[Mapbender-commits] r4747 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org
Sun Sep 27 04:04:43 EDT 2009
Author: kmq
Date: 2009-09-27 04:04:42 -0400 (Sun, 27 Sep 2009)
New Revision: 4747
Added:
trunk/mapbender/http/extensions/jquery.tableeditor.js
added jquery tableeditor
Added: trunk/mapbender/http/extensions/jquery.tableeditor.js
--- trunk/mapbender/http/extensions/jquery.tableeditor.js (rev 0)
+++ trunk/mapbender/http/extensions/jquery.tableeditor.js 2009-09-27 08:04:42 UTC (rev 4747)
@@ -0,0 +1,66 @@
+var TableEditor = {
+_init : function() {
+ var me = this;
+ this.table = $('<table class="listeditor"></table>');
+ this.select = $('<select class="listeditor"></select>');
+ var addButton = $("<a>Add</a>").click(function(event){
+ me.addEntry($(this).prev().val());
+ event.preventDefault()
+ this.element.after(addButton).after(this.select).after(this.table);
+ this.element = this.table;
+ this._populateSelect(this.options.url,this.select);
+addEntry: function(text){
+ var rows = $("tr",this.element);
+ for(var i = 0;i<rows.length;i++)
+ if($("td:first",rows[i]).text() == $(this.select).val())
+ // list already contains this entry
+ return;
+ this.element.append("<tr><td>"+ text +"</td></tr>");
+val : function(){
+ var entries = [];
+ $("tr",this.element).each(function(){ alert("oh hia"); });
+ return entries;
+_populateSelect : function(url,select) {
+ var me = this;
+ options = { url: url,
+ method: 'list',
+ callback: (function (result,success, message){
+ for( entry in result.list)
+ var selectOption = $('<option value="'+ result.list[entry].name +'">'+ result.list[entry].name +'</option>');
+ select.append(selectOption);
+ var req = Mapbender.Ajax.Request(options);
+ req.send();
+$.widget("ui.tableedit",TableEditor);
+$.ui.tableedit.getter = "val";
+//$.extend($.ui.tableedit);
More information about the Mapbender_commits
