper.appendTo((o.appendTo == 'parent' ? this.element[0].parentNode : o.appendTo));
+ if(this.helper[0] != this.element[0] && !(/(fixed|absolute)/).test(this.helper.css("position"))) this.helper.css("position", "absolute");
+ * - Position generation -
+ * This block generates everything position related - it's the core of draggables.
+ this.margins = { //Cache the margins
+ left: (parseInt(this.element.css("marginLeft"),10) || 0),
+ top: (parseInt(this.element.css("marginTop"),10) || 0)
+ this.cssPosition = this.helper.css("position"); //Store the helper's css position
+ this.offset = this.element.offset(); //The element's absolute position on the page
+ this.offset = { //Substract the margins from the element's absolute offset
+ top: this.offset.top - this.margins.top,
+ left: this.offset.left - this.margins.left
+ this.offset.click = { //Where the click happened, relative to the element
+ left: e.pageX - this.offset.left,
+ top: e.pageY - this.offset.top
+ this.offsetParent = this.helper.offsetParent(); var po = this.offsetParent.offset(); //Get the offsetParent and cache its position
+ if(this.offsetParent[0] == document.body && $.browser.mozilla) po = { top: 0, left: 0 }; //Ugly FF3 fix
+ this.offset.parent = { //Store its position plus border
+ top: po.top + (parseInt(this.offsetParent.css("borderTopWidth"),10) || 0),
+ left: po.left + (parseInt(this.offsetParent.css("borderLeftWidth"),10) || 0)
+ var p = this.element.position(); //This is a relative to absolute position minus the actual position calculation - only used for relative positioned helpers
+ this.offset.relative = this.cssPosition == "relative" ? {
+ top: p.top - (parseInt(this.helper.css("top"),10) || 0) + this.offsetParent[0].scrollTop,
+ left: p.left - (parseInt(this.helper.css("left"),10) || 0) + this.offsetParent[0].scrollLeft
+ } : { top: 0, left: 0 };
+ this.originalPosition = this.generatePosition(e); //Generate the original position
+ this.helperProportions = { width: this.helper.outerWidth(), height: this.helper.outerHeight() };//Cache the helper size
+ if(o.cursorAt) {
+ if(o.cursorAt.left != undefined) this.offset.click.left = o.cursorAt.left + this.margins.left;
+ if(o.cursorAt.right != undefined) this.offset.click.left = this.helperProportions.width - o.cursorAt.right + this.margins.left;
+ if(o.cursorAt.top != undefined) this.offset.click.top = o.cursorAt.top + this.margins.top;
+ if(o.cursorAt.bottom != undefined) this.offset.click.top = this.helperProportions.height - o.cursorAt.bottom + this.margins.top;
+ * - Position constraining -
+ * Here we prepare position constraining like grid and containment.
+ if(o.containment) {
+ if(o.containment == 'parent') o.containment = this.helper[0].parentNode;
+ if(o.containment == 'document' || o.containment == 'window') this.containment = [
+ 0 - this.offset.relative.left - this.offset.parent.left,
+ 0 - this.offset.relative.top - this.offset.parent.top,
+ $(o.containment == 'document' ? document : window).width() - this.offset.relative.left - this.offset.parent.left - this.helperProportions.width - this.margins.left - (parseInt(this.element.css("marginRight"),10) || 0),
+ ($(o.containment == 'document' ? document : window).height() || document.body.parentNode.scrollHeight) - this.offset.relative.top - this.offset.parent.top - this.helperProportions.height - this.margins.top - (parseInt(this.element.css("marginBottom"),10) || 0)
+ if(!(/^(document|window|parent)$/).test(o.containment)) {
+ var ce = $(o.containment)[0];
+ var co = $(o.containment).offset();
+ this.containment = [
+ co.left + (parseInt($(ce).css("borderLeftWidth"),10) || 0) - this.offset.relative.left - this.offset.parent.left,
+ co.top + (parseInt($(ce).css("borderTopWidth"),10) || 0) - this.offset.relative.top - this.offset.parent.top,
+ co.left+Math.max(ce.scrollWidth,ce.offsetWidth) - (parseInt($(ce).css("borderLeftWidth"),10) || 0) - this.offset.relative.left - this.offset.parent.left - this.helperProportions.width - this.margins.left - (parseInt(this.element.css("marginRight"),10) || 0),
+ co.top+Math.max(ce.scrollHeight,ce.offsetHeight) - (parseInt($(ce).css("borderTopWidth"),10) || 0) - this.offset.relative.top - this.offset.parent.top - this.helperProportions.height - this.margins.top - (parseInt(this.element.css("marginBottom"),10) || 0)
+ //Call plugins and callbacks
+ this.propagate("start", e);
+ this.helperProportions = { width: this.helper.outerWidth(), height: this.helper.outerHeight() };//Recache the helper size
+ if ($.ui.ddmanager && !o.dropBehaviour) $.ui.ddmanager.prepareOffsets(this, e);
+ this.helper.addClass("ui-draggable-dragging");
+ this.mouseDrag(e); //Execute the drag once - this causes the helper not to be visible before getting its correct position
+ return true;
+ convertPositionTo: function(d, pos) {
+ if(!pos) pos = this.position;
+ var mod = d == "absolute" ? 1 : -1;
+ return {
+ top: (
+ pos.top // the calculated relative position
+ + this.offset.relative.top * mod // Only for relative positioned nodes: Relative offset from element to offset parent
+ + this.offset.parent.top * mod // The offsetParent's offset without borders (offset + border)
+ - (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollTop) * mod // The offsetParent's scroll position, not if the element is fixed
+ + (this.cssPosition == "fixed" ? $(document).scrollTop() : 0) * mod
+ + this.margins.top * mod //Add the margin (you don't want the margin counting in intersection methods)
+ left: (
+ pos.left // the calculated relative position
+ + this.offset.relative.left * mod // Only for relative positioned nodes: Relative offset from element to offset parent
+ + this.offset.parent.left * mod // The offsetParent's offset without borders (offset + border)
+ - (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollLeft) * mod // The offsetParent's scroll position, not if the element is fixed
+ + (this.cssPosition == "fixed" ? $(document).scrollLeft() : 0) * mod
+ + this.margins.left * mod //Add the margin (you don't want the margin counting in intersection methods)
+ generatePosition: function(e) {
+ var position = {
+ top: (
+ e.pageY // The absolute mouse position
+ - this.offset.click.top // Click offset (relative to the element)
+ - this.offset.relative.top // Only for relative positioned nodes: Relative offset from element to offset parent
+ - this.offset.parent.top // The offsetParent's offset without borders (offset + border)
+ + (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollTop) // The offsetParent's scroll position, not if the element is fixed
+ - (this.cssPosition == "fixed" ? $(document).scrollTop() : 0)
+ left: (
+ e.pageX // The absolute mouse position
+ - this.offset.click.left // Click offset (relative to the element)
+ - this.offset.relative.left // Only for relative positioned nodes: Relative offset from element to offset parent
+ - this.offset.parent.left // The offsetParent's offset without borders (offset + border)
+ + (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollLeft) // The offsetParent's scroll position, not if the element is fixed
+ - (this.cssPosition == "fixed" ? $(document).scrollLeft() : 0)
+ if(!this.originalPosition) return position; //If we are not dragging yet, we won't check for options
+ * Constrain the position to a mix of grid, containment.
+ if(this.containment) {
+ if(position.left < this.containment[0]) position.left = this.containment[0];
+ if(position.top < this.containment[1]) position.top = this.containment[1];
+ if(position.left > this.containment[2]) position.left = this.containment[2];
+ if(position.top > this.containment[3]) position.top = this.containment[3];
+ if(o.grid) {
+ var top = this.originalPosition.top + Math.round((position.top - this.originalPosition.top) / o.grid[1]) * o.grid[1];
+ position.top = this.containment ? (!(top < this.containment[1] || top > this.containment[3]) ? top : (!(top < this.containment[1]) ? top - o.grid[1] : top + o.grid[1])) : top;
+ var left = this.originalPosition.left + Math.round((position.left - this.originalPosition.left) / o.grid[0]) * o.grid[0];
+ position.left = this.containment ? (!(left < this.containment[0] || left > this.containment[2]) ? left : (!(left < this.containment[0]) ? left - o.grid[0] : left + o.grid[0])) : left;
+ return position;
+ //Compute the helpers position
+ this.position = this.generatePosition(e);
+ this.positionAbs = this.convertPositionTo("absolute");
+ //Call plugins and callbacks and use the resulting position if something is returned
+ this.position = this.propagate("drag", e) || this.position;
+ if(!this.options.axis || this.options.axis != "y") this.helper[0].style.left = this.position.left+'px';
+ if(!this.options.axis || this.options.axis != "x") this.helper[0].style.top = this.position.top+'px';
+ if($.ui.ddmanager) $.ui.ddmanager.drag(this, e);
+ return false;
+ //If we are using droppables, inform the manager about the drop
+ var dropped = false;
+ if ($.ui.ddmanager && !this.options.dropBehaviour)
+ var dropped = $.ui.ddmanager.drop(this, e);
+ if((this.options.revert == "invalid" && !dropped) || (this.options.revert == "valid" && dropped) || this.options.revert === true) {
+ var self = this;
+ $(this.helper).animate(this.originalPosition, parseInt(this.options.revert, 10) || 500, function() {
+ self.propagate("stop", e);
+ self.clear();
+ } else {
+ this.propagate("stop", e);
+ this.clear();
+ return false;
+ clear: function() {
+ this.helper.removeClass("ui-draggable-dragging");
+ if(this.options.helper != 'original' && !this.cancelHelperRemoval) this.helper.remove();
+ //if($.ui.ddmanager) $.ui.ddmanager.current = null;
+ this.helper = null;
+ this.cancelHelperRemoval = false;
+ // From now on bulk stuff - mainly helpers
+ plugins: {},
+ uiHash: function(e) {
+ return {
+ helper: this.helper,
+ position: this.position,
+ absolutePosition: this.positionAbs,
+ options: this.options
+ propagate: function(n,e) {
+ $.ui.plugin.call(this, n, [e, this.uiHash()]);
+ if(n == "drag") this.positionAbs = this.convertPositionTo("absolute"); //The absolute position has to be recalculated after plugins
+ return this.element.triggerHandler(n == "drag" ? n : "drag"+n, [e, this.uiHash()], this.options[n]);
+ if(!this.element.data('draggable')) return;
+ this.element.removeData("draggable").unbind(".draggable").removeClass('ui-draggable');
+ this.mouseDestroy();
+$.extend($.ui.draggable, {
+ defaults: {
+ appendTo: "parent",
+ axis: false,
+ cancel: ":input",
+ delay: 0,
+ distance: 1,
+ helper: "original"
+$.ui.plugin.add("draggable", "cursor", {
+ start: function(e, ui) {
+ var t = $('body');
+ if (t.css("cursor")) ui.options._cursor = t.css("cursor");
+ t.css("cursor", ui.options.cursor);
+ stop: function(e, ui) {
+ if (ui.options._cursor) $('body').css("cursor", ui.options._cursor);
+$.ui.plugin.add("draggable", "zIndex", {
+ var t = $(ui.helper);
+ if(t.css("zIndex")) ui.options._zIndex = t.css("zIndex");
+ t.css('zIndex', ui.options.zIndex);
+ if(ui.options._zIndex) $(ui.helper).css('zIndex', ui.options._zIndex);
+$.ui.plugin.add("draggable", "opacity", {
+ if(t.css("opacity")) ui.options._opacity = t.css("opacity");
+ t.css('opacity', ui.options.opacity);
+ if(ui.options._opacity) $(ui.helper).css('opacity', ui.options._opacity);
+$.ui.plugin.add("draggable", "iframeFix", {
+ $(ui.options.iframeFix === true ? "iframe" : ui.options.iframeFix).each(function() {
+ $('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>')
+ .css({
+ width: this.offsetWidth+"px", height: this.offsetHeight+"px",
+ position: "absolute", opacity: "0.001", zIndex: 1000
+ .css($(this).offset())
+ .appendTo("body");
+ $("div.DragDropIframeFix").each(function() { this.parentNode.removeChild(this); }); //Remove frame helpers
+$.ui.plugin.add("draggable", "scroll", {
+ var o = ui.options;
+ var i = $(this).data("draggable");
+ o.scrollSensitivity = o.scrollSensitivity || 20;
+ o.scrollSpeed = o.scrollSpeed || 20;
+ i.overflowY = function(el) {
+ do { if(/auto|scroll/.test(el.css('overflow')) || (/auto|scroll/).test(el.css('overflow-y'))) return el; el = el.parent(); } while (el[0].parentNode);
+ return $(document);
+ }(this);
+ i.overflowX = function(el) {
+ do { if(/auto|scroll/.test(el.css('overflow')) || (/auto|scroll/).test(el.css('overflow-x'))) return el; el = el.parent(); } while (el[0].parentNode);
+ }(this);
+ if(i.overflowY[0] != document && i.overflowY[0].tagName != 'HTML') i.overflowYOffset = i.overflowY.offset();
+ if(i.overflowX[0] != document && i.overflowX[0].tagName != 'HTML') i.overflowXOffset = i.overflowX.offset();
+ drag: function(e, ui) {
+ if(i.overflowY[0] != document && i.overflowY[0].tagName != 'HTML') {
+ if((i.overflowYOffset.top + i.overflowY[0].offsetHeight) - e.pageY < o.scrollSensitivity)
+ i.overflowY[0].scrollTop = i.overflowY[0].scrollTop + o.scrollSpeed;
+ if(e.pageY - i.overflowYOffset.top < o.scrollSensitivity)
+ i.overflowY[0].scrollTop = i.overflowY[0].scrollTop - o.scrollSpeed;
+ } else {
+ if(e.pageY - $(document).scrollTop() < o.scrollSensitivity)
+ $(document).scrollTop($(document).scrollTop() - o.scrollSpeed);
+ if($(window).height() - (e.pageY - $(document).scrollTop()) < o.scrollSensitivity)
+ $(document).scrollTop($(document).scrollTop() + o.scrollSpeed);
+ if(i.overflowX[0] != document && i.overflowX[0].tagName != 'HTML') {
+ if((i.overflowXOffset.left + i.overflowX[0].offsetWidth) - e.pageX < o.scrollSensitivity)
+ i.overflowX[0].scrollLeft = i.overflowX[0].scrollLeft + o.scrollSpeed;
+ if(e.pageX - i.overflowXOffset.left < o.scrollSensitivity)
+ i.overflowX[0].scrollLeft = i.overflowX[0].scrollLeft - o.scrollSpeed;
+ } else {
+ if(e.pageX - $(document).scrollLeft() < o.scrollSensitivity)
+ $(document).scrollLeft($(document).scrollLeft() - o.scrollSpeed);
+ if($(window).width() - (e.pageX - $(document).scrollLeft()) < o.scrollSensitivity)
+ $(document).scrollLeft($(document).scrollLeft() + o.scrollSpeed);
+$.ui.plugin.add("draggable", "snap", {
+ var inst = $(this).data("draggable");
+ inst.snapElements = [];
+ $(ui.options.snap === true ? '.ui-draggable' : ui.options.snap).each(function() {
+ var $t = $(this); var $o = $t.offset();
+ if(this != inst.element[0]) inst.snapElements.push({
+ item: this,
+ width: $t.outerWidth(), height: $t.outerHeight(),
+ top: $o.top, left: $o.left
+ var d = ui.options.snapTolerance || 20;
+ var x1 = ui.absolutePosition.left, x2 = x1 + inst.helperProportions.width,
+ y1 = ui.absolutePosition.top, y2 = y1 + inst.helperProportions.height;
+ for (var i = inst.snapElements.length - 1; i >= 0; i--){
+ var l = inst.snapElements[i].left, r = l + inst.snapElements[i].width,
+ t = inst.snapElements[i].top, b = t + inst.snapElements[i].height;
+ //Yes, I know, this is insane ;)
+ if(!((l-d < x1 && x1 < r+d && t-d < y1 && y1 < b+d) || (l-d < x1 && x1 < r+d && t-d < y2 && y2 < b+d) || (l-d < x2 && x2 < r+d && t-d < y1 && y1 < b+d) || (l-d < x2 && x2 < r+d && t-d < y2 && y2 < b+d))) continue;
+ if(ui.options.snapMode != 'inner') {
+ var ts = Math.abs(t - y2) <= 20;
+ var bs = Math.abs(b - y1) <= 20;
+ var ls = Math.abs(l - x2) <= 20;
+ var rs = Math.abs(r - x1) <= 20;
+ if(ts) ui.position.top = inst.convertPositionTo("relative", { top: t - inst.helperProportions.height, left: 0 }).top;
+ if(bs) ui.position.top = inst.convertPositionTo("relative", { top: b, left: 0 }).top;
+ if(ls) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: l - inst.helperProportions.width }).left;
+ if(rs) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: r }).left;
+ if(ui.options.snapMode != 'outer') {
+ var ts = Math.abs(t - y1) <= 20;
+ var bs = Math.abs(b - y2) <= 20;
+ var ls = Math.abs(l - x1) <= 20;
+ var rs = Math.abs(r - x2) <= 20;
+ if(ts) ui.position.top = inst.convertPositionTo("relative", { top: t, left: 0 }).top;
+ if(bs) ui.position.top = inst.convertPositionTo("relative", { top: b - inst.helperProportions.height, left: 0 }).top;
+ if(ls) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: l }).left;
+ if(rs) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: r - inst.helperProportions.width }).left;
+$.ui.plugin.add("draggable", "connectToSortable", {
+ start: function(e,ui) {
+ inst.sortables = [];
+ $(ui.options.connectToSortable).each(function() {
+ if($.data(this, 'sortable')) {
+ var sortable = $.data(this, 'sortable');
+ inst.sortables.push({
+ instance: sortable,
+ shouldRevert: sortable.options.revert
+ sortable.refreshItems(); //Do a one-time refresh at start to refresh the containerCache
+ sortable.propagate("activate", e, inst);
+ stop: function(e,ui) {
+ //If we are still over the sortable, we fake the stop event of the sortable, but also remove helper
+ $.each(inst.sortables, function() {
+ if(this.instance.isOver) {
+ this.instance.isOver = 0;
+ inst.cancelHelperRemoval = true; //Don't remove the helper in the draggable instance
+ this.instance.cancelHelperRemoval = false; //Remove it in the sortable instance (so sortable plugins like revert still work)
+ if(this.shouldRevert) this.instance.options.revert = true; //revert here
+ this.instance.mouseStop(e);
+ //Also propagate receive event, since the sortable is actually receiving a element
+ this.instance.element.triggerHandler("sortreceive", [e, $.extend(this.instance.ui(), { sender: inst.element })], this.instance.options["receive"]);
+ this.instance.options.helper = this.instance.options._helper;
+ } else {
+ this.instance.propagate("deactivate", e, inst);
+ drag: function(e,ui) {
+ var inst = $(this).data("draggable"), self = this;
+ var checkPos = function(o) {
+ var l = o.left, r = l + o.width,
+ t = o.top, b = t + o.height;
+ return (l < (this.positionAbs.left + this.offset.click.left) && (this.positionAbs.left + this.offset.click.left) < r
+ && t < (this.positionAbs.top + this.offset.click.top) && (this.positionAbs.top + this.offset.click.top) < b);
+ $.each(inst.sortables, function(i) {
+ if(checkPos.call(inst, this.instance.containerCache)) {
+ //If it intersects, we use a little isOver variable and set it once, so our move-in stuff gets fired only once
+ if(!this.instance.isOver) {
+ this.instance.isOver = 1;
+ //Now we fake the start of dragging for the sortable instance,
+ //by cloning the list group item, appending it to the sortable and using it as inst.currentItem
+ //We can then fire the start event of the sortable with our passed browser event, and our own helper (so it doesn't create a new one)
+ this.instance.currentItem = $(self).clone().appendTo(this.instance.element).data("sortable-item", true);
+ this.instance.options._helper = this.instance.options.helper; //Store helper option to later restore it
+ this.instance.options.helper = function() { return ui.helper[0]; };
+ e.target = this.instance.currentItem[0];
+ this.instance.mouseCapture(e, true);
+ this.instance.mouseStart(e, true, true);
+ //Because the browser event is way off the new appended portlet, we modify a couple of variables to reflect the changes
+ this.instance.offset.click.top = inst.offset.click.top;
+ this.instance.offset.click.left = inst.offset.click.left;
+ this.instance.offset.parent.left -= inst.offset.parent.left - this.instance.offset.parent.left;
+ this.instance.offset.parent.top -= inst.offset.parent.top - this.instance.offset.parent.top;
+ inst.propagate("toSortable", e);
+ //Provided we did all the previous steps, we can fire the drag event of the sortable on every draggable drag, when it intersects with the sortable
+ if(this.instance.currentItem) this.instance.mouseDrag(e);
+ } else {
+ //If it doesn't intersect with the sortable, and it intersected before,
+ //we fake the drag stop of the sortable, but make sure it doesn't remove the helper by using cancelHelperRemoval
+ this.instance.cancelHelperRemoval = true;
+ this.instance.options.revert = false; //No revert here
+ this.instance.mouseStop(e, true);
+ //Now we remove our currentItem, the list group clone again, and the placeholder, and animate the helper back to it's original size
+ this.instance.currentItem.remove();
+ if(this.instance.placeholder) this.instance.placeholder.remove();
+ inst.propagate("fromSortable", e);
+$.ui.plugin.add("draggable", "stack", {
+ var group = $.makeArray($(ui.options.stack.group)).sort(function(a,b) {
+ return (parseInt($(a).css("zIndex"),10) || ui.options.stack.min) - (parseInt($(b).css("zIndex"),10) || ui.options.stack.min);
+ $(group).each(function(i) {
+ this.style.zIndex = ui.options.stack.min + i;
+ this[0].style.zIndex = ui.options.stack.min + group.length;
+})(jQuery);
+ * jQuery UI Droppable
+ * http://docs.jquery.com/UI/Droppables
+ * Depends:
+ * ui.core.js
+ * ui.draggable.js
+(function($) {
+$.widget("ui.droppable", {
+ this.element.addClass("ui-droppable");
+ this.isover = 0; this.isout = 1;
+ //Prepare the passed options
+ var o = this.options, accept = o.accept;
+ o = $.extend(o, {
+ accept: o.accept && o.accept.constructor == Function ? o.accept : function(d) {
+ return $(d).is(accept);
+ //Store the droppable's proportions
+ this.proportions = { width: this.element[0].offsetWidth, height: this.element[0].offsetHeight };
+ // Add the reference and positions to the manager
+ $.ui.ddmanager.droppables.push(this);
+ plugins: {},
+ ui: function(c) {
+ return {
+ draggable: (c.currentItem || c.element),
+ helper: c.helper,
+ position: c.position,
+ absolutePosition: c.positionAbs,
+ options: this.options,
+ element: this.element
+ var drop = $.ui.ddmanager.droppables;
+ for ( var i = 0; i < drop.length; i++ )
+ if ( drop[i] == this )
+ drop.splice(i, 1);
+ this.element
+ .removeClass("ui-droppable ui-droppable-disabled")
+ .removeData("droppable")
+ .unbind(".droppable");
+ over: function(e) {
+ var draggable = $.ui.ddmanager.current;
+ if (!draggable || (draggable.currentItem || draggable.element)[0] == this.element[0]) return; // Bail if draggable and droppable are same element
+ if (this.options.accept.call(this.element,(draggable.currentItem || draggable.element))) {
+ $.ui.plugin.call(this, 'over', [e, this.ui(draggable)]);
+ this.element.triggerHandler("dropover", [e, this.ui(draggable)], this.options.over);
+ out: function(e) {
+ $.ui.plugin.call(this, 'out', [e, this.ui(draggable)]);
+ this.element.triggerHandler("dropout", [e, this.ui(draggable)], this.options.out);
+ drop: function(e,custom) {
+ var draggable = custom || $.ui.ddmanager.current;
+ if (!draggable || (draggable.currentItem || draggable.element)[0] == this.element[0]) return false; // Bail if draggable and droppable are same element
+ var childrenIntersection = false;
+ this.element.find(".ui-droppable").not(".ui-draggable-dragging").each(function() {
+ var inst = $.data(this, 'droppable');
+ if(inst.options.greedy && $.ui.intersect(draggable, $.extend(inst, { offset: inst.element.offset() }), inst.options.tolerance)) {
+ childrenIntersection = true; return false;
+ if(childrenIntersection) return false;
+ if(this.options.accept.call(this.element,(draggable.currentItem || draggable.element))) {
+ $.ui.plugin.call(this, 'drop', [e, this.ui(draggable)]);
+ this.element.triggerHandler("drop", [e, this.ui(draggable)], this.options.drop);
+ return true;
+ return false;
+ activate: function(e) {
+ $.ui.plugin.call(this, 'activate', [e, this.ui(draggable)]);
+ if(draggable) this.element.triggerHandler("dropactivate", [e, this.ui(draggable)], this.options.activate);
+ deactivate: function(e) {
+ $.ui.plugin.call(this, 'deactivate', [e, this.ui(draggable)]);
+ if(draggable) this.element.triggerHandler("dropdeactivate", [e, this.ui(draggable)], this.options.deactivate);
+$.extend($.ui.droppable, {
+ defaults: {
+ disabled: false,
+ tolerance: 'intersect'
+$.ui.intersect = function(draggable, droppable, toleranceMode) {
+ if (!droppable.offset) return false;
+ var x1 = (draggable.positionAbs || draggable.position.absolute).left, x2 = x1 + draggable.helperProportions.width,
+ y1 = (draggable.positionAbs || draggable.position.absolute).top, y2 = y1 + draggable.helperProportions.height;
+ var l = droppable.offset.left, r = l + droppable.proportions.width,
+ t = droppable.offset.top, b = t + droppable.proportions.height;
+ switch (toleranceMode) {
+ case 'fit':
+ return (l < x1 && x2 < r
+ && t < y1 && y2 < b);
+ break;
+ case 'intersect':
+ return (l < x1 + (draggable.helperProportions.width / 2) // Right Half
+ && x2 - (draggable.helperProportions.width / 2) < r // Left Half
+ && t < y1 + (draggable.helperProportions.height / 2) // Bottom Half
+ && y2 - (draggable.helperProportions.height / 2) < b ); // Top Half
+ break;
+ case 'pointer':
+ return (l < ((draggable.positionAbs || draggable.position.absolute).left + (draggable.clickOffset || draggable.offset.click).left) && ((draggable.positionAbs || draggable.position.absolute).left + (draggable.clickOffset || draggable.offset.click).left) < r
+ && t < ((draggable.positionAbs || draggable.position.absolute).top + (draggable.clickOffset || draggable.offset.click).top) && ((draggable.positionAbs || draggable.position.absolute).top + (draggable.clickOffset || draggable.offset.click).top) < b);
+ break;
+ case 'touch':
+ return (
+ (y1 >= t && y1 <= b) || // Top edge touching
+ (y2 >= t && y2 <= b) || // Bottom edge touching
+ (y1 < t && y2 > b) // Surrounded vertically
+ (x1 >= l && x1 <= r) || // Left edge touching
+ (x2 >= l && x2 <= r) || // Right edge touching
+ (x1 < l && x2 > r) // Surrounded horizontally
+ break;
+ default:
+ return false;
+ break;
+ This manager tracks offsets of draggables and droppables
+$.ui.ddmanager = {
+ current: null,
+ droppables: [],
+ prepareOffsets: function(t, e) {
+ var m = $.ui.ddmanager.droppables;
+ var type = e ? e.type : null; // workaround for #2317
+ for (var i = 0; i < m.length; i++) {
+ if(m[i].options.disabled || (t && !m[i].options.accept.call(m[i].element,(t.currentItem || t.element)))) continue;
+ m[i].visible = m[i].element.css("display") != "none"; if(!m[i].visible) continue; //If the element is not visible, continue
+ m[i].offset = m[i].element.offset();
+ m[i].proportions = { width: m[i].element[0].offsetWidth, height: m[i].element[0].offsetHeight };
+ if(type == "dragstart" || type == "sortactivate") m[i].activate.call(m[i], e); //Activate the droppable if used directly from draggables
+ drop: function(draggable, e) {
+ $.each($.ui.ddmanager.droppables, function() {
+ if(!this.options) return;
+ if (!this.options.disabled && this.visible && $.ui.intersect(draggable, this, this.options.tolerance))
+ dropped = this.drop.call(this, e);
+ if (!this.options.disabled && this.visible && this.options.accept.call(this.element,(draggable.currentItem || draggable.element))) {
+ this.isout = 1; this.isover = 0;
+ this.deactivate.call(this, e);
+ return dropped;
+ drag: function(draggable, e) {
+ //If you have a highly dynamic page, you might try this option. It renders positions every time you move the mouse.
+ if(draggable.options.refreshPositions) $.ui.ddmanager.prepareOffsets(draggable, e);
+ //Run through all droppables and check their positions based on specific tolerance options
+ if(this.options.disabled || this.greedyChild || !this.visible) return;
+ var intersects = $.ui.intersect(draggable, this, this.options.tolerance);
+ var c = !intersects && this.isover == 1 ? 'isout' : (intersects && this.isover == 0 ? 'isover' : null);
+ if(!c) return;
+ var parentInstance;
+ if (this.options.greedy) {
+ var parent = this.element.parents('.ui-droppable:eq(0)');
+ if (parent.length) {
+ parentInstance = $.data(parent[0], 'droppable');
+ parentInstance.greedyChild = (c == 'isover' ? 1 : 0);
+ // we just moved into a greedy child
+ if (parentInstance && c == 'isover') {
+ parentInstance['isover'] = 0;
+ parentInstance['isout'] = 1;
+ parentInstance.out.call(parentInstance, e);
+ this[c] = 1; this[c == 'isout' ? 'isover' : 'isout'] = 0;
+ this[c == "isover" ? "over" : "out"].call(this, e);
+ // we just moved out of a greedy child
+ if (parentInstance && c == 'isout') {
+ parentInstance['isout'] = 0;
+ parentInstance['isover'] = 1;
+ parentInstance.over.call(parentInstance, e);
+ * Droppable Extensions
+$.ui.plugin.add("droppable", "activeClass", {
+ activate: function(e, ui) {
+ $(this).addClass(ui.options.activeClass);
+ deactivate: function(e, ui) {
+ $(this).removeClass(ui.options.activeClass);
+ drop: function(e, ui) {
+$.ui.plugin.add("droppable", "hoverClass", {
+ over: function(e, ui) {
+ $(this).addClass(ui.options.hoverClass);
+ out: function(e, ui) {
+ $(this).removeClass(ui.options.hoverClass);
+})(jQuery);
Added: branches/print_dev/http/extensions/jquery.contextmenu.r2.js
--- branches/print_dev/http/extensions/jquery.contextmenu.r2.js (rev 0)
+++ branches/print_dev/http/extensions/jquery.contextmenu.r2.js 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,144 @@
+ * ContextMenu - jQuery plugin for right-click context menus
+ * Author: Chris Domigan
+ * Contributors: Dan G. Switzer, II
+ * Parts of this plugin are inspired by Joern Zaefferer's Tooltip plugin
+ * Dual licensed under the MIT and GPL licenses:
+ * http://www.opensource.org/licenses/mit-license.php
+ * http://www.gnu.org/licenses/gpl.html
+ * Version: r2
+ * Date: 16 July 2007
+ * For documentation visit http://www.trendskitchens.co.nz/jquery/contextmenu/
+(function($) {
+ var menu, shadow, trigger, content, hash, currentTarget;
+ var defaults = {
+ menuStyle: {
+ listStyle: 'none',
+ padding: '1px',
+ margin: '0px',
+ backgroundColor: '#fff',
+ border: '1px solid #999',
+ width: '100px'
+ itemStyle: {
+ margin: '0px',
+ color: '#000',
+ display: 'block',
+ cursor: 'default',
+ padding: '3px',
+ border: '1px solid #fff',
+ backgroundColor: 'transparent'
+ itemHoverStyle: {
+ border: '1px solid #0a246a',
+ backgroundColor: '#b6bdd2'
+ eventPosX: 'pageX',
+ eventPosY: 'pageY',
+ shadow : true,
+ onContextMenu: null,
+ onShowMenu: null
+ $.fn.contextMenu = function(id, options) {
+ if (!menu) { // Create singleton menu
+ menu = $('<div id="jqContextMenu"></div>')
+ .hide()
+ .css({position:'absolute', zIndex:'500'})
+ .appendTo('body')
+ .bind('click', function(e) {
+ e.stopPropagation();
+ if (!shadow) {
+ shadow = $('<div></div>')
+ .css({backgroundColor:'#000',position:'absolute',opacity:0.2,zIndex:499})
+ .appendTo('body')
+ .hide();
+ hash = hash || [];
+ hash.push({
+ id : id,
+ menuStyle: $.extend({}, defaults.menuStyle, options.menuStyle || {}),
+ itemStyle: $.extend({}, defaults.itemStyle, options.itemStyle || {}),
+ itemHoverStyle: $.extend({}, defaults.itemHoverStyle, options.itemHoverStyle || {}),
+ bindings: options.bindings || {},
+ shadow: options.shadow || options.shadow === false ? options.shadow : defaults.shadow,
+ onContextMenu: options.onContextMenu || defaults.onContextMenu,
+ onShowMenu: options.onShowMenu || defaults.onShowMenu,
+ eventPosX: options.eventPosX || defaults.eventPosX,
+ eventPosY: options.eventPosY || defaults.eventPosY
+ var index = hash.length - 1;
+ $(this).bind('contextmenu', function(e) {
+ // Check if onContextMenu() defined
+ var bShowContext = (!!hash[index].onContextMenu) ? hash[index].onContextMenu(e) : true;
+ if (bShowContext) display(index, this, e, options);
+ return false;
+ return this;
+ function display(index, trigger, e, options) {
+ var cur = hash[index];
+ content = $('#'+cur.id).find('ul:first').clone(true);
+ content.css(cur.menuStyle).find('li').css(cur.itemStyle).hover(
+ function() {
+ $(this).css(cur.itemHoverStyle);
+ function(){
+ $(this).css(cur.itemStyle);
+ ).find('img').css({verticalAlign:'middle',paddingRight:'2px'});
+ // Send the content to the menu
+ menu.html(content);
+ // if there's an onShowMenu, run it now -- must run after content has been added
+ // if you try to alter the content variable before the menu.html(), IE6 has issues
+ // updating the content
+ if (!!cur.onShowMenu) menu = cur.onShowMenu(e, menu);
+ $.each(cur.bindings, function(id, func) {
+ $('#'+id, menu).bind('click', function(e) {
+ hide();
+ func(trigger, currentTarget);
+ menu.css({'left':e[cur.eventPosX],'top':e[cur.eventPosY]}).show();
+ if (cur.shadow) shadow.css({width:menu.width(),height:menu.height(),left:e.pageX+2,top:e.pageY+2}).show();
+ $(document).one('click', hide);
+ function hide() {
+ menu.hide();
+ shadow.hide();
+ // Apply defaults
+ $.contextMenu = {
+ defaults : function(userDefaults) {
+ $.each(userDefaults, function(i, val) {
+ if (typeof val == 'object' && defaults[i]) {
+ $.extend(defaults[i], val);
+ else defaults[i] = val;
+})(jQuery);
+$(function() {
+ $('div.contextMenu').hide();
\ No newline at end of file
Added: branches/print_dev/http/img/OSGeo_logo.png
(Binary files differ)
Property changes on: branches/print_dev/http/img/OSGeo_logo.png
___________________________________________________________________
+ application/octet-stream
Added: branches/print_dev/http/img/button_digitize/geomClone.png
Property changes on: branches/print_dev/http/img/button_digitize/geomClone.png
Added: branches/print_dev/http/javascripts/mod_addWmsFromFilteredList_button.php
--- branches/print_dev/http/javascripts/mod_addWmsFromFilteredList_button.php (rev 0)
+++ branches/print_dev/http/javascripts/mod_addWmsFromFilteredList_button.php 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,80 @@
+<?php
+# $Id: mod_addWmsFromFilteredList_button.php 3873 2009-04-14 10:36:20Z astrid_emde $
+# http://www.mapbender.org/Add_WMS_from_filtered_list_%28AJAX%29
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+echo "var addWmsFromFilteredListId = '" . $e_id . "';";
+var addWmsFromFilteredList_title;
+var addWmsFromFilteredListPopup;
+eventInit.register(function () {
+ var $addWmsFromFilteredListButton = $("#" + addWmsFromFilteredListId);
+ addWmsFromFilteredList_title = $addWmsFromFilteredListButton.get(0).title;
+ $addWmsFromFilteredListButton.click(function () {
+ addWmsFromFilteredList_showPopup();
+var addWmsFromFilteredList_showPopup = function () {
+ addWmsFromFilteredListPopup = new mb_popup({
+ title:addWmsFromFilteredList_title,
+ url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?<?php
+ echo session_name() . '=' . session_id() . '&';
+ echo "guiID=" . $gui_id . '&';
+ echo "elementID=" . $e_id;
+ width:720,
+ height:600,
+ left:300,
+ top:100
+ addWmsFromFilteredListPopup.show()
+eventLocalize.register(function () {
+ addWmsFromFilteredListPopup.destroy();
+ mod_addWmsFromFilteredList_init();
+var mod_addWmsFromFilteredList_img = new Image();
+mod_addWmsFromFilteredList_img.src = "<?php echo $e_src; ?>";
+var mod_addWmsFromFilteredList_img_over = new Image();
+mod_addWmsFromFilteredList_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
+function mod_addWmsFromFilteredList_init() {
+ var obj = document.getElementById(addWmsFromFilteredListId);
+ obj.src = mod_addWmsFromFilteredList_img.src;
+ obj.onmouseover = new Function("mod_addWmsFromFilteredList_over()");
+ obj.onmouseout = new Function("mod_addWmsFromFilteredList_out()");
+function mod_addWmsFromFilteredList_over(){
+ document.getElementById(addWmsFromFilteredListId).src = mod_addWmsFromFilteredList_img_over.src;
+function mod_addWmsFromFilteredList_out(){
+ document.getElementById(addWmsFromFilteredListId).src = mod_addWmsFromFilteredList_img.src;
Added: branches/print_dev/http/php/mod_customTree.php
--- branches/print_dev/http/php/mod_customTree.php (rev 0)
+++ branches/print_dev/http/php/mod_customTree.php 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,318 @@
+<?php
+require_once(dirname(__FILE__) . "/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>" />
+ <title>Untitled Document</title>
+ <style type="text/css">
+ .ui-selecting {
+ color:red;
+ .treeNode {
+ color:green;
+ .treeLeaf {
+ color:blue;
+ .ui-selected {
+ border-width:thin;
+ border-style:solid;
+ border-color:red;
+ background-color:transparent;
+ font-size:9px;
+ .ui-draggable {
+ .div-border {
+ border-color:black;
+ font-size:9px;
+ .contextMenu
+ display:none;
+ </style>
+ <link rel='stylesheet' type='text/css' href='../css/popup.css'>
+ <script type='text/javascript'>
+<?php
+ require_once(dirname(__FILE__) . "/../extensions/jquery-1.2.6.min.js");
+ require_once(dirname(__FILE__) . "/../extensions/jquery-ui-personalized-1.5.2.js");
+ require_once(dirname(__FILE__) . "/../extensions/jquery.contextmenu.r2.js");
+ require_once(dirname(__FILE__) . "/../extensions/jqjson.js");
+ require_once(dirname(__FILE__) . "/../javascripts/popup.js");
+ require_once(dirname(__FILE__) . "/../../lib/event.js");
+ require_once(dirname(__FILE__) . "/../../lib/customTreeModel.js");
+ require_once(dirname(__FILE__) . "/../../lib/customTreeController.js");
+ require_once(dirname(__FILE__) . "/../../lib/buttonNew.js");
+ var myTree = new CustomTree();
+ var applicationId;
+ var findAllWmsInTree = function (aTree) {
+ return findAllWmsInNode(aTree.root).sort();
+ findAllWmsInNode = function (aNode) {
+ if (!aNode.isFolder) {
+ return [aNode.wmsId];
+ var wmsIdArray = [];
+ for (var i = 0; i < aNode.childNodeList.count(); i++) {
+ var child = aNode.childNodeList.get(i);
+ var newArray = findAllWmsInNode(child);
+ wmsIdArray = wmsIdArray.concat(newArray);
+ return wmsIdArray;
+ var saveTreeOnUnloadOrChange = function (myTree) {
+ if (myTree.hasChanged) {
+ var saveChanges = confirm("You have changed the tree. All changes will be lost. Save changes?");
+ if (saveChanges) {
+ Save.updateDatabase(function () {
+ var addMissingWmsToCustomTree = function (aTree, anApplicationId) {
+ // get available WMS ...
+ var queryObj = {
+ command:"getWmsByApplication",
+ parameters: {
+ "applicationId": anApplicationId
+ $.post("../php/mod_customTree_server.php", {
+ queryObj:$.toJSON(queryObj)
+ }, function (json, status) {
+ var replyObj = eval('(' + json + ')');
+ var root = aTree.root;
+ var wmsIdArray = findAllWmsInTree(aTree);
+ for (var index in replyObj.data.wmsArray) {
+ var found = false;
+ for (var j = 0; j < wmsIdArray.length; j++) {
+ if (wmsIdArray[j] == index) {
+ found = true;
+ break;
+ if (!found) {
+ var wmsNode = new CustomTreeNode();
+ wmsNode.name = replyObj.data.wmsArray[index];
+ wmsNode.wmsId = index;
+ myTree.root.append(wmsNode);
+ myTree.hasChanged = false;
+ displayMyTree = new customTreeController(myTree, {
+ contextMenu: true,
+ droppable: true,
+ id: "myTree"
+ var getCustomTreeByApplication = function (applicationName) {
+ // load a previously saved
+ // customized tree from the database
+ var queryObj = {
+ command:"getCustomTreeByApplication",
+ parameters: {
+ "applicationId":applicationName
+ myTree = new CustomTree();
+ var root = myTree.root;
+ root.name = "(" + applicationId + ")";
+ var nodeArray = replyObj.data.nodeArray;
+ myTree.importNestedSets(nodeArray);
+ addMissingWmsToCustomTree(myTree, applicationId);
+ droppable: true,
+ id: "myTree"
+ var selectApplication = function (applicationName) {
+ applicationId = applicationName;
+ getCustomTreeByApplication(applicationId);
+ var getApplications = function () {
+ var queryObj = {
+ command:"getApplications"
+ $select = $("#applicationSelect");
+ $select.change(function () {
+ saveTreeOnUnloadOrChange(myTree);
+ selectApplication(this.options[this.selectedIndex].value);
+ for (var index in replyObj.data.applicationArray) {
+ var currentApplication = replyObj.data.applicationArray[index];
+ $currentOption = $("<option id='application" + index + "' value='" + currentApplication + "'>" + currentApplication + "</option>");
+ $select.append($currentOption);
+ var Save = {
+ buttonParameters : {
+ on:"../img/button_blink_red/wmc_save_on.png",
+ over:"../img/button_blink_red/wmc_save_over.png",
+ off:"../img/button_blink_red/wmc_save_off.png",
+ type:"toggle"
+ updateDatabase : function (callback) {
+ if (!applicationId || applicationId == "...") {
+ callback();
+ return;
+ var data = {
+ "applicationId": applicationId,
+ "folderArray": myTree.exportNestedSets()
+ var queryObj = {
+ command:"update",
+ parameters:{
+ data: data
+ $.post("mod_customTree_server.php", {
+ alert(replyObj.success);
+ callback();
+ var Restart = {
+ on:"../img/button_blink_red/exit_on.png",
+ over:"../img/button_blink_red/exit_over.png",
+ off:"../img/button_blink_red/exit_off.png",
+ type:"singular"
+ removeAllFolders: function(){
+ return;
+ var confirmDelete = confirm("You are about to delete your customized folder structure. Proceed?");
+ if (confirmDelete) {
+ var queryObj = {
+ "command": "delete",
+ "parameters": {
+ queryObj: $.toJSON(queryObj)
+ }, function(json, status){
+ $(function () {
+ getApplications();
+ var toolbox = new ButtonGroup("controls");
+ // save tool
+ var saveButton = new Button(Save.buttonParameters);
+ toolbox.add(saveButton);
+ saveButton.registerPush(function () {
+ Save.updateDatabase(saveButton.triggerStop);
+ // restart tool
+ var restartButton = new Button(Restart.buttonParameters);
+ toolbox.add(restartButton);
+ restartButton.registerPush(function () {
+ Restart.removeAllFolders();
+ // dialogue: save changes on unload
+ $(window).unload(function () {
+ </script>
+ </head>
+ <body>
+ <select id='applicationSelect'>
+ <option>...</option>
+ </select>
+ <div id="controls"></div>
+ <hr>
+ <div class="contextMenu" id="folderMenu">
+ <ul>
+ <li id="addFolder"><img src="images/folder_add.png" /> Add </li>
+ <li id="deleteFolder"><img src="images/folder_delete.png" /> Delete</li>
+ <li id="editFolder"><img src="images/folder_edit.png" /> Edit</li>
+ </ul>
+ </div>
+ <div class="contextMenu" id="rootMenu">
+ <ul>
+ </ul>
+ </div>
+ <div id='myTree'></div>
+ <div id='wmsTree'></div>
+ </body>
+</html>
Added: branches/print_dev/http/php/mod_customTree_server.php
--- branches/print_dev/http/php/mod_customTree_server.php (rev 0)
+++ branches/print_dev/http/php/mod_customTree_server.php 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,186 @@
+<?php
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+ * encodes and delivers the data
+ * @param object the un-encoded object
+function sendOutput($out){
+ global $json;
+ $output = $json->encode($out);
+ header("Content-Type: text/x-json");
+ echo $output;
+$json = new Mapbender_JSON();
+$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
+$resultObj = array();
+$data = array();
+$e = new mb_exception("command: " . $queryObj->command);
+$userId = $_SESSION[mb_user_id];
+$user = new User($userId);
+switch($queryObj->command){
+ case 'delete':
+ $applicationId = $queryObj->parameters->applicationId;
+ // get all of the users applications
+ $allowedApplicationArray = $user->getApplicationsByPermission(0);
+ if (in_array($applicationId, $allowedApplicationArray)) {
+ $sql = "DELETE FROM gui_treegde WHERE fkey_gui_id = $1";
+ $v = array($applicationId);
+ $t = array("s");
+ $res = db_prep_query($sql, $v, $t);
+ $resultObj["success"] = "Deletion successful. " . $sql . " (" . $applicationId . ")";
+ else {
+ $resultObj["error"] = "Access denied to application " . $applicationId . ".";
+ break;
+ case 'getApplications':
+ // get all of the users applications that contain treeGDE
+ $sql = "SELECT fkey_gui_id FROM gui_element WHERE " .
+ "e_id = 'treeGDE' AND fkey_gui_id IN (";
+ $v = array();
+ $t = array();
+ foreach ($allowedApplicationArray as $i => $application) {
+ array_push($v, $application);
+ array_push($t, "s");
+ if ($i > 0) {
+ $sql .= ",";
+ $sql .= "$" . ($i+1);
+ $sql .= ")";
+ $applicationArray = array();
+ while ($row = db_fetch_array($res)) {
+ array_push($applicationArray, $row[0]);
+ $data = array("applicationArray" => $applicationArray);
+ $resultObj["data"] = $data;
+ break;
+ case 'getWmsByApplication':
+ $sql = "SELECT b.wms_id AS id, b.wms_title AS title " .
+ "FROM gui_wms AS a, wms AS b " .
+ "WHERE a.fkey_wms_id = b.wms_id AND a.fkey_gui_id = $1";
+ $t = array("s");
+ $res = db_prep_query($sql,$v,$t);
+ $wmsArray = array();
+ $wmsArray[$row["id"]] = $row["title"];
+ $data = array("wmsArray" => $wmsArray);
+ else {
+ $resultObj["data"] = array("wmsArray" => array());
+ break;
+ case 'getCustomTreeByApplication':
+ $sql = "SELECT lft, rgt, my_layer_title, wms_id " .
+ "FROM gui_treegde " .
+ "WHERE fkey_gui_id = $1 ORDER BY lft";
+ $t = array("s");
+ $nodeArray = array();
+ $wmsIdArray = explode(",", $row["wms_id"]);
+ foreach ($wmsIdArray as $wmsId) {
+ if (is_numeric($wmsId)) {
+ $sqlWms = "SELECT wms_title FROM wms WHERE wms_id = $1";
+ $vWms = array($wmsId);
+ $tWms = array("i");
+ $resWms = db_prep_query($sqlWms, $vWms, $tWms);
+ $rowWms = db_fetch_array($resWms);
+ $wmsArray[$wmsId] = $rowWms[0];
+ $currentNode = array(
+ "left" => $row["lft"],
+ "right" => $row["rgt"],
+ "name" => $row["my_layer_title"],
+ "wms" => $wmsArray
+ array_push($nodeArray, $currentNode);
+ $data = array("nodeArray" => $nodeArray);
+ else {
+ $resultObj["data"] = array("nodeArray" => array());
+ break;
+ case 'update':
+ $elementArray = $queryObj->parameters->data->folderArray;
+ $applicationId = $queryObj->parameters->data->applicationId;
+ $t = array("s");
+ for ($i = 0; $i < count($elementArray); $i++) {
+ $currentElement = $elementArray[$i];
+ $sql = "INSERT INTO gui_treegde (fkey_gui_id, lft, rgt, " .
+ "my_layer_title, wms_id) VALUES ($1, $2, $3, $4, $5)";
+ $v = array(
+ $applicationId,
+ $currentElement->left,
+ $currentElement->right,
+ $currentElement->name,
+ $currentElement->wms
+ $t = array("s", "i", "i", "s", "s");
+ $data = array("sql" => $sql, "data" => $v);
+ $resultObj["success"] = "Elements have been updated in the database.";
+ break;
+ // Invalid command
+ default:
+ $resultObj["error"] = "no action specified...";
+sendOutput($resultObj);
Added: branches/print_dev/lib/customTreeController.js
--- branches/print_dev/lib/customTreeController.js (rev 0)
+++ branches/print_dev/lib/customTreeController.js 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,279 @@
+var customTreeController = function (myTree, options) {
+// this.myTree = new CustomTree();
+// this.myTree.root.name = "My tree";
+ var currentlyDraggedNode;
+ this.options = options;
+ this.myTree = myTree;
+ this.$root = $("<ul></ul>");
+ var that = this;
+ // --------------- BEHAVIOUR (begin) ------------------
+ var addLeafBehaviour = function ($domNode, treeNode) {
+ $label = $domNode.children().eq(0);
+ // enable context menu
+ if (that.options.contextMenu) {
+ addContextMenuToLeaf($domNode, treeNode);
+ // make leaves draggable
+ makeNodeDraggable($domNode, treeNode);
+ treeNode.hasChanged = function () {
+ that.myTree.hasChanged = true;
+ var addFolderBehaviour = function ($domNode, treeNode) {
+ if (treeNode != that.myTree.root) {
+ // enable folder closing and opening
+ addOpenCloseBehaviour($label);
+ addContextMenuToFolder($domNode, treeNode);
+ // make inner nodes draggable
+ else {
+ addContextMenuToRoot($domNode, treeNode);
+ // make all folders droppable
+ if (that.options.droppable) {
+ makeNodeDroppable($label, treeNode);
+ var deleteNode = function (treeNode) {
+ if (treeNode.containsNonFolder()) {
+ alert("This folder contains a WMS. It may not be deleted. Move the WMS before deleting the folder.");
+ else {
+ treeNode.remove();
+ var editNode = function ($domNode, treeNode) {
+ var newName = prompt('Name:', treeNode.name);
+ if (newName) {
+ treeNode.setName(newName);
+ var addNode = function ($domNode, treeNode) {
+ var newName = prompt('Name:');
+ if (newName) {
+ var newChild = treeNode.addChild();
+ newChild.setName(newName);
+ // CONTEXT MENU
+ var addContextMenuToLeaf = function ($domNode, treeNode) {
+ $domNode.contextMenu('leafMenu', {
+ onContextMenu: function(e) {
+ return true;
+ onShowMenu: function(e, menu) {
+ return menu;
+ bindings: {
+ 'deleteService': function () {
+ deleteNode(treeNode);
+ var addContextMenuToFolder = function ($domNode, treeNode) {
+ $domNode.contextMenu('folderMenu', {
+ onContextMenu: function(e){
+ return true;
+ onShowMenu: function(e, menu){
+ return menu;
+ bindings: {
+ 'addFolder': function(item){
+ addNode($domNode, treeNode);
+ 'deleteFolder': function(){
+ 'editFolder': function(){
+ editNode($domNode, treeNode);
+ var addContextMenuToRoot = function ($domNode, treeNode) {
+ $domNode.contextMenu('rootMenu', {
+ return true;
+ return menu;
+ bindings: {
+ // OPEN AND CLOSE BEHAVIOUR
+ var addOpenCloseBehaviour = function ($domNode) {
+ $domNode.toggle(function () {
+ $(this).siblings().hide("fast");
+ }, function () {
+ $(this).siblings().show("fast");
+ // DRAGGABLE AND DROPPABLE
+ var makeNodeDraggable = function ($domNode, treeNode) {
+ $domNode.draggable({
+ "helper": "clone",
+ "start": function(){
+ $(this).addClass("currently-dragging");
+ currentlyDraggedNode = treeNode;
+ var makeNodeDroppable = function ($domNode, treeNode) {
+ $domNode.droppable({
+ "accept": function ($draggable) {
+ var $invalidDroppables = $(".currently-dragging .treeNodeDrop");
+ var $invalidDroppablesMinusThis = $invalidDroppables.not($domNode);
+ if ($invalidDroppables.size() > $invalidDroppablesMinusThis.size()) {
+ return false;
+ return true;
+ "tolerance": "pointer",
+ "drop": function (e, ui) {
+ $toDomNode = $(this);
+ $fromDomNode = $(ui.draggable);
+ currentlyDraggedNode.afterMove = function () {
+ $toDomNode.next().append($(ui.draggable));
+ $(".treeLeaf").removeAttr("style");
+ $("*").removeClass("currently-dragging");
+ currentlyDraggedNode.move(treeNode);
+ // --------------- BEHAVIOUR (end) ------------------
+ var createLeaf = function (treeNode) {
+ var $currentItem = $("<li class='treeLeaf'></li>");
+ var $currentLabel = $("<span>" + treeNode.name + "</span>");
+ $currentItem.append($currentLabel);
+ addLeafBehaviour($currentItem, treeNode);
+ treeNode.$domNode = $currentItem;
+ treeNode.isFolder = false;
+ treeNode.afterRemove = function () {
+ $currentItem.remove();
+ return $currentItem;
+ var createFolder = function (treeNode) {
+ var $currentItem = $("<li class='treeNode'></li>");
+ var $currentLabel = $("<div class='treeNodeDrop'><span>" + treeNode.name + "</span></div>");
+ var $currentFolder = $("<ul></ul>");
+ $currentItem.append($currentFolder);
+ treeNode.isFolder = true;
+ addFolderBehaviour($currentItem, treeNode);
+ treeNode.afterSetName = function () {
+ $currentLabel.children().eq(0).html(treeNode.name);
+ treeNode.afterAddChild = function (newChild) {
+ $newNode = createFolder(newChild);
+ var $folder = $currentItem.children().eq(1);
+ $folder.append($newNode);
+ treeNode.afterAppend = function (newChild) {
+ * A recursive function to draw the nodes of a tree and attach
+ * draggables and droppables
+ * @param {Object} $domNode
+ * @param {Object} treeNode
+ var drawNode = function ($domNode, treeNode) {
+ var numOfChildren = treeNode.childNodeList.count();
+ var $newNode;
+ if (numOfChildren === 0 && treeNode != that.myTree.root && !treeNode.isFolder) {
+ $newNode = createLeaf(treeNode);
+ else {
+ $newNode = createFolder(treeNode);
+ // visit the child nodes (depth first)
+ var $folder = $newNode.children().eq(1);
+ for (var i = 0; i < numOfChildren; i++) {
+ drawNode.apply(that, [$folder, treeNode.childNodeList.get(i)]);
+ // attach node to tree
+ $domNode.append($newNode);
+ $("#" + this.options.id).empty();
+ $("#" + this.options.id).append(that.$root);
+ drawNode(that.$root, that.myTree.root);
Added: branches/print_dev/lib/customTreeModel.js
--- branches/print_dev/lib/customTreeModel.js (rev 0)
+++ branches/print_dev/lib/customTreeModel.js 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,407 @@
+ * @class A List object is an array of arbitrary objects with additional methods.
+ * @constructor
+var List = function() {
+ * gets the number of elements in this {@link List}
+ * @returns number of elements in this {@link List}
+ * @type Integer
+ this.count = function() {
+ return this.list.length;
+ * deletes the object at index i; -1 refers to the last object in this {@link List}
+ * @param {Integer} i index
+ this.del = function(i){
+ i = this.getIndex(i);
+ if (i !== false) {
+ for(var z = i; z < this.count() - 1; z++){
+ this.list[z] = this.list[z+1];
+ this.list.length -= 1;
+ return true;
+ return false;
+ * empties this {@link List}
+ this.empty = function() {
+ while (this.list !== null && this.count() > 0) {
+ this.list.pop();
+ * @returns the object at index i; -1 refers to the last object in this {@link List}
+ * @type Integer or false
+ this.get = function(i) {
+ if (i !== false) {return this.list[i];}
+ return false;
+ * adds a reference to item to this {@link List}.
+ * @param {Object} item an object
+ this.add = function(item) {
+ var i = this.list.length;
+ this.list[i] = item;
+ * adds a copy of item to this {@link List}.
+ this.addCopy = function(item) {
+ this.add(cloneObject(item));
+ * attaches the {@link List} aList to this {@link List}
+ * @param {List} aList another list
+ this.union = function(aList) {
+ for (var i=0; i < aList.count(); i++) {this.addCopy(aList.get(i));}
+ * checks if the index is valid and returns it if it is; if i == -1, the correct index is retrieved.
+ * @private
+ * @return Integer or false
+ * @type Integer
+ this.getIndex = function(i){
+ var len = this.list.length;
+ if (i<0 && len + i > -1) {
+ return len + i;
+ else if (i > -1 && i < len){
+ return i;
+ var e = new Mb_exception("class List: function getIndex: member index " + i + " is not valid");
+ return false;
+ * @returns a {String} representation of this List
+ * @type String
+ this.toString = function(){
+ var str = "";
+ for (var i =0 ; i < this.count() ; i++){
+ str += this.get(i).toString();
+ return str;
+ this.list = null;
+ * A tree
+ * Using adjacency model
+ * w/ nested sets output
+var CustomTree = function () {
+ this.root = new CustomTreeNode (null);
+ var that = this;
+ this.hasChanged = false;
+ this.toNestedSets = function () {
+ var nodeArray = toNestedSetsNode.apply(this, [[], this.root, 1]);
+ return nodeArray;
+ var toNestedSetsNode = function (nodeArray, node, nextLeft) {
+ var left = nextLeft;
+ var right;
+ var newLeft = nextLeft + 1;
+ var nodeCount = node.childNodeList.count();
+ var containsFolder = false;
+ for (var i = 0; i < nodeCount; i++) {
+ var currentChild = node.childNodeList.get(i);
+ // ... recursion
+ if (currentChild.isFolder) {
+ nodeArray = toNestedSetsNode.apply(that, [nodeArray, currentChild, newLeft]);
+ newLeft = nodeArray[-1 + nodeArray.length].right + 1;
+ containsFolder = true;
+ else {
+ wmsIdArray.push(currentChild.wmsId);
+ // node has NOT at least one child which is a folder
+ if (containsFolder) {
+ right = newLeft;
+ else {
+ right = left + 1;
+ nodeArray.push({
+ "left": left,
+ "right": right,
+ "name": node.name,
+ "isFolder": node.isFolder,
+ "wms": wmsIdArray.join(",")
+ return nodeArray;
+ * Returns this tree as nested sets
+ this.toString = function () {
+ return $.toJSON(this.exportNestedSets());
+ this.exportNestedSets = function () {
+ // initialising recursion
+ return nodeArray = toNestedSetsNode.apply(this, [[], this.root, 1]);
+ * Create this tree from nested sets
+ this.fromString = function(str){
+ var nodeArray = eval(str);
+ this.importNestedSets(nodeArray);
+ this.importNestedSets = function (nodeArray) {
+ if(nodeArray===undefined || nodeArray.length<1)
+ return false;
+ //numeric sort function
+ var nodeSort = function(a,b){
+ return a.left-b.left;
+ //sort nodes by their left
+ nodeArray.sort(nodeSort);
+ //apply root node
+ var currentNode = this.root;
+ currentNode.applyKeys(nodeArray[0]);
+ var rights = [nodeArray[0].right];
+ for (var i = 1; i < nodeArray.length; i++) {
+ //finish all nodes that have no further childs
+ while (rights[rights.length-1] < nodeArray[i].left){
+ rights.pop();
+ currentNode = currentNode.parentNode;
+ //check if there is an error in data or we have muliple roots
+ if(currentNode == null)
+ return false;
+ //insert new node
+ var newNode = new CustomTreeNode(currentNode);
+ newNode.isFolder = true;
+ rights.push(nodeArray[i].right);
+ newNode.applyKeys(nodeArray[i]);
+ currentNode.append(newNode);
+ // add WMS
+ var wmsIdArray = nodeArray[i].wms;
+ for (var j in wmsIdArray) {
+ var newWmsNode = new CustomTreeNode(newNode);
+ newWmsNode.wmsId = j;
+ newWmsNode.name = wmsIdArray[j];
+ newNode.append(newWmsNode);
+ //new node is the one that take next childs
+ currentNode = newNode;
+ return true;
+ var toStringNode = function (nodeArray, node, nextLeft) {
+ var right;
+ // node has children...
+ if (nodeCount > 0) {
+ // ... recursion
+ nodeArray = toStringNode.apply(that, [nodeArray, currentChild, newLeft]);
+ right = newLeft;
+ // node is a leaf...
+ else {
+ right = left + 1;
+ nodeArray.push({
+ "left": left,
+ "right": right,
+ "id": node.id
+ return nodeArray;
+ this.empty = function () {
+ for (var i = -1 + this.root.childNodeList.count(); i >= 0; i--) {
+ var currentChild = this.root.childNodeList.get(i);
+ currentChild.remove();
+ * A list of nodes
+var CustomTreeChildList = function () {
+ this.list = [];
+CustomTreeChildList.prototype = new List();
+ * A single node
+ * @param {Object} parentNode
+var CustomTreeNode = function (parentNode) {
+ this.name;
+ this.isFolder = false;
+ this.parentNode = parentNode;
+ this.childNodeList = new CustomTreeChildList();
+ this.applyKeys = function(obj){
+ this.name = obj.name;
+ this.afterMove = function () {
+ this.afterRemove = function () {
+ this.afterAddChild = function () {
+ this.afterSetName = function () {
+ this.setName = function (newName) {
+ this.name = newName;
+ this.afterSetName();
+ this.hasChanged();
+ this.hasChanged = function () {
+ this.addChild = function () {
+ this.childNodeList.add(new CustomTreeNode(this));
+ var newChild = this.childNodeList.get(-1);
+ newChild.name = "(new node)";
+ newChild.isFolder = true;
+ this.afterAddChild(newChild);
+ return newChild;
+ this.getNumberOfChildren = function () {
+ var cnt = this.childNodeList.count();
+ var numOfChildren = cnt;
+ if (cnt > 0) {
+ for (var i = 0; i < cnt; i++) {
+ numOfChildren += this.childNodeList.get(i).getNumberOfChildren();
+ return numOfChildren;
+ this.remove = function () {
+ this.childNodeArray = [];
+ this.parentNode.removeChild(this);
+ this.parentNode = null;
+ this.afterRemove();
+ this.removeChild = function (someNode) {
+ for (var i = 0; i < this.childNodeList.count(); i++) {
+ var child = this.childNodeList.get(i);
+ if (child == someNode) {
+ this.childNodeList.del(i);
+ break;
+ this.move = function (toParent) {
+ toParent.append(this);
+ this.afterMove();
+ this.append = function (someNode) {
+ someNode.parentNode = this;
+ this.childNodeList.add(someNode);
+ this.isFolder = true;
+// this.afterAppend(someNode);
+ this.containsFolder = function () {
+ if (child.isFolder) {
+ return true;
+ return false;
+ this.containsNonFolder = function () {
+ var foundNonFolder = false;
+ if (!child.isFolder) {
+ return true;
+ else {
+ foundNonFolder = foundNonFolder || child.containsNonFolder();
+ return foundNonFolder;
Added: branches/print_dev/resources/db/update/update_2.7.sql
--- branches/print_dev/resources/db/update/update_2.7.sql (rev 0)
+++ branches/print_dev/resources/db/update/update_2.7.sql 2009-05-22 12:10:55 UTC (rev 3957)
@@ -0,0 +1,63 @@
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
+UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
+-- new definition of addWMSfromfilteredList_ajax due to i18n
+UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
+-- polish entries for translations table
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
More information about the Mapbender_commits
