[Mapbender-commits] r6677 - in trunk/mapbender/http/img: . button_digitize_blue_red
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 2 16:58:23 EDT 2010
Author: marc
Date: 2010-08-02 20:58:22 +0000 (Mon, 02 Aug 2010)
New Revision: 6677
Added:
   trunk/mapbender/http/img/button_digitize_blue_red/
   trunk/mapbender/http/img/button_digitize_blue_red/del_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/del_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/del_original.xcf
   trunk/mapbender/http/img/button_digitize_blue_red/del_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/delete_node_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/delete_node_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/delete_node_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/geomClone.png
   trunk/mapbender/http/img/button_digitize_blue_red/geomInfo.png
   trunk/mapbender/http/img/button_digitize_blue_red/geomRemove.png
   trunk/mapbender/http/img/button_digitize_blue_red/geomRemoveDb.png
   trunk/mapbender/http/img/button_digitize_blue_red/line.png
   trunk/mapbender/http/img/button_digitize_blue_red/line_continue_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/line_continue_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/line_continue_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/line_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/line_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/line_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/move_node_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/move_node_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/move_node_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/new_node_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/new_node_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/new_node_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/point.png
   trunk/mapbender/http/img/button_digitize_blue_red/point_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/point_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/point_on.xcf
   trunk/mapbender/http/img/button_digitize_blue_red/point_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/polygon.png
   trunk/mapbender/http/img/button_digitize_blue_red/polygon_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/polygon_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/polygon_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/rectangle_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/rectangle_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/rectangle_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_off.png
   trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_on.png
   trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_over.png
   trunk/mapbender/http/img/button_digitize_blue_red/trans.png
new digitize buttons (V1)
Added: trunk/mapbender/http/img/button_digitize_blue_red/del_off.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/del_off.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/img/button_digitize_blue_red/del_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/del_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/del_original.xcf
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/del_original.xcf
Added: trunk/mapbender/http/img/button_digitize_blue_red/del_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/del_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/delete_node_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/delete_node_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/delete_node_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/delete_node_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/delete_node_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/delete_node_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/geomClone.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/geomClone.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/geomInfo.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/geomInfo.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/geomRemove.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/geomRemove.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/geomRemoveDb.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/geomRemoveDb.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line_continue_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line_continue_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line_continue_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line_continue_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line_continue_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line_continue_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/line_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/line_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/mergeLines_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/mergePolygons_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/move_node_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/move_node_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/move_node_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/move_node_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/move_node_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/move_node_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/new_node_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/new_node_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/new_node_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/new_node_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/new_node_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/new_node_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/point.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/point.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/point_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/point_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/point_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/point_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/point_on.xcf
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/point_on.xcf
Added: trunk/mapbender/http/img/button_digitize_blue_red/point_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/point_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/polygon.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/polygon.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/polygon_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/polygon_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/polygon_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/polygon_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/polygon_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/polygon_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/punchPolygon_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/rectangle_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/rectangle_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/rectangle_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/rectangle_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/rectangle_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/rectangle_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_off.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_off.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_on.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_on.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_over.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/splitPolygon_over.png
Added: trunk/mapbender/http/img/button_digitize_blue_red/trans.png
Property changes on: trunk/mapbender/http/img/button_digitize_blue_red/trans.png
More information about the Mapbender_commits mailing list
